Hi everyone on my passat cc 2013, the ABS are making errors and causes lots of problems. i did buy a set of new abs sensors but the same errors keeps coming up. anyone that could help me resolve this?
Saturday,07,July,2018,11:53:35:51522
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
VIN: WVWZZZ3CZDE548345 License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 4F 52 53 55
56 61 62 69 72 77
VIN: WVWZZZ3CZDE548345 Mileage: 132660km-82431miles
Address 01: Engine (J623-CTHD) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 026 BP HW: 03C 907 309 M
Component: 1.4l R4 TSI H02 5064
Revision: LKH02--- Serial number: 00000000000000
Coding: 00250032006401000000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM14TSI01103C906026BP 001003
ROD: EV_ECM14TSI_VW46.rod
VCID: 6FAE21F7B6544E3CCE-803A
4327 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 132661 km
Date: 2018.07.07
Time: 11:37:18
Coolant temperature: 78 °C
Intake air temperature: 41 °C
Voltage terminal 30: 12.156 V
Cruise Control System (CCS): status-Bits 0-7: 11110100
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 00000000
Cruise control switch-off: reversible-Bits 0-7: 11111111
Cruise control switch-off: irreversible-Bits 0-7: 11111111
Acceleration: 0.000 m/s²
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
[ABS brake control moduleRead out DTC]
Mileage: 132661 km
Date: 2018.07.07
Time: 11:37:18
Readiness: 1110 0101
Part No SW: 0AM 300 058 P HW: 0AM 927 769 D
Component: GSG DSG AG7 431 4566
Revision: 00043014 Serial number: CU501212045219
Shop #: WSC 52922 001 1048576
VCID: 3E30CCB369BEF7B415-806A
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal
Reset counter: 10
Mileage: 132661 km
Date: 2018.07.07
Time: 11:49:43
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AS HW: 3AA 614 109 AS
Component: J104 C2 450M VE3F 0030
Revision: --H07--- Serial number: 00000006479656
Coding: 0122225
Shop #: WSC 05311 000 00000
VCID: 7EB00CB3293E37B455-802A
03841 - RPM Sensor Rear Left: Incorrect Signal
Reset counter: 63
Mileage: 132661 km
Date: 2018.07.07
Time: 11:44:52
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 156
Hex Value: 0x0000
Reset counter: 63
Mileage: 132661 km
Date: 2018.07.07
Time: 11:45:02
Hex Value: 0x0000
Voltage: 12.00 V
Bin. Bits: 00011111
Count: 191
Hex Value: 0x0000
Part No SW: 3AA 907 044 AG HW: 3AA 907 044 AG
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0010004849
VCID: 75A2139FD40874EC04-8020
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
Component: BCM PQ47 H++ 421 1465
Revision: BD421001
Coding: 0008000000000000008800809400A9642355008860220D20E484C72000C1
Shop #: WSC 52928 001 104857
VCID: 41CAB74FD840884C68-8014
Subsystem 1 - Part No SW: 3C8 955 119 F HW: 3C8 955 119 F Labels: 1KX-955-119.CLB
Component: WWS464 161012 010 0604
Serial number: 161012
Coding: 00B795
Component: RLFS 024 0042
Serial number: Y12M12D04H14M21S44S1
Coding: 0228DD
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H06 0016
Revision: -------- Serial number: 28261232002180
Coding: 118104
Shop #: WSC 00016 204 84156
ASAM Dataset: EV_EPHVA18VW47X0000 001005
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3E30CCB3A1BEF7B415-806A
Address 13: Auto Dist. Reg Labels: 3AA-907-567.clb
Part No SW: 3AA 907 567 A HW: 3AA 907 567
Component: AC201 RDW A 036 0170
Revision: 00036000 Serial number: 00000000569699
Coding: 0010000
Shop #: WSC 05311 000 08193
VCID: 383CDAAB4B9AC984DF-806C
01316 - ABS Control Module
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 63
Mileage: 132661 km
