VW t5 and t6 security access problem
   #21
milanocito
Middle East
C?ID=322802
vw t5 2015
Thursday,18,October,2018,13:17:23:08971
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
VIN: WV2ZZZ7HZFH127303   License Plate:
Mileage: 312260km-194029mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 0B
VIN: WV2ZZZ7HZFH127303   Mileage: 312260km-194029miles
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H45 6303
   Revision: 26H45---    Serial number: 00000000000000
   Coding: 01194012230400080000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GH 003004
   ROD: EV_ECM20TDI01103L906019FM_003.rod
   VCID: F7BE832B4EEECFF264-80A2
6 Faults Found:
5111 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
          P0135 00 [039] - Malfunction
                    Mileage: 312261 km
                    Date: 2018.10.18
                    Time: 13:57:49
                    Coolant temperature: 58 °C
                    Intake air temperature: 35 °C
                    Ambient air pressure: 910 mbar
                    Voltage terminal 30: 12.440 V
5253 - Diesel Particle Filter; Differential Pressure Sensor
          P2452 00 [039] - Elect. Malfunction
                    Mileage: 312261 km
                    Time: 00:00:00
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 12.600 V
                    Sensor for particle filter differential press: raw value: 1057 hPa
                    Particle filter: difference pressure: -5 hPa
                    Particle filter: offset for differential press.: 3 hPa
                    Particle filter: differential pressure: dynamic offset: 5 hPa
                    Outside air temperature: 26.5 °C
                    Particle filter: soot mass measured: 8.02 g
                    Particle filter: soot mass calculated: 22.77 g
4911 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [167] - Malfunction
                    Mileage: 312261 km
                    Date: 2018.10.18
                    Time: 13:57:47
                    Voltage terminal 30: 12.460 V
                    Exh.gas temp.sen 1: 65.0 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 1000.0 °C
                    Exh.gas temp.sen 4: 1000.0 °C
                    Shut-off timer: last engine shut-off time: 907 s
4912 - Exhaust Gas Temperature Sensor 4 Bank 1
          P246E 00 [167] - Electrical Malfunction
                    Mileage: 312261 km
                    Date: 2018.10.18
                    Time: 13:57:47
5257 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [039] - Malfunction
                    Mileage: 312261 km
                    Date: 2018.10.18
                    Time: 13:57:43
                    Shut-off timer: last engine shut-off time: 903 s
5258 - Exhaust Gas Temperature Sensor 4 Bank 1
          P246E 00 [039] - Electrical Malfunction
                    Mileage: 312261 km
                    Date: 2018.10.18
                    Time: 13:57:43
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 L    HW: 7E0 907 379 L
   Component: ESP MK25A XT  H50 0113
   Revision: 00H50001
   Coding: 108724AD09A6089C24A590713A6112
   Shop #: WSC 02757 790 49152
   VCID: BB365F1B3A462B9240-80EE
02214 - Tire Pressure Warning
                    Reset counter: 34
                    Mileage: 308536 km
                    Date: 2018.10.04
                    Time: 03:35:31
                    Count: 16384
                    Count: 4097
                    Count: 397
                    Count: 766
   Component: LENKW.SENSOR  H07 0070
   Serial number: 15021504650684
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: FEB0960F61D4FEBA27-80AA
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 AF    HW: 7E5 907 040 AF
   Component: ClimatronicT5 H19 0407
   Revision: 00001004
   Coding: 0000000502
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: EC94AC4707A87C2A99-80B8
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0010403150015283
9474929 - Motor for Rear Air Distribution
          B1093 71 [008] - Actuator stuck
                    Reset counter: 43
                    Mileage: 295502 km
                    Date: 2018.08.19
                    Time: 00:03:55
9476629 - Position Sensor for Rear Air Distribution Flap Motor
          B109A 15 [008] - Open or Short to Plus
                    Fault Frequency: 61
                    Reset counter: 25
                    Mileage: 291167 km
                    Date: 2018.08.06
                    Time: 01:06:19
9480753 - Control/Display Unit for Rear Climatronic
          B10AA 31 [008] - No Signal
                    Reset counter: 42
                    Mileage: 309740 km
                    Date: 2018.10.08
                    Time: 22:09:48
   Part No SW: 7H0 937 087 P    HW: 7H0 937 087
   Component: BCM T5GP H+4  H34 0424
   Revision: BO034001    Serial number: 0673 055150167
   Coding: 62B0F93A0A212012002008106C2B8DD40000612F60840000320000000800
   Shop #: WSC 02739 790 00000
   VCID: C1CA2DF358AA41421A-8094
   Subsystem 1 - Part No SW: 7E0 959 801 J    HW: 7E0 959 801 J  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU025021550563840
   Coding: 0000A1
   Subsystem 2 - Part No SW: 7E0 959 802 J    HW: 7E0 959 802 J  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8654
   Serial number: KU0KU024021550553425
   Coding: 1000A1
