2015 A3 premium plus hacks
dhpress1
chicago, usa
C?ID=18868
Hello all....looking to do a few things and need some help:
1) windows up with key fob
2) drl’s On with turn signals
3) passenger mirror tilt in reverse. (Not sure if this is possible?
Thx all
dp
I did stfa and didn’t see anything but I might not have done an exhaustive search. 👍🏻
Going to need a full Auto-Scan to be able suggest the correct settings.
BTW unless you have memory seats the mirror tilt on reverse is a PITA as the mirror doesn't return to the same position - without the seat memory in the door controller it makes a "best guess" which isn't very good much of the time :banghead:
hadez16
C?ID=289891
stfa?
PITA?
Comfort opening should be a menu option in your MMI. (Central locking menu)
No?
dhpress1
chicago, usa
C?ID=18868
stfa?
PITA?
No?
search the forum archives
pain in the @$$
if only it were that easy....lol
dp
dhpress1
chicago, usa
C?ID=18868
Here ya go:
TBAx
C?ID=287144
Well, thats only the GVL...
hadez16
C?ID=289891
We need a FULL Auto-Scan!
Wrapped in CODE-Tags (Text Editor)
dhpress1
chicago, usa
C?ID=18868
sorry about that, i'm a n00b to all of this :)
here ya go
Friday,15,June,2018,19:20:01:12112
VCDS Version: 18.2.1.2 (x64)
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 52 55 5F 6C
          BB BC
VIN:    Mileage:
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 0A1D00324426000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C5DEA2047246724AB-8078
15271 - EVAP System
   Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4515
   Revision: 05853104    Serial number: TFK01412010104
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1E3930E8019885B435-804A
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 63404000000625
   Coding: 13FF6A9234290A70017C030981C929C8562C5080C08194B4024100588208
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 4895B6B0F39CAB04AF-801C
   Revision: 00021000    Serial number: 0355051571
   Coding: 030C0C
   VCID: 3A71DC78BD70C99429-806E
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000521595
   VCID: 336FF15C9A1A38DCEA-8066
   Serial number: 59B88167000000000001
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0137
   Serial number: 01011433500648
   Coding: 04151A46C04122F541C04004511007A00800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79F30374F8F6028C60-802C
   Component: WWS371 141127  042 0585
   Serial number:         141204043259
   Coding: 0A47F7
   Serial number: 23535289
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 14 11 2014  00000602
   Serial number: 00000000000031370026
   Sun Roof:
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST00025LWO00000
   Coding: 101F00
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39391433101129
   Coding: 0030150011
   ROD: EV_EPHVA18AU3700000_002_AU37.rod
   VCID: 4281A498D5A0815471-8016
   Serial number: 003GCR0120EW
   VCID: 4797B58CFE82A47CA6-8012
   Belt Pretensioner left:
   Serial number: 34178311B11121441280
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34178312B11121471496
   Coding: 333135
   Occupant Detection:
   Serial number: 6940000Y1400019HJC0U
   Coding: 303230
   Subsystem 4 - Part No SW: -----------    HW: 480 000 212 14
   Serial number: 35700000000EC905021F
   Subsystem 5 - Part No SW: -----------    HW: 480 000 212 14
   Serial number: 358000000007A9050217
   Subsystem 6 - Part No SW: -----------    HW: 480 400 412 14
   Serial number: 3510002B118B3AB4308$
   Subsystem 7 - Part No SW: -----------    HW: 480 400 412 14
   Serial number: 3520002AF18B3AB63228
   Subsystem 8 - Part No SW: -----------    HW: 480 400 109 14
   Serial number: 3550002B5175A8E3A0BE
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 109 14
   Serial number: 3560002BB175A8E2E3AQ
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 10121408490809
   Coding: A018
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 0A114CB8AD10191479-805E
   Part No SW: 8V0 920 971 D    HW: 8V0 920 971 D
   Coding: 03E418192B88D7050200E8001800000000000000
   VCID: 3E79D068A158E5B415-806A
   Revision: --------    Serial number: 29111410803436
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   VCID: 72E13458A58071D421-8026
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 28 11 2014  A0095290
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00010.11.14
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 4689B888F988BD745D-8012
   Revision: 00000000    Serial number: 14000341144004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346DF2409F143FE4F3-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0352513607
   Coding: 030211
   VCID: 3875C670837CDB84DF-806C
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0352878377
   Coding: 030211
   Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
   Serial number: 251114BKO12286
   Coding: 00101F204000048000000002
   VCID: 4085AE90DBAC934467-8014
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 8102
   VCID: 438FA19CCABA885C7A-8016
   Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
   Serial number: 261114BKP10195
   Coding: 001017204000048000000002
   VCID: 3F87AD6CA652ECBC1E-806A
   Coding: 012A000101000000
   VCID: 75EB0F44D4EE66EC04-8020
   Part No SW: 8V0 035 038 B    HW: 8V0 035 038 B
   Component: MU-H-LNS-US   H43 0394
   Serial number: A302L0EB007857
   Coding: 01730102FF0A000021220001041A00102F000105010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
   Component: NAR 2015  --- 0035
   Component: DU High  H49 0014
   Serial number: AUZ8Z9EY2028UJ
   Multimedia Operating Unit:
   Serial number: C1000017111400030187
   Component: Gracenote  --- 3006
1564 - Microphone 1
          B129B 13 [008] - Open Circuit
                    Reset counter: 80
                    Mileage: 33243 km
                    Date: 2018.04.03
                    Time: 09:51:30
                    Voltage terminal 30: 12.6 V
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE.rod
   VCID: 3065FE506B0C03C497-8064
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 011214BKU00507
   Coding: 000017204000048000000002
   Component: TSG HBFS      020 0028
   Serial number: 011214BKU0050A
End-------------------------(Elapsed Time: 04:51)--------------------------
dhpress1
chicago, usa
C?ID=18868
thx andy, i will give that a try later this afternoon. i'll report back my findings.
