My MIL lit up and shows above captioned codes. Could someone point me to a diagnostic process for (especially 00912) these codes? I have swaped the intake and exhaust sensors on the driver's side but the code didn't follow the new position. I would also like to know the firing order and cylinder position of this C6 3.2 engine. I have read conflicting information. Am I correct thinking #1 cylinder is at the front of the engine on the passenger side followed to thr rear by #2 & then #3; driver's side has #4 in front on driver's side followed to the rear by #5 & #6? Regarding the CPS, what MB and group should I be focusing on and what are good PIDs to hope to see for a helthy CPS? Is a resistance check possible to determine if the CPS is OK? The engine has a cold start long cranking, rolling idle and surging acceleration hesitation.
Wednesday,06,June,2018,13:45:18:52331
VCDS Version: 18.2.1.2 (x64)
VIN: WAUKG74F06N018485 License Plate: BNT-1949
Mileage: 229010km-142300mi Repair Order: 6/7/06
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 34 36 37 42 46 47 4F
52 53 55 56 61 62 65 67 6D 72 76 77
VIN: WAUKG74F06N018485 Mileage: 229010km-142300miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F1 910 559 F HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0040
Revision: --H15--- Serial number:
Coding: 010D0106190F0520
Shop #: WSC 98765 666 36911
VCID: 2E5915CDB9DB2E3485-807A
000912 - Camshaft Position Sensor (G301)
P0390 - 006 - Malfunction - MIL ON
Fault Status: 10100001
Fault Frequency: 59
Reset counter: 40
Mileage: 228668 km
Date: 2018.05.23
Time: 14:34:05
RPM: 1152 /min
Mass Air / Rev.: 267.1 mg/str
Temperature: 84.0°C
Idle
Bin. Bits: 00000100
009766 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit
P2626 - 008 - Open - MIL ON
Fault Status: 10101000
Fault Frequency: 26
Reset counter: 40
Mileage: 228670 km
Date: 2018.05.23
Time: 16:21:57
RPM: 1440 /min
Mass Air / Rev.: 92.7 mg/str
Temperature: 94.5°C
Overrun
Time: 230.4 s
Bin. Bits: 00000100
009236 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
P2414 - 006 - - MIL ON
Fault Frequency: 13
Reset counter: 40
Mileage: 228682 km
Date: 2018.05.24
Time: 16:03:38
RPM: 2368 /min
Mass Air / Rev.: 256.2 mg/str
Temperature: 40.5°C
Part Throttle
Time: 25.6 s
Bin. Bits: 00000010
004406 - Fuel Trim: Bank 1 (Add)
P1136 - 006 - System too Lean - MIL ON
Reset counter: 40
Mileage: 228950 km
Date: 2018.05.31
Time: 17:44:55
RPM: 672 /min
Mass Air / Rev.: 174.4 mg/str
Temperature: 87.0°C
Idle
Time: 76.8 s
Bin. Bits: 00000010
Readiness: 0000 0101
Part No SW: 4F1 910 156 P HW: 09L 927 156 A
Component: AG6 09L 3,2 FSI USA 0010
Revision: --H01--- Serial number: 4025867
Shop #: WSC 02335 785 00200
VCID: 31630EB1A8E531CC98-8064
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Coding: 0016799
VCID: 2D5B12C1B4DD552CBC-8078
Component: FBSAUDIC6 ELV H30 0170
Revision: 17040501 Serial number: 10600300135994
Coding: 0000143
Shop #: WSC 07109 444 65458
VCID: 63CFB4F9A299D35C5A-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H44 0070
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H26 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
Fault Status: 00100001
Reset counter: 32
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 360DI057523065
Coding: 0000003
VCID: 2143FEF1F805814C08-8074
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000143989
Subsystem 3 - Serial number: 0120.04.050000000100010106ÿ
Subsystem 4 - Serial number: 010106ÿ
00384 - Optical Databus
Fault Status: 00101011
Fault Frequency: 125
Reset counter: 39
Mileage: 228658 km
Date: 2018.05.23
Time: 11:24:35
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0150
Revision: 00000026 Serial number: 00000030016936
Coding: 0524582
VCID: 5BBF8C199AE9EB9C12-800E
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Coding: 0013123
VCID: 66C9ADED51ABA674BD-8032
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00141886
Shop #: WSC 02335
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7158818
VCID: 1B3FCC19DA69AB9CD2-804E
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 E HW: 4E0 035 593 A
Component: SDAR