03301 - Response Closing Status of Drivers Door
                    Fault Frequency: 118
                    Reset counter: 17
                    Mileage: 309652 km
                    Date: 2018.10.08
                    Time: 07:10:46
03589 - Switch for Driver Side Window Regulator
                    Fault Status: 00101110
                    Reset counter: 41
                    Mileage: 309652 km
                    Date: 2018.10.08
                    Time: 07:11:54
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231501901837
   Coding: 108004
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001003
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: BB365F1B32462B9240-80EE
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00VPM6$
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02754 790 50316
   VCID: B52249231462FDE2B6-80E0
   Part No SW: 7E0 920 870 N    HW: 7E0 920 870 N
   Component: KOMBI         H04 0805
   Coding: 160E01
   Shop #: WSC 02737 790 50316
   VCID: B42474271F18E4EA81-80E0
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H34 0424
   Revision: BO034001
   Coding: 042200
   VCID: F0ACB837238098CAA5-80A4
   Component: IMMO          H04 0805
   VCID: EA98AA5F0D5C621AEB-80BE
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  037 0144
   Revision: 00000001    Serial number: VWZ1Z3I4290532
   Coding: 0500040004
   VCID: E582D963EC424D62C6-80B0
6 Faults Found:
                    Reset counter: 29
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:09
                    Reset counter: 29
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:09
                    Reset counter: 143
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:05
                    Reset counter: 143
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:05
                    Reset counter: 143
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:17
03138 - Input AUX IN
                    Reset counter: 143
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:08
End----------(Elapsed Time: 01:09, VBatt start/end: 12.5V/12.4V)-----------
Address 01,,channel IDE01637-Service regeneration of particulate filter while driving,adapted from,0 ,to,1 ,
milanocito
Middle East
C?ID=322802
vw t5 2015 same problem
i traied to reset dpf and to do regeneration while driving ...it is asking for security access ...and security access was accepted
6 Faults Found:
                    Mileage: 312261 km
                    Date: 2018.10.18
                    Time: 13:57:49
                    Mileage: 312261 km
                    Time: 00:00:00
                    Mileage: 312261 km
                    Date: 2018.10.18
                    Time: 13:57:47
                    Mileage: 312261 km
                    Date: 2018.10.18
                    Time: 13:57:47
                    Mileage: 312261 km
                    Date: 2018.10.18
                    Time: 13:57:43
                    Mileage: 312261 km
                    Date: 2018.10.18
                    Time: 13:57:43
   Revision: 00H50001
                    Reset counter: 34
                    Mileage: 308536 km
                    Date: 2018.10.04
                    Time: 03:35:31
                    Count: 16384
                    Count: 4097
                    Count: 397
                    Count: 766
   Coding: 01
   Revision: 00001004
   Coding: 0000000502
   Slave 1:
                    Reset counter: 43
                    Mileage: 295502 km
                    Date: 2018.08.19
                    Time: 00:03:55
                    Fault Frequency: 61
                    Reset counter: 25
                    Mileage: 291167 km
                    Date: 2018.08.06
                    Time: 01:06:19
                    Reset counter: 42
                    Mileage: 309740 km
                    Date: 2018.10.08
                    Time: 22:09:48
   Coding: 0000A1
   Coding: 1000A1
                    Reset counter: 17
                    Mileage: 309652 km
                    Date: 2018.10.08
                    Time: 07:10:46
                    Reset counter: 41
                    Mileage: 309652 km
                    Date: 2018.10.08
                    Time: 07:11:54
   Coding: 108004
   Coding: 160E01
   Revision: BO034001
   Coding: 042200
   Coding: 0500040004
6 Faults Found:
                    Reset counter: 29
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:09
                    Reset counter: 29
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:09
                    Reset counter: 143
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:05
                    Reset counter: 143
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:05
                    Reset counter: 143
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:17
                    Reset counter: 143
                    Mileage: 171155 km
                    Date: 2017.03.26
                    Time: 03:14:08
AIB Wolfgang
Hello
Sorry, but did you ever read what Sebastian mentioned above?
There will be no regeneration with such faults stored!
Please, first eliminate all stored faults by repairing them. And then..........
Regeneration will work fine:popcorn:
   #24
milanocito
Middle East
C?ID=322802
first thing i did auto scan ,,,,
i did fixed dtc and erase ,,,
it is not just one car ,,,,i repir this cars ,,,,,