dhpress1
chicago, usa
C?ID=18868
ok tried and still not working: using the latest software - 18.2
[Select]
[09 - Cent Elect.]
[Security Access - 16]
Enter USED # IN VAG-COM TOOL
[Do It!]
[Adaptation - 10]
IDE08542-IDE02021-Access control 2-Comfort closing active - ACTIVE
IDE08542-IDE02022-Access control 2-Comfort opening active - ACTIVE
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active CAN'T LOCATE
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active CAN'T LOCATE
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable CAN'T LOCATE
not sure what i'm missing, just an FYI, both values were 'ACTIVE' when i clicked on them.
thx again for your help....any update on the turn signal request?
Scratching head. These are definitely defined in the ASAM/ROD data for your BCM:
IDE08542-ENG116652 Access control 2 - Funk Komfort oeffnen
IDE08542-ENG116651 Access control 2 - Funk Komfort schliessen
IDE08542-ENG122994 Access control 2 - Menuesteuerung Komfortbedienung einstellbar
What method are you using to locate them?
dhpress1
chicago, usa
C?ID=18868
using the drop down located at the top
Right, but the unfiltered list is rather long and it's hard to find stuff in it.
Are you using the 'Search' box to narrow it down, like this?
Instead of 'ESI' try 'Komfort' since that's common to all three of the ones you haven't found.
dhpress1
chicago, usa
C?ID=18868
i will try that and see what happens, although it appears to be in numeric order. thank you sir
dhpress1
chicago, usa
C?ID=18868
success....although the 'search' didn't work i was able to find it. one was not 'active' i chg'd it and viola....
now lets try the drl's on with turn signals (DRL's on w/ blinkers) any ideas uwe?
thank you so much.
DV52
C?ID=194404
dhpress: Hi- one of the rare pleasures in my unremarkable existence is taking every opportunity to steal Uwe's thunder (yes, I know that I should get a life)!! So,thankyou for providing this opportunity and I hope that my suggestion below is correct!
From the code-string on the BCM in your auto-scan, I suspect that your car has HID fittings. This means I hope, that the DRLs are controlled on your NAR model car by the Leuchte-sets Leuchte2SL VLB10 (left-side) and Leuchte3SL VRB21 (right-side).
Now - the next bit is a complete guess because I find American accents difficult to understand (this is purely my failing). When you say "now lets try the drl's on with turn signals (DRL's on w/ blinkers)" - I'm guessing that you want to disable what's more commonly known as DRL wink (i.e. the process whereby the DRL illumination is dimmed/extinguish on the side where the turn signal is operating).
If my translation of your request to Aussie speak is correct, try this:
  1. Select the BCM (@ address hex09)
  2. Select Security Code
  3. Enter the magic number 31347
  4. Select adaptation
  5. Search for "ENG115955" and select ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,
  6. IF and only if the setting for this channel is Blinken links aktiv (beide Phasen), change to not active
  7. Search for "ENG115944" and select ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3
  8. IF and only if the setting for this channel is Blinken rechts aktiv (beide Phasen), change to not active
  9. exit vcds
dhpress1
chicago, usa
C?ID=18868
ok, well i tried this and don't see everything or i'm missing something.
channel - same for both addresses provided....
selection list - new value
thx....
DV52
C?ID=194404
^^^^ No, you didn't miss anything - your screenshot means that your car isn't programmed as per the NAR model mk7 that I used in my reply (damn, I didn't steal Uwe's thunder after all :cry:).
So, now the question is which Leuchte-set controls the DRLs in your car? I've taken a second guess at this (again using information from my NAR database) and I have altered my response above. Try again - please (hopefully, thunder will be thieved this time)!
