Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: CFFB camshaft and crankshaft sync
  1. #21
    New User
    Nov 2019
    I have a similar engine and consider getting VCDS to check the timing as well as I replaced the timing belt and want to make a double-check.
    Is it the ECU not providing this data or it is VCDS that's currently not able to read it?
    Would mine also miss that measurement :ENG106252 Synchronous angle
    I have an autoscan from the time when I borrowed a cable from a colleague , but I don't have access to the cable any more to check if that field is there or not.
    I guess these things are described in the rod files, but no idea if they get updated.
    Adresse 01: Motorelektronik (J623-CFGB) Labeldatei:. DRV\03L-906-018-CFF.clb
    Teilenummer SW: 03L 906 018 RS HW: 03L 906 018 MH
    Bauteil: R4 2,0L EDC H28 5357
    Revision: 41H28--- Seriennummer:
    Codierung: 001D003A042601080000
    Betriebsnr.: WSC 33361 790 00999
    ASAM Datensatz: EV_ECM20TDI01103L906018RS 003003
    ROD: EV_ECM20TDI01103L906018RQ.rod
    VCID: 0C13C296A761AF26FD-8058
    Thanks
    Montag,08,Januar,2018,19:39:10:11000
    VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
    VCDS Version: MFT 17.8.1.0
    Datenstand: 20171211 DS276.6
    www.Diagnosetool.de
    Fahrzeug-Ident.-Nr.: TMBLF93TXE9030809   KFZ-Kennzeichen: FMV2220
    Kilometerstand: 101580km   Reparaturauftrag: vva
    Fahrzeugtyp: 3T-SK46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 18 19 22 25 2E 36 37 42 44 46 47
              4F 52 55 56 61 62 69 6D 72 77
    Fahrzeug-Ident.-Nr.: TMBLF93TXE9030809   Kilometerstand: 101580km
    03-Bremsenelektronik -- Status: i.O. 0000
    04-Lenkwinkelsensor -- Status: i.O. 0000
    09-Zentralelektrik -- Status: Fehler 0010
    16-Lenkradelektronik -- Status: i.O. 0000
    18-Standheizung -- Status: Fehler 0010
    19-Diagnoseinterface -- Status: i.O. 0000
    22-Allrad -- Status: i.O. 0000
    25-Wegfahrsperre -- Status: i.O. 0000
    2E-Media Player 3 -- Status: i.O. 0000
    36-Sitzverst. Fahr. -- Status: i.O. 0000
    37-Navigation -- Status: i.O. 0000
    42-Türelektr. Fahrer -- Status: i.O. 0000
    44-Lenkhilfe -- Status: i.O. 0000
    46-Komfortsystem -- Status: i.O. 0000
    47-Soundsystem -- Status: i.O. 0000
    4F-Zentralelektrik II -- Status: i.O. 0000
    52-Türelektr. Beifahr. -- Status: i.O. 0000
    55-Leuchtweitenreg. -- Status: i.O. 0000
    56-Radio -- Status: i.O. 0000
    61-Batterieregelung -- Status: i.O. 0000
    62-Türelektr. hi. li. -- Status: i.O. 0000
    69-Anhänger -- Status: i.O. 0000
    6D-Heckklappe -- Status: i.O. 0000
    72-Türelektr. hi. re. -- Status: i.O. 0000
    77-Telefon -- Status: i.O. 0000
    Adresse 02: Getriebe        Labeldatei: DRV\02E-927-770.clb
       Teilenummer SW: 02E 300 016 D    HW: 02E 927 770 AL
       Bauteil: GSG DSG AG6     521 4013
       Revision: 05652104    Seriennummer: 00001310182007
       Codierung: 0000020
       Betriebsnr.: WSC 33361 790 00085
       VCID: 1525A7F23CAB6EEE52-8040
