VIN: WAUZZZ8K99A224816 License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 69 72 77
VIN: WAUZZZ8K99A224816 Mileage: 259200km-161059miles
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (------CDHB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K1 907 115 K HW: 8K1 907 115
Component: 1.8l R4/4V TF H07 0002
Revision: A5H07---
Coding: 0104001018070920
Shop #: WSC 04632 996 94821
ASAM Dataset: EV_ECM18TFS8K1907115K A01003
ROD: EV_ECM18TFS_AU48.rod
VCID: 3634D0ECF8CE6C879BB-8062
4865 - No Communication with Towing System Control Module (J345)
U1003 00 [039] - -
[J345 - Towing Recognition Control ModuleNo Communication]
Mileage: 259203 km
Date: 2018.07.13
Time: 20:28:35
Coolant temperature: 33 °C
Intake air temperature: 33 °C
Voltage terminal 30: 11.638 V
Readiness: 1110 0101
Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE
Component: ESP8 front H04 0240
Coding: 038500
VCID: 7CA002C486E276D72DF-8028
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H80 0145
Coding: 031100
Shop #: WSC 06325 000 00000
VCID: 3038E6F41A2A42B7C17-8064
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000014032020
Component: J764 ELV MLB H36 0042
Serial number: 0209000018487002
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8T2 820 043 Q HW: 8T2 820 043 Q
Component: KLIMA 1 ZONE H06 0150
Revision: B0000000 Serial number: 01270320091300
Coding: 64040000
VCID: 40D8B634AA8AD237317-8014
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H24 0253
Revision: 04024001 Serial number: 00000000227751
Coding: 2600D8914134AF310001000000001D0D0F1D230800010101000000
Shop #: WSC 01234 444 262143
VCID: 2F3AE58807145D4FD8D-807A
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 240309 H05 0070
Serial number: SWF09030240361
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10428295
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 Q HW: 8K0 941 531 Q
Component: E1 - LDS H07 0090
Serial number: 00000000002303090277
03110 - Active Steering Control Module (J792)
Reset counter: 236
Mileage: 259203 km
Date: 2018.07.13
Time: 20:56:00
01517 - Control Module for Trailer/Towing Sensor (J345)
Reset counter: 236
Mileage: 259203 km
Date: 2018.07.13
Time: 20:28:00
03207 - Charisma Switch Module
Reset counter: 236
Mileage: 259203 km
Date: 2018.07.13
Time: 20:56:00
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Serial number: 0038JD1F2P00
Coding: 30363435363030303030554A3052384B3053
VCID: 3C20C2C4C6E2B6D76DF-8068
Serial number: 6334MSME462036723
Serial number: 6344MSME45206C1AE
Serial number: 6352QSME351F1F38S
Serial number: 6362QSME611C11022
Serial number: 63732SME6F21260C0
Serial number: 63832SME34200318L
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315ICU0005X
Coding: 000016
VCID: 3D26CFC0DD78BFDF5A1-8068
Part No SW: 8K0 920 900 HW: 8K0 920 900
Component: KOMBIINSTR. H18 0224
Revision: 00000000 Serial number: 9DL75DU39
Coding: 2F0D080002000008010001
VCID: 678A4DA8EF64C50FD0D-8032
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G09318803D
Coding: 000303
VCID: 4BC2911893CC016FD45-801E
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 1906E1B4050309
Reset counter: 236
Mileage: 259203 km
Date: 2018.07.13
Time: 20:28:31
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008719388
Coding: 011C02204001410001
VCID: 41DEB330A180DB3F3E9-8014
Revision: 00002001 Serial number: 0117781492
Coding: 017F062200390040013001
Shop #: WSC 06325 123 12345
01403 - Glass-Break Sensors; Rear
Fault Status: 01101011
Reset counter: 236
Mileage: 259203 km
Date: 2018.07.13
Time: 21:10:06
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6E84388CC09E144793B-803A
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008692094
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 00000000337919
VCID: 3332E9F8EB3C79AFBC5-8066
Part No: 8K5 907 357
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 77AA1DE8B3C4558F40D-8022
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
Component: Concert3 H01 0310
Revision: 00000004 Serial number: AUZ5Z6I1192247
Coding: 0502008201018D000159070000
VCID: 45D6A720B5A8F71F021-8010
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
03138 - Input AUX IN
Reset counter: 236
Mileage: 259203 km
Date: 2018.07.13
Time: 20:33:02
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000008718818
Coding: 010C02204001210001
VCID: 44D0BA24BE92CE1715F-8010
Address 69: Trailer
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000008718850
Part No SW: 8T0 862 335 D HW: 8T0 862 335 C
Component: FSE_256x BT H33 0600
Revision: 00000000 Serial number: 00000005063268
Coding: 0010390
Shop #: WSC 04632 996 89440
VCID: 3B22C1D8CF6CB1EF645-806E
End----(Elapsed Time: 01:33, VBatt start/end: 11.0V/10.9V. VIgn 10.9V)-----
