Results 1 to 7 of 7
Thread: Headlight Out Error When Using LEDs
    Jul 2018
    I have a 2003 VW Jetta wagon with LED headlights. This is the MK4/ALH model/engine. The dash throws an error of headlights not working with the symbol blinking. This prevents me from setting a speed on cruise control. I have to turn off the lights to set cruise control. Is there a way to disable this headlamp check/error with VCDS? Or is my only option to try and find a different way to wire my lights?
    I've thought about installing load resistors hooked up to a relay so I can flick them on to correct the error when I want to set cruise control instead of turning off the lights, which probably freaks out other nearby drivers every time I do it. But this is a last resort tactic if I can't find a better solution.
    I don't think there's any way to change that on an Mk.4, but please post an Auto-Scan so people can see exactly what modules are installed in your car.
    Jul 2018
    Sunday,08,July,2018,15:18:33:45815
    VCDS Version: 18.2.1.5 (x64)  HEX-NET CB: 0.4411.4
    VIN: WVWSP61J23W493678   License Plate: DUDA
    Mileage: 196170km-121894mi   Repair Order:
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: WVWSP61J23W493678   Mileage: 196170km-121894miles
    Address 01: Engine        Labels: 038-906-012-AGR.clb
       Part No: 038 906 012 GN
       Component: RCS4MP  EDC G520SG  4308
       Coding: 00002
       Shop #: WSC 00777
       VCID: E288D35B6CFDC654D2-4B3C
    19561 - Valve for Intake Manifold Flap (N239)
                P3105 - 35-10 - Open or Short to Ground - Intermittent
    16955 - Brake Switch (F)
                P0571 - 35-10 - Implausible Signal - Intermittent
    17911 - Load Signal from Alternator Term. DF
                P1503 - 35-10 - Implausible Signal - Intermittent
       Part No: 1C0 907 379 M
       Coding: 0019458
       Shop #: WSC 01266 785 00200
       VCID: B4246503D68918E470-5184
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
       Part No: 1C0 909 605 F
       Component: 03 AIRBAG VW61 0202 0003
       Coding: 12339
       Shop #: WSC 01266
       VCID: A71E824F475F637CC5-5160
    00532 - Supply Voltage B+
       Part No: 1J0 920 906 L
       Component: KOMBI+WEGFAHRSP VDO V11
       Coding: 07232
       VCID: B12A6C17799B2DCC1B-5160
       WVWSP61J23W493678     VWZ7Z0C6820513
    7 Faults Found:
    01176 - Key
    01177 - Engine Control Unit
                64-10 - Not Currently Testable - Intermittent
    01316 - ABS Control Module
                49-00 - No Communications
                80-10 - Single-Wire Operation - Intermittent
    01304 - Radio
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 01266
       VCID: F0ACA913B21164C454-5160
    01304 - Radio
       Part No: 1C0 959 799 C
       Component: 8A Komfortgerát HLO 0003
       Coding: 00258
       Shop #: WSC 01266
       VCID: B73E520F97FFF3FC55-4B1E
       Component: 8A Tőrsteuer.FS KLO 0009
       Component: 8A Tőrsteuer.BF KLO 0009
       Component: 8A Tőrsteuer.HL KLO 0009
       Component: 8A Tőrsteuer.HR KLO 0009
    00913 - Window Regulator Switch; Front Right Driver (E81)
    End----(Elapsed Time: 05:12, VBatt start/end: 12.0V/11.8V. VIgn 11.8V)-----
  4. Likes Uwe liked this post
    Yeah.... The lights in that car are not computer-controlled. I'm not sure how it does bulb-out checks...
    Jul 2018
    I'll ask around on some other forums and see. I'm sure there's a non-resistor solution. Thanks for checking!
    Verified VCDS User shwagondawheels's Avatar
    Jul 2018
    Dang MK4s can't do cool stuff...
    Quote Originally Posted by shwagondawheels View Post
    The design of the systems in 'em is from the mid-to-late 1990s.