    Adresse 03: Bremsenelektronik (J104)       Labeldatei:. DRV\1K0-907-379-60EC1F.clb
       Teilenummer SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
       Bauteil: ESP MK60EC1   H31 0152
       Revision: 00H31001
       Codierung: 843D6016192500FA211306E498220052350150
       VCID: 7DF59F52E4DB96AEFA-8028
    Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei:| DRV\5K0-907-044.clb
       Teilenummer SW: 3T0 907 044 CG    HW: 3T0 907 044 CG
       Bauteil: Climatronic   H19 0709
       Revision: 00001009
       Codierung: 0010000003
       ASAM Datensatz: EV_Climatronic A01010
       ROD: EV_ClimaAutoBasis_SK35.rod
       VCID: 79FD8B42F8F3AA8ED6-802C
    Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\1K0-937-08x-09.clb
       Teilenummer SW: 1K0 937 087 AN    HW: 1K0 937 087 AN
       Bauteil: BCM PQ35  H+  112 0771
       Revision: AF112771
       Codierung: 40190ABBE80508C0400800C0710089EC4B7000AE636DA5608081C7040041
       Subsystem 1 - Teilenummer: 3T1 955 119 B  Labeldatei: DRV\1KX-955-119.CLB
       Bauteil: Wischer 30101  26  0700
       Codierung: 00D7B7
       Subsystem 2 - Teilenummer: 1K0 955 559 AH  Labeldatei: DRV\1K0-955-559-AG.CLB
       Bauteil: RLS 251013 05  54  0403
       Codierung: 0630ED
    1 Fehler gefunden:
    03821 - Entriegelung links für Laderaumabdeckung
                012 - elektrischer Fehler im Stromkreis
                 Umgebungsbedingungen:
                        Fehlerstatus: 01101100
                        Fehlerpriorität: 5
                        Fehlerhäufigkeit: 10
                        Verlernzähler: 39
                        Kilometerstand: 93138 km
                        Zeitangabe: 0
                        Datum: 2017.08.16
                        Zeit: 06:18:07
                            Kl.15 AUS
                        Spannung: 12.15 V
                            aus
                            ein
                            Kl.50 AUS
                            aus
                            aus
    Adresse 10: Einparkhilfe 2 (J791)       Labeldatei:| DRV\3T0-919-475-V2.clb
       Teilenummer SW: 3T0 919 475 D    HW: 4H0 919 475 E
       Bauteil: PARKHILFE PLA H06 0005
       Revision: --------    Seriennummer: 56231328402509
       Codierung: 158302
       Betriebsnr.: WSC 56862 002 1048576
       ASAM Datensatz: EV_EPHVA2CAS46X0000 001003
       ROD: EV_EPHVA2CAS46X0000_001.rod
       VCID: 3E77585EA15D4DB6A3-806A
    Adresse 15: Airbag        Labeldatei: DRV\5N0-959-655.lbl
       Teilenummer SW: 3T0 959 655 D    HW: 3T0 959 655 D
       Bauteil: J234__LDA VW10 HI   2518
       Revision: 25019000    Seriennummer: 003LEPN0T4LB
       Codierung: 0017473
       VCID: 428F2CAE1DA52956C7-8016
       Subsystem 1 - Seriennummer: 6332MTS632132903
       Subsystem 2 - Seriennummer: 6342MTS632142903
       Subsystem 3 - Seriennummer: 6351HTS6FSRLECKJ
       Subsystem 4 - Seriennummer: 6361HTS6P5LLECKR
       Subsystem 5 - Seriennummer: 63727TS6VMAUDCKJ
       Subsystem 6 - Seriennummer: 00000000000000000
    Adresse 16: Lenkradelektronik (J527)       Labeldatei:| DRV\5K0-953-569.clb
