Results 1 to 8 of 8
Thread: Fitting Adaptive Cruise Control to a 2008 Touareg V6TDI
    Verified VCDS User hedditch's Avatar
    Oct 2014
    Australia
    Question Fitting Adaptive Cruise Control to a 2008 Touareg V6TDI
    I an currently in the process of Retrofitting Adaptive Cruise Control
    (ACC) into my 2008 V6 3.0 TDI (CASA) Touareg. This is exactly the
    same as has been done by two other members on the Club Touareg Forum,
    however one had a V10 TDI and the other had a V8 Gas engine. I
    currently have all the coding information I require with the exception
    of the Engine Codes, which I am a little uncertain about.
    On the V10 the code changes have been determined to be as follows...
    1. Go into the gateway module #19 I believe.
    enable the #13 module for acc
    2. Code the ABS unit #03 I believe
    go to coding, whatever # is there add +2048 to it. For example mine was
    008578 + 2048 = 10626
    3. Activate the acc in the ENGINE #01 module
    first deactivate the CCS. Go to "coding II" - type 16167 to deactivate.
    Then type in 13377 to activate acc . If you somehow need to revert to regular ccs
    the activation code is 11463
    4. Under the steering wheel # 16 you will need to select the correct
    switch coding. Mine is 0010222
    My only area of concern is point #3 - Engine #01 -
    Can anybody tell me what changes, if any need to be done to the engine coding the support the ACC fitment?
    Kind regards
    Stuart.
    Please post up some real scan data so people can see exactly what ECU you have.
    Oct 2014
    Australia
    Saturday,24,November,2012,10:49:39:04442
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Stuart
    Chassis Type: 7L - VW Touareg
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGZZZ7LZ8D046567   Mileage: 127160km/79013miles
    Address 01: Engine (CAS)       Labels: 059-907-401-CAT1.clb
       Part No SW: 7L0 907 401 N    HW: 7L0 907 401 H
       Component: 3.0TDI EDC17G104AG  0060
       Revision: --H02---    Serial number: VWX3Z0G1687973
       Coding: 04210023590F0D68
       Shop #: WSC 12345 123 54321
       VCID: 36693693425627A8CB9
    Address 02: Auto Trans        Labels: 09D-927-750.lbl
       Part No SW: 09D 927 750 FT    HW: 09D 927 750 FT
       Component: AL 750 6A           1168
       Revision: 00H75000    Serial number:
       Coding: 0012392
       VCID: 850B015FCF30FC30923
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
       Part No SW: 7L0 907 379 L    HW: 7L0 907 379 L
       Component: ESP ALLRAD MK25E1   0303
       Revision: 00H53001
       Coding: 0004482
       Shop #: WSC 31414 790 00001
       VCID: 42815A43199E8B08771
       Part No SW: 3D0 909 139 B    HW: 5WK 485 04
       Component:    Kessy            6840
       Revision: 68406620    Serial number: VWX3Z0G1687973
       Coding: 0000232
       VCID: 2855E8EB9FE24158495
       Part No: XXXXXXXXXXX
    Address 08: Auto HVAC        Labels: 7L6-907-044.clb
       Part No: 7L6 907 044 AF
       Component: CLIMAtronic 2+2     4331
       Coding: 0020020
       VCID: 78F5F8AB0FC211D8195
       Part No: 7L6 907 049 F
       Component: CLIMAtronic FOND    0503
    Address 09: Cent. Elect.        Labels: 7Lx-937-049-V2.clb
       Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
       Component: J519                2000
       Revision: -0004---    Serial number: --------------
       Coding: 600004003B221C000000000000000000
       VCID: 8005104BD712D918A15
    Address 15: Airbags        Labels: 7L0-959-655.lbl
       Part No SW: 7L0 959 655     HW: 7L0 959 655
       Component: J234  39 VW8T       0250
       Revision: 92011025    Serial number: 0039P003JRFF
       Coding: 0013113
