Results 1 to 10 of 14
Thread: 2018 Alltrack counter blink with DRLs tweak worked
    Verified VCDS User shwagondawheels's Avatar
    Jul 2018
    I used DV52s instructions and spread sheet (I could not hyperlink the spread sheet) Even with LEDs this worked great and should defiantly catch other driver's attention in the daytime.
    VCDS Tweak Instructions: Counter Blinking DRLs - Halogen Headlights (worked with the LEDs on a 2018 Alltrack)
    1.Select 09 - Central Electr control module
    2.Select Security Access - 16 from the "Open Controller" screen
    3.Enter the magic number 31347 and return to the "Open Controller" screen
    4.Select Adaptation - 10 from the "Open Controller" screen
    5.From the pull-down button find the adaptation channels listed below
    6.Change the two Leuchte channels to the values below
    1.TIP: use the "search" facility on the latest RT software to find the two channels listed below as follows:
    •Enter LB4 into the search box to find the Left Hand DRL channel
    •Enter RB32 into the search box to find the Right Hand DRL channel
    If you want the DRLs to counter blink with the turn signal, change to these the settings
    •( 8 )-Leuchte4TFL LB4-Lichtfunktion C 4 to Blinken links Hellphase
    •( 8 )-Leuchte5 TFL RB32-Lichtfunktion C 5 to Blinken rechts Hellphase
    If you want the DRLs to blink in unison with the turn signal, change to these the settings
    •( 8 )-Leuchte4TFL LB4-Lichtfunktion C 4 to Blinken links Dunkelphase
    •( 8 )-Leuchte5 TFL RB32-Lichtfunktion C 5 to Blinken rechts Dunkelphase
    Video with the caution lights on with DRLs for demo.
    Jul 2018
    I also would like to do the five brake light mod to this car but I am having trouble finding the adaptation channel settings someone else has already figured out for led tail lights.
    Here it the adaptation map for the tail lights only of his 2018 Alltrack. Tring to keep it short and sweet for now that is.
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,43 - allgemeine LED ,16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,43 - allgemeine LED ,16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    He has these tail lights just like quailallstar on here does.
    ^^^ try this:
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 and
    Change to 100 (from 127)
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 and
    Change to Brake light (from not active)
    PS Interesting settings for the inner lights - they are programmed for Parking lights and they have an illumination value of 127 (Max illumination). If you implement my suggestion, the inner lights will also illuminate to the same value when the brake pedal is pressed. So a car traveling at the rear will see no difference between Parking lights and brake lights for the inner lamps (of course the outer Brake lights and the 3rd Brake light will illuminate when the pedal is pressed). On factory programmed fittings there is a difference in illumination level when the one lamp operates as both brake and parking light function -this provides a differentiation in lighting function for the two states for vehicles traveling behind. If you want this "factory" lighting effect, please ask
  4. Likes shwagondawheels liked this post
    Jul 2018
    I thought that was strange as well. I'll give this a try next time I'm with the car and post a video of before and after.
    Along with those changes to get the outer and inner lights to blink together as well for either turn signal won't I have to change
    To Blinken links Hellphase (from Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht))
    Thanks!
    Jul 2018
    Actually I may be wrong about my suggestion. I think that whole lower clear strip is it's own light for the turn signal. I need to spend more time with the car but it's not mine and in my driveway to play with whenever I want.
    Quote Originally Posted by shwagondawheels View Post
    Thanks!
    hmm........ Alas leuchte programming ain't that easy where the blinken-command is used. You need to "decouple" the hellphase-command with the dunklephase-command before you add another light function because of the enforced priority order of the Alpha-channels (yeah I know - WTF does this mean? It's secret geek-speak understood only by the wizened elves @ VAG HQ )
    This is how I suggest that you do it:
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 > minimize
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 > maximize
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 > maximize
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 > 100
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 > 0
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 > 127
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 > 0
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 > 29
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 > 0A
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 > 43 - allgemeine LED
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 > Always
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 > Brake light
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 > Blinken links Hellphase
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 > Blinken links Dunkelphase
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 > not active
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 > Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 > not active
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 > not active
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 > not active
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 > minimize
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 > maximize
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 > maximize
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 > 100
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 > 0
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 > 127
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 > 0
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 > 2A
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 > 1A
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 > 43 - allgemeine LED
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 > Always
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 > Brake light
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 > Blinken links Hellphase
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 > Blinken links Dunkelphase
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 > not active
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 > Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 > not active
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 > not active
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 > not active
    My hypothesis is that with the above changes, the inner LED will replicate the outer LED plus the inner LED will also illuminate as a Parking light. If you want to dim the parking light function to distinguish it from the Brake light function - lower the 2 x settings that I have bolded blue (I suggest something like 50%)
  8. Likes Uwe liked this post
    Jul 2018
    chicago, usa
    now that's really cool, wonder if it could be done on my a3? i posted that question in that thread.
    dp
    just living the dream
    chicago, usa
  10. #8
    Quote Originally Posted by dhpress1 View Post
    dhpress: yes, I've often contemplated that very same question - only joking
    Seriously, the trick to the application of the above suggestion to any MQB platform vehicle is whether the inner/outer tail lights have the factory settings in post #2 above. If the answer is "yes" - it's a good sign
  11. Likes Uwe, dhpress1 liked this post
  12. #9
    Jul 2018
    chicago, usa
    Didn't I post all that stuff somewhere? LoL....
    dp
    chicago, usa
  13. #10
    Jul 2018
    I sounds like you may be spot on. When I attempt this just to verify it works and to take less of my time backtracking if I mess up or something. It wont hurt anything to just do all the changes to one inner tail light then do a function check while I visually compare the old setting to the new ones?
