Results 1 to 6 of 6
Thread: Coding for passat abs bosch 5.7
    New User
    Jun 2018
    Middle East
    hi for all
    can any one help please to coding abs bosch 5.7 for passat
    itry many coding and login code without successful
    thanks
    this log file
    Monday,25,June,2018,09:21:45:50475
    VCDS Version: 18.2.1.2  HEX-NET CB: 0.4411.4
    VIN: WVWZZZ3BZ2P222992   License Plate:
    Chassis Type: 3B (3A - VW Passat B4 (1994 > 1997))
    Scan: 01 02 03 08 15 25 41
    Address 01: Engine        Labels: 038-906-019-AVF.lbl
       Part No: 038 906 019 EP
       Component: 1,9l R4 EDC 0000AG  1464
       Coding: 00001
       Shop #: WSC 00028
       VCID: 699A4BCF11BCC90C90-4B1E
       WVWZZZ3BZ2P222992     VWZ7Z0A4196145
    18261 - Powertrain Data Bus
                P1853 - 35-10 - Implausible Message from ABS Controller - Intermittent
    18027 - Glow Plug Relay (J52)
                P1619 - 35-10 - Open or Short to Ground - Intermittent
    18044 - Powertrain Data Bus
                P1636 - 35-00 - Missing Message from Airbag Controller
    18057 - Powertrain Data Bus
                P1649 - 35-00 - Missing Message from ABS Controller
    Readiness: 0 0 X X X
       Part No: 3B0 927 156 S
       Component: AG5 01V 1.9l-PD RdW 2224
       Coding: 00103
       Shop #: WSC 00028
       VCID: 3620D0B3108256F4CD-5160
    18265 - Load Signal
                P1857 - 35-10 - Error Message from ECU - Intermittent
    17087 - Brake Switch (F)
                P0703 - 35-10 - Electrical Malfunction - Intermittent
       Part No: 4B0 614 517 G
       Component: ABS/ESP front       3428
       Coding: 00000
       VCID: 250207FFBD242D6C74-51F2
                66-10 - Not Matched - Intermittent
                35-00 -  -
       Part No: 3B1 907 044 K
       Component: CLIMATRONIC B5GP    0010
       Coding: 17000
       Shop #: WSC 00028
       VCID: 291A0BCFD13C090C50-5184
    00818 - Sensor for Evaporator Outlet Temperature (G263)
                30-00 - Open or Short to Plus
    00797 - Sunlight Photo Sensor (G107)
    01271 - Positioning Motor for Temperature Flap (V68)
                35-10 -  -  - Intermittent
                35-00 -  -
    01273 - Fresh Air Blower (V2)
    End----(Elapsed Time: 01:17, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    What brakes does it have? Post the PR Codes sticker please.
    Vehicle Identification No. WVWZZZ3BZ2P222992
    Model passat sedan
    PA
    Date of production 27.09.2001
    Year 2002
    Sales type 3B3165
    Engine Code AVF
    Transmission Code EYF
    x
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PA Standard wheel bolts
    Vehicle class differentiation units/platform components 0DE Installation differentiation for build status of vehicle class B5 (VW Passat)
    Emission standard 0GE Emission standard EU3
    Trailer hitch 1D0 without trailer towing
    airbag 4UE driver and front passanger airbags
    Automatic transmission indicator light 9FB Automatic transmission indicator light
    Aktivkohlebehälter / Ottopartikelfilter 1E0 Without activated charcoal canister
    Storage compartment 7N0 Without overhead storage compartment
    Aerials 8L3 roof antenna
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SL Left exterior mirror, aspherical
    Right exterior mirror 5RQ Right exterior mirror: convex
    Alternative drive system 0K0 Without alternative drive system
    Drive type 1X0 Front-wheel drive
    Outside temperature display 9Y0 Without outdoor temperature gage
    Equipment levels A8S Standard equipment
    Brake type in rear 1KD Disc brakes in rear
    batteries J0R Battery 380 A (80 Ah)
    Brake type, front 1ZC Disc brakes in front (Geomet D)
    Controls (steering wheel/steering column) 4LA Without control element
    Beverage holders 4M6 Beverage holders
    Component part sets with country-specific design requirements B0A build parts set without county specific documentatio
    floor covering 3MQ Ibolours floor covering
    Brake systems 1AT electronic satbility programme -ESP-
    Owner's manuals 0VF Information kit in English