       VCID: FAF162A3B1CE83C8EF1
    Address 16: Steering wheel        Labels: 7L6-953-549.lbl
       Part No: 7L6 953 549 F
       Component: J527                3601
       Coding: 0010011
    Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
       Part No SW: 7L6 920 890 K    HW: 7L6 920 890 K
       Component: J285 KOMBI-INST.    9733
       Revision: KHH06V02
       Coding: 0005701
       Shop #: WSC 30021 000 1048576
       VCID: 4085504B13929918615
    Address 19: CAN Gateway        Labels: 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 7L6 920 890 K
       Component: J533  GW-K-CAN TP20 9733
       Coding: 7FE2E7EBC8046003
       VCID: F0E5408BE3B2C998515
       Part No: 0AD 927 755 BG
       Component: TRANSFERCASE        0126
       VCID: 8103154FDB18D010AEB
    Address 34: Level Control        Labels: None
       Part No: 7L0 907 553 J
       Component: LUFTFDR.-CDC- 3C3P1 3125
       Coding: 0015521
       VCID: 3A7122A3714EC3C82F1
       Part No SW: 7L6 035 680 C    HW: 7L6 035 680 A
       Component: RNS-MID       H04 3810
       Revision: AB001001    Serial number: VWZ6Z7G7272099
       Coding: 06010402040000210000
       ASAM Dataset: ------------------------- ------
       VCID: 32610A836D3E3B88E71
    Address 46: Central Conv.        Labels: 7L0-959-933.lbl
       Part No: 7L6 959 933 A
       Component: 1A HSG              0600
       Coding: 0000081
       VCID: 4085504B10929918615
       Part No: 7L0 959 701 R
       Component: Tuersteuergeraet FS 6302
       Part No: 7L0 959 702 R
       Component: Tuersteuergeraet BF 6302
       Part No: 7L6 959 703
       Component: Tuersteuergeraet HL 0202
       Part No: 7L6 959 704
       Component: Tuersteuergeraet HR 0202
       Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
       Part No: 7L6 951 171 B
       Component:    Innenraumsensor  0020
    Address 55: Xenon Range        Labels: 7L6-907-357-A.lbl
       Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
       Component: AFS-Steuergeraet    0001
       Revision:   H02       Serial number:
       Coding: 1288579
       VCID: 39733DAF7448C8D026B
       Subsystem 1 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul l    X008
       Coding: 00000019
       Subsystem 2 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul r    X008
       Coding: 00000019
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L6 955 119 C
       Component: J400__ Front Wiper  5301
       Coding: 0001397
       VCID: 3A7122A3754EC3C82F1
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     271107 046  0204
       Coding: 00208933
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
       Component: ANHAENGERELEKTRONIK 8854
       Coding: 0000001
       Shop #: WSC 12345 123 12345
       VCID: 387538AB4F42D1D8D95
       Part No SW: 7L6 907 441 B    HW: 7L6 907 441 B
       Component: J772__Rearview      0033
       Revision: 00H13000    Serial number:    PA8 J860593
       Coding: 0010001
       VCID: 346D0C9B572A35B8F5D
    Address 76: Park Assist        Labels: 3D0-919-283.lbl
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
    Address 77: Telephone        Labels: RETROFIT77.lbl
       Part No SW: KTC 364 96P     HW: KTC 364 96P
       Component: SWP:3.24.7      H24 0212
       Shop #: WSC 21977 142 74100
       VCID: 3E792EB36966EFE8139
    For #3 coding should be:
    04210023590F0E68
    You can see that, if you press [Long Coding Helper].
    PS. update your VCDS.
  5. Likes jakematic, Uwe, Dana liked this post
    Oct 2014
    Australia
    Old Scan...
    Thank you very much for that, now the install begins..
    Stuart.
    Oct 2014
    Australia
    ACC Installed and working
    Just thought I should close out this thread..
