How to test Radiator Fan, Control Modle, or relay with VCDS Lite audi a4 / b6
DrPeter
16.4905° S, 151.7375° W
Regarding S4 and S42, how do I identify those fuses in those locations?
Like Jack said... workshop manuals - www.erwin.audi.com
- They will provide wiring diagrams, component locations, repair information and pictures/drawings too!
I would not want to diagnose a Volkswagen, an Audi, a Bentley or a Lamborghini or even a Bugatti without the proper wiring diagram in hand, there are just too many variables that these vehicles can have and sometimes these diagrams are not 100% correct, so pay attention to that as well.
When you find the wiring diagram, use this link below to help understand what you are looking at:
How to read wiring diagrams
drpeter
   #22
verrilli
C?ID=171692
The ground points can be verified in the repair manual for locations.
www.erwin.audi.com
You have no faults.....and you don't have readiness achieved.
Please preform readiness tests.........then repost full scan.
Ok, I have the wiring diagrams.
I also checked ground to the Fan CU and the ECU. The bolts to the chassis seem tight.
I performed the readiness test. The first time it was successful, but then I realized that I had the fan plug disconnected. I plugged it in, reset the fault, and now I can't get the O2 sensor heating test to pass. Do I have to wait some time on that one?
Here is the auto-scan output. Following that are the MVBs at various points.
Any suggestions? I'm about to give up and bring to service shop although I hate to give up ! But I also don't want buy another Fan ECU if I'm not sure that's the culprit.
Thursday,06,August,2015,21:49:19:37593
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: WAULC68E13A154719   License Plate:
Mileage: 270350km-167987mi   Repair Order:
          67 69 75 76 77
VIN: WAULC68E13A154719   Mileage: 270350km-167987miles
Address 01: Engine        Labels: 06B-909-518-AMB.lbl
   Part No SW: 8E0 909 518 AF    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0001
   Coding: 0016751
   Shop #: WSC 63351 000 00000
   VCID: 74E7161D1429F69E42-515E
Readiness: 0100 0000
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8E0 927 156 P
   Component: AG5 01V 1.8l5VT USA 0910
   Coding: 0001002
   VCID: 3B75FD2179F779E643-5140
   Part No: 8E0 614 517 H
   Component: ABS/ESP allrad      2328
   Coding: 04277
   Shop #: WSC 12345
   VCID: 2D51C379E783E756CD-5124
            35-10 -  -  - Intermittent
   Part No: 8E0 820 043 L
   Component:   A4 Klimaautomat   1016
   Coding: 00000
   Shop #: WSC 63351
   VCID: 2A5BC865D66DF06E28-5140
00710 - Defroster Flap Positioning Motor (V107)
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
01810 - Actuating Motor for Temperature Flap; Right (V159)
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  USA 0305
   Coding: 00003
   Shop #: WSC 63351
   VCID: 3467D61D04A9B69E82-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 C
   Component: Airbag 8.4EP        2000
   Coding: 0010607
   VCID: 377DE11145DF5D86A7-5140
   Part No: 8E0 953 549 L
   Component: Lenksáulenmodul     0308
   Coding: 00041
   Shop #: WSC 63351
   VCID: 3C77FE3D2CF97EDE4A-4B1A
   Part No: 8E0 920 950 L
   Component: KOMBI+WEGFAHRS. RB4 D35
   Coding: 03200
   Shop #: WSC 09211
   VCID: 326BD005FEBDB8AE90-5140
   WAULC68E13A154719     AUZ6Z0B0187480
            53-10 - Supply Voltage Too Low - Intermittent
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   VCID: 6BD50D611917296693-515E
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BB
   Component: Komfortgerát T7B    1311
   Coding: 11788
   Shop #: WSC 63351
   VCID: 72EB10053E3DF8AE50-4B1A
   Component: Tõrsteuer.FS BRM 0002
   Component: Tõrsteuer.BF BRM 0002
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0002
6 Faults Found:
01134 - Alarm Horn (H12)
            29-10 - Short to Ground - Intermittent
            49-00 - No Communications
01370 - Alarm triggered by Interior Monitoring
            35-00 -  -
01561 - Rear left door
01562 - Rear right door
   Part No: 8E0 035 195 F
   Component: symphony II NP2    0051
   Coding: 01001
   Shop #: WSC 08102
   VCID: 2A5BC865D66DF06E28-4E96
            36-00 - Open Circuit
00878 - Connection to Speaker Front Left
00879 - Connection to Speaker Front Right
End-------------------------(Elapsed Time: 06:37)--------------------------
Here are the MVBs right before I turn off the ignition.
