Results 11 to 20 of 26
Thread: CFFB camshaft and crankshaft sync
    New User
    Jul 2018
    Uwe, thank you for the reply! I find this kind of measurement useful for monitoring the tooth-belt (aka timing belt) condition. With time belt gets stetched out and I could see that with my 1.9 PD TDI. I am hoping to find a way to inspect that on modern VAG CR TDI's as well.
    Changing the timing tooth belt on PD TDI's, it was very easy to install it 1-2 degrees off, and many people complained about rough idle and fuel economy. It is not just the injection timing, but also the physical intake and exhaust valves' timing, which cannot be compensated by the ECU, except for the actual PD injection timing.
    Btw, what is ENG106252 Synchronous angle for?
  2. #12
    Quote Originally Posted by Bambur View Post
    Good question. Unfortunately, VW does not bother to tell us these things.
  3. Likes Fredrick Awuor liked this post
  4. #13
    New User
    Jul 2018
    OK, no problem! I keep searching and will post here if I find it
  5. Likes Uwe, Fredrick Awuor liked this post
  6. #14
    New User
    Lithuania
    PD injectors are also electronically controlled.
    Valve timing in these TDIs (be it either PD or CR) is VERY important (as well as CR pump timing, opposed to what most people think/say).
    CR belt is very long (160 teeth) as opposed to PD belt (120 teeth).
    Besides in the TB path there are much more rollers and idlers (1 tensioner + 3 idlers on CR vs 1 tensioner + 1 idler on PD). Over time/miles they get worn (actually by 140k km all idlers except the large one have play and bearing noise) so free play is introduced. This impactis timing as well.
    The belt is prone to stretching, more or less, too. It's 25 mm wide, as opposed to PD which is 30 mm.
    And finally CRs have almost twice as long TB replacement intervals as PD had (120k km for early PDs and 210k km for some CRs).
    Removing TB cover to inspect the TB system is not that straight forward on CR as it's on PD - much more components will need to be removed.
    So monitoring the cam/crank sync angle makes sense.
    Answering OP's original question:
    try to find a measuring block with something as "start of synchronization" in it's name. I believe the engine must be running for that. However, if I remember correctly, the reading is a bit different than what you were used to see in PD engines (degrees between crank and cam).
  7. Likes Fredrick Awuor liked this post
  8. #15
    New User
    Oct 2018
    Hello All. Ive got the same engine, but I cannot find ENG106252 Synchronous angle in advanced measuring blocks? I seen on other various posts, engine codes like CAGA for e.g. allow this channel to be viewed, is their an alternative IDE I can view? Oh how I wish I was back on CAN, alas, efficiency allows it not.
  9. #16
    Quote Originally Posted by Mu81n View Post
    Hello All. I’ve got the same engine, but I cannot find ENG106252 Synchronous angle in advanced measuring blocks? I seen on other various posts, engine codes like CAGA for e.g. allow this channel to be viewed, is their an alternative IDE I can view? Oh how I wish I was back on CAN, alas, efficiency allows it not.
    Please post an Auto-Scan so we can see exactly what ECU you have and what ASAM data it uses.
