Help Passat cc Abs Problems
Retrofit
C?ID=332539
Hi everyone on my passat cc 2013, the ABS are making errors and causes lots of problems. i did buy a set of new abs sensors but the same errors keeps coming up. anyone that could help me resolve this?
Saturday,07,July,2018,11:53:35:51522
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
VIN: WVWZZZ3CZDE548345   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 4F 52 53 55
          56 61 62 69 72 77
VIN: WVWZZZ3CZDE548345   Mileage: 132660km-82431miles
Address 01: Engine (J623-CTHD)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 026 BP    HW: 03C 907 309 M
   Component: 1.4l R4 TSI   H02 5064
   Revision: LKH02---    Serial number: 00000000000000
   Coding: 00250032006401000000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM14TSI01103C906026BP 001003
   ROD: EV_ECM14TSI_VW46.rod
   VCID: 6FAE21F7B6544E3CCE-803A
4327 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 132661 km
                    Date: 2018.07.07
                    Time: 11:37:18
                    Coolant temperature: 78 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 12.156 V
                    Cruise Control System (CCS): status-Bits 0-7: 11110100
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 00000000
                    Cruise control switch-off: reversible-Bits 0-7: 11111111
                    Cruise control switch-off: irreversible-Bits 0-7: 11111111
                    Acceleration: 0.000 m/s²
4675 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [039] - -
          [ABS brake control moduleRead out DTC]
                    Mileage: 132661 km
                    Date: 2018.07.07
                    Time: 11:37:18
Readiness: 1110 0101
   Part No SW: 0AM 300 058 P    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 4566
   Revision: 00043014    Serial number: CU501212045219
   Shop #: WSC 52922 001 1048576
   VCID: 3E30CCB369BEF7B415-806A
006279 - Wheel-Speed Signal from ABS Control Module
               P1887 - 000 - Implausible Signal
                    Reset counter: 10
                    Mileage: 132661 km
                    Date: 2018.07.07
                    Time: 11:49:43
   Part No SW: 3AA 614 109 AS    HW: 3AA 614 109 AS
   Component: J104   C2 450M VE3F 0030
   Revision: --H07---    Serial number: 00000006479656
   Coding: 0122225
   Shop #: WSC 05311 000 00000
   VCID: 7EB00CB3293E37B455-802A
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 63
                    Mileage: 132661 km
                    Date: 2018.07.07
                    Time: 11:44:52
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 156
                    Hex Value: 0x0000
                    Reset counter: 63
                    Mileage: 132661 km
                    Date: 2018.07.07
                    Time: 11:45:02
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 AG    HW: 3AA 907 044 AG
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010004849
   VCID: 75A2139FD40874EC04-8020
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 1465
   Revision: BD421001
   Coding: 0008000000000000008800809400A9642355008860220D20E484C72000C1
   Shop #: WSC 52928 001 104857
   VCID: 41CAB74FD840884C68-8014
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 161012  010 0604
   Serial number: 161012
   Coding: 00B795
   Component: RLFS  024 0042
   Serial number: Y12M12D04H14M21S44S1
   Coding: 0228DD
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0016
   Revision: --------    Serial number: 28261232002180
   Coding: 118104
   Shop #: WSC 00016 204 84156
   ASAM Dataset: EV_EPHVA18VW47X0000 001005
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3E30CCB3A1BEF7B415-806A
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000569699
   Coding: 0010000
   Shop #: WSC 05311 000 08193
   VCID: 383CDAAB4B9AC984DF-806C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 63
                    Mileage: 132661 km
                    Date: 2018.07.07
                    Time: 11:46:02
                    Count: 4
                    Reset counter: 63
                    Mileage: 132661 km
                    Date: 2018.07.07
                    Time: 11:46:02
                    Count: 4
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__70H VW10 HI   2118
   Revision: 25018000    Serial number: 003L7PR0AX85
   Coding: 0012360
   VCID: 7CB406BB3F2225A47B-8028
   Subsystem 1 - Serial number: 6332MTS652243172
   Subsystem 2 - Serial number: 6342MTS644783172
   Subsystem 3 - Serial number: 6351HTS6LQRKGBKR
   Subsystem 4 - Serial number: 6361HTS6TRDAIBKR
