2012 GTI 2.0L TSI (CCTA) ABS, ASR, Airbag and Tier Pressure warnings.
The last time I saw these warning all at the same time was due to a bad left rear wheel speed sensor, at 71450 miles ago. I was told by VW service not to be surprise if the right rear wheel speed sensor goes bad in a month or so and now at 79019miles.
I did my autoscan yesterday (7/10/18) I don’t want to assume anything, but from a quick look at this scan I see the right rear wheel speed sensor has a fault 003 - Mechanical Failure – Intermittent that could be the probable cause to these errors.
Please take a look at my autoscan and tell me what you think is the probable cause.
Thanks for your help.
Tuesday,10,July,2018,07:41:04:53083
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
VIN: WVWFV7AJ2CWxxxxx License Plate:
Mileage: 127170km-79019mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
VIN: WVWFV7AJ2CWxxxxx Mileage: 127170km-79019miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AS HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0040
Revision: AAH18--- Serial number:
Coding: 0403010A1C070160
Shop #: WSC 35252 001 1048576
VCID: 77AB151173C1B10F432-8022
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 015 - - Intermittent
Fault Status: 00101111
Fault Frequency: 10
Mileage: 126753 km
Date: 2012.11.18
Time: 12:19:36
RPM: 1904 /min
Load: 10.6 %
Temperature: 86.0°C
Temperature: 69.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.811 V
U1017 - 000 - - Intermittent
Mileage: 127068 km
Date: 2012.11.28
Time: 10:26:60
RPM: 2027 /min
Load: 15.7 %
Temperature: 45.0°C
Temperature: 33.0°C
Voltage: 12.065 V
Part No SW: 02E 300 057 C HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2724
Revision: 05351113 Serial number: 00001107280798
VCID: 196F33A9A595477F956-804C
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Fault Frequency: 255
Reset counter: 1
Mileage: 127139 km
Date: 2012.11.29
Time: 11:33:03
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C492300FE881106E692200041B70800
VCID: 7BA3092143E9956F27A-802E
03842 - RPM Sensor Rear Right: Incorrect Signal
Reset counter: 36
Mileage: 126753 km
Count: 3
Count: 12
Count: 20480
Count: 87
Count: 36096
Count: 207
Count: 65280
Fault Frequency: 7
Reset counter: 12
Mileage: 126753 km
Date: 2012.11.18
Time: 12:19:46
Count: 3
Count: 12
Count: 29184
Count: 16390
Count: 47872
Count: 65280
Fault Status: 00100011
Reset counter: 12
Mileage: 127174 km
Date: 2012.11.29
Time: 20:30:14
Count: 4608
Count: 83
Count: 48128
Count: 58590
Count: 62720
Fault Status: 00101100
Fault Frequency: 9
Reset counter: 12
Mileage: 126753 km
Count: 3
Count: 12
Count: 20480
Count: 80
Count: 36096
Count: 207
Count: 65280
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001016
Coding: 0000001002
VCID: 00597ECD2A8FF6B7728-8054
Part No SW: 1K0 937 086 P HW: 1K0 937 086 P
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 6F180A1A90272A04008800C17000054448010386534D8D60648020200040
VCID: 3D27C7391D7D5B5F59E-8068
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 05091 26 0512
Coding: 009795
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA0KGF9
Coding: 00003131
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FDBBD3117F1494F4B2-806A
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--00060U5M00
Serial number: 3572MSME39000263ZZZG
Serial number: 3582MSME1A6B6562ZZZ+
Serial number: 3512QSME42255D22ZZZQ
Serial number: 3522QSME7E385B14ZZZ2
Serial number: 35527SME49646628ZZZL
Serial number: 35627SME606B6628ZZZM
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Fault Frequency: 12
Reset counter: 52
Mileage: 126753 km
Date: 2018.06.28
Time: 12:19:53
Part No SW: 5K0 953 507 AJ HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KHF000DD
Coding: 589A140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 78A9162D725FBE774A8-802C
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H08 0010
Serial number: 0085037
Part No SW: 5K6 920 972 C HW: 5K6 920 972 C
Component: KOMBI H03 0607
Coding: 270F01
VCID: 3635D81538CB8807984-8062
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 020911F1001578
Coding: 350000
VCID: 3537DF19254D831F91E-8060
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223REJ6N06
VCID: 7EA500355CFB8047004-802A
Component: IMMO H03 0607
VCID: 6A8D3C653CF31CE7CCC-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660800500
VCID: 290F0369F9F5D7FF056-807C
Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
Component: Tuer-SG 009 2103
Coding: 0001076
VCID: 372BD5113341710F832-8062
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 74 3201
Revision: 00H20000
VCID: 3431E21D22379A17A60-8060
01316 - ABS Control Module
Fault Status: 00101101
Fault Frequency: 11
Reset counter: 52
Mileage: 127174 km
Date: 2012.11.29
Time: 20:30:15
Voltage: 13.50 V
DU
Temperature: 39.0°C
RPM: 1830 /min
Speed: 15.0 km/h
Speed: 15.0 km/h
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2117
Coding: 0001076
VCID: 323DE405D8239427B4C-8066
Part No SW: 1K0 035 164 C HW: 1K0 035 164 C
Component: LOW NAR SDARS H02 0004
Revision: -----03S Serial number: VWZ4Z6L3179074
Coding: 01000400040005
VCID: 221D144584C304A744C-8076
Reset counter: 129
Mileage: 118819 km
Date: 2012.05.03
Time: 17:58:59
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660754150
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270B0551EF61E18F132-8072
End----------(Elapsed Time: 01:01, VBatt start/end: 12.2V/12.2V)-----------