    I have now installed ACC in my 2008 Touareg V6TDI and it works perfectly...My Modified Scan Log is attached for information.. (Address 13 Auto Distance Regulation)
     Tuesday,30,June,2015,13:10:23:04442
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    Dealer/Shop Name: Hedditch
    Workshop Code: 123 12345 054321
    VIN: WVGZZZ7LZ8D046567   License Plate: XVG493
    Mileage: 196240km-121937mi   Repair Order:
    Chassis Type: 7L (6N0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 22 28 34 37 46 55 56 68 69
              6C 76 77
    VIN: WVGZZZ7LZ8D046567   Mileage: 196240km-121937miles
    68-Wiper Electr. -- Status: OK 0000
     Touarge
       Component: 3.0TDI EDC17A104AG  0060
       Coding: 04210023590F0E68
       VCID: 3669369342562791843-508E
       Coding: 0012392
       VCID: 050B815F4F307C095D9-50C8
       Revision: 00H53001
       Coding: 0014722
       VCID: 42815A43199E8B3138B-8017
       Coding: 0000232
       VCID: 2855E8EB9FE2416106F-807D
       Coding: 0020020
       VCID: 78F5F8AB0FC211E156F-802D
       Subsystem 1 - Part No: 7L6 907 049 F
       Coding: 600004002B221C000000000000000000
       VCID: 0005904B571259216EF-8055
    Address 13: Auto Dist. Reg        Labels: None
       Part No SW: 7L6 907 567     HW: 7L6 907 567
       Component: AC201  RDW 1    030 0363
       Revision: 00030000    Serial number: 00000000003464
       Coding: 0010000
       Shop #: WSC 98765 666 38533
       VCID: 7BFFE7A73EF43AF93BD-802E
       Coding: 0013113
       VCID: 7AF1E2A331CE03F120B-802F
       Coding: 0010021
       Revision: KHH06V02
       Coding: 0005701
       VCID: 4085504B139299212EF-8015
       Coding: FFE2E7EBC8046003
       VCID: 70E5C08B63B249A19EF-8025
       VCID: 0103954F5B185029611-50E6
    Address 28: HVAC, Rear
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Coding: 0015521
       VCID: 3A7122A3714EC3F160B-806F
       Component: RNS-MID       H04 5238
       Coding: 0E0004020400002100
       VCID: 32610A836D3E3BB1A8B-8067
       Coding: 0000081
       VCID: 4085504B109299212EF-4A9C
       Subsystem 1 - Part No: 7L0 959 701 R
       Subsystem 2 - Part No: 7L0 959 702 R
       Subsystem 3 - Part No: 7L6 959 703
       Subsystem 4 - Part No: 7L6 959 704
       Subsystem 5 - Part No: 7L0 907 719 A
       Subsystem 6 - Part No: 7L6 951 171 B
    Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
       Coding: 1288579
       VCID: 39733DAF7448C8E9691-806C
       Coding: 00000019
       Coding: 00000019
       Coding: 0001397
       VCID: 3A7122A3754EC3F160B-806F
       Coding: 00208933
       Shop #: WSC 31414
       Coding: 0000003
       VCID: 387538AB4F42D1E196F-806D
       Revision: 00H13000    Serial number:    PA8 J790212
       Coding: 0010001
       VCID: 346D0C9B572A3581BA7-8061
    Address 76: Park Assist        Labels: Redir Fail!
       VCID: 3E792EB36966EFD15C3-806B
    End-------------------------(Elapsed Time: 03:36)--------------------------
    Kind regards and many thanks....
    Stuart........
  8. Likes Uwe, AIB Wolfgang liked this post
    Jun 2014
    Well done !!!!
    I also retrofited ACC in Touareg V10 BLE engine , but 7LA model.
    Possible, but not easy.
  10. #8
    Dec 2018
    Iím looking into putting acc on my 2010 Touareg, thanks for the scan info but what sensors did you use? The dual newer ones or were you able to track down the emblem one. I know vw made very few that werenít even sold in the states with adaptive cruise (the only one I know of was a vw training center Touareg)
