Results 1 to 10 of 14
Thread: Vagcom Key FOB Programming
    Feb 2017
    Canada
    Hi
    I have been trying to use my Vagcom unit to Program a new Key FOB for my 1998 Beetle TDI. I do not have a working remote only my Valet Key. I have tried to use the procedure which I have found on Youtube which goes into Adaptation and with a key (my Valet key since I do not have a working key FOB) and I am unsuccessful. Can anyone help me with my Key Programming?
  3. Likes Jetta ,97 liked this post
    Feb 2017
    Canada
    Thanks I apparently cannot post attachments so here it is in-line.
    Thursday,12,July,2018,12:19:42:56923
    VCDS Version: 18.2.1.2 (x64)
    VIN: 3VWCF21C3XM413776   License Plate: 927DJN
    Mileage: 276160km-171597mi   Repair Order:
    Chassis Type: 1C - VW New Beetle (1998 > 2010)
    Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
       Mileage: 276160km-171597miles
    Address 01: Engine        Labels: 038-906-018-AGR.lbl
       Part No: 038 906 018 BK
       Component: 1,9l R4 EDC G400SG  2145
       Coding: 00002
       Shop #: WSC 00066
       VCID: 60C41814E09DF84447-4B00
    Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
       Part No: 1J0 907 379 G
       Component: ABS     20 IE CAN  0001
       Coding: 03504
       Shop #: WSC 00066
       VCID: 356A99400F9F2DECC4-4B18
    Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
       Part No: 1J0 909 609
       Component:  F AIRBAG VW3 SG   0002
       Coding: 00070
       Shop #: WSC 00066
       VCID: 6CDC7C241C55AC24EB-4B00
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
                28-10 - Short to Plus - Intermittent
    Address 17: Instruments        Labels: 1C0-919-xx0.lbl
       Part No: 1C0 919 801 F
       Component: KOMBIINST.      M73 V20
       Coding: 02342
       Shop #: WSC 131071
       VCID: 26484E0CC23956747D-4B00
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AJ
       Component: 5X Zentral-SG Komf. 0001
       Coding: 00256
       Shop #: WSC 00066
       VCID: 06082E8C22F976741D-4B00
       Subsystem 1 - Part No: 1J2959802A
       Component: 07 Tőrsteuerger. FS0001r
       Subsystem 2 - Part No: 1J2959801D
       Component: 5X Tőrsteuerger. BF0002B
    01483 - Control Circuit for Rear Lid Remote Unlocking
                25-10 - Unknown Switch Condition - Intermittent
    00953 - Interior Light Time limit
    01179 - Incorrect Key Programming
                35-00 -  -
    00943 - Heated Exterior Mirror; Driver Side (Z4)
                35-00 -  -
                35-00 -  -
    End-------------------------(Elapsed Time: 04:47)--------------------------
    This is a scan which I ran just before attempting to Program my new key FOB. It shows an '01179 - Incorrect Key Programming
    35-00 - -' line but as I had mentioned in my post I do not have a working Key FOB. I took the Blade out of my ONLY remote (which died recently) and attached it to the New FOB and turned on the Ignition with that. I have a working Valet Key and a working Blade from my old working FOB. I have not used any functions other than Autoscan with my VagCom unit. I simply went to Central Convenience and with the old blade in the Ignition and turned to the on position I went through the Adaptation section of the VagCom menu and picked the 1 key option and proceeded to hold the Open Button on the new Key FOB for 3 seconds etc etc. No joy.
    Been here?
    http://wiki.ross-tech.com/wiki/index..._2)#Adaptation
    Specifically, did you clear out old remote matching via channel 0 first?
  6. Likes robertdaleweir liked this post
    Feb 2017
    Canada
    Been here?
    Yes I forgot to mention that before. Also that was the exact video I followed. I have a follow up question as well. Could I have a faulty Control Module and how would I check for that? Not sure how I hit that Like but it was unintentional.
    Feb 2017
    Canada
    Quote Originally Posted by robertdaleweir View Post
    OK Should I be able to use the VCDS adaptation procedure to program a FOB if I do not have a working FOB? I do not have a working FOB so I cannot test to see if I have a faulty Control Module. Can someone weigh in to help me with this problem?
    Yes, I can't think of any reason why a working fob should be needed.
    Where did you get the "new" fob?
  10. #8
    Feb 2017
    Canada
    OK. You will have to ask my wife about why. I guess it is because she wants it.
    I bought it at:
    https://www.ebay.ca/usr/yourkeysuppl...72.m2749.l2754
    Yes I have checked the battery and it is fine. Can I use the VagCom to specifically check the CCM Module?
  11. #9
    Aug 2016
    Switzerland
    Did you observe the correct carrier frequency? There's 315MHz for North America and 434 for the rest of the world, IIRC.
  12. Likes Uwe, Fredrick Awuor liked this post
  13. #10
    Feb 2017
    Canada
    I really do not know. I bought it from the USA. I will try to get that information tomorrow. Thanks for the Tip.
