Results 1 to 3 of 3
Thread: Audi A4 8W trailer retrofit, recoding 17 and A5
    Jun 2018
    Hi all,
    I just got an A4 in from the dealer (yeah, that's right) which has a trailer module retrofitted.
    Now both the instruments (17) and the Frt. Sense drive assist (A5) need an alteration to there coding in order to add trailer(module) support.
    Since there is no coding help (yet) for these modules, does somebody now what the codings should be?
    Tuesday,19,June,2018,10:57:46:51329
    VCDS Version: 18.2.1.2 (x64)
    VIN: WAUZZZF40JA124676   License Plate:
    Mileage: 15201km-9445mi   Repair Order:
    Chassis Type  F4-AU49 (8W5)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 46 52 5F 69 6D 81 A5 BB BC
    VIN: WAUZZZF40JA124676   Mileage: 15201km-9445miles
    46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CVNA)       Labels: None
       Part No SW: 04E 906 022 B    HW: 04E 907 309 R
       Component: R4 1.4l TFS   H22 4032
       Revision: 44H22000
       Coding: 022500324324150834080000000000000000000000000000
       ASAM Dataset: EV_ECM14TFS01104E906022B 002002
       ROD: EV_ECM14TFS011_AU49.rod
       VCID: 1E39D60C017F54B435-804A
    Readiness: 1110 0001
    Address 02: Auto Trans (J217)       Labels:* Redir Fail!
       Part No SW: 8W2 927 155 AD    HW: 0CJ 927 156
       Component: 0CK 14TFSIRdW H05 0002
       Revision: --H05---    Serial number: 0000002738
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002027
       ROD: EV_TCMDL382021_AU48.rod
       VCID: 030F87788ADD995C3A-8056
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
       Component: V553 MTFP  003 0576
       Serial number: 75145041180003000676
       Part No SW: 8W0 907 379 K    HW: 8W0 907 379 J
       Component: ESP9 Plus     H10 0766
       Coding: 04AA049910A40A9A11A4489800835292F4A5D2202008508812004A492FA54B
       Shop #: WSC 06324 790 00001
       ASAM Dataset: EV_ESP9BOSCHCMP 002013
       ROD: EV_ESP9BOSCHCMP_002.rod
       VCID: 4D9B61401C199F2C9C-8018
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 S    HW: 8W0 820 043 S
       Component: Klima Zone 3  H60 0210
       Coding: 240800095544000D02000100880000000000000000000000000000000000
       Shop #: WSC 06335 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 438F4778CA5D595C7A-8016
       Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
       Component: J126 FLuftV  H09 0003
       Serial number: 00000000000002051009
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: F492190900PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 CF    HW: 8W0 907 063 BF
       Component: BCM1 MLBevo   H13 0267
       Coding: 07501143E11800CD0504001058AE80F9110B3108000000000000000020001A810A450122025601
       VCID: 01038D7090C18B4C28-8054
       Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS491 171219  043 0813
       Serial number: 89435300301735301459
       Coding: 5BC7F7
       Serial number: 21027746X81A955555A0
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
       Component: E1 - LDS  H06 0008
       Serial number: 13 12 2017  01214943
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE120111723510160
       Interior Light Module:
       Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: B00641570
       Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2617000199352006
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
       Component: Airbag10.44   H03 0107
       Serial number: 003UP00BUPVQ
       Coding: AACCF0C00C800000585400F3D04C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 006016
       ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
       VCID: 4C9D6C44E70396248B-8018
       Subsystem 1 - Part No SW: -----------    HW: 442 062 811 17
       Serial number: 3577Y00C92532140F33T
       Subsystem 2 - Part No SW: -----------    HW: 442 062 811 17
       Serial number: 3587Y00C126D2BC1A49B
       Subsystem 3 - Part No SW: -----------    HW: 442 0B0 601 18
       Serial number: 3517700BD291FA12E40J
       Subsystem 4 - Part No SW: -----------    HW: 442 0B0 601 18
       Serial number: 3527700B72914AA2945C
       Subsystem 5 - Part No SW: -----------    HW: 442 0C2 507 17
       Serial number: 35575009F2772290421%
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C2 507 17
       Component: FrontSensor_P  1C5 014A
       Serial number: 35675009F277229712AD
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 507 17
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500AF275CB2330CD
       Subsystem 8 - Part No SW: -----------    HW: 442 430 212 17
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00B92532142E1B7
       Subsystem 9 - Part No SW: -----------    HW: 442 430 212 17
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M00C125A1C63F0FP
       Part No SW: 4M0 907 129 KS    HW: 4M0 907 129 KS
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 0B1FAF58A28DD11C42-805E
       Part No SW: 8W5 920 770 C    HW: 8W5 920 770 C
       Component: MMA4T18BENRW  H13 0518
       Revision: 0518v2.0    Serial number:    W7FDLF91U
       Coding: 05A468C0288000080D2069601000000000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       VCID: 40854874DB4B424467-8014
              U1014 00 [009] - -
                        Reset counter: 109
                        Mileage: 15201 km
                        Date: 2018.06.19
                        Time: 10:51:03
       Part No SW: 8W5 907 468 F    HW: 8W5 907 468 E
       Component: Gateway       H42 0123
       Revision: 7A000001    Serial number: 0187A843218112
       Coding: 0301000100000640260700000059001248180007100000000175078E10000000
       ASAM Dataset: EV_CGateCONTIAU491 003111
       ROD: EV_CGateCONTIAU491.rod
       Subsystem 1 - Part No SW: 8W0 951 523 D    HW: 8W0 951 523 D
       Component: J453 MFL  H02 0002
       Serial number: 20180103023310 20064
       Serial number: 5544336404
       Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
       Component: TSG FS        005 0129
       Serial number: 0000298347936
       Coding: 00149B215000000000001082
       Shop #: WSC 06325 790 00001
       ROD: EV_DCU2DriveSideMAXHCONT.rod
       VCID: 4FA77B481615AD3CEE-801A
       Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0410
       Coding: 09000380008000
       ASAM Dataset: EV_EPSZFAU49X 003023
       ROD: EV_EPSZFAU49X_003.rod
       VCID: 4281427CD547505471-8016
    Address 46: Central Conv.
