Charging Help PLEASE!! - Im stumped... Alternator only active when VCDS plugged in!
a4bill
Canada
C?ID=340446
Car: 2011 Audi A4 B8 Premium Plus S-Line
Manufacture Date 01/11
Mileage 130938kms
Problem: Alternator seems to only charge when VCDS is connected prior to starting. Reads 13.2v at idle when VCDS is plugged in but drops to battery voltage 12.xxV once car is restarted without VCDS plugged in. If I disconnect VCDS it will stay at 13.2 until I turn car off again.
Problem started after i did an oil change and used a snap on scanner to reset service interval. Maybe affected car?? I didnt go into long coding on that POS.
What Ive changed:
Battery X3 , (2 New Varta and one Optima Red top to be sure)
Coding serial # changed every time another was put in.
Alternator x3 , 1 New Audi, My original rebuilt, and a salvage one.
Battery ground cable with management module x2 1new, 1 salvage
DIAG: (Please disregard the audio codes...I have a custom setup which ive disconnected for all intensive purposes)
Wednesday,20,June,2018,18:12:15:37798
VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: WAUKFCFL7BN0xxxx0   License Plate:
Mileage: 130930km-81356mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 3C 42 46 47 52 53 55 56
          62 72 77
VIN: WAUKFCFL7BN0xxxx0   Mileage: 130930km-81356miles
Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AG    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H19 0002
   Revision: E1H19---
   Coding: 0104010A290F0160
   Shop #: WSC 41810 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
   ROD: EV_ECM20TFS0118K2907115AG.rod
   VCID: 74B1201BDE3215C765F-8020
Readiness: 0010 0101
   Part No SW: 8K0 927 158 K    HW: 0BK 927 156 N
   Component: 0BK 20TFSIUSA H08 0010
   Revision: --H08---
   Coding: 001112
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL551211 001013
   ROD: EV_TCMAL551211_001.rod
   VCID: 3E25C233A0FE8F9743B-806A
   Part No SW: 8K0 907 379 BG    HW: 8K0 907 379 BG
   Component: ESP8 quattro  H04 0020
   Coding: 1D0500
   Shop #: WSC 02391 823 56573
   VCID: 7F5BFF37E7F4469F08D-802A
   Part No SW: 8K0 907 064 CG    HW: 8K0 907 064 CG
   Component: BCM2 2.0      H05 0435
   Coding: 0D0100
   Shop #: WSC 02399 823 56573
   VCID: 77AB1717CFC47EDF40D-8022
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Serial number: 2310000084433007
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01211220101752
   Coding: 64002000
   VCID: 00597CCB9A0A3967717-8054
                    Reset counter: 68
                    Mileage: 130934 km
                    Date: 2010.01.22
                    Time: 00:02:37
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000743334
   Coding: 26001097443CAF010001080300003D0D4F1C530802010161000000
   Shop #: WSC 09550 758 180955
   VCID: 3C21C83BB6629D876DF-8068
   Component: WWS 211210  H06 0070
   Serial number: SWF10120215400
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11194728
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002511101139
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003GLD0N0RP%
   Coding: 30453735423030303030554A304C384B3053
   VCID: 45D7ADDFC528DC4F021-8010
   Serial number: 6334MSME5A62757ET
   Serial number: 6344MSME59530F23G
   Serial number: 6352QSME3E7F4D24$
   Serial number: 6362QSME007E2B10D
   Serial number: 63732SME687C4728A
   Serial number: 63832SME067E502C3
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372JLH000PO
   Coding: 000036
   VCID: 3D27C53FAD78948F5A1-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 930 M    HW: 8K0 920 930 M
   Component: KOMBIINSTR.   H27 0258
   Revision: 00200000    Serial number: EJ857UMDA
   Coding: 8B06090002000008020000
   VCID: 372BD7178F44BEDF80D-8062
   Part No SW: 8T0 907 468 AC    HW: 8T0 907 468 J
   Component: GW-BEM 6CAN   H06 0117
   Revision: HB800053    Serial number: 5300H10727810A
   Coding: 103200
   VCID: 025D76C394062B77673-8056
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 392FD12FB950A8AF769-806C
   Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001002251840
   Coding: 00581B00000000000000
   VCID: 3B23CB27B36C9ABF645-806E
   Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0030
   Revision: 00H01000    Serial number: 6PZ 009 014-82
   VCID: 3C21C83BBA629D876DF-8068
   Subsystem 1 - Part No: 8K0 907 568 H
   Component: J0770_SWA_Slave_H01 0030
   Subsystem 2 - Serial number: 6PZ 009 014-92
   Subsystem 3 - Serial number: 5F09.12.1000H010003C321474ÿ
   Subsystem 4 - Serial number: 321474ÿ
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1401
   Coding: 011C13204E00410001
   VCID: 53F383873BFC72FF9C5-8006
   Revision: 00002001    Serial number: 0141378858
   Coding: 01061E3A00FA440583B0013200000000
   Component: GTO BF  H01 0050
   Serial number: 00000000000000335817
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS039  H07 0041
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T0 035 223 AR    HW: 8T0 035 223 AJ