                Address 01: Engine  (8E0 909 518 AF)
21:50:05 Group 131: Engine Cooling (Map Cooling)
  100.0°C  Engine Outlet Temp. (actual)
  101.0°C  Engine Outlet Temp. (specified)
  61.0°C  Radiator Outlet Temperature
  14.1 %  Thermostat Duty Cycle
21:50:05 Group 132: Engine Cooling (Map Cooling)
  39.0°C  Temp. Difference Engine/Radiator
  00001110  Cooling Status
21:50:05 Group 134: Engine Cooling (Temperatures)
  97.0°C  Oil Temperature
  25.0°C  Ambient Temperature
  66.0°C  Intake Air Temperature (G42)
  100.0°C  Engine Outlet Temperature
21:50:16 Group 131: Engine Cooling (Map Cooling)
  102.0°C  Engine Outlet Temp. (actual)
  57.0°C  Radiator Outlet Temperature
  31.4 %  Thermostat Duty Cycle
21:50:16 Group 132: Engine Cooling (Map Cooling)
  43.0°C  Temp. Difference Engine/Radiator
  00000110  Cooling Status
21:50:16 Group 137: Engine Cooling (Air Condition Requirements)
  A/C-Low  A/C Readiness
  Compr.ON  A/C Compressor
  13.8 bar  A/C-Pressure
  79.2 %  Fan Request from A/C-System
Here they are 7 minutes after. I think the 137 is frozen from when the ignition was turned off ??
21:58:00 Group 131: Engine Cooling (Map Cooling)
  99.0°C  Engine Outlet Temp. (actual)
  104.0°C  Engine Outlet Temp. (specified)
  44.0°C  Radiator Outlet Temperature
  3.9 %  Thermostat Duty Cycle
21:58:00 Group 132: Engine Cooling (Map Cooling)
  55.0°C  Temp. Difference Engine/Radiator
  00001000  Cooling Status
21:58:00 Group 135: Engine Cooling (Fan Activation)
  11.0 %  Fan 1 Activation Duty Cycle
21:58:08 Group 131: Engine Cooling (Map Cooling)
21:58:08 Group 132: Engine Cooling (Map Cooling)
  54.0°C  Temp. Difference Engine/Radiator
21:58:08 Group 137: Engine Cooling (Air Condition Requirements)
  A/C-High  A/C Readiness
  14.2 bar  A/C-Pressure
  81.2 %  Fan Request from A/C-System
Here they are just before the 15 minutes are up
22:05:20 Group 131: Engine Cooling (Map Cooling)
  42.0°C  Radiator Outlet Temperature
22:05:20 Group 132: Engine Cooling (Map Cooling)
  52.0°C  Temp. Difference Engine/Radiator
22:05:20 Group 135: Engine Cooling (Fan Activation)
22:05:28 Group 131: Engine Cooling (Map Cooling)
22:05:28 Group 134: Engine Cooling (Temperatures)
  99.0°C  Engine Outlet Temperature
22:05:28 Group 137: Engine Cooling (Air Condition Requirements)
and finally here they are after the fans have spontaneously come on and then I turned on the ignition again. The fans go off at this point.
22:07:44 Group 131: Engine Cooling (Map Cooling)
  94.0°C  Engine Outlet Temp. (actual)
22:07:44 Group 132: Engine Cooling (Map Cooling)
22:07:44 Group 135: Engine Cooling (Fan Activation)
22:07:52 Group 131: Engine Cooling (Map Cooling)
22:07:52 Group 134: Engine Cooling (Temperatures)
  81.0°C  Oil Temperature
  94.0°C  Engine Outlet Temperature
22:07:52 Group 137: Engine Cooling (Air Condition Requirements)
  Compr.OFF  A/C Compressor
  6.8 bar  A/C-Pressure
  0.0 %  Fan Request from A/C-System
   #23
verrilli
C?ID=171692
My problem turned out to be a bad (new) Fan ECU module. The module I got was off ebay and was from China. I guess there was a reason it was 1/3 the price of a factory module.
