Results 1 to 3 of 3
Thread: touran security codes
    Pirate
    Jun 2018
    hi i have a 2004 touran 1.9pd that i cannot gain accsess to the steering angle sensor to reset, nor can i get the security code to work on the dash, i have tried also on another 2004 touran and cannot gain entry, keeps coming up security code rejected.
    does anyone have any ideas?.
    I only need to look at the dash as i tried to upgrade from poverty spec to fuel computer version due to a control cumputer failure in the poverty spec one,, but the fuel gauge is programmed differntly or so it seems as the new dash will not register the fuel level nor read the resistance, but the poverty spec works fine?
    Thanks.
    here is a scan
    Getting help on this forum requires the use of a legitimate VCDS system.
    The are available directly from us:
    http://www.ross-tech.com/distributors.php#uk
    Let us know via PM if/when you get one so we can adjust your forum status.
    Hayes 666 lets be friends and all play in the same sand box of evil.
    Satan indeed resides here are you related?
    http://forums.ross-tech.com/member.php?666-Beelzebub
