Results 1 to 5 of 5
Thread: A6 C7 2011 problem Vent and engine
    Pirate
    Jul 2018
    Poland
    hello, sorry for my english... i have two problems.
    first. I started the car and then turned off. After checking the errors:
    18660 - Start Interruption due to Insufficient Engine Speed
              P151D 00 [032] - -
                        Mileage: 150903 km
                        Date: 2018.06.29
                        Time: 20:29:37
    two. I don't understand what's going on here...
    0033 - Motor for Rear Right Upper Body Vent
              B10D4 22 [009] - Signal Amplitude Too High
                        Fault Frequency: 21
                        Reset counter: 137
                        Mileage: 149668 km
                        Date: 2018.06.12
                        Time: 17:28:11
    Anyone had this problem?
    Best regats!
    Nov 2015
    There's not enough data there to answer any questions. A full autoscan will be needed rather than just the fault codes.
  3. Likes Boki Ar, PetrolDave, Uwe liked this post
    Pirate
    Jul 2018
    Poland
    A6 C7 2011 engine and vent problem
    Hi, i have a problem, look this logs.
    I started the car and then turned off. so first fault it's about that.
    best regats!
    Getting help on this forum requires the use of a legitimate VCDS system.
    The are available directly from us:
    http://www.ross-tech.com/distributors.php#pl
    Let us know via PM if/when you get one so we can adjust your forum status.
    Jan 2018
    Missed some again Uwe.
    2006 EOS 3.2 V6.
