Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: 2015 A3 premium plus hacks
    Jul 2018
    chicago, usa
    Hello all....looking to do a few things and need some help:
    1) windows up with key fob
    2) drl’s On with turn signals
    3) passenger mirror tilt in reverse. (Not sure if this is possible?
    Thx all
    dp
    I did stfa and didn’t see anything but I might not have done an exhaustive search. 👍🏻
    Going to need a full Auto-Scan to be able suggest the correct settings.
    BTW unless you have memory seats the mirror tilt on reverse is a PITA as the mirror doesn't return to the same position - without the seat memory in the door controller it makes a "best guess" which isn't very good much of the time
    Jun 2017
    stfa?
    PITA?
    Comfort opening should be a menu option in your MMI. (Central locking menu)
    No?
    Jul 2018
    chicago, usa
    stfa?
    PITA?
    No?
    search the forum archives
    pain in the @$$
    if only it were that easy....lol
    dp
    Jul 2018
    chicago, usa
    Here ya go:
    dp
    just living the dream
    chicago, usa
  6. #6
    Dec 2016
    DE
    Well, thats only the GVL...
  7. #7
    Jul 2018
    chicago, usa
    not sure what you mean?!
    dp
    chicago, usa
  8. #8
    Jun 2017
    We need a FULL Auto-Scan!
    Wrapped in CODE-Tags (Text Editor)
  9. #9
    Jul 2018
    chicago, usa
    sorry about that, i'm a n00b to all of this
    here ya go
    Friday,15,June,2018,19:20:01:12112
    VCDS Version: 18.2.1.2 (x64)
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 52 55 5F 6C
              BB BC
    VIN:    Mileage:
    Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
       Component: 2.0l R4 TFSI  H13 0005
       Revision: --H13---
       Coding: 0A1D00324426000F3000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
       ROD: EV_ECM20TFS0205G0906259A.rod
       VCID: 2C5DEA2047246724AB-8078
    15271 - EVAP System
       Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4515
       Revision: 05853104    Serial number: TFK01412010104
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 1E3930E8019885B435-804A
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 63404000000625
       Coding: 13FF6A9234290A70017C030981C929C8562C5080C08194B4024100588208
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 4895B6B0F39CAB04AF-801C
       Revision: 00021000    Serial number: 0355051571
       Coding: 030C0C
       VCID: 3A71DC78BD70C99429-806E
       Component: AC Automat    H13 0060
       Revision: 20027000    Serial number: 00000000521595
       VCID: 336FF15C9A1A38DCEA-8066
       Serial number: 59B88167000000000001
       Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
       Component: BCM MQBAB MNA H18 0137
       Serial number: 01011433500648
       Coding: 04151A46C04122F541C04004511007A00800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 79F30374F8F6028C60-802C
       Component: WWS371 141127  042 0585
       Serial number:         141204043259
       Coding: 0A47F7
       Serial number: 23535289
       Coding: 00006C
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 14 11 2014  00000602
       Serial number: 00000000000031370026
       Sun Roof:
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST00025LWO00000
       Coding: 101F00
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39391433101129
       Coding: 0030150011
       ROD: EV_EPHVA18AU3700000_002_AU37.rod
       VCID: 4281A498D5A0815471-8016
       Serial number: 003GCR0120EW
       VCID: 4797B58CFE82A47CA6-8012
       Belt Pretensioner left:
       Serial number: 34178311B11121441280
       Coding: 333135
       Belt Pretensioner right:
       Serial number: 34178312B11121471496
       Coding: 333135
       Occupant Detection:
       Serial number: 6940000Y1400019HJC0U
       Coding: 303230
       Subsystem 4 - Part No SW: -----------    HW: 480 000 212 14
       Serial number: 35700000000EC905021F
       Subsystem 5 - Part No SW: -----------    HW: 480 000 212 14
       Serial number: 358000000007A9050217
       Subsystem 6 - Part No SW: -----------    HW: 480 400 412 14
       Serial number: 3510002B118B3AB4308$
       Subsystem 7 - Part No SW: -----------    HW: 480 400 412 14
       Serial number: 3520002AF18B3AB63228
       Subsystem 8 - Part No SW: -----------    HW: 480 400 109 14
       Serial number: 3550002B5175A8E3A0BE
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 400 109 14
       Serial number: 3560002BB175A8E2E3AQ
       Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 10121408490809
       Coding: A018
       ROD: EV_SMLSKLOMQB_013_AU37.rod
       VCID: 0A114CB8AD10191479-805E
       Part No SW: 8V0 920 971 D    HW: 8V0 920 971 D
       Coding: 03E418192B88D7050200E8001800000000000000
       VCID: 3E79D068A158E5B415-806A
       Revision: --------    Serial number: 29111410803436
       Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
       VCID: 72E13458A58071D421-8026
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 28 11 2014  A0095290
       Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7082
       Serial number: HA1-00010.11.14
       Coding: 0001
       ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
       VCID: 4689B888F988BD745D-8012
       Revision: 00000000    Serial number: 14000341144004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 346DF2409F143FE4F3-8060
       Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
       Serial number: 0352513607
       Coding: 030211
       VCID: 3875C670837CDB84DF-806C
       Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0352878377
       Coding: 030211
       Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
       Serial number: 251114BKO12286
       Coding: 00101F204000048000000002
       VCID: 4085AE90DBAC934467-8014
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 8102
       VCID: 438FA19CCABA885C7A-8016
       Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
       Serial number: 261114BKP10195
       Coding: 001017204000048000000002
       VCID: 3F87AD6CA652ECBC1E-806A
       Coding: 012A000101000000
       VCID: 75EB0F44D4EE66EC04-8020
       Part No SW: 8V0 035 038 B    HW: 8V0 035 038 B
       Component: MU-H-LNS-US   H43 0394
       Serial number: A302L0EB007857
       Coding: 01730102FF0A000021220001041A00102F000105010001047E
       ROD: EV_MUHig6C3HBAS_AU37.rod
       Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
       Component: NAR 2015  --- 0035
       Component: DU High  H49 0014
       Serial number: AUZ8Z9EY2028UJ
       Multimedia Operating Unit:
       Serial number: C1000017111400030187
       Component: Gracenote  --- 3006
    1564 - Microphone 1
              B129B 13 [008] - Open Circuit
                        Reset counter: 80
                        Mileage: 33243 km
                        Date: 2018.04.03
                        Time: 09:51:30
                        Voltage terminal 30: 12.6 V
       Coding: 027300010201000300
       ROD: EV_2CamSysRearPASE.rod
       VCID: 3065FE506B0C03C497-8064
       Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0028
       Serial number: 011214BKU00507
       Coding: 000017204000048000000002
       Component: TSG HBFS      020 0028
       Serial number: 011214BKU0050A
    End-------------------------(Elapsed Time: 04:51)--------------------------
    dp
    chicago, usa
  10. Likes iichel liked this post
  11. #10
    Administrator Andy's Avatar
    Sector 7G
    For remote windows, try the tweaks shown here:
    http://forums.ross-tech.com/showthre...ll=1#post68215
  12. Likes Uwe, dhpress1 liked this post