   Part No SW: 3C5 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20121130201143
   Coding: 2982A70000
   VCID: 71AA278FA06058CCD8-8024
   Coding: E20000
   Part No SW: 3C8 920 880 M    HW: 3C8 920 880 M
   Component: KOMBI         H05 0505
   Coding: 140E01
   Shop #: WSC 05314 115 12345
   VCID: 3620D493898E3FF4CD-8062
   Part No SW: 7N0 907 530 AJ    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1634
   Revision:   H51       Serial number: 271112F2003502
   Coding: 469006
   Shop #: WSC 05314 000 00000
   VCID: 78BC1AABCB1A09841F-802C
   Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
   Component:    IMMO         043 0404
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0555
   Revision: 12110009    Serial number: 0006147138
   Coding: 0200B7
   Shop #: WSC 05311 115 00000
   VCID: 6D923BFFBC58BC2CFC-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000003248683
   Coding: 010090
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.302 1202
   Revision: 1BH04737    Serial number: 00123380035301
   Coding: 0000258
   VCID: 3FCEB1B76EB4FEBC1E-806A
                    Fault Status: 11101101
                    Reset counter: 63
                    Mileage: 132661 km
                    Date: 2018.07.07
                    Time: 11:46:21
                    (no units): 4.0
                    Voltage: 12.10 V
   Component:    KSG PQ47 ELV 043 0638
   Coding: 00910A0001860E763604941570084F0B605800
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
   Component: EZE_2         H51 1634
   Coding: 00000008
   VCID: 6FAE21F7BE544E3CCE-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0555
   Revision: 14110009    Serial number: 0006127455
   Coding: 0200B6
   VCID: 6E903CF3B15E4734C5-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000003254118
   Coding: 010090
   Revision:   H19       Serial number: 00000000639214
   Coding: 0022167
   VCID: 3620D493418E3FF4CD-8062
                    Fault Status: 01111101
                    Reset counter: 63
                    Mileage: 132661 km
                    Date: 2018.07.07
                    Time: 11:37:15
                    Voltage: 12.10 V
                    Count: 104
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 B    HW: 6R0 907 357 A
   Component: LWR-ECU       005 0030
   Coding: 078A000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 393ADFAFB890D08C20-806C
13705985 - Databus
          U1123 00 [137] - Received Error Message
          [Fehlerwert im Signal BR3_Rad_kmh_HL]
                    Reset counter: 63
                    Mileage: 132661 km
                    Date: 2018.07.07
                    Time: 11:48:31
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: RCD310 EU     H03 5006
   Revision: -----07S    Serial number: VWZ4Z2M1411407
   Coding: 0500040004000F
   VCID: 72A82883AD6663D421-8026
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AJ
   Component: Batt.regelung H51 1634
   Coding: 032F7864
   VCID: 71AA278FA86058CCD8-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000001490733483
   Revision: 3A001001    Serial number: 00008030449361
   Coding: 4100000100000000
   VCID: 302CE28B63EA11C497-8064
   Part No SW: 5K0 035 730 F    HW: 5K0 035 730 F
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007662567764
   Coding: 0A10000000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 281C0AEB533A59044F-807C
End----------(Elapsed Time: 01:45, VBatt start/end: 12.1V/12.1V)-----------
I would start by making a log of the wheel speeds in MVB 001 of the ABS module, just to see what you can see.
Did you install the correct part number sensors, because these maybe phase/polarity created dependent!
FOD is suspect!
Retrofit
C?ID=332539
i did go in to basic settings and channel 001 didnt show any values in the blocks
Not Basic Settings. Measuring Blocks.
Retrofit
C?ID=332539
Thank you Uwe :-) i found out that LeftRear sensor didnt show any values. and i know suspect LeftRear sensor ring to cause the problem. i will change the part asap. and let you know if it worked.
What part number sensors did you install? :rolleyes:
Reluctor's indeed fail........
Retrofit
C?ID=332539
I dont have the part number right now, but i have changed every sensors all around and it didnt Help at leftrear side. I dont suspect the sensor atm.
No I am just saying to be advised it could be the wrong part number too so it costs no money to check.
Retrofit
C?ID=332539
After useing a volt-meter on the Rearleft side. It turns out that the wire to the sensor was bad, and after a Quick repair it finally works. Cleared all DTC's and the car has no faultcodes :-)
