hamod_00
New Member
- Jun 25, 2018
- 2
- 0
- Middle East
- HN1-013096 (2nd hand?)
hi for all
can any one help please to coding abs bosch 5.7 for passat
itry many coding and login code without successful
thanks
this log file
thanks
this log file
Monday,25,June,2018,09:21:45:50475
VCDS Version: 18.2.1.2 HEX-NET CB: 0.4411.4
VIN: WVWZZZ3BZ2P222992 License Plate:
Chassis Type: 3B (3A - VW Passat B4 (1994 > 1997))
Scan: 01 02 03 08 15 25 41
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 EP
Component: 1,9l R4 EDC 0000AG 1464
Coding: 00001
Shop #: WSC 00028
VCID: 699A4BCF11BCC90C90-4B1E
WVWZZZ3BZ2P222992 VWZ7Z0A4196145
18261 - Powertrain Data Bus
P1853 - 35-10 - Implausible Message from ABS Controller - Intermittent
18027 - Glow Plug Relay (J52)
P1619 - 35-10 - Open or Short to Ground - Intermittent
18044 - Powertrain Data Bus
P1636 - 35-00 - Missing Message from Airbag Controller
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 3B0 927 156 S
Component: AG5 01V 1.9l-PD RdW 2224
Coding: 00103
Shop #: WSC 00028
VCID: 3620D0B3108256F4CD-5160
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
17087 - Brake Switch (F)
P0703 - 35-10 - Electrical Malfunction - Intermittent
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 00000
VCID: 250207FFBD242D6C74-51F2
66-10 - Not Matched - Intermittent
35-00 - -
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 K
Component: CLIMATRONIC B5GP 0010
Coding: 17000
Shop #: WSC 00028
VCID: 291A0BCFD13C090C50-5184
00818 - Sensor for Evaporator Outlet Temperature (G263)
30-00 - Open or Short to Plus
00797 - Sunlight Photo Sensor (G107)
01271 - Positioning Motor for Temperature Flap (V68)
35-10 - - - Intermittent
35-00 - -
01273 - Fresh Air Blower (V2)
End----(Elapsed Time: 01:17, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