Date: 2018.07.07
Time: 11:46:02
Count: 4
Reset counter: 63
Mileage: 132661 km
Date: 2018.07.07
Time: 11:46:02
Count: 4
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__70H VW10 HI 2118
Revision: 25018000 Serial number: 003L7PR0AX85
Coding: 0012360
VCID: 7CB406BB3F2225A47B-8028
Subsystem 1 - Serial number: 6332MTS652243172
Subsystem 2 - Serial number: 6342MTS644783172
Subsystem 3 - Serial number: 6351HTS6LQRKGBKR
Subsystem 4 - Serial number: 6361HTS6TRDAIBKR
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BM HW: 5K0 953 569 T
Revision: FF010041 Serial number: 20121130201143
Coding: 2982A70000
VCID: 71AA278FA06058CCD8-8024
Component: E221__MFL-TK6 H07 0022
Coding: E20000
Part No SW: 3C8 920 880 M HW: 3C8 920 880 M
Component: KOMBI H05 0505
Coding: 140E01
Shop #: WSC 05314 115 12345
VCID: 3620D493898E3FF4CD-8062
Part No SW: 7N0 907 530 AJ HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1634
Revision: H51 Serial number: 271112F2003502
Coding: 469006
Shop #: WSC 05314 000 00000
VCID: 78BC1AABCB1A09841F-802C
Part No SW: 3AA 959 433 B HW: 3AA 959 433 B
Component: IMMO 043 0404
Revision: 00043000 Serial number: VWZCZ000000000
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0555
Revision: 12110009 Serial number: 0006147138
Coding: 0200B7
Shop #: WSC 05311 115 00000
VCID: 6D923BFFBC58BC2CFC-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000003248683
Coding: 010090
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.302 1202
Revision: 1BH04737 Serial number: 00123380035301
Coding: 0000258
VCID: 3FCEB1B76EB4FEBC1E-806A
Fault Status: 11101101
Reset counter: 63
Mileage: 132661 km
Date: 2018.07.07
Time: 11:46:21
Term 15 On
(no units): 4.0
Voltage: 12.10 V
Component: KSG PQ47 ELV 043 0638
Coding: 00910A0001860E763604941570084F0B605800
Part No SW: 7N0 907 532 HW: 7N0 907 530 AJ
Component: EZE_2 H51 1634
Coding: 00000008
VCID: 6FAE21F7BE544E3CCE-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0004
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0555
Revision: 14110009 Serial number: 0006127455
Coding: 0200B6
VCID: 6E903CF3B15E4734C5-803A
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000003254118
Coding: 010090
Revision: H19 Serial number: 00000000639214
Coding: 0022167
VCID: 3620D493418E3FF4CD-8062
Fault Status: 01111101
Reset counter: 63
Mileage: 132661 km
Date: 2018.07.07
Time: 11:37:15
Voltage: 12.10 V
Count: 104
Hex Value: 0x1263
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 B HW: 6R0 907 357 A
Component: LWR-ECU 005 0030
Coding: 078A000001000000
ASAM Dataset: EV_HeadlRegulVWLWRCC 002004
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 393ADFAFB890D08C20-806C
13705985 - Databus
[Fehlerwert im Signal BR3_Rad_kmh_HL]
Reset counter: 63
Mileage: 132661 km
Date: 2018.07.07
Time: 11:48:31
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: RCD310 EU H03 5006
Revision: -----07S Serial number: VWZ4Z2M1411407
Coding: 0500040004000F
VCID: 72A82883AD6663D421-8026
Part No SW: 7N0 907 534 HW: 7N0 907 530 AJ
Component: Batt.regelung H51 1634
Coding: 032F7864
VCID: 71AA278FA86058CCD8-8024
Component: J367-BDM H07 0180
Serial number: 00000000001490733483
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030449361
Coding: 4100000100000000
VCID: 302CE28B63EA11C497-8064
Part No SW: 5K0 035 730 F HW: 5K0 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662567764
Coding: 0A10000000010110
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 281C0AEB533A59044F-807C
End----------(Elapsed Time: 01:45, VBatt start/end: 12.1V/12.1V)-----------
