2012 Jetta S - "No ROD file found" "... please send an Autoscan ... to Ross-Tech"
Got same error with 18.2.
"No ROD file found
Unable to find a ROD file for:
EV_Kombi_cy _VCC_RM09 A04114 (VW36*)
Please make sue uou are using the latest version (including BETA).
If you are using the lates version,
please send an Autoscan from this car to Ross_Tech."
"No ROD file found
Sunday,15,July,2018,18:33:23:59981
VCDS Version: 18.5.4.2 HEX-NET CB: 0.4427.4
Data version: 20180518 DS291.0
VIN: 3VW2K7AJ5CM342254 License Plate: 2012 JETTA
Mileage: 99424 Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56
Address 01: Engine (CBP) Labels: 06G-906-055-CBP.clb
Part No SW: 06G 906 055 AE HW: 06G 906 055 B
Component: 2.0l 85 KW 01 1302
Revision: T5H06--- Serial number:
Coding: 0001015
Shop #: WSC 33562 001 1048576
VCID: 6C9410B24F61BA2BA1-8038
049493 - No Communication with Instrument Cluster
U0155 - 000 - - Intermittent
Mileage: 159828 km
Date: 2007.14.09
Time: 17:06:18
Temperature: 46.0°C
Temperature: 21.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.319 V
001121 - Fuel Level Sensor Circuit
P0461 - 000 - Implausible Signal - Intermittent
Mileage: 159828 km
Date: 2007.14.09
Time: 17:06:19
Temperature: 45.0°C
Temperature: 21.0°C
Voltage: 12.192 V
000801 - Engine Speed Sensor (G28)
P0321 - 000 - Implausible Signal - Intermittent
Mileage: 159833 km
Date: 2007.14.10
Time: 16:46:39
RPM: 88 /min
Load: 75.3 %
Temperature: 58.0°C
Temperature: 34.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.557 V
Part No SW: 09G 927 750 LE HW: 09G 927 750 LE
Component: AQ 250 6F 2618
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 7F4ED7FE2E1731B314-802A
Reset counter: 5
Mileage: 53694 km
Date: 2035.14.19
Time: 23:15:45
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: B14B240C512608FC8D0D24E98A1D1061A70000
VCID: 7BB623EEFA0F2D9338-802E
Reset counter: 210
Mileage: 159833 km
Date: 2007.14.10
Time: 17:28:29
Count: 3
Count: 12
Count: 20992
Count: 16390
Count: 43264
Count: 63745
Count: 252
Count: 121
Reset counter: 210
Mileage: 159833 km
Date: 2007.14.10
Time: 17:28:29
Count: 3
Count: 12
Count: 20992
Count: 8194
Count: 43264
Count: 63745
Count: 252
Count: 121
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 170
Mileage: 159833 km
Date: 2007.14.10
Time: 17:32:49
Count: 2
Count: 12
Count: 28672
Count: 16401
Count: 43264
Count: 63745
Count: 252
Count: 121
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AM HW: 5C0 820 047 AM
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000603299
VCID: 6B9613AE4A6FBD13A8-803E
Reset counter: 210
Mileage: 159833 km
Date: 2007.14.10
Time: 17:28:36
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0251
Revision: B2066001 Serial number: 04371281110159
Coding: 7B994B9A08AB0B0008302000240884D400C2502E60000000300000000000
VCID: 2F2EC7BE7EF70133C4-807A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H09 0007
Serial number: WRH000372TB
Coding: 180000
Subsystem 4 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3464
Coding: 800000
Reset counter: 205
Mileage: 160012 km
Date: 2012.14.21
Time: 23:41:36
03444 - Ignition Starter Switch
Reset counter: 210
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTM02CDHS
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3424C8D29FD122EBB9-8060
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y11000086GM0L
Coding: 303148
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME2D542163ZZZT
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME18213262ZZZJ
Serial number: 3516KSME5B070914ZZZQ
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME2E167211ZZZO
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME36051D13ZZZQ
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME3C051D13ZZZX
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 5C6 920 951 HW: 5C6 920 951
Component: KOMBI H04 0604
Coding: 270201
Shop #: WSC 00066 000 00123
ASAM Dataset: EV_Kombi_cÿ_VDD_RM09 A04114
ROD: N/A
VCID: 689C6CA29399960BC5-803C
No ASAM data for: "EV_Kombi_cÿ_VDD_RM09" (VW36 *)
12648448 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 210
Mileage: 159833 km
Date: 2071.14.10
Time: 17:28:53
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0251
Revision: B2066001
Coding: 102200
VCID: 70AC04C2A3495ECB9D-8024
Reset counter: 210
Mileage: 159833 km
Date: 2007.14.10
Time: 17:28:59
Component: IMMO H04 0604
VCID: 6A9816AA8D95A41BD3-803E
Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
Component: LOW NAR H02 0004
Revision: -----03S Serial number: VWZ4Z6L3199396
Coding: 05000400010006
VCID: 23063B8E223FB55350-8076
Reset counter: 170
Mileage: 159833 km
Date: 2007.14.10
Time: 17:29:07
End----(Elapsed Time: 01:12, VBatt start/end: 11.3V/11.3V. VIgn 11.2V)-----