    Interface not compatible.
       Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
       Component: TSG BFS       005 0129
       Serial number: 0000298630559
       Coding: 00149B215C00000000001080
       ROD: EV_DCU2PasseSideMAXHCONT.rod
       VCID: 4E99664C111FA434E5-801A
       Part No SW: 8W0 035 193 H    HW: 8W0 035 193 A
       Component: MU-HS-LN-EU   050 0213
       Coding: 01940201FF0A000053110001000A00102F00016401F00100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP_AU49.rod
       VCID: 3C7D3C84B7A326A43B-8068
       Subsystem 1 - Part No SW: 8W0 919 866 AB    HW: -----------
       Component: ECE 2018  --- 0032
       Subsystem 2 - Part No SW: 8W1 919 604     HW: 8W1 919 604
       Component: DU Std AU49x  H32 0170
       Serial number: TPO00124101700720520
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 N    HW: 8W0 919 614 N
       Component: ControlUnit_B  H22 0134
       Serial number: APVAK127121700040791
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: ConWysTrailer H20 0211
       Serial number: 0384670490
       Coding: 0100000202000000
       VCID: 336F17B89AFDE9DCEA-8066
       Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0163
       Revision: --------    Serial number: 31709400800000
       Coding: 0570
       ASAM Dataset: EV_DeckLidCONTIAU736 001015
       ROD: EV_DeckLidCONTIAU736_AU49.rod
       VCID: 326112BC65E7E0D4E1-8066
       Part No SW: 8W1 713 041 G    HW: 8W1 713 041 J
       Component: GSM-LL        H09 0077
       Revision: 0L0D5012    Serial number: 18011045541594
       ROD: EV_GSMWaehlZFAU736_AU49.rod
       VCID: 377723A88E8505FCD6-8062
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
       Component: BVS           H17 0050
       Coding: 0404090200000403022023A0A50000FC00F0C020C000
       ROD: EV_BVSMLBevKOSTAAU736.rod
    0646 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 109
                        Mileage: 15201 km
                        Date: 2018.06.19
                        Time: 10:51:04
                        Control Module temperature: 29 °C
                        Voltage terminal 15: 12.20 V
       Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
       Component: TSG HFS       005 0129
       Serial number: 0000297714184
       Coding: 000099210000000000001080
       ROD: EV_DCU2RearDriveMAXHCONT.rod
       VCID: 51A37D300021BBCCF8-8004
       Component: TSG HBFS      005 0129
       Serial number: 0000297713985
       ROD: EV_DCU2RearPasseMAXHCONT.rod
    End-------------------------(Elapsed Time: 04:15)--------------------------
    Jun 2017
    MLBevo trailer retrofit coding:
    (if address exists...)
    Address 01: Byte5, Bit4
    Address 13: Byte3, Bit3
    Address 09: Byte13, Bit4 (removable trailer hitch)
    OR Byte36, Bit4 (panning trailer hitch [is this the right english word for it?])
    Address 17: Byte14, Bit5
    Address 46: Byte 14, Bit 6
    Address 3C: Byte0, Bit4
    Address 6C: Byte4, Bit0
    Address 6D: Byte1, Bit7
    Address 74: Byte0, Bit7
    Address A5: Byte11, Bit0
    As you do not own a HEX-V2 or HEX-NET Interface, you cannot complete your coding! (no access to 46...)
    Mar 2017
    Poland
    hadez16 please help me with coding full led a4 8w
    skype milkatrek