Serial number: AUZ4Z7D2021847
VCID: 2953E6D18035490C50-807C
Reset counter: 248
Mileage: 228658 km
Date: 2018.05.23
Time: 11:12:14
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D08CE4P
Coding: 0013622
Shop #: WSC 40233 444 83861
VCID: 2649EDED912B66747D-8072
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME084866531
Subsystem 3 - Serial number: 6342CSME095138491
Subsystem 4 - Serial number: 6351HSME07085324$
Subsystem 5 - Serial number: 6361HSME07001029U
Subsystem 6 - Serial number: 6371VSME071B5D21N
Subsystem 7 - Serial number: 6381VSME066F0A6B
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0310
Revision: 00H01000 Serial number: 90026051440478
Coding: 0002242
Shop #: WSC 02323 785 00200
VCID: 2757E0E996217F7C46-8072
Component: E0221 H07 0090
Part No SW: 4F0 910 930 A HW: 4F0 920 980 N
Component: KOMBIINSTR. M73 H15 0630
Revision: 01000000 Serial number: 4PY52RW45
Coding: 2161263
Shop #: WSC 07109 444 999999
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 1200805428809A
Coding: ECFE7BCD1B7906
Shop #: WSC 07109 444 52498
Fault Frequency: 19
Reset counter: 54
Mileage: 228658 km
Date: 2018.05.23
Time: 11:26:05
Address 34: Level Control Labels: None
Part No SW: 4F0 910 553 HW: 4F0 907 553
Component: J197 LUFTFEDER H15 0040
Serial number: 006280004517
Coding: 0000210
VCID: 61C3BEF1B885C14C48-8034
Reset counter: 33
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H44 1100
Revision: 00000000 Serial number: 378DR057521094
VCID: 387533954B9FE084DF-806C
02927 - DVD Read Error
Fault Frequency: 10
Reset counter: 39
Mileage: 228658 km
Date: 2018.05.23
Time: 12:56:56
Hex Value: 0x5B08
Hex Value: 0x4756
Hex Value: 0x0401
Hex Value: 0x0000
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00-00000
Coding: 0052971
Part No SW: 4F0 910 289 B HW: 4F0 907 289 B
Component: Komfortgeraet H18 0130
Revision: 01300018 Serial number: 01004042370000
Coding: 7764669
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 A HW: 4F0 035 223 A
Component: DSP-High C6 H09 0140
Revision: PROD_01 Serial number: 00000000782185
Coding: 0000126
VCID: 1C3DCF05DF67ACA4DB-8048
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000000614
Coding: 0002114
VCID: 5EB9850D89FBFEB475-800A
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00-00000
Coding: 0052971
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: 5DBB820184FDE5AC6C-8008
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Coding: 0000017
Shop #: WSC 02331 785 00200
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H02 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394EX057543394
VCID: 234FF4F9E219935C1A-8076
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000028101
Shop #: WSC 00477 384 00291
Subsystem 1 - Part No: 4F0 915 105 E
Component: von JCB 1504220025
Coding: 34463039313531303545204A434231353034323230303235
00532 - Supply Voltage B+
Reset counter: 33
Mileage: 228658 km
Date: 2018.05.23
Time: 11:35:29
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0052778
VCID: 69D3A6D140B5890C90-803C
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 HW: 4F0 907 273
Component: Reifendruck 3 H04 0080
Revision: 00040080 Serial number: 00000900004252
Coding: 0062221
Shop #: WSC 07109 444 54528
VCID: 60C5BBF5B38FC84447-8034
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Revision: 00000000 Serial number: 00000503290361
Shop #: WSC 12336 024 394758
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 B
Component: ValeoHeckdeckel H14 0280
Revision: --H14001 Serial number: E5030000B
Shop #: WSC 23250 431 715754
VCID: 6CDDDFC54F479C24EB-8038
Subsystem 1 - Part No: 4F9 910 592
Subsystem 3 - Serial number: KK09.05.05--H14001001A0047ÿ
Subsystem 4 - Serial number: 1A0047ÿ
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0052778
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0020
Revision: 00H09000 Serial number: 00000000000000
Coding: 0201216
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H10 0440
Revision: 00000000 Serial number: 00000007521090
Coding: 0010900
VCID: 2241F1FDFD039A5411-8076
End-------------------------(Elapsed Time: 03:21)--------------------------
