Results 1 to 10 of 10
Thread: A5 passat B8
    Pirate
    Jul 2017
    Italy
    A5 passat B8
    can you help me passat b8
    Oct 2014
    Arandjelovac, Serbia
    Please post an full Auto Scan.
  3. Likes iichel, Uwe liked this post
    Pirate
    Jul 2017
    Italy
    Getting help on this forum requires the use of a legitimate VCDS system.
    The are available directly from us:
    http://www.ross-tech.com/distributors.php#it
    Let us know via PM if/when you get one so we can adjust your forum status.
  6. Likes Jetta ,97 liked this post
    Jan 2018
    Scan info still in the first post.
    2006 EOS 3.2 V6.
    Quote Originally Posted by Shep View Post
    Oops. Fixed.
    Pirate
    Jul 2017
    Italy
    vcds is coming
    I wanted to ask you acc must communicate with the camera?
  10. #8
    Pirate
    Jul 2017
    Italy
    Monday,09,July,2018,13:12:40:27574
    VCDS Version: 18.2.1.5 (x64)
    VIN: WVWZZZ3CZGP016614   License Plate:
    Mileage: 123342km-76641mi   Repair Order:
    Chassis Type  3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 65 6C
              A5 BB BC CA
    VIN: WVWZZZ3CZGP016614   Mileage: 123342km-76641miles
    CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
       Component: R4 2,0L EDC   H22 1343
       Revision: B5H22---
       Coding: 011D0012036405083000
       Shop #: WSC 00028 028 00030
       ASAM Dataset: EV_ECM20TDI01104L906026ET 002001
       ROD: EV_ECM20TDI01104L906026FL.rod
       VCID: 000B6C479B68B54424-8054
       Part No SW: 0D9 300 041 A    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4801
       Revision: 06253104    Serial number: TFK01508180808
       Shop #: WSC 00028 028 00025
       ROD: EV_TCMDQ250021.rod
       VCID: 16272A1FE9EC2BF4EE-8042
       Revision: 00000000    Serial number: 62805000001930
       Coding: 0FEC6A8F34210B72077D060141C749F0562CD0E0608292F11862F0084202
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 7AFF1EAFFDB4EF946A-802E
       Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
       Component: VWKESSYMQB    026 0710
       Revision: 00026000    Serial number: 0382651624
       Coding: 000F0F0F03
       ASAM Dataset: EV_KessyHellaMQBAB 004032
       VCID: 397DC1A3B832248C23-806C
       Part No SW: 5G0 907 044 BG    HW: 5G0 907 044 BG
       Component: Climatronic   H04 1202
       Revision: 00001K10
       Coding: 12020124202100011115500000101902
       ASAM Dataset: EV_ACClimaBHBVW37X 005137
       ROD: EV_ACClimaBHBVW37X_005_VW37.rod
       VCID: 6DD525F3BCFA482CFF-8038
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Revision: --------    Serial number: 86580810151068
       Coding: 00951E46C24102FF4FC44084F11C07281880000000000000000000000000
       Shop #: WSC 19460 666 12345
       ROD: EV_BCMBOSCH_015.rod
       VCID: 0301634B8A7EAE5C39-8056
       Component: WWS    150813  042 0607
       Serial number:         151004085956
       Component: RLHS  037 0059
       Serial number: S2Y15M10D17H10M37S57
       Coding: 90A8DD
       Light switch:
       Serial number: 30 08 2015  10000329
       Component: Sensor, DWA  006 0326
       Serial number: 000000000ZY151772LB4
       Serial number: 00000000000068354238
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391528601234
       Coding: 0071151811
       ROD: EV_EPHVA18AU3700000_002_VW27.rod
       VCID: 4483A057CFF0696440-8010
       Component: ACC BOSCH MQB H04 0192
       Coding: 3200678259FFC428949C804D
       ASAM Dataset: EV_ACCBOSCHVW48X 001008
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3463F0979F50D9E4F0-8060
       Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
       Component: Airbag VW20   013 0195
       Revision: --------    Serial number: 003STPLZQ6CD
       Shop #: WSC 00028 028 00007
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F09EFBBE696CABC5D-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 510 15
       Serial number: 3576U000000E6121B617
       Subsystem 2 - Part No SW: -----------    HW: 454 000 810 15
       Serial number: 3586U000000EE4D8A61-
       Subsystem 3 - Part No SW: -----------    HW: 454 802 109 15
       Serial number: 3516RA83D81080000007
       Subsystem 4 - Part No SW: -----------    HW: 454 802 109 15
       Serial number: 3526RB42D81080000004
       Subsystem 5 - Part No SW: -----------    HW: 454 802 109 15
       Serial number: 3556V16E87B08000000J
       Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20151014500252
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3D75D5B3AC1A18AC0F-8068
       Part No SW: 3G0 920 791 A    HW: 3G0 920 791 A
       Component: KOMBI         410 1340
       Coding: 07A509986E84000801887B071000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009048
       VCID: 275917DB5E86A27C45-8072
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2227