       Teilenummer SW: 5K0 953 521 DD    HW: 5K0 953 569 AE
       Bauteil: LENKS.MODUL   016 0140
       Revision: FF010042    Seriennummer: 20131029200907
       Codierung: 1892140000
       ASAM Datensatz: EV_SMLSNGVOLWSXS A01004
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 71EDB362A083E2CE6E-8024
       Steuergerät für Multifunktionslenkrad:
       Subsystem 1 - Teilenummer SW: 5E0 919 719 G    HW: 5E0 919 719 G
       Bauteil: E221__MFL-PR6  H04 0120
       Codierung: 830000
    Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:| DRV\5K0-920-xxx-17.clb
       Teilenummer SW: 3T1 920 841 M    HW: 3T1 920 841 M
       Bauteil: KOMBI         H07 0811
       Codierung: 111E01
       ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04721
       VCID: 3D755F52AC5B56AEBA-8068
    Adresse 18: Standheizung        Labeldatei: DRV\1K0-815-007.clb
       Teilenummer: 7N0 963 272 C
       Bauteil: Standheizer     044 4840
       Revision: 00044000    Seriennummer: 09024302000000
       Codierung: 0021032
       Betriebsnr.: WSC 00192 002 1048576
       VCID: 356547725C6B8EEE72-8060
    3 Fehlercodes gefunden:
    00664 - Kraftstoffvorratsanzeige
                002 - unterer Grenzwert unterschritten - Sporadisch
                        Fehlerstatus: 00100010
                        Fehlerpriorität: 7
                        Fehlerhäufigkeit: 5
                        Verlernzähler: 88
                        Kilometerstand: 100953 km
                        Zeitangabe: 0
                        Datum: 2017.12.19
                        Zeit: 07:14:12
    01410 - Heizgerät überhitzt
                        Fehlerstatus: 01100000
                        Fehlerpriorität: 2
                        Fehlerhäufigkeit: 1
                        Verlernzähler: 64
                        Zeitangabe: 0
                            Nachlauf
                        Temperatur: 148.0°C
                        Temperatur: -48.0°C
                        Spannung: 11.71 V
    02251 - Heizgerät verriegelt
                        Fehlerpriorität: 2
                        Fehlerhäufigkeit: 1
                        Verlernzähler: 64
                        Zeitangabe: 0
    Adresse 19: Diagnoseinterface (J533)       Labeldatei:. DRV\7N0-907-530-V2.clb
       Teilenummer SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
       Bauteil: J533  Gateway H55 1642
       Revision:   H55       Seriennummer: 250913F1003287
       Codierung: 359302
       VCID: 7BF1914AFACF989EC4-802E
    Adresse 22: Allrad        Labeldatei: DRV\0AY-907-554-V1.clb
       Teilenummer SW: 0BR 907 554 C    HW: 0BR 907 554 C
       Bauteil: Haldex 4Motion      3018
       Codierung: 0000005
       VCID: 458537B20C8B1E6EE2-8010
    Adresse 25: Wegfahrsperre (J334)       Labeldatei:| DRV\5K0-920-xxx-25.clb
       Teilenummer SW: 5K0 953 234     HW: 5K0 953 234
       Bauteil: IMMO          H07 0811
       Codierung: 000000
       ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03710
       VCID: 6ADFA40E8D5511162F-803E