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    Chrome package QJ0 Without aluminum/chrome work package
    General operating permit, alterations C04 Operating permit, alteration
    Shock absorption/suspension, chassis 1BA Federung/Daempfung, standard
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FA roof without cut out
    Load-through hatch/ski bag 3X0 without load through system
    Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
    Theft protection system 7AA Electronic immobilizer
    Inserts 5MA Decorative inserts
    Interference suppression 8E2 Local interference suppression for FM/AM radio reception
    Park distance control 7X0 Without park distance control
    Manufacturing sequence differentiation 0FG Mosel manufacturing sequence
    window regulator 4R3 Power windows with comfort operation
    fire extinguisher 6A0 without fire extinguisher
    Malfunction display 9HA Without additional malfunction display
    Headlight activation 8K0 Without special driving light switching
    Antifreeze 1C1 Antifreeze up to -25 degree Celsius tolerance up to -30 degree C
    throttle control 0L2 accelerator pedal with electronic modul
    Alternators 8GL Alternator 120 A
    Transmission types/gearshift mechanisms 0G7 tiptronic
    Transmission shafts, rear axle 1YA Without transmission shafts f. rear axle
    Transmission shafts 1WD Transmission shaft for tripod joints
    Weight category rear axle 0YD Weight range 4 installation control only, no requirement forecast
    Weight category front axle 0JK Weight category front axle weight range 10
    Base engine T9J 4-cylinder diesel engine 1.9 l unit 038.K
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    cruise control system 8T0 Without cruise control system (CCS)
    Exterior noise suppression measures 2B1 additional noise dampener
    Garage door opener VC0 without Garage door opener
    Transmission specifications G0F Five-speed automatic transmission
    Cruise control system and speed limiter 6Y0 without speed warning system
    glove box 4Z2 glove box, lockable
    Center high-mounted stop light 8R1 Center high-mounted stop lamp
    handle for hand brake lever 6PA Hand brake lever handle in plastic
    Rear seats 3NZ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8BG Twin-headlamps for driving on the right, with integrated high beam
    Instrument clusters U0C Instrument cluster with tachometer, clock and km/h speedometer
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    Sticker (customized or special edition) 0KA Without decals and emblems
    Body style K8B Notchback
    Luggage compartment floor covering 6SD Luggage compartment floor covering in needle-punched nonwoven (dimensionally stable)
    Cassette and CD storage unit 4W0 without cassette / CD tray
    Child seats QA0 without child seat
    Climatic zones 0Y1 Standard climatic zones
    headrest for seat, rear 3Q1 headrest for seat, rear
    Head restraints 3J7 Tilt- and height-adjustable head restraints for front seats
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Body measures 5C0 Without special body measures
    Catalytic converter control 8KA without catalyst control
    Front license plate bracket 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K1 Transit coating (wax)
    Paint coating FB3 Surface, interior trim, soft-touch paint
    Rear cargo area 3GK Without add. lower section for luggage comp. floor
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S4 Two reading lights front, two rear
    steering 1N1 Power steering
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 2PQ Steering wheel for airbag system
    Speaker installation 8RE 4 speakers (passive)
    Headlight range control 8Q1 Headlight range control
    Center armrest 6E3 Front center armrest
    Multi-function display/trip computer 9Q0 Without multi-function display/ trip computer
    Engine cooling 8Z6 Engine cooling, version 2
    Engine specifications D3E 4-cyl. turbo diesel engine 1.9 L/96 KW TDI Unit injector, EU3 Basic engine is: T9J
