Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
Thread: 2015 A3 premium plus hacks
    Jul 2018
    chicago, usa
    thx andy, i will give that a try later this afternoon. i'll report back my findings.
    dp
    just living the dream
    chicago, usa
  2. #12
    Jul 2018
    chicago, usa
    ok tried and still not working: using the latest software - 18.2
    [Select]
    [09 - Cent Elect.]
    [Security Access - 16]
    Enter USED # IN VAG-COM TOOL
    [Do It!]
    [Adaptation - 10]
    IDE08542-IDE02021-Access control 2-Comfort closing active - ACTIVE
    IDE08542-IDE02022-Access control 2-Comfort opening active - ACTIVE
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active CAN'T LOCATE
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active CAN'T LOCATE
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable CAN'T LOCATE
    not sure what i'm missing, just an FYI, both values were 'ACTIVE' when i clicked on them.
    thx again for your help....any update on the turn signal request?
    dp
    chicago, usa
  3. #13
    Scratching head. These are definitely defined in the ASAM/ROD data for your BCM:
    IDE08542-ENG116652 Access control 2 - Funk Komfort oeffnen
    IDE08542-ENG116651 Access control 2 - Funk Komfort schliessen
    IDE08542-ENG122994 Access control 2 - Menuesteuerung Komfortbedienung einstellbar
    What method are you using to locate them?
  4. #14
    Jul 2018
    chicago, usa
    using the drop down located at the top
    dp
    chicago, usa
  5. #15
    Quote Originally Posted by dhpress1 View Post
    Right, but the unfiltered list is rather long and it's hard to find stuff in it.
    Are you using the 'Search' box to narrow it down, like this?
    Instead of 'ESI' try 'Komfort' since that's common to all three of the ones you haven't found.
  6. Likes dhpress1 liked this post
  7. #16
    Jul 2018
    chicago, usa
    i will try that and see what happens, although it appears to be in numeric order. thank you sir
    dp
    chicago, usa
  8. #17
    Jul 2018
    chicago, usa
    success....although the 'search' didn't work i was able to find it. one was not 'active' i chg'd it and viola....
    now lets try the drl's on with turn signals (DRL's on w/ blinkers) any ideas uwe?
    thank you so much.
    dp
    chicago, usa
  9. #18
    May 2014
    dhpress: Hi- one of the rare pleasures in my unremarkable existence is taking every opportunity to steal Uwe's thunder (yes, I know that I should get a life)!! So,thankyou for providing this opportunity and I hope that my suggestion below is correct!
    From the code-string on the BCM in your auto-scan, I suspect that your car has HID fittings. This means I hope, that the DRLs are controlled on your NAR model car by the Leuchte-sets Leuchte2SL VLB10 (left-side) and Leuchte3SL VRB21 (right-side).
    Now - the next bit is a complete guess because I find American accents difficult to understand (this is purely my failing). When you say "now lets try the drl's on with turn signals (DRL's on w/ blinkers)" - I'm guessing that you want to disable what's more commonly known as DRL wink (i.e. the process whereby the DRL illumination is dimmed/extinguish on the side where the turn signal is operating).
    If my translation of your request to Aussie speak is correct, try this:
    1. Select the BCM (@ address hex09)
    2. Select Security Code
    3. Enter the magic number 31347
    4. Select adaptation
    5. Search for "ENG115955" and select ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,
    6. IF and only if the setting for this channel is Blinken links aktiv (beide Phasen), change to not active
    7. Search for "ENG115944" and select ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3
    8. IF and only if the setting for this channel is Blinken rechts aktiv (beide Phasen), change to not active
    9. exit vcds
    Last edited by DV52; 07-04-2018 at 09:05 PM. Reason: Changed Leuchte-sets. Twice!!!
  10. Likes Uwe, jyoung8607 liked this post
  11. #19
    Jul 2018
    chicago, usa
    ok, well i tried this and don't see everything or i'm missing something.
    channel - same for both addresses provided....
    selection list - new value
    thx....
    dp
    chicago, usa
  12. Likes DV52 liked this post
  13. #20
    May 2014
    ^^^^ No, you didn't miss anything - your screenshot means that your car isn't programmed as per the NAR model mk7 that I used in my reply (damn, I didn't steal Uwe's thunder after all ).
    So, now the question is which Leuchte-set controls the DRLs in your car? I've taken a second guess at this (again using information from my NAR database) and I have altered my response above. Try again - please (hopefully, thunder will be thieved this time)!