    Adresse 2E: Media Player 3 (J650)       Labeldatei:. DRV\5N0-035-342.lbl
       Teilenummer SW: 5N0 035 342 G    HW: 5N0 035 342 G
       Bauteil: SG EXT.PLAYER H19 0770
       Revision: A1001003    Seriennummer: 7665393234
       Codierung: 010100
       VCID: 2B51610A4A2FC81E14-807E
    Adresse 36: Sitzverst. Fahr. (J810)       Labeldatei: 3C0-959-760.lbl
       Teilenummer SW: 3C8 959 760 E    HW: 3C8 959 760 E
       Bauteil: Sitzmemory    H05 3101
       Revision: 00H05000
       Codierung: 00003B
       Betriebsnr.: WSC 12336 024 394758
       VCID: 37794D7A86677CFE60-8062
    Adresse 37: Navigation (J0506)       Labeldatei:. DRV\1T0-035-680.clb
       Teilenummer SW: 3T0 035 686 C    HW: 3T0 035 686 C
       Bauteil: RNS-MID       H10 5238
       Revision: AB001001    Seriennummer: SKZ6Z7N8301003
       Codierung: 00060002000000811000
       VCID: 3667407E816D85F67B-8062
       Subsystem 1 - Teilenummer: 3T0 051 859 AP
       Bauteil: EU West V14  8477
    Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:. 8X0-959-793.clb
       Teilenummer SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Bauteil: TSG FA        H10 0415
       Revision: --------    Seriennummer: --------------
       Codierung: 011D0220DE00001000
       VCID: 52AF1CEE0DC5B9D677-8006
    Adresse 44: Lenkhilfe        Labeldatei: DRV\1K0-909-14x-GEN3.clb
       Teilenummer: 1K0 909 144 R
       Bauteil: EPS_ZFLS Kl. 197    3501
       Revision: 00H22000
       VCID: 397D4B4270736A8E96-806C
    Adresse 47: Soundsystem (R12)       Labeldatei: 5K0-035-456.clb
       Teilenummer SW: 5C6 035 456 A    HW: 5C6 035 456 A
       Bauteil: KonzernAmp10K H07 6813
       Revision: --------    Seriennummer: EAA098A0094641
       ASAM Datensatz: EV_AudioVerst10KanalBNO1 A01003
       ROD: EV_AudioVerst10KanalBNO1.rod
       VCID: 2647903E59CDF576CB-8072
    Adresse 4F: Zentralelektrik II (J520)       Labeldatei:. DRV\1K0-907-532.clb
       Teilenummer SW: 7N0 907 532     HW: 7N0 907 530 AM
       Bauteil: EZE_2         H55 1642
       Codierung: 050B0500
       VCID: 6FE9B51ABEB7F43E78-803A
       Subsystem 1 - Teilenummer SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Bauteil: J245EE04SKB03  H03 0090
       Seriennummer: 0123456789ABCDEFGHIJ
       Subsystem 2 - Teilenummer SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Bauteil: J394EE04SKB03  H03 0090
    Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:. 8X0-959-792.clb
       Teilenummer SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Bauteil: TSG BF        H10 0415
       VCID: 51AD13E208C3C2CE4E-8004
    Adresse 55: Leuchtweitenreg. (J745)       Labeldatei:. DRV\5M0-907-357-V3.clb
       Teilenummer SW: 5M0 907 357 F    HW: 7L6 907 357 C
       Bauteil: AFS-ECU       H04 0111
       Codierung: 01CA00003F000000
       ASAM Datensatz: EV_HeadlRegulVWAFSPt 002016
       VCID: 37794D7A8E677CFE60-8062
       Leistungsmodul für Scheinwerfer links:
       Subsystem 1 - Teilenummer SW: 8U0 941 329     HW: 8U0 941 329   Labeldatei: 3D0-941-329.CLB
