Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 05.5 Jetta TDI Not Running
    The wire harness under the VC to the Injectors and glow plugs is kaput, & maybe even back to ECU
    Isolate all and to main connector and correct the condition of chafe........very common!
    Check or replace all blown fuses!
    Get a new battery!
  2. Likes MartinsX liked this post
  3. #12
    Jun 2018
    I had started to look for chafe under the battery as I had heard that was a common area, I had also checked all the fuses in the engine harness bay and in the dash and replaced those. The battery is 2 years old I think. You are saying the section of harness that runs to the injectors is chafe prone?
  4. #13
    Fails beneath the VC and externally..........
  5. #14
    Jun 2018
    Ok good to know, what are some of the other common points external to the valve cover? I am hoping to have some time this weekend to check.
  6. #15
    Remove ECU and tone generate and qualify every track under the VC for load test & ability to carry current using WD.
    No magic!
    Work .....time to RTFB & work!
    You better check fuses and consumer B+ supply!
    Check car and ECU for FOD water ingress!
  7. #16
    Jun 2018
    Took a quick glance last night and found chafed wires on the back side of the head running to the turbo. Will complete more extensive check this weekend
  8. Likes Uwe liked this post
