Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Vagcom Key FOB Programming
    Feb 2017
    Canada
    Did you observe the correct carrier frequency? There's 315MHz for North America and 434 for the rest of the world, IIRC.
    I have contacted the supplier and they assure me that it is a 315Mhz FOB. Thank you for this heads up, I never would have thought to even ask this question.
  2. #12
    Aug 2016
    The Hague, NL
    315MHz should be OK, right?
  3. #13
    Jul 2018
    On that year should be manual procedure.
    One key,that is able to start the car,in the ignition - ON position and the second key in the driver door lock. Turn and hold to lock position for 10 sec. You should hear the horn sound. Still holding on to lock position press unlock button once. Again, the horn should beep. Take the keys out and try..
    Also what part number on the remote do you have? Has to be the right one otherwise you cannot program it..
    Good luck
  4. Likes Jetta ,97 liked this post
  5. #14
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by robertdaleweir View Post
    It all depend what part number you have on remote .
    Is it possible to see part number ?
    1998-2001 is one remote (Part number 1J0 959 753 F or T) Ending with "F" was old round shape , "T" is square shape , "F" is discontinue from Dealer , only can find it online.
    2002-2003 is (Part number 1J0 959 753 AM or DC), and they both 315Mhz
    So if you have remote form 2002-2003 it will not work in your car .
    On this yaer model VCDS will program it with out any problems, do not need manual procedure, I have done it 100 times.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  6. Likes Uwe liked this post