       Bauteil: LeiMo links  H01 0003
       Codierung: 8E0000
       Leistungsmodul für Scheinwerfer rechts:
       Subsystem 2 - Teilenummer SW: 8U0 941 329     HW: 8U0 941 329   Labeldatei: 3D0-941-329.CLB
       Bauteil: LeiMo rechts  H01 0003
       Codierung: 8E0000
    Adresse 56: Radio (J0506)       Labeldatei:. DRV\1T0-035-680.clb
    Adresse 61: Batterieregelung (J840)       Labeldatei:. DRV\1K0-907-534.clb
       Teilenummer SW: 7N0 907 534     HW: 7N0 907 530 AM
       Bauteil: Batt.regelung H55 1642
       Codierung: 030F185A
       VCID: 71EDB362A883E2CE6E-8024
       Subsystem 1 - Teilenummer SW: 1K0 915 181 H    HW: 1K0 915 181 A
       Bauteil: J367-BDM  H07 0180
       Seriennummer: 30287856231491260666
    Adresse 62: Türelektr. hi. li. (J388)       Labeldatei:. DRV\8X0-959-795.clb
       Teilenummer SW: 8X0 959 795 D    HW: 8X0 959 795 D
       Bauteil: TSG HL        H07 0415
       Codierung: 010C00200000001000
       VCID: 50AB16E603C9CBC641-8004
    Adresse 69: Anhänger (J345)       Labeldatei:. DRV\1K0-907-383-V2.clb
       Teilenummer SW: 1K0 907 383 E    HW: 1K0 907 383 E
       Bauteil: Anhaenger     H08 0080
       Revision: 3A002002    Seriennummer: 00000126931723
       Codierung: 0100000100000000
       VCID: 2F69751A7E37B43E38-807A
    Adresse 6D: Heckklappe (----)       Labeldatei:| DRV\7N0-959-107.clb
       Teilenummer SW: 7N0 959 107 E    HW: 7N0 959 107 A
       Bauteil: HDSG-Modul    H11 0243
       Revision: 41011001    Seriennummer: 284300297
       Codierung: 083301C002
       ASAM Datensatz: EV_HDSGSk462 301136
       ROD: EV_HDSGSk462_SK46.rod
       VCID: 397D4B42B8736A8E96-806C
    Adresse 72: Türelektr. hi. re. (J389)       Labeldatei:. DRV\8X0-959-795.clb
       Bauteil: TSG HR        H07 0415
    Adresse 77: Telefon (J412)       Labeldatei:| DRV\3C8-035-730-A.clb
       Teilenummer SW: 3C8 035 730 D    HW: 3C8 035 730 D
       Bauteil: Telefon       022 0982
       Revision: --------    Seriennummer: 35502105065935
       Codierung: 020100000100010000000101
       ASAM Datensatz: EV_UHVPremi 002709
       ROD: EV_UHVPremi.rod
       VCID: 24438A362FF10766D5-8070
    Ende----------------------------(Dauer: 04:04)-----------------------------
    Adresse 18,7N0 963 272 C,Anpassungskanal 42,geändert von,0,auf,1,
    Adresse 18: Fehlercodes gelöscht
  2. #22
    Quote Originally Posted by vlado View Post
    I don't see it defined in the data for your ECU.
  3. #23
    I'm just curious Uwe if some ECU's don't report this angle could you create a merged block with some math done of G28 & G40 to create it for people?
  4. #24
    I don't the data we can get from those sensors has nearly enough resolution for us to make this computation with the accuracy required to be useful.
  5. #25
    SUX at least it was a shot!
  6. #26
    Feb 2019
    I too cannot find the synchronization (torsion) value on my 2.0 TDI. Code is CGLC. There must be some way of checking the cam adjustment? My fuel consumption is terrible at the moment and want to cross this off the check list.
