2013 Passat tdi Regen issue
machado
Canada
C?ID=59468
This car had Egr faults a month ago and the heater core was replaced under warranty because it was plugged(tsb) Now I have these fault codes he said it ran rough. I drove it it runs fine now possible carbon build up on intake and egr valve. I tried to do regen with Ross-tech but I don't know what I was doing wrong I kept getting error. The soot was 19g soot value 1.02g. I did perform regen with another scanner but I cant figure out what I was doing wrong with ross-tech. Car drives fine for now. Thanks Mario
Thursday,21,June,2018,14:22:34:15785
VCDS Version: 18.2.1.2
VIN: 1VWCN7A3XDC139151   License Plate: ADRIAN
Mileage: 139690km-86799mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
VIN: 1VWCN7A3XDC139151   Mileage: 139690km-86799miles
Address 01: Engine (J623-CKRA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 997 009 J    HW: 03L 907 309 S
   Component: R4 2.0l TDI   H24 9981
   Revision: 71H24---    Serial number:
   Coding: 001D0012842400008000
   Shop #: WSC 93200 999 00000
   ASAM Dataset: EV_ECM20TDI01103L997009J 004004
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B7E8A76B258099C32-806E
10624 - EGR System
          P0402 00 [104] - Excessive Flow
                    Mileage: 139600 km
                    Date: 2018.06.20
                    Time: 18:42:58
                    Engine speed: 1394.00 /min
                    Vehicle speed: 46 km/h
                    Coolant temperature: 86 °C
                    Intake air temperature: -40 °C
                    Voltage terminal 30: 14.000 V
                    Air mass: actual value (mg/stroke): 514.6 mg/stroke
                    Standardized airflow ratio: filtered: 1.1962
                    EGR Solen.val.: actual value: 99.61 %
                    Throttle valve adapter: actual value: 100.06 %
                    Charge air pressure specified value: 962 hPa
                    Charge air pressure: actual value: 1077 hPa
                    Mean injection quantity: 0.00 mg/stroke
17932 - Particulate Trap Bank 1
          P2002 00 [096] - Efficiency Below Threshold
                    Mileage: 139632 km
                    Date: 2018.06.21
                    Time: 04:33:27
                    Engine speed: 2368.50 /min
                    Normed load value: 66.3 %
                    Vehicle speed: 125 km/h
                    Coolant temperature: 97 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.180 V
                    Exhaust mass flow of low-pressure EGR: 46.9 kg/h
                    Exhaust mass flow of low-pressure EGR: calculated: 35.6 kg/h
                    Differential pressure ratio: low-pressure EGR: 3.500
                    Mean injection quantity: 18.76 mg/stroke
                    Low-pressure EGR differential pressure sensor: adapted signal: 130.4 hPa
                    Offset for differential pressure: low pressure EGR: 0.5 hPa
                    Particle filter: difference pressure: 106 hPa
5282 - Intake Air Temp. Sensor (G42)
          P0113 00 [040] - Signal too High
                    Fault Frequency: 25
                    Mileage: 139600 km
                    Date: 2018.06.20
                    Time: 18:38:04
                    Engine speed: 823.50 /min
                    Normed load value: 36.1 %
                    Coolant temperature: 65 °C
                    Voltage terminal 30: 13.620 V
                    Exh.gas temp.sen 4: 41.0 °C
                    Specified value of low pressure exhaust flap: 100.00 %
                    Actual value of low pressure exhaust flap: 100.23 %
                    Low-pressure exhaust flap: offset closed: 0.68 %
                    Low-pressure exhaust flap: status-Bits 0-7: 0
                    Low-pressure exhaust flap: status-Bits 0-7: 8
                    Low-pressure exhaust flap: status-Bits 0-7: 55
                    Low-pressure exhaust flap: status-Bits 0-7: 66
                    Exhaust flap: actual value: 4308.6 mV
Readiness: 0 2 0 0 0
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05651213    Serial number: 00001302041648
   Shop #: WSC 09003 957 00200
   VCID: 244C510AE7E6566463-8070
   Revision: 00H31001
   Coding: C54BC0F549250003A30C03E9921A0042271000
   VCID: 7DFA446EE4CCC7AC4C-8028
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0205288523
   Coding: 130C0C
   VCID: 346CA14A9F06C6E4F3-8060
