Hello there, would appreciate any help in figuring out my problem which started after I upgraded my MMI to a 3G+ unit... for some reason TPMS, as well as service interval reminder systems are not available and are greyed out in MMI screen. Spent countless hours researching to no avail. Thanks in advance...
Below is the complete scan I took few days ago:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 28 34 36 3C 42 46 47 4C 4F
52 55 56 5F 62 69 6C 6D 6F 72 76
VIN: WA1WMAFEXBD001699 Mileage: 205920km-127952miles
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 HW: 4L0 907 401 D
Component: 3.0TDI EDC17 H16 0005
Revision: 54H16--- Serial number:
Coding: 2A2A4012257600050000
Shop #: WSC 57875 000 104857
ASAM Dataset: EV_ECM30TDI0114L2910401 001005
ROD: EV_ECM30TDI0114L2910401.rod
VCID: 61C2765D7038FF4C48-8035
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 S HW: 0C8 927 750 S
Component: AL1000 AISIN 001 1785
Coding: 001378
Shop #: WSC 56630 001 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_AU56.rod
VCID: 3C7CE729B71AF2A43B-8069
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0627857
VCID: 346CCF09574A3AE4F3-8061
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10602901631000
Coding: 0000135
Shop #: WSC 31414 790 00001
VCID: 254A224DEC90536C74-8071
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AF
Component: KLIMA 4 ZONEN H13 0060
Revision: 00---022 Serial number: 00000000242890
Coding: 0002A036
VCID: 254A224D2C90536C74-8071
Subsystem 1 - Part No SW: 8K0 959 772 A HW: 8K0 959 772
Component: SLR-B8 H05 0003
Serial number: 1002038346
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 A HW: 8K0 959 772
Serial number: 1002038198
Coding: 070000
Part No SW: 4F0 910 279 AC HW: 4F0 907 279 C
Component: ILM Fahrer H28 0360
Coding: 0133123
VCID: 6AD01171450EBC1499-803F
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H17 0100
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0031168
VCID: 27562845969C417C46-8073
Reset counter: 85
Mileage: 205922 km
Date: 2018.07.15
Time: 10:55:18
Temperature: 34.0∞C
Voltage: 12.03 V
Bin. Bits: 01001
Hex Value: 0x04F1
Hex Value: 0x0002
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
Reset counter: 85
Mileage: 205922 km
Date: 2018.07.15
Time: 10:55:18
Temperature: 34.0∞C
Voltage: 12.03 V
Bin. Bits: 01001
Hex Value: 0x0411
Hex Value: 0x0005
Speed: -3.6 km/h
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09H8JH
Coding: 0014131
VCID: 2B5ED4758A74651CA2-807F
Subsystem 1 - Part No: 4L0 910 339 A
Component: BF-Gewichtsens. H03 0030
Subsystem 2 - Serial number: 6332QSME576D1A14M
Subsystem 3 - Serial number: 6342QSME576D1826O
Subsystem 4 - Serial number: 6352QSME73684328I
Subsystem 5 - Serial number: 6362QSME546D513AP
Subsystem 6 - Serial number: 63734SME6C6553162
Subsystem 7 - Serial number: 63834SME725F223C7
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90026102040292
Coding: 0012152
Component: E0221 H02 0100
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 984 A HW: 4L0 920 984 A
Component: KOMBIINSTR. H10 0209
Revision: 00000000 Serial number: FLR20A38A
Coding: 8BD664040D019709020301
VCID: 3162C61D68580FCC98-8065
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 Q HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0047
Revision: MB300033 Serial number: 3300M10716802A
Coding: 00C303
VCID: 3D7AEA2DA400FBAC0C-8069
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790324892
Part No SW: 4L0 910 158 HW: 4L0 919 158 AA
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---010 Serial number: 00000000242965
Coding: 0000006
VCID: 68D46B795B028E048F-803D
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 J HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7860
Revision: --H03001 Serial number: 15.1528-0122.2
Coding: 0015520
VCID: 3162C61DA8580FCC98-8065
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00001002027972
Coding: 00581B00000011110000
VCID: 3260C9116D5E34D4E1-8067
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E58DD61B966103485-807B
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H01 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F29.07.1000H010003C911689ˇ
Subsystem 4 - Serial number: 911689ˇ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0004000126472
Coding: 011F57205E40440004
VCID: 48948BF9FBC2AE04AF-801D
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01332678850000
Coding: 3569693
VCID: 356AF20D5C3023ECC4-8061
Part No SW: 4L0 035 466 A HW: 4L0 035 466 A
Component: BO Q7 H30 0110
Revision: 05S00000 Serial number: 00804100004762
Coding: 0D000001
VCID: 29522E7D4088770C50-807D
Subsystem 1 - Part No SW: 4L0 910 465 A HW: 4L0 035 465
Component: BO Q7 SLAVE H41 0780
Serial number: 01406100004033
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H03 0110
Revision: 00000276 Serial number: 00002760027230
Coding: 0758733
VCID: 234E3C55E2A4AD5C1A-8077
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000070741
Coding: 0012001
VCID: 5EB84DA18946C0B475-800B
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0004000128178
VCID: 479688C5F6DCA17CA6-8013
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000032
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471G/0A7519338
Coding: 020007010000000000
VCID: 5DBA4AAD4440DBAC6C-8009
Part No SW: 4L2 035 746 G HW: 4L2 035 746 D
Component: H-BNT-NA H41 0901
Revision: -------- Serial number: 224L$0D7536513
Coding: 180200060204F97F73023345FD772003140000000100000202
Shop #: WSC 65365 001 104857
Subsystem 1 - Part No: 8R0 060 884 BL
Component: NAR 2014 0902
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466HY0A0071089
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000001968878
Component: CD-Database 5571
Reset counter: 85
Mileage: 205922 km
Date: 2018.07.15
Time: 10:55:31
Bin. Bits: 10000000 10000000
Bin. Bits: 00000000 00000000
01524 - Antenna for Telephone
Fault Status: 01101011
Reset counter: 85
Mileage: 205922 km
Date: 2018.07.15
Time: 10:59:21
Voltage: 12.00 V
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0357
Revision: Serial number: 0004000128621
Coding: 010E57204040230004
VCID: 468885C1F1D6B8745D-8013
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H08 0070
Revision: 2A001001 Serial number: 00000132320655
Coding: 0200000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H04--- Serial number: 525PA8-J0642NL
Coding: 1021001
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H55 0500
Revision: --H55001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CDC17694FFAA224EB-8039
Subsystem 3 - Serial number: RD03.08.10--H55001001A0099ˇ
Subsystem 4 - Serial number: 1A0099ˇ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0070
Revision: AAH05061 Serial number: 106480645-----
Coding: 0003595
VCID: 26482541919658747D-8073
Component: J_245_EE16_SKB10H11 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H11 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H11 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0004000128682
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 85
Mileage: 205922 km
Date: 2018.07.15
Time: 10:55:20
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H02 0100
Revision: 00H02000 Serial number: 85131014606720
Coding: 0231266
VCID: 2C5CD7698F7A6224AB-8079
End-------------------------(Elapsed Time: 04:45)--------------------------
