Results 11 to 20 of 34
Thread: Traffic Sign Assist currently limited
    Jul 2014
    Tallinn, Estonia
    No message during my drive to work. So the problem is solved for me.
  2. Likes downtime, Uwe, iichel liked this post
  3. #12
    May 2017
    Ok, then it seems it's good.
  4. #13
    Mar 2015
    Australia
    I've just fitted the 3Q0 lane assist camera to my B6 Passat.
    I am having the same issue with the 'Sign Assist currently limited' warning. The feature appears to be working properly. It detects signs with a high degree of accuracy which it then displays in the MFD and also in the top left corner of the Discover Media screen.
    My GPS antenna is a factory antenna from my old RNS510 so I don't think it is any sort of GPS issue.
    I think I just have some adaptation that is not 100% correct...
    Are you able to share the settings you have currently for the following adaptation channels?
    5F
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification
    ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_discla imer
    ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_thresho ld_high
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
  5. #14
    Jul 2014
    Tallinn, Estonia
    Quote Originally Posted by kamold View Post
    5F
    Here you go...
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Terminal
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated
    ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_discla imer,not
    ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off ,not
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_thresho ld_high,not
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,a ctivated
  6. Likes kamold liked this post
  7. #15
    Mar 2015
    Australia
    Thanks for that.
    I have the same settings but still have the warning message.
    I have road sign detection set to fusion.
    My camera coding is
    000406040000040100021044C090800090000E100000
    Do you mind sharing your coding string and road sign detection mode?
  8. #16
    May 2017
    How old is your map data? And is the PSD1.5 enabled in 5F long coding?
    The error is due that it cannot find the corresponding traffic sign data from map data or it is not transmitted correctly from navi system to camera and forwards from that.
  9. #17
    Mar 2015
    Australia
    Map data is 2018/2019. Current release.
    I will check the PSD coding thanks.
  10. #18
    Mar 2015
    Australia
    I set PSD coding on the camera and Discover media to active, and version 1.5.
    I can enable Sign Assist but it is no longer detecting any signs...
    I'm sure I've messed up the settings now. Though I don't have a fault from sign assist, and I don't have a missing messages error from the PSD comms....
    Anyone notice what I've got wrong here?
    Here is my current autoscan:
    Saturday,11,August,2018,09:52:37:58930
    VCDS Version: 18.7.1.1 (x64)  HEX-V2 CB: 0.4427.4
    Data version: 20180731 DS293.0
    VIN: WVWZZZ3CZ9E08   License Plate:
    Mileage: 127870km-79454mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 36 42 44 46 47 52 53
              55 5F 62 65 6C 6D 72 A5
    VIN: WVWZZZ3CZ9E08   Mileage: 127870km-79454miles
    Address 01: Engine (BWS)       Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 906 032 AM    HW: 03H 906 032 AB
       Component: R3.6-FSI-EU4    F   3488
       Revision: 5GH04---    Serial number: VWZCZ000000000
       Coding: 0000175
       Shop #: WSC 52104 002 1048576
       VCID: 6D87377FB19F9D4F492-8038
    Readiness: 0110 0100
       Part No SW: 02E 300 012 E    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1903
       Revision: 04844002    Serial number: 00000810231260
       Coding: 0000024
       Shop #: WSC 11111 111 45799
       VCID: 127D4483C861E2B7340-8046
    Address 03: ABS Brakes        Labels:. User\3AA-614-109.lbl
       Part No SW: 3AA 698 109 N    HW: 3AA 614 109 AL
       Component: J104   C2 450M VEDF 0042
       Revision: --H07---    Serial number: 00000007379684
       Coding: 0119716
       VCID: 44D1B2DBC295BC07F6C-8010
       Part No SW: 3AD 907 044 G    HW: 3AD 907 044 G
       Component: Climatronic   H03 0404
       Coding: 0039050004
       Shop #: WSC 12345 123 61029
       ROD: EV_ACClimaBHBVW411_VW46.rod
       VCID: 372BD5178FC3E79F63E-8062
    13701424 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Bordnetz - kein Signal/Kommunikation]
                        Reset counter: 223
                        Mileage: 127876 km
                        Date: 2018.08.11
                        Time: 09:43:24
       Revision: 00H54000    Serial number: 00000009027172
       Coding: 668E8F0700041A00470000001E000000000B79435C400120000000000000
       Shop #: WSC 12345 123 00000
       VCID: 3333E107973B0BBF5F6-8066
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 100908 022  0601
       Coding: 00047029
       Shop #: WSC 12345
       Component: RLS     121108 054  0402
       Coding: 00208936
       Shop #: WSC 12345
       Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0480
       Revision: --------    Serial number: 39431711102403
       Coding: 0131166011
       ASAM Dataset: EV_EPHVA2CVW364GP00 001010
       ROD: EV_EPHVA2CVW364GP00_VW36.rod
       VCID: 3B23C927B3EBC3FF876-806E
    13639168 - Databus
              [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
                        Reset counter: 223
                        Mileage: 127876 km
                        Date: 2018.08.11
                        Time: 09:43:24
    Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
       Part No SW: 3AA 907 567 A    HW: 3AA 907 567
       Component: AC201  RDW A    036 0170
       Revision: 00036000    Serial number: 00000000569541
       Coding: 0010000
       Shop #: WSC 00046 000 00000
       VCID: 3829D62B8E5DE8E76A4-806C
       Part No SW: 5N0 959 655     HW: 5N0 959 655
       Component: J234__00S VW10 HI   1815
       Revision: 19013000    Serial number: 0039BPMPB81T
       Coding: 0012371
       Shop #: WSC 05311 000 00000
       VCID: 7AAD0C23F0D13AF7DC0-802E
       Subsystem 1 - Serial number: 6333FTS665962908
       Subsystem 2 - Serial number: 6343FTS632552888
       Subsystem 3 - Serial number: 6353ETS6NTCKVVNR
       Subsystem 4 - Serial number: 6363ETS640PKVVNR
       Part No SW: 3C5 953 501 BM    HW: 5K0 953 569 T
       Revision: FF010041    Serial number: 20160725000799
       Coding: 399AA50003
       VCID: 71BF2B0FA12779AF6DA-8024
       Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0036
       Coding: 830000
    Address 17: Instruments (J285)       Labels:. 3C8-920-xxx-17.clb-SRI1
       Part No SW: 3AA 920 881     HW: 3AA 920 881
       Component: KOMBI         H03 0705
       Coding: 711F01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
       Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1682
       Revision:   H56       Serial number: 110114F2000857
       Coding: 462007
