Unable to access block 01, updated to 18.2.1, then the HEX+CAN was updated when I first started with the car. It is a post fix resale, but I wanted to check the DEF tank level before sending the kid out on a road trip, which needs the address 01 advanced meas to work. Checked that interface was working on a 2014 Beetle, closest I had to the 2015 Jetta, Able to check ash loading, and all the 01 block functions worked. Looking for the EV_ECM20TDI01104L997016B wasn't found, only EV_ECM20TDI01104L997016.rod, EV_ECM20TDI01104L997016_M.rod and EV_ECM20TDI01104L997016E.rod were found.
Friday,13,July,2018,17:11:47:30462
VCDS Version: 18.2.1.5 (x64)
VIN: 3VW3A7AJ8FM****** License Plate:
Mileage: 94140km-58495mi Repair Order:
Address 01: Engine
Control Module Part Number: 04L 997 016 B
Component and/or Version: R4 2.0l TDI H20 9468
Software Coding: 01190012042410085000
Work Shop Code: WSC 03340
VCID: 3261099865599FD4E2-8066
Advanced Identification/FAZIT
Identification: RB8-658
Revision: 8AH20---
Date: 27.10.14
Manufacturer number: 1415
Test stand number: 0785
Flash Status
Programming Attempts(application): 2/2/2
Successful Attempts(application): 2/2/2
Flash Date: 18.06.27
Misc.
Hardware number: 04L 907 309 K
Workshop System Name: J623
ASAM Dataset: EV_ECM20TDI01104L997016B
ASAM Dataset Revision: 004002
Car Info
Chassis Number: 3VW3A7AJ8FM******
Engine code: CVCA
VCDS Info:
Labels: None
Readiness: No script available
ROD: ERROR - EV_ECM20TDI01104L997016B 004002 (VW36)
Address 01: Engine (J623-CVCA) Labels: None
Part No SW: 04L 997 016 B HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9468
Revision: 8AH20---
Shop #: WSC 03340 444 00000
ASAM Dataset: EV_ECM20TDI01104L997016B 004002
ROD: N/A
No ASAM data for: "EV_ECM20TDI01104L997016B" (VW36)
Address 01: Engine
Revision: 8AH20---
Date: 27.10.14
Flash Status
Misc.
Car Info
Engine code: CVCA
VCDS Info:
Labels: None
Revision: 8AH20---
ROD: N/A