   Component: DSP Prem      H19 0320
   Revision: 00019001    Serial number: 34803000565201
   Coding: 0203010302
   Shop #: WSC 93168 999 13806
   VCID: 7EA50233E0FE4F9703B-802A
7 Faults Found:
                    Reset counter: 28
                    Mileage: 130938 km
                    Date: 2010.01.22
                    Time: 23:25:02
                    Voltage: 12.70 V
                    Temperature: 36.0°C
                    Temperature: 41.0°C
                    Bin. Bits: 00000100
                    Reset counter: 28
                    Mileage: 130938 km
                    Date: 2010.01.22
                    Time: 23:25:02
                    Voltage: 12.70 V
                    Temperature: 36.0°C
                    Temperature: 40.0°C
                    Bin. Bits: 00000100
00420 - Front Right DSP Midrange Speaker (R104)
                    Reset counter: 28
                    Mileage: 130938 km
                    Date: 2010.01.22
                    Time: 23:25:02
                    Voltage: 12.80 V
                    Temperature: 36.0°C
                    Temperature: 41.0°C
                    Bin. Bits: 00000100
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                    Reset counter: 28
                    Mileage: 130938 km
                    Date: 2010.01.22
                    Time: 23:25:02
                    Voltage: 12.80 V
                    Temperature: 36.0°C
                    Temperature: 40.0°C
                    Bin. Bits: 00000100
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Reset counter: 28
                    Mileage: 130938 km
                    Date: 2010.01.22
                    Time: 23:25:02
                    Voltage: 12.80 V
                    Temperature: 36.0°C
                    Temperature: 40.0°C
                    Bin. Bits: 00000100
02247 - Subwoofer (R148/R157)
                    Reset counter: 28
                    Mileage: 130938 km
                    Date: 2010.01.22
                    Time: 23:25:03
                    Voltage: 12.70 V
                    Temperature: 36.0°C
                    Temperature: 40.0°C
                    Bin. Bits: 00000100
00422 - Rear Right DSP Midrange Speaker (R106)
                    Reset counter: 28
                    Mileage: 130938 km
                    Date: 2010.01.22
                    Time: 23:25:02
                    Voltage: 12.80 V
                    Temperature: 36.0°C
                    Temperature: 40.0°C
                    Bin. Bits: 00000100
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1401
   VCID: 52FD868304E67BF7973-8006
   Revision: 00000003    Serial number: 10000000694308
   VCID: 3431E01B9E3255C7A5F-8060
   Part No: 8K5 907 357 B
   Coding: 0000004
   VCID: 392FD12FB550A8AF769-806C
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H06 0351
   Revision: 00000009    Serial number: AUZ5Z6J1514965
   Coding: 240300020101870003D9270800
   VCID: 46D5AAD3F8AED7570BB-8012
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 27
                    Mileage: 130934 km
                    Date: 2010.01.22
                    Time: 00:02:47
            000 -  -  - Intermittent
                    Reset counter: 68
                    Mileage: 130939 km
                    Date: 2010.01.22
                    Time: 17:35:17
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1401
   Coding: 010C13204000210001
   VCID: 56F57A93280E67D77BB-8002
   Component: TSG HR        H06 1401
   Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
   Component: FSE_256x BT     H42 0650
   Revision: 00000000    Serial number: 00000005104215
   Coding: 0010370
   Shop #: WSC 02335 785 00200
   VCID: 3D27C53FA178948F5A1-8068
End----------(Elapsed Time: 01:48, VBatt start/end: 12.6V/12.5V)-----------
IM STUMPED.
If anyone can help Id appreciate it.
It almost seems live VCDS is waking up the part of the computer that initiates the charging.
ALSO: Signal wire at alternator 8.4v not charging 10.0v when awake.
a4bill
Canada
C?ID=340446
Verify LIN......
Thank you for the response.
Where/how can I verify that? (I'm new to the VCDS world and not 100% sure on this stuff.)
I tried searching forums but came up empty.
update - - 19-can gateway 0-bto 907 468 ac - gw-bem 6can h06 0117
current coding 103200
in byte 2 bin0 did not have "Generator (with LIN Connection) Installed
or bin 1 did not have Battery Data Module (BCM /with LIN connection) Installed
I changed the bins (checkmarks in long coding helper) and updated the module but to no affect.
(Is this what you meant)
P.S... Jack - im willing to pay for your Help.
Thanks.
Thanks.
Money is not needed, however, I appreciate that offer and I'm here for collective plus enlightenment/entertainment purposes.
No worries..... I whore here for free, unless it is a service I am doing here at shop, in clock hours and even than forum members are given additional consideration.
