Results 1 to 6 of 6
Thread: VW Passat ABS coding
    Jun 2016
    Guyana
    Hello good day guys, coding for the abs module, i changed abs module, and saved the old abs coding information, but when inputted code in replacement module it is rejected, kindly help
    before abs module changed (old abs module)
     Tuesday,17,July,2018,09:17:23:17560
    VCDS Version: 18.2.1.2
    VIN: WVWZZZ3CZCP043448   License Plate: GEORGETECHPASSAT
    Mileage: 35540km-22083mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4C 4F 52 53 55 56 61
              62 72
    VIN: WVWZZZ3CZCP043448   Mileage: 35540km-22083miles
    4C-Tire Pressure II -- Status: Sporadic communication error 1000
    Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
       Part No SW: 03C 906 016 CD    HW: 03C 907 309 E
       Component: 1.4l R4 TSI   H15 9971
       Revision: L5H15---    Serial number: VWZCZ000000000
       Coding: 00250012002401000000
       Shop #: WSC 96010 981 187377
       ASAM Dataset: EV_ECM14TFS01103C906016CD 001014
       ROD: EV_ECM14TFS01103C906016CD.rod
       VCID: 63CF828A6A11205C5A-8036
    4815 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [036] - -
                        Mileage: 35545 km
                        Date: 2018.07.17
                        Time: 00:08:01
                        Coolant temperature: 49 C
                        Intake air temperature: 38 C
                        Voltage terminal 30: 12.109 V
                        CAN status - engine control module-Bits 0-7: 00000000
                        CAN TimeOut meter - transmission-Bits 0-7: 00000000
                        Generator power: 0 W
                        CAN TimeOut meter - gateway-Bits 0-7: 00000000
                        CAN TimeOut meter - battery manager-Bits 0-7: 00000000
    14413 - Implausible Data Received from ABS Control Module
              U0415 00 [036] - -
                        Mileage: 35545 km
                        Date: 2018.07.17
                        Time: 00:08:01
    5250 - Function Restriction due to Faults in Other Modules
              U1113 00 [036] - -
                        Mileage: 35545 km
                        Date: 2018.07.17
                        Time: 00:08:01
    4660 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [036] - -
                        Mileage: 35545 km
                        Date: 2018.07.17
                        Time: 00:08:03
    4675 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [039] - -
                        Mileage: 35545 km
                        Date: 2018.07.17
                        Time: 00:08:01
                        Cruise Control System (CCS): status-Bits 0-7: 11101110
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 00000010
                        Cruise control switch-off: reversible-Bits 0-7: 11111111
                        Cruise control switch-off: irreversible-Bits 0-7: 00000001
                        Acceleration: 0.000 m/s
    Readiness: 1110 0101
       Part No SW: 0AM 300 053 J    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 3464
       Revision: 00043014    Serial number: CU501111156674
       VCID: 336F32CA5271F0DCEA-8066
    006279 - Wheel-Speed Signal from ABS Control Module
                   P1887 - 000 - Implausible Signal
                        Fault Frequency: 105
                        Reset counter: 10
                        Mileage: 35253 km
                        Date: 2012.11.14
                        Time: 02:18:04
       Part No SW: 3AA 614 109 AG    HW: 3AA 614 109 AG
       Component: J104   C2 450M VDDD 0023
       Revision: --H07---    Serial number: 00000005054121
       Coding: 0008037
       Shop #: WSC 00028 028 00001
       VCID: 72E1F7CE6DEBB9D421-8026
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 170
                        Mileage: 35253 km
                        Date: 2012.11.14
                        Time: 02:18:06
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 2
                        Hex Value: 0x0000
                        Fault Frequency: 101
                        Reset counter: 221
                        Mileage: 35253 km
                        Date: 2012.11.14
                        Time: 02:18:16
                        Hex Value: 0x0000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 191
                        Hex Value: 0x0000
                        Fault Status: 00101001
                        Reset counter: 6
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 10011111
                        Count: 3
                        Hex Value: 0x0000
                        Reset counter: 6
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 10011111
                        Count: 3
                        Hex Value: 0x0000
                        Reset counter: 6
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 10011111
                        Count: 3
                        Hex Value: 0x0000
       Part No SW: 3AA 907 044 B    HW: 3AA 907 044 B
       Component: Climatronic   H03 0101
       Revision: 00001K01
       Coding: 0014003003
       Shop #: WSC 00028 028 00022
       VCID: 2F673EBA7659D43C8E-807A
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 H    HW: 3AA 937 087 H
       Component: BCM PQ47 H+   421 0464
       Revision: BC421001
       Coding: 0008000000000000009800801400293423D50088606C8960E480C7240041
       VCID: 3F876EFAAE3924BC1E-806A
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 10111  26  0612
       Coding: 00B795
       Component: RLS 221111 05  54  0403
       Coding: 0B30ED
       Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
       Component: J234__10J VW10 HI   1918
       Revision: 23016000    Serial number: 003JZPNU8X59
       Coding: 0012362
       VCID: 4B9F4A2A2A81881C82-801E
       Subsystem 1 - Serial number: 6332MTS693883091
       Subsystem 2 - Serial number: 6342MTS624773071