  10. #17
    New User
    Oct 2018
    Apologies for the late reply. Please see below:
    Wednesday,06,March,2019,18:03:08:60391
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZ1KZAW419147   License Plate: SB10VEK
    Mileage: 217150km-134930mi   Repair Order:
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZAW419147   Mileage: 217150km-134930miles
       Part No SW: 03L 906 018     HW: 03L 907 309 R
       Component: R4 2.0l TDI   H21 9978
       Revision: 42H21---    Serial number: 00000000000000
       Coding: 00190012042500080000
       Shop #: WSC 52856 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018 003014
       ROD: EV_ECM20TDI01103L906018D.rod
       VCID: 67D82FEE9E8633727C-8032
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 163B400D09230003680C02E890200082340000
       VCID: 78FA7C92CB38AC8AE5-802C
       Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6DD45DC6BC7A192206-8038
       Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
       Component: BCM PQ35  M   103 0575
       Revision: 00103 AG
       Coding: 48180A3A9025F1C044080080000081E443010088524D8160648000200000
       VCID: 306A84B263C8B4CA6D-8064
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 27041  21  0512
       Coding: 009795
       Subsystem 2 - Part No: 1K8 951 171
       Subsystem 3 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRA79E0J
       Coding: 00003133
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3B70A39EB28E4792C8-806E
       Serial number: 3572MSME04670252ZZZJ
       Serial number: 3582MSME0C037452ZZZR
       Serial number: 3512QSME06125D17ZZZQ
       Serial number: 3522QSME22145D16ZZZQ
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Component: J0527           056 0111
       Coding: 0000532
       VCID: 78FA7C920B38AC8AE5-802C
       Subsystem 1 - Part No: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TK6   H06 0022
       Coding: 00000226
       Part No SW: 5K0 920 970 N    HW: 5K0 920 970 N
       Component: KOMBI         H03 0305
       Coding: 470B00
       VCID: 397CB996B8B27582DA-806C
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H07 0112
       Revision:   H07 01    Serial number: 020510F1011493
       Coding: E9807F06000212000003
       VCID: 69DC29D6409205026A-803C
       Component: IMMO          H03 0305
       VCID: 6ADE56DA8D940E1A63-803E
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0090
       Revision: A1001003    Serial number: 7667994532
       VCID: 264662EA510CEA7A87-8072
       Component: Tuer-SG         009 2114
       Coding: 0000692
       VCID: 316C81B6A8C2BDC262-8064
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       Coding: 0000692
       VCID: 326E8EBAADC486DA1B-8066
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: RCD310 EU     H11 5032
       Revision: -----01S    Serial number: VWZ4Z2K1207605
       Coding: 0100040004
       VCID: 65C425E66C8A21624E-8030
    00856 - Radio Antenna
                        Fault Status: 00100111
                        Reset counter: 30
                        Mileage: 202480 km
                        Date: 2013.03.03
                        Time: 07:52:28
                        Fault Status: 00101011
                        Fault Frequency: 13
                        Reset counter: 13
                        Mileage: 215435 km
                        Date: 2013.07.09
                        Time: 14:05:47
                        Fault Frequency: 14
                        Reset counter: 13
                        Reset counter: 10
                        Mileage: 215996 km
                        Date: 2013.07.15
                        Time: 14:25:38
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 346288A257D088EA09-8060
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0000144
       VCID: 3564B5A65CAA91E23E-8060
    End-------------------------(Elapsed Time: 02:16)--------------------------
    Wednesday,06,March,2019,18:24:06:60391
  11. #18
    New User
    Oct 2018
    I wonder if the below is of any use for monitoring, especially the camshaft position, start less end = sum of angle? Or along those line:
    IDE00021 Engine speed 777 /min
    IDE00351 Main injection: start of activation -4.00
    IDE00365 Injection amount deviation cylinder 1 -0.36 mg/stroke
    IDE00366 Injection amount deviation cylinder 2 0.23 mg/stroke
    IDE00367 Injection amount deviation cylinder 3 0.50 mg/stroke
    IDE00368 Injection amount deviation cylinder 4 -0.37 mg/stroke
    IDE00394 Camshaft position: start of phase window 122.78
    IDE00395 Camshaft position: end of phase window 250.84
  12. #19
    I don't see it in the data for that ECU either, sorry.
  13. #20
    New User
    Oct 2018
    Thank you for the swift response. Tis seems I am doomed. I don’t see why VAG can’t do this across the board, where timing/crank-cam correlation can be seen via VCDS. Unfortunately, the garage that did the initial work failed epically (wrong crank locking pin!) Although rectified, I suspect my fuel pump & cam isn’t as per spec (good enough to run & not flag any faults-is that even possible?), to elaborate, as one of the posters mentioned on this site (https://forums.ross-tech.com/showthr...-Cambelt/page2), when the pin is locked for the fuel pump, this is the optimum level for the pump to operate. Which I assume will also lead to better fuel efficiency.