       Revision: --------    Serial number: 17101510803198
       Coding: 030300045F087300FB00025A1C0F00010001070000000000000000000000
       Shop #: WSC 00028 028 00213
       ROD: EV_GatewConti_013_VW37.rod
       VCID: 75E50D93D4AA80EC07-8020
       Serial number: 29150002033150115416
       Coding: 2DFFFF
       Serial number: 5256628103
       Analog clock:
       Component: Analoguhr  209 2002
       Serial number: 15000089008008
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71ED3983A0C2ACCCDB-8024
       Serial number: 0000170383267
       Coding: 003F0B20D000020000001000
       VCID: 4799B75BFEC6427CA5-8012
       Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2033
       Revision: 00000000    Serial number: 0000440984
       Coding: 01000011005001
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
       ROD: EV_SteerAssisVWBSMQBA_008_VW48.rod
       VCID: 3B71DBABB20E169C31-806E
       Serial number: 0000170406570
       Coding: 003F0120DE00020000001000
       VCID: 4687BA5FF9CC5B745E-8012
       Coding: 039A00000F210200
       ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
       VCID: 3F89AFBBA6160ABC1D-806A
       Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0003
       Coding: E02400
       Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0003
       Coding: E02400
       Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0003
       Coding: E02400
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 043 B    HW: 3G0 035 043
       Component: MU-H-N-EU     H42 0343
       Serial number: A599J0FB022330
       Coding: 02840201FF00000051110001000808001F0100E401200000DF
       VCID: 1B313B2B12CE769CD1-804E
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9RU303KSL
       Subsystem 2 - Part No SW: V03 959 800 QM    HW: -----------
       Component: ECE 2015/2016  --- 0123
       Component: Gracenote2  --- 1011
       Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0009
       Serial number: 40000000009799
       ROD: EV_RDKBERU30_006_VW48.rod
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H07 0100
       Coding: 0184020162002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
       VCID: 77F9079BCEA6F2FC15-8022
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H07 0272
       Serial number: 05011711P10491
       Coding: 0004080200000401002223448050A10098000E300040
       ROD: EV_MFKBoschMQBB_VW27.rod
       VCID: 3C73D8B7B70011A438-8068
    0660 - No Basic Setting
              B2010 00 [009] -  -
                        Reset counter: 52
                        Mileage: 123342 km
                        Date: 2018.07.09
                        Time: 13:05:04
                        Control Module temperature: 57 C
                        Outside air temperature: 26.0 C
                        Vehicle speed: 0.00 km/h
                        System run time: 181.0 s
                        Voltage terminal 15: 12.3 V
                        mid: 00 1E
                        Status of camera: System malfunction
                        Engine_Running_Info: 0
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1122675 - Databus
                        Reset counter: 52
                        Mileage: 123342 km
                        Date: 2018.07.09
                        Time: 13:05:04
                        System run time: 181.5 s
                        Voltage terminal 15: 12.2 V
                        mid: 01 E0
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1122597 - Databus
                        Reset counter: 52
                        Mileage: 123342 km
                        Date: 2018.07.09
                        Time: 13:05:04
                        mid: 01 43
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    0311 - Data Set Implausible
              B2012 00 [009] -  -
                        Reset counter: 52
                        Mileage: 123342 km
                        Date: 2018.07.09
                        Time: 13:05:04
                        mid: 00 51
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
       Component: TSG HFS       011 0031
       Serial number: 0000167108139
       Coding: 000E01200100020000001000
       ASAM Dataset: EV_DCURearDriveMAXCONT 006001
       VCID: 499DB163E8D2B40CB3-801C
       Component: TSG HBFS      011 0031
       Serial number: 0000167108138
       ASAM Dataset: EV_DCURearPasseMAXCONT 006001
    Address CA: Sunroof
    Interface not compatible.
    End-------------------------(Elapsed Time: 06:47)--------------------------
  11. #9
    So you found an obsolete interface that belongs to someone else to use on on your B8 Passat?
  12. Likes PetrolDave liked this post
  13. #10
    Pirate
    Jul 2017
    Italy
    : Banghead:
