Adjusting matrix headlight activation speed
paradyne
C?ID=42816
I'm looking to adjust the activation speed of the matrix headlight high beam on my 2018 S5 (UK model). Much as I did with the high beam assist on my older B8.5 A5, it will suit the roads around here better with a lower activation speed.
I have done a scan of the adaption map for module 'A5 - Frt Sens. Drv. Assist' and it shows two likely entries for this:
IDE03885-Speed threshold for high beam recommendation off,27 km/h,2
IDE03886-Activation speed for high beam assistant,57 km/h,2
However, when I open the controller and go to adaptions these fields are not listed at all, to even try changing them.
What have I missed? Do I need to login first? I haven't been able to find a code yet.
My scans are posted here.
MasterTommy
Amsterdam
C?ID=295586
Please post an auto-scan.
Have you checked other modules involved for any adjustable adaptations?
His scan is here in the Reference Scans section.
That's puzzling. I can't think of any reason why something that shows up in a map wouldn't show up when you try to access it directly.
NEtech
C?ID=56995
You have posted Adaptation maps, from something that is not in the Autoscan of your car (from a MQB Model):
SW:5Q0-980-653-G HW:5Q0-980-653 --- Frt Sens. Drv. Assist
You have this for Address A5: Frt Sens. Drv. Assist (R242):
SW: 8W7 907 217 A HW: 8W7 907 217 A
paradyne
C?ID=42816
Aarghh!! I got my files mixed up! Sorry! That explains the discrepancy. It was from a TT I had for a couple of days.
That still leaves me trying to find a setting for the switch on / off speed.
I will have to remove my autoscan post too, and sort out the correct files. Can't believe I managed to do that!