Here is a helpful link with data to review to educate yourself.
http://forums.ross-tech.com/showthr...-you-should-have-a-baseline-understanding-of-!
a4bill
Canada
C?ID=340446
Thanks Jack,
I'll do a little viewing to grasp the understanding of the systems. I've been working on cars for the last 20 yrs but this one got me. Im planning to drop the car off at the dealership on monday to get the computers re-programmed. I dont know im just so frustrated right now. So far im just driving the car with VCDS active and its charging. I need to figure out what system actives this alternator.
Thanks Jack,
I'm curious: Is there something you need to do in VCDS to get the car to charge or it enough to just plug it in?
Faulty ignition switch, BCM or wake due to damage from FOD!
History?
When did these audio and control head issues or FOD commence?
a4bill
Canada
C?ID=340446
History?
Audio control issues because I have an Android nav system installed and using the factory amplifier to run another amp for my sound system. (I'm an audiophile and the b&o didn't cut it) that's been installed for 2 yrs without issue.
Control head issue Is because the factory display was replaced with an aftermarket unit by RSNAV. It's never given me a problem. The car has never given me a problem since I bought it 4 yrs ago.
Also, I have removed the audio mod to do further testing so the factory control head is now in it.
As for programming ... I've never touched the coding... I just bought the vcds to help me diagnose this issue. I wanted to know what I was up against before I took it to the dealer to diagnose. I dint want them saying my computers were bad and needed replacing without me knowing if they were still good or not. As for ignition switch.. it's a push to start .. key never hits the switch. I have a spare push button and swapped that too.
The only thing I can think of was the service reset after the oil change using the snap on Solus scanner .. it's the only place my head goes back to. Which was done exactly 2hrs before the car died on me.
When I was driving after the oil change I got a "please start engine to charge battery. System will shut down shortly" message . I was on the highway doing 120kph .. the car has no idea it's running I guess.
a4bill
Canada
C?ID=340446
@Uwe
Thanks for chiming in. The car acts normally when vcds is active prior to starting. Been driving it all day like that to test. The minute I unplug it and restart ...just runs on batt power and I get the battery warning message. I was hoping vcds could help me. But am now more frustrated than before. Lol
Recode BCM 1 with this and see if it wakes up.
Coding: 26001091063CAF010000080300003D0D0F1C460802010161000000
a4bill
Canada
C?ID=340446
Thank you good sir. I'll try that in the am. It's a bit late now...and the car is parked right in front of my 80yr old landladys bedroom window...no need for her to hear me out there and start yelling and throwing things at me! Haha.
But who am I trying to kid..This issues consumed me for a week. Odds are I'll wake up at 2am and try it.
I'll Let you know how it works out.
Be sure to have VCDS configured for WSC, Tester number, And Importer number!
If it doesn't work return coding to what it was before in 0x09.
a4bill
Canada
C?ID=340446
Well... I wish I could say it worked, but I cant. Car runs normally but it didnt wake up the charging system at all. I let the battery hit 11.5 volts at idle to see if it would engage.
For some reason I'm steering into the direction of section 19- can gateway.
:banghead::banghead::banghead:
Okay set 0x09 back and do you have a legacy scan of this car from way before this happened?
When does the alternator field and charge upon communication with which controller or is by just plugging in the OBD2 port or a query of gateway?
Please advise.....
a4bill
Canada
C?ID=340446
Has been set back to how it was. I don't have a previous scan of the car. I've never had VCDS until now, I bought it to help diagnose this problem.
The alternator engages when I have vcds plugged into obd2 port only. Doesn't need to be in any particular mode. As long as obd2 is plugged in and the program recognizes the car it charges.
Procedure to get charging:
Plug in vcds
Turn on ignition
Start vcds program to get to main menu
Start car while vcds still plugged in and program active
13+ v while running
At this point I can unplug the cable and the car is fine until I shut it off. After which it thinks the car isn't on hence the "start car to charge battery , system will turn off shortly" message while I'm already driving and car is on.
Also to note: voltage at obd2 port reads same as battery and the CAN high and low signals appear to be within a reasonable level. It's all been checked.
What is the status of every fuse in the car and connected to the gateway?
I'm starting to lean toward possible bad BCM or Gateway from blow fuse/broken wire and VCDS somehow is linking the CAN as a termination when plugged in to wake the LIN.
Kind of like condition when an exciter won't start a D+ when the light or cluster is damaged in earlier cars.
a4bill
Canada
C?ID=340446
All fuses checked in all locations. All ok. Even swapped out relays to be sure.
One thing I discovered was if I unplug the alternator connection on the back and rev to 3000rpm the alternator wakes up. When I plug back in, it goes dead again. (This process was checked on more than one alternator.)
Is anything shared on the LIN in WD?
Isolate with test overlay to control component.
@Uwe
This doesn't really answer my question. What do you mean by "Is active"? Is just just plugging your interface in enough? Or do you have to communicate with the car?
a4bill
Canada
C?ID=340446
Sorry I should have been more thorough with my answer.
If VCDS is communicating through the OBD2 port with the car when the car is on accessory and i hit the start button to start the engine, the alternator wakes up.
If VCDS is not connected through OBD2 port, the car will not charge and is only relying on battery power.