    Left vanity mirror 4SD Vanity mirror, left, illuminated
    Right vanity mirror 4TD Vanity mirror, right, illuminated
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TC Rear fog light for driving on the right
    Front fog lamp/additional headlamp 8WA Without fog lights
    Rear of platform module base 4P1 Rear floor panel module, type 2
    Hubcaps 1NC Full wheel covers
    Wheels C5E Steel wheels 6J x 15 ET 37
    Radios 8AA without radio
    Smoker's/non-smoker's package 9JB Smoker's package, ashtrays in front and rear
    Tire pressure monitoring system 7K0 Without tyre pressure monitor
    tire H6S 195/65 R15 V tyres
    Spare wheel/breakdown kit 1G2 Spare wheel with full tyre, steel
    Restraint systems, front 3QT 3-point seat belts in front, with tensioner and height adjustment
    PH2 air con "Climatronic", free of cfc
    SQ5
    Gearshift knob/handle 6Q1 Gearshift knob/handle in plastic
    Special labels/plates 0SC Labels in English
    Tail lamp assemblies 8SA Rear combination lamp, standard design
    Materials of low flammability 4Q1 Materials of low flammability
    Seat belt check 9P0 without press button buckle with warning contact
    Center rear seat belts 3C3 Lap belt with retractor for the center rear seat
    Gearshift boot/cover 6R0 Gearshift boot for automatic transmission
    seat covers N0U Cut pile seat covering
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A0 without seat heater
    Safety certificate 0LA Without special labels safety certificates
    Side lights 8F2 side-mounted turn signals
    Voice enhancer VX0 Without voice enhancer
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B1 Protective side molding
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
    power outlet 7B6 12-volt socket(s)
    Bumper 2JB Standard bumpers
    parking light warning lamp 8NA without parking light warning lamp
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Nameplate set 1DG "TDI" (PD) lettering set
    Special alarm systems 9A0 Without taxi alarm system
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B22 Type approval country Israel
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 MHz
    Partition 3CA without partition
    Door and side trim panels 3LD door and side trim panels
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Assembly parts for engine (drive bearing) 1VG Assembly part for 4-cyl. engine
    Front underbody guard 1SA Without additional front underbody guard
    Identification plates 1EY Special identification label with weight data, but without general operating permit (ROW)
    First aid kit / warning triangle 1T2 warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Front seats Q2J convenience seat
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    LongLife Service Regime QG2 LongLife Service Regime cannot be activated
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GH Windshield in heat-insulating glass with sunshield
    floor mats 0TA without floor mats
    Decorative trims 4ZB Bright decorative trims
    Additional body panels, side 6EP Additional stone guard body covers
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    Duty-free tires 1V0 Without duty-free and cost-free tires
    Additional dust seals 6U0 Without additional seals outside
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  4. Likes Boki Ar liked this post
    With the PR Codes data, we can refer to this Wiki Page and deduce the following:
    Login:
    0?xxx: Chassis - 9 = VW Passat
    0x?xx: Brakes - 5 = (PR-1LB/1LE/1ZC)
    0xx?x: Engine - 5 = (PR-T5X/T4N/T9J*/T6T/T1K/T1E/T7F*) (*with Brakes: PR-1LB/1LE/1ZC)
    0xxx?: Transmission - 7 = Automatic (PR-G0E/G0F/G0Q)
    So the Login is 09557
    Coding:
    0?xxx: Chassis - 4 = VW Passat
    0x?xx: Brakes - 2 = (PR-1LB/1LE/1ZC)
    0xx?x: Engine - 5 = (PR-T5X/T4N/T9J*/T6T/T1K/T1E/T7F*) (* with Brakes: PR-1LB/1LE/1ZC)
    So the Coding is 04257
    Now watch this video:
    Indeed your Excellency.....
    New User
    Jun 2018
    Middle East
    ok thanks its work my freind
