I am looking to to be able to turn off the DRL'S through the MMI, does anyone know if this is possible . I have tried the various module but cannot find the option. i have attached a scan. thanks in advance.
Wednesday,23,May,2018,10:11:00:49916
VCDS Version: 18.2.0.3 (x64)
Dealer/Shop Name: SVS
VIN: WAUZZZF45JA097412 License Plate:
Mileage: 222km-137mi Repair Order:
Chassis Type F4-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 22 2B 42 44 46 52 5F 80 81 A5 BB
BC
VIN: WAUZZZF45JA097412 Mileage: 222km-137miles
46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
80-Batt. reg. aux. accum. -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DDWA) Labels: None
Part No SW: 8W0 906 259 K HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0005
Revision: --H15---
Coding: 0A6500322326050B34082000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259K 001008
ROD: EV_ECM20TFS0208W0906259K.rod
VCID: 49994356E87BFE0C8F-801C
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 80A 927 155 BE HW: 0CJ 927 156
Component: 0CJ 20TFSIRdW H05 0003
Revision: --H05--- Serial number: 0000000132
Shop #: WSC 05761 780 00200
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU48.rod
VCID: 6DD1D7C6BC53022CC3-8038
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041170296002077
Part No SW: 8W0 907 379 K HW: 8W0 907 379 J
Component: ESP9 Plus H10 0766
Coding: 14AA40992CAB0A9D11A24892207F5292F4A5D2280234508812044A492FA54B
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 4D9177461C13E22CA3-8018
420352 - TPMS Warning; Front Left Tire
C1054 00 [175] - Pressure too Low
Mileage: 181 km
Date: 2018.05.22
Time: 17:21:44
416768 - TPMS Warning; Front Right Tire
C1056 00 [175] - Pressure too Low
Mileage: 181 km
Date: 2018.05.22
Time: 17:21:44
420096 - TPMS Warning; Rear Left Tire
C1058 00 [175] - Pressure too Low
Mileage: 181 km
Date: 2018.05.22
Time: 17:21:44
417024 - TPMS Warning; Rear Right Tire
C105A 00 [175] - Pressure too Low
Mileage: 181 km
Date: 2018.05.22
Time: 17:21:44
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H55 0210
Coding: 140900095544440D02000100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44875262CF5923647C-8010
Subsystem 1 - Part No SW: 4M2 820 021 B HW: 4M2 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000001932715
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 312119C800PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501143E11800CD051587141BAC80F9110B3108000000000000000020001A810A450122025601
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_BCM1BOSCHAU736 018006
ROD: EV_BCM1BOSCHAU736_018_AU49.rod
VCID: 020B947A95CDED540E-8056
Subsystem 1 - Part No SW: 8W2 955 119 HW: 8V2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 171009 043 0813
Serial number: 89425300401728202972
Coding: 5BC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 20867372X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 14 08 2017 01082546
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE105091723610404
Coding: 230000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00567100
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000188796002
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0107
Serial number: 003UP00A00UC
Coding: AACCF0C00CA00000585400F3D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 4C977A42E709EB24B4-8018
Subsystem 1 - Part No SW: ----------- HW: 442 061 910 17
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y00AF25B69E1617E
Subsystem 2 - Part No SW: ----------- HW: 442 062 010 17
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y00B9258C232F524
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 310 17
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700C92839F53823G
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 310 17
Component: SideSensor_Pr 1C7 0148
Serial number: 3527700C72839F54808J
Subsystem 5 - Part No SW: ----------- HW: 442 0C1 207 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500B12665760D354
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C1 207 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500AD2665765217A
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 442 0C1 705 17
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500AB2624FF512CG
Subsystem 8 - Part No SW: ----------- HW: 442 432 410 17
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00C724C3A72F10H
Subsystem 9 - Part No SW: ----------- HW: 442 432 410 17
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00A5263F3B3D0BP
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76E3F8AAC905C1F432-8022
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H18 0371
Coding: 25A451D0A88006000123E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001027
ROD: EV_DashBoardAU736_AU49.rod
VCID: 4385517ECA57245C45-8016
Part No SW: 8W5 907 468 F HW: 8W5 907 468 E
Component: Gateway H42 0123
Revision: 7A000001 Serial number: 0187A826317B11
Coding: 0201000100208640298700000059001248380007100000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491.rod
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20171106160834 22371
Subsystem 2 - Part No SW: 8W0 915 181 A HW: 8W0 915 181 A
Serial number: 8012025604
8519683 - Energy Management Active
U140B 00 [008] - -
Reset counter: 43
Mileage: 84 km
Date: 2018.05.17
Time: 08:04:55
EM_vehicle_state: 00 00
Static current shutdown level: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
8531970 - Quiescent Current
U1406 00 [009] - Too High
Fault Frequency: 12
Reset counter: 3
Mileage: 84 km
Date: 2018.05.10
Time: 14:19:16
Total static current-current total quiescent current: 105 mA
Total static current-Total time quiescent current exceeded: 1.0 H
Address 22: AWD (J492) Labels:* None
Part No SW: 8W0 927 755 A HW: 0CJ 927 749
Component: B9_DL3_N_SD6H18 0005
Serial number: 1718338099
Coding: 110C0000
ASAM Dataset: EV_AWDCQUOD31 001048
ROD: EV_AWDCQUOD31.rod
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 17000281345009
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 326B04BA65ED9DD4DE-8066
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 8W0 959 593 H HW: 8W0 959 593 F
Component: TSG FS 005 0125
Serial number: 0000287279901
Coding: 001F8A214001000000001082
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 4FAD6D4E161FD03CD1-801A
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 09000380808000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 428B547AD54D2D544E-8016
Address 46: Central Conv.
Interface not compatible.
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 8W0 959 592 H HW: 8W0 959 592 F
Component: TSG BFS 005 0125
Serial number: 0000286863448
Coding: 001F8A214001000000001080
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 4E93704A1115D934DA-801A
196660 - Motor for Window Regulator
B1487 54 [008] - Missing Calibration / Basic Setting
Reset counter: 43
Mileage: 84 km
Date: 2018.04.23
Time: 14:07:03
Part No SW: 8W5 035 035 B HW: 8W5 035 035
Component: MU-P-LND-EU 034 1177
Serial number: A829K0HB043491
Coding: 01940101FF0A000053111101000A00332F0002E701700100DE
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 366338AA898581F4F2-8062
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 8W2 919 605 HW: 8W2 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9HBK00PM8
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK110101700020116
Component: Gracenote2 --- 1016
Address 80: Batt. reg. aux. accum.
Address 81: Gear Shift (J587) Labels: None
Part No SW: 8W2 713 041 G HW: 8W2 713 041 J
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 17102344560103
ASAM Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 387F369283917784E0-806C
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 8W0 907 217 C HW: 8W0 907 217 C
Component: BVS H17 0050
Coding: 0404090100000403024023A0A50000FC00F0C020C000
ROD: EV_BVSMLBevKOSTAAU736.rod
VCID: 3C772A82B7A95BA404-8068
Part No SW: 8W0 959 595 H HW: 8W0 959 595 F
Component: TSG HFS 005 0125
Serial number: 0000286621520
Coding: 000F88200001000000001080
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 51A96B36002BC6CCC7-8004
Component: TSG HBFS 005 0125
Serial number: 0000286621521
ROD: EV_DCU2RearPasseMAXHCONT.rod
End---------------------(Elapsed Time: 05:13, Deb=2)-----------------------