   Part No SW: 561 907 044 R    HW: 561 907 044 R
   Component: Climatronic   H03 0405
   Revision: 00001K01
   Coding: 0010001012
   ROD: EV_ACClimaBHBVW411_VW41.rod
   VCID: 26484B0259DAA4747D-8072
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B882B2AD408880201360085480071008645A005F064806000BC70
   VCID: 74EC614AD78686E433-8020
   Component: RLS 210313 05  54  0403
   Coding: 22300A
   Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
   Component: AirbagVW10G   014 0851
   Serial number: 003MWM01MX8E
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75EA5C4ED4FC9FEC04-8020
   Serial number: 6940000Y130000T9UK0G
   Coding: 303047
   Serial number: 3572MSME65247378ZZZZ
   Serial number: 3582MSME35406478ZZZV
   Serial number: 3516KSME35627D22ZZZT
   Serial number: 3526KSME27472023ZZZH
   Serial number: 3556LSME7D646921ZZZ%
   Serial number: 3566LSME116C6921ZZZX
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20130221201828
   Coding: 001A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DFA446EECCCC7AC4C-8028
   Component: E221__MFL-YVJ  H07 0022
   Coding: E30000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 870 C    HW: 561 920 870 C
   Component: KOMBI         H07 0705
   Coding: 331E01
   VCID: 193270FE18A41B8CC0-804C
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 28041303290352
   Coding: 461000
   VCID: 76E85B42C1FA94F40D-8022
   Component: IMMO          H07 0705
   Coding: 000007
   VCID: 6AD07F328D42401499-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Revision: 00000000    Serial number: 13000013122005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3064AD5A6B1EFAC497-8064
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664589784
   Coding: 010100
   VCID: 2A50BF3245C2801459-807E
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000055321739
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 60C41D1A737E0A4447-8034
   Part No SW: 3C0 035 684 G    HW: 3C0 035 684 G
   Component: RNS-MID       H03 3696
   Revision: AB001001    Serial number: VWZ6Z7N8064081
   Coding: 24090042010000A6000B
   VCID: 2756460656D0BD7C46-8072
                    Fault Frequency: 15
                    Reset counter: 57
                    Mileage: 139584 km
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0525
   Revision: 12110009    Serial number: 0006532695
   Coding: 0405FD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C3C69EA17966EA4DB-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630130429161347
   Coding: 800000
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 53
                    Mileage: 139588 km
                    Date: 2018.06.20
                    Time: 13:17:00
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 3776964646702DFCD6-8062
   Part No: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0035118
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: 6FE66E26BEA0A53CCE-803A
   Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
   Component: J245 P05 FFD7  H07 0004
   Serial number: 53388786011235700831
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0005
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0525
   Revision: 14110009    Serial number: 0006541800
   Coding: 0405FC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D3A64EE0C8C67AC2C-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631130430190455
   Coding: 800000
                    Fault Frequency: 15
                    Reset counter: 57
                    Mileage: 139584 km
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664432633
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A708F72BD62309429-806E
End-------------------------(Elapsed Time: 03:50)--------------------------
Dana
Western PA, USA
Hi Mario,
Assuming all 3 those codes are related (and they could be) I think the exhaust system is restricted. Either that or the EGR system is malfunctioning severely enough to cause that IAT fault. You could try running individual Basic settings for the exhaust components but I'd consider pulling the DPF and EGR filter to see what it looks like.
The 19g of soot might not be accurate if a dealer re-flashed the module and reset everything without replacing parts. On that note, if any TDI "fixes" were performed I'd ask to see the work orders and check to see what hard parts were replaced.
Car is under useful life and extended warranty, please have the OEM fix it for free.