       VCID: 7BA30927F3EB03FFC76-802E
       Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
       Component: Haldex 4Motion      4013
       Coding: 0000005
       Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
       Component:    IMMO         052 0407
       Revision: 00052000    Serial number: VWZCZ000000000
       Shop #: WSC 12345 123 2097151
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
       Component: Sitzverstellung     1101
       Revision: 00005000    Serial number: 00000000000000
       VCID: 2F3BED777B132F5F3BE-807A
       Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1518
       Revision: 71009005    Serial number: 00000691888917
       Coding: 0005047
       VCID: 71BF2B0FADA779AF6DA-8024
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 143    3501
       Revision: 00H15000
       VCID: 392FD32FB557F1EF95A-806C
       Component:    KSG PQ47 ELV 052 0638
       Coding: 00900A00D1034E7F000694157008DFCE607801
       Part No SW: 3C0 035 456 F    HW: 3C0 035 456 F
       Component: DSP 10 Kanal        0013
       Revision: 00010000    Serial number: 00000000002780
       VCID: 2313114727DB9B3FAF6-8076
                        Reset counter: 223
                        Mileage: 127876 km
                        Date: 2018.08.11
                        Time: 09:48:03
                        Reset counter: 223
                        Mileage: 127876 km
                        Date: 2018.08.11
                        Time: 09:48:03
                        Fault Status: 00100111
                        Reset counter: 7
                        Mileage: 127876 km
                        Date: 2018.08.11
                        Time: 09:48:16
                        Reset counter: 7
                        Mileage: 127876 km
                        Date: 2018.08.11
                        Time: 09:48:16
       Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1518
       Revision: 71009005    Serial number: 00000649588929
       Coding: 0005046
       VCID: 72BD2403A8A142B7940-8026
       Revision:   H19       Serial number: 00000001024031
       Coding: 0022157
       Shop #: WSC 12345 111 45725
       VCID: 3635D81384491E97788-8062
       Component: AFS-Steuergeraet    0136
       Coding: 2344193
       VCID: 3431E21B92350C8746C-8060
       Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000035
       Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Coding: 00000035
       Part No SW: 5C0 035 680 E    HW: 5C0 035 680 E
       Component: MU-S-ND-ER    H31 0363
       Serial number: VWZAZ2T5074914
       Coding: 027404080000000011111105400908001F01079600F08101CE
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 231311472B5B9B3FAF6-8076
       Subsystem 1 - Part No SW: 5NA 919 866 C    HW: -----------
       Component: MRM2 2018/19  --- 1010
    6714 - Databus
              [VIN: no communication]
                        Reset counter: 223
                        Mileage: 127876 km
                        Date: 2018.08.11
                        Time: 09:43:23
                        Voltage terminal 30: 11.7 V
    7194 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 223
                        Mileage: 127876 km
                        Date: 2018.08.11
                        Time: 09:43:26
                        Voltage terminal 30: 11.8 V
                        BAP-BAP_Function_ID: 02
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000000699648
       Coding: 0000144
       VCID: 70B92E0BA6AD70A7624-8024
       Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0011
       Serial number: 40000000055443
       ASAM Dataset: EV_RDKBERU30 005005
       ROD: EV_RDKBERU30_005.rod
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
       Component: VW428 RVC Mid H04 0040
       Coding: 01130608A201000700
       ASAM Dataset: EV_CamSysRearPANAVW428 002002
       ROD: EV_CamSysRearPANAVW428.rod
       VCID: 3039EE0B6AAD30A7224-8064
       Part No SW: 3C9 827 383 F    HW: 3C9 827 383 F
       Component: J605  HECKDECKEL    0720
       Revision: 00H27001
       Shop #: WSC 05311 000 08193
       Subsystem 1 - Part No: 3C9 827 384 F
       Component: J756  HECKDECKEL    0720
       Subsystem 2 - Serial number: 0800H27001001B0148˙
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000000693593
       Coding: 0000144
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H04 0272
       Serial number: 290515null1593
       Coding: 000406040000040100021344C090800090000E100000
       ROD: EV_MFKBoschMQBB_VW46.rod
       VCID: 3C21CA3BB6E5C4C78EC-8068
    End----(Elapsed Time: 01:53, VBatt start/end: 12.0V/11.9V. VIgn 11.8V)-----
    5F Admap:
    ;SW:5C0-035-680-E   HW:5C0-035-680-E ---  Information Electr. --- SA: S12345
    ;Component:MU-S-ND-ER    H31 0363, Coding:027404080000000011111105400908001F01079600F08101CE
    ;EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW26.rod
    ;Saturday,11,August,2018,09:55:08:58930
    ;VCDS Version: Beta 18.7.1 (x64)  Data version: 20180731 DS293.0
    ;VCID: 231311472B5B9B3FAF6-8076
    IDE00346-Summertime-automatic,none ,1
    IDE00758-Base volume of telephone,50 %,1
    IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Number 1 for roadside assistance,5E 05 A1 08 50 77 95 F9 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00845-Wheel circ.,0 mm,2
    IDE02122-Developer mode,activated ,1
    IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36 ,49
    IDE02502-Confirmation of installation change,02 F5 ,2
    IDE02607-Wheel pulse,0 ,2
    IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE05111-Fee-based traffic information (TMC),1024 ,2
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),4 ,40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),7 ,40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),4 ,40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,0 ,40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,0 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,7 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
    IDE10604-Menu entries for mobile online services,not activated ,1
    IDE11122-Country identification: country of sale HMI,AU ,2
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
    MAS00950-Audio Parameter,1 ,1
    MAS00951-Bluetooth,On ,1
    MAS03782-WLAN,On ,1
    ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP ,1
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
    ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not activated ,60
    ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,not activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
    ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,not activated ,60
    ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,not activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
    ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,not activated ,60
    ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,not activated ,60
    ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,not activated ,60
    ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,not activated ,60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated ,60
    ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,not activated ,60
    ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,not activated ,60
    ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,not activated ,60
    ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,not activated ,60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
    ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated ,60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,activated ,60
    ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,not activated ,60
    ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,not activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
    ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,not activated ,60
    ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,not activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
    ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,not activated ,60
    ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,not activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,activated ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,not activated ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,not activated ,64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,not activated ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,not activated ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,not activated ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,not activated ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not activated ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,not activated ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not activated ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,not activated ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,not activated ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
    ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Comfort data bus ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,not activated ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,not activated ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Terminal 15 ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15 ,64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,not activated ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,not activated ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,not activated ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated ,64
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,not activated ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,not activated ,64
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not available ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Not available ,8
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Not available ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Comfort data bus ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Not available ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Not available ,8
    ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,20 ,6
    ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,50 ,6
    ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,20 ,6
    ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,50 ,6
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,3 ,12
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,15 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,60 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,0 ,12
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,0 ,12
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,10 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,15 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,90 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,0 %,12
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,0 %,12
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 2D 1E 37 28 37 28 2D 1E 07 64 1E 04 10 03 0A 00 00 00 01 03 ,40
    ENG117919-Startup_Screen_Sticker_HMI,00 02 ,2
    ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF ,30
    ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF ,30
    ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On ,30
    ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless,OFF ,30
    ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF ,30
    ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF ,30
    ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
    ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless,OFF ,30
    ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,blocked ,30
    ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0 ,30
    ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On ,30
    ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF ,30
    ENG109862-ENG185778-Vehicle_configuration-FoD,SWaP ,30
    ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On ,30
    ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless,OFF ,30
    ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF ,30
    ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF ,30
    ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF ,30
    ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF ,30
    ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not activated ,30
    ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present ,30
    ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present ,30
    ENG109862-ENG127492-Vehicle_configuration-LGI,OFF ,30
    ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated ,30
    ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF ,30
    ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF ,30
    ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF ,30
    ENG109862-ENG142152-Vehicle_configuration-Map_Style,0 ,30
    ENG109862-ENG152537-Vehicle_configuration-media_control,not activated ,30
    ENG109862-ENG138662-Vehicle_configuration-Mirror_link,On ,30
    ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU ,30
    ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565 ,30
    ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF ,30
    ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF ,30
    ENG109862-ENG127495-Vehicle_configuration-online_media,OFF ,30
    ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF ,30
    ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF ,30
    ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF ,30
    ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF ,30
    ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated ,30
    ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF ,30
    ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF ,30
    ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00 ,30
    ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00 ,30
    ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0 ,30
    ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active ,30
    ENG109862-ENG117844-Vehicle_configuration-picture_navi,On ,30
    ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not activated ,30
    ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not activated ,30
    ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0 ,30
    ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF ,30
    ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF ,30
    ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5 ,30
    ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF ,30
    ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated ,30
    ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open,not activated ,30
    ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
    ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe,not activated ,30
    ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS ,30
    ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not activated ,30
    ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no restriction ,30
    ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region ,30
    ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not activated ,30
    ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present ,30
    ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF ,30
    ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated ,30
    ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,0 ,30
    ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF ,30
    ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF ,30
    ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On ,30
    ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF ,30
    ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF ,30
    ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,blocked ,30
    ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF ,30
    ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF ,30
    ENG109862-ENG117852-Vehicle_configuration-UPnP,On ,30
    ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not activated ,30
    ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not activated ,30
    ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not activated ,30
    ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF ,30
    ENG109862-ENG127494-Vehicle_configuration-VZO,OFF ,30
    ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF ,30
    ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,On ,30
    ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not activated ,30
    Elapsed Time: 00:37
    A5 admap:
    ;SW:3Q0-980-654-H   HW:3Q0-980-654-A ---  Frt Sens. Drv. Assist
    ;Component:MQB_B_MFK     H04 0272, Coding:000406040000040100021344C090800090000E100000
    ;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_VW46.rod
    ;Saturday,11,August,2018,09:53:42:58930
    ;VCDS Version: Beta 18.7.1 (x64)  Data version: 20180731 DS293.0
    ;VCID: 3C21CA3BB6E5C4C78EC-8068
    IDE00001-Production mode,Deactivating ,3
    IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated ,1
    IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated ,1
    IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated ,1
    IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated ,1
    IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated ,1
    IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated ,1
    IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated ,1
    IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated ,1
    IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h,2
    IDE04733-Road sign detection fusion mode,Road sign fusion ,1
    IDE07358-Distance to calibration field,1500 mm,2
    IDE09375-IDE05717-Axle offset-Front axle transverse position,2.10001 mm,4
    IDE09375-IDE05718-Axle offset-Rear axle transverse position,1.20001 mm,4
    IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,680 mm,8
    IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,680 mm,8
    IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,680 mm,8
    IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,680 mm,8
    IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2400 mm,24
    IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,742.5 mm,24
    IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1497 mm,24
    IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2400 mm,24
    IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-742.5 mm,24
    IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1497 mm,24
    IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2400 mm,24
    IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,742.5 mm,24
    IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,903 mm,24
    IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2400 mm,24
    IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-742.5 mm,24
    IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,903 mm,24
    IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
    IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
    IDE10872-Warning intensity: lane depart. warning,Medium ,1
    IDE10873-BAP personalization,activated ,1
    IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.621 °,8
    IDE10924-MAS05286-Initial calibration: result-Roll angle,0.459 °,8
    IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.940 °,8
    IDE10924-MAS10678-Initial calibration: result-Camera height,1290 mm,8
    ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0 ,3
    ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0 ,3
    ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic ,3
    ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled ,3
    ENG120319-Mask_error_reactions_for_development,not activated ,1
    ENG107577-Masked_fault_classes-,255 ,4
    ENG130777-standstill_mode,not activated ,1
    ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,1 ,5
    ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,20 ,5
    ENG130779-Xcp_interface,not activated ,1
    Elapsed Time: 00:07
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
  11. #19
    Mar 2015
    Australia
    I somehow managed to delete my last post from my phone
    siLC would you mind posting your coding and admaps for 5F and A5?
    I had posted mine but I'll have to post them again tomorrow from my laptop.
    Basically I have PSD 1.5 enabled on A5 and 5F and I have no errors but the traffic sign recognition is no longer working...
  12. #20
    May 2017
    ^ Did you do a factory reset to 5F after setting the PSD bit? I have a faint memory print that it is needed, otherwise it won't display anything.