       Subsystem 3 - Serial number: 6351HTS604CB0AKR
       Subsystem 4 - Serial number: 6361HTS6PD9HV9KJ
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C5 953 501 BE    HW: 5K0 953 569 R
       Revision: FF010040    Serial number: 20111122200057
       Coding: 4980250000
       VCID: 69D390A2883D7A0C90-803C
       Part No SW: 3AA 920 870 C    HW: 3AA 920 870 C
       Component: KOMBI         H03 0609
       Coding: 560F01
       VCID: 326137CE656BF9D4E1-8066
       Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
       Component: J533  Gateway H41 1623
       Revision:   H41       Serial number: 171111F1001674
       Coding: 461007
       VCID: 3E7913FEA9332DB415-806A
                        Reset counter: 170
                        Mileage: 35253 km
                        Date: 2012.11.14
                        Time: 02:18:21
    03109 - Tire Pressure Monitoring Control Module 2 (J793)
                        Reset counter: 5
                        Mileage: 35545 km
                        Date: 2012.12.07
                        Time: 00:01:31
       Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
       Component:    IMMO         042 0400
       VCID: 377706DA46091CFCD6-8062
    02823 - Requirements for Locking the Steering Column Lock not met
                000 -  -  - Intermittent
                        Reset counter: 6
                        Mileage: 35254 km
                        Date: 2012.11.14
                        Time: 03:48:35
       Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0534
       Revision: 12110009    Serial number: 0003912075
       Coding: 0212B7
       Shop #: WSC 00028 028 00215
       VCID: 356B0CD29405EEECC4-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0408
       Serial number: 00000002599705
       Coding: 000290
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 221
       Part No: 1K0 909 144 N
       Component: EPS_ZFLS Kl. 194    3301
       Revision: 00H22000
       VCID: 356B0CD25C05EEECC4-8060
    01316 - ABS Control Module
                        Fault Status: 11101101
                        Reset counter: 170
                        Mileage: 35253 km
                        Date: 2012.11.14
                        Time: 02:18:27
                        Voltage: 12.13 V
                            DD
                        Temperature: 36.0C
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.5 V
                            PD
                        Temperature: 35.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
       Component:    KSG PQ47 ELV 042 0634
       Coding: 00910A0002860E76340494157C085F0B607801
       Component: EZE_2         H41 1623
       Coding: 00000008
       VCID: 6FE7FEBABED9943CCE-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
       Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0534
       Revision: 14110009    Serial number: 0003920019
       Coding: 0212B6
       VCID: 36690BDE8903E5F4CD-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0408
       Serial number: 00000002588675
       Coding: 000290
                        Reset counter: 221
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000445023
       Coding: 0022167
                        Fault Status: 01101101
                        Reset counter: 221
                        Mileage: 32529 km
                        Date: 2012.05.29
                        Time: 06:15:51
                        Voltage: 11.90 V
                        Count: 105
                        Hex Value: 0x12F3
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Coding: 029600000B000200
       VCID: 377706DA8E091CFCD6-8062
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H04 0011
       Coding: 230000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H04 0011
       Coding: 230000
    5275648 - Left/Right Driving Switch-Over Active
              C1080 00 [009] -  -
                        Reset counter: 170
                        Mileage: 35253 km
                        Date: 2018.06.24
                        Time: 02:18:33
    13705985 - Databus
                        Fault Frequency: 98
                        Reset counter: 221
                        Mileage: 35253 km
                        Date: 2018.06.24
                        Time: 02:18:33
    13705987 - Databus
                        Fault Frequency: 97
                        Reset counter: 221
                        Mileage: 35253 km
                        Date: 2018.06.24
                        Time: 02:38:19
    Address 56: Radio
       Component: Batt.regelung H41 1623
       Coding: 03271864
       VCID: 71E3F8C2A8ED82CCD8-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900132730
    End-------------------------(Elapsed Time: 03:24)--------------------------
    after abs module changed
     Tuesday,17,July,2018,09:51:44:17560
    VIN: WVWZZZ3CZCP043448   License Plate: PASSAT3CGEORGEPART2
              62 72
    4C-Tire Pressure II -- Status: Cannot be reached 1100
              U1017 00 [167] - -
                        Mileage: 35545 km
                        Date: 2018.07.17
                        Time: 00:08:01
              U0415 00 [039] - -
                        Mileage: 35545 km
                        Date: 2018.07.17
                        Time: 00:08:01
              U1113 00 [039] - -
                        Mileage: 35545 km
                        Date: 2018.07.17
                        Time: 00:08:01
              U1017 00 [039] - -
                        Mileage: 35545 km
                        Date: 2018.07.17
                        Time: 00:08:03
              U1017 00 [039] - -
                        Mileage: 35545 km
                        Date: 2018.07.17
                        Time: 00:08:01
                        Fault Frequency: 106
                        Reset counter: 10
                        Mileage: 35253 km