    Thursday,09,January,2020,20:51:02:10363
    VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
    VIN: WAUZZZ8K8DA019111   License Plate:
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
    VIN: WAUZZZ8K8DA019111   Mileage: 176380km-109597miles
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 KD    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---
       Coding: 32194012242601080000
       Shop #: WSC 45123 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018KD 003005
       ROD: EV_ECM20TDI01103L906018JG.rod
       VCID: 76B5E47C3845BA07E3B-8022
       Part No SW: 8K9 907 379 L    HW: 8K9 907 379 L
       Component: ESP8 quattro  H09 0100
       Coding: 061544
       Shop #: WSC 06334 000 00000
       VCID: 4BC3658813C797EF6C5-801E
       Part No SW: 8K0 907 064 FC    HW: 8K0 907 064 FC
       Component: BCM2 2.0      H10 0602
       Coding: 03B20000000000000000
       Shop #: WSC 06335 000 00000
       VCID: 76B5E47C38C5BA07E3B-8022
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0812000010987021
       Serial number: 2312000008927005
       Part No SW: 8K2 820 043 AD    HW: 8K2 820 043 AD
       Revision: D1000000    Serial number: 01010220120923
       Coding: 342402E000
       VCID: 6B83C508738777EF0C5-803E
       Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 AD
       Component: BCM1 1.0      H14 0103
       Revision: 04014001    Serial number: 00000026734701
       Coding: 290000308034A7E01481000300001F1F009D070827080201000008000000030000000024000000
       Shop #: WSC 24550 123 104857
       VCID: 74B1DE742EB9A817DDF-8020
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 030212  H06 0070
       Serial number: SWF12020030078
       Coding: 00FD11
       Component: G397_RLFS  H06 0001
       Serial number: 20146343
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002601121540
       Serial number: 71080F06000000000001
       Serial number: 003KFD90VJ4S
       Coding: 30534435363030303030554A3052384B3053
       VCID: 48C95A8402317CF7417-801C
       Serial number: 6334MSME6A7043238
       Serial number: 6344MSME6B1405359
       Serial number: 6352QSME446C1848O
       Serial number: 6362QSME3C6C307AV
       Serial number: 63732SME446D0354
       Serial number: 63832SME196C0A667
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20120209000335
       Coding: 000017
       VCID: 4FFB7198E7DFABCF00D-801A
       Part No SW: 8K0 920 982 B    HW: 8K0 920 982 B
       Component: KOMBIINSTR.   H35 0540
       Revision: 00000000    Serial number: NTE21312D
       Coding: 3304290202012600010000
       VCID: 33331D686B37EF2F045-8066
       Part No SW: 8R0 907 468 C    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H10 0025
       Revision: 1Y030014    Serial number: 1441Y1213102A5
       Coding: 00CF07FF00
       VCID: 3FDB4158577F3B4FF0D-806A
       Serial number: 0285756701
       Serial number: 12021001088011200181
       Part No SW: 8K0 959 793 Q    HW: 8K0 959 793 Q
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000022583491
       Coding: 011002204001410001
       VCID: 4EC56C9CE0D5A2C70BB-801A
       Revision: 00001000    Serial number: 0028339006
       Coding: 100000000001
       Shop #: WSC 24552 123 104857
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 34311E746EB9E8171DF-8060
       Revision: 00002001    Serial number: 0168122851
       Coding: 013B062220B900408020023680000000
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 111
                        Mileage: 176389 km
                        Date: 2020.01.09
                        Time: 20:14:24
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 111
                        Mileage: 176389 km
                        Date: 2020.01.09
                        Time: 20:15:12
       Part No SW: 8K0 959 792 Q    HW: 8K0 959 792 Q
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000023538209
       VCID: 4DC76B90EDD399DF721-8018
       Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
       Component: EPB-4         H01 0001
       Revision: --------    Serial number: 10000000015760
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3635247C78C5FA0723B-8062
       Part No SW: 4G0 035 056 H    HW: 4G0 035 056
       Component: Radio U STD   H60 0134
       Revision: AB001007    Serial number: 229B-0C7553067
       Coding: 010003020100000001
       VCID: 2615F43CA8E58A8793B-8072
       Part No SW: 8R2 035 652 F    HW: 8R2 035 652
       Component: B-BN-EU       H62 0191
       Revision: --------    Serial number: 147BP0C7506005
       Coding: 01010101000681ED07800F4E000000030000
       VCID: 372B29787F4F030F38D-8062
       Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
       Component: DU6 Basic  H42 0098
       Serial number: 9465AU0C2504754
       Subsystem 2 - Part No SW: 8T0 919 611     HW: 8T0 919 611
       Component: E0380 Bedient  H01 0100
       Serial number: 00000001062793
       Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
       Revision:             Serial number: 0000023308328
       Coding: 010002204001210001
       VCID: 43D34DA83B975FAF945-8016
       Revision:             Serial number: 0000023308409
    End----------(Elapsed Time: 01:45, VBatt start/end: 13.9V/14.4V)-----------
