Results 1 to 6 of 6
Thread: 2003 24v VR6 AXK sporadic P1152s
    Sep 2016
    I have a 2004 Rialta/2003 Eurovan and I go camping frequently from Southern California to Utah and Colorado. I've been getting sporadic P1152s. One time I had a P1152 and P1151 at the same time and I’ve had P0420 once but it hasn’t reoccurred. The P1152s occurs randomly. When they do occur the car runs like crap (feels like it's missing or flooded) and I can hear the fuel pump buzzing when I pull over and stop. If I wait a couple hours or overnight the symptoms are gone but may reoccur after a few hour of driving I've included a link to a csv log file which I was running when the event occurred. It was after 5+ hours of driving that day and 20 minutes after filling up and it was hot (90s). Look at group 32 field 2 on line 904 and watch it start climbing.
    I've read about what needs to be explored to isolate the cause but I don't have all the tools to do the diagnostics and there isn't a VW mechanic that will work on it within 60 miles and the problem can't be reproduced on demand.
    Thanks for your help.
    Log file: https://drive.google.com/open?id=1Ol...39GRHqTB-lSoKB
    Friday,12,August,2016,12:52:00:56009
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
    VCDS Version 16.8.0.3 (x64)
    Data version: 20160803 DS255
    Address 01: Engine Labels: 022-906-032-AXK.lbl
    Control Module Part Number: 022 906 032 AH
    Component and/or Version: MOTRONIC ME7.1 G 0003
    Software Coding: 00003
    Work Shop Code: WSC 02757
    VCID: 51A778E09B33F3CA7F-515B
    17560 - Long Term Fuel Trim Additive Air; Bank 1; Range 2
    P1152 - 35-10 - System too Lean - Intermittent
    17559 - Long Term Fuel Trim Additive Air; Bank 1; Range 1
    P1151 - 35-10 - System too Lean - Intermittent
    Thursday,22,September,2016,16:10:55:56009
    VCDS Version 16.8.1.1 (x64)
    Data version: 20160902 DS256
    Address 01: Engine Labels: 022-906-032-AXK.LBL
    VCID: 51A778E09B33F3CA77-513D
    Sunday,25,September,2016,16:31:20:56009
    VCID: 51A778E09B33F3CA77-515B
    16804 - Catalyst System; Bank 1
    P0420 - 35-00 - Efficiency Below Threshold
    Readiness: 0000 1000
    Friday,21,April,2017,12:33:44:56009
    VCDS Version 17.1.3.0 (x64)
    Part No: 022 906 032 AH
    Component: MOTRONIC ME7.1 G 0003
    Coding: 00003
    Shop #: WSC 02757
    VCID: 51A778E09B33F3C936-515B
    Normally, I would say those faults are indicative of an intake air leak, but your fuel pump buzzing makes me wonder.. Are you sure there's a correlation?
    If no false air leak found & measuring the FP volume and PSI results in specification replace the MAF.......
    Sep 2016
    Except when this problem occurs the car runs great, starts in a second and I'm averaging 15.5-17 mpg.
    It seems to occur usually under strain, higher speeds or elevation gain, you can see engine load in the linked log file. The fuel pump noise is odd because when I pull over I'm idling but the buzzing continues 3-4 minutes. Is there something else under the drivers seat that would make a noise? The vehicle has about 86,000 miles. In the log file it recovered on it's own without pulling over after about 10 minutes.
    Jun 2014
    The brake booster hose leaking is a known issue on the AXK Eurovan.
  6. Likes Jack@European_Parts liked this post
    Fuel filter should not be dismissed or the actual FPR.