                        Date: 2012.11.14
                        Time: 02:18:04
       Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
       Component: J104   C2 450M V4DD 0023
       Revision: --H07---    Serial number: 00000005319025
       Coding: 0000000
       Shop #: WSC 05311 000 00000
       VCID: 71E3F8C268ED82CCD8-8024
    8 Faults Found:
                        Reset counter: 221
                        Mileage: 35545 km
                        Date: 2012.12.07
                        Time: 20:18:41
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 2
                        Hex Value: 0x0000
                000 -  -
                        Reset counter: 221
                        Mileage: 35545 km
                        Date: 2012.12.07
                        Time: 20:23:31
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00000000
                        Count: 215
                        Hex Value: 0x0000
    03201 - Adaptation Overboost
                        Reset counter: 221
                        Mileage: 35545 km
                        Date: 2012.12.07
                        Time: 20:23:31
                        Reset counter: 221
                        Mileage: 35545 km
                        Date: 2012.12.07
                        Time: 20:23:31
                        Reset counter: 221
                        Mileage: 35545 km
                        Date: 2012.12.07
                        Time: 20:23:31
                        Reset counter: 221
                        Mileage: 35545 km
                        Date: 2012.12.07
                        Time: 20:23:31
                        Reset counter: 221
                        Mileage: 35545 km
                        Date: 2012.12.07
                        Time: 20:23:31
                        Reset counter: 221
                        Mileage: 35545 km
                        Date: 2012.12.07
                        Time: 20:23:31
       Revision: 00001K01
       Coding: 0014003003
       Revision: BC421001
       Coding: 00B795
       Coding: 0B30ED
       Coding: 0012362
       Coding: 4980250000
       Coding: 560F01
       Coding: 461007
                        Reset counter: 170
                        Mileage: 35253 km
                        Date: 2012.11.14
                        Time: 02:18:21
                        Reset counter: 221
                        Mileage: 35545 km
                        Date: 2012.12.07
                        Time: 00:01:31
                        Reset counter: 6
                        Mileage: 35254 km
                        Date: 2012.11.14
                        Time: 03:48:35
       Coding: 0212B7
       Slave Driver:
       Coding: 000290
                        Reset counter: 221
       Revision: 00H22000
                        Reset counter: 170
                        Mileage: 35253 km
                        Date: 2012.11.14
                        Time: 02:18:27
                        Voltage: 12.13 V
                            DD
                        Temperature: 36.0C
                000 -  -  - MIL ON
                            PD
                        Temperature: 35.0C
                        Count: 2
                            SteerAng n.Init
       Coding: 00000008
       Coding: 0212B6
       Slave Passenger:
       Coding: 000290
                        Reset counter: 221
       Coding: 0022167
                        Reset counter: 221
                        Mileage: 32529 km
                        Date: 2012.05.29
                        Time: 06:15:51
                        Voltage: 11.90 V
                        Count: 104
                        Hex Value: 0x12F3
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Coding: 230000
       Coding: 230000
              C1080 00 [009] -  -
                        Reset counter: 170
                        Mileage: 35253 km
                        Date: 2018.06.24
                        Time: 02:18:33
    13705985 - Databus
                        Reset counter: 221
                        Mileage: 35253 km
                        Date: 2018.06.24
                        Time: 02:18:33
    13705987 - Databus
                        Fault Frequency: 97
                        Reset counter: 6
                        Mileage: 35253 km
                        Date: 2018.06.24
                        Time: 02:38:19
    Address 56: Radio
       Coding: 03271864
    End-------------------------(Elapsed Time: 03:20)--------------------------
    with the issue we changed abs sensor and wiring but same problem , the sensor is fully functional on another car and we checked wiring, so we decided to change abs module.
    thanks in advance.
  2. Likes Boki Ar liked this post
  3. #2
    Are you sure "-AF" is a suitable replacement for "-AG"?
  4. Likes Golftwincharged liked this post
  5. #3
    Indeed it is..........
    OP: Fix the fault code first then the module will accept the coding...........
    Coding: 0008037
    Vehicle Identification No. WVWZZZ3CZCP043448
    Model Passat Limousine
    Blue Motion
    PA
    Date of production 06.12.2011
    Year 2012
    Sales type 3623AZ
    Engine Code CAXA
    Transmission Code NQK
    Axle drive 7A
    Equipment QQ
  6. Likes Golftwincharged, Uwe liked this post
  7. #4
    Jun 2016
    Guyana
    was supplied according to vin information.
  8. #5
    Jun 2016
    Guyana
    okay thank you very much sir!!! appreciate it
  9. #6
    Jun 2016
    Guyana
    UPDATES: I changed the abs sensors rear with correct replacements , coding accepted ( factoring in the additional coding information for the TPMS ) so the coding value was 0008037 + 1024
    inputted code : 0009061 ( coding accepted) then carried out basic settings for : G85 , G200, G201, G251 and adaptation overboost.
    car works perfectly, thanks again for the inputs.
  10. Likes Uwe, Fredrick Awuor liked this post
