First post so I hope I do this correctly.
I purchased a 2009 Tiguan in April 2018 (152000 km) with no driveability issues. Car has no modifications. Car began to idle rough at startup and idle at the end of May (155590 km) and threw fault codes: P0300 P0301 P0302 P0302.
Steps taken to narrow down the issue:
Moved around coil packs to see if the problem followed. It didn't
Checked fuel rail hold pressure (80C coolant temp). Pressure held and increased after shutoff.
Full tank of gas from a different supplier.
New set of plugs BKR7EIX gapped at .030” out of the box. Old plugs were gapped correctly .030” and OEM 06H905H905601A. No improvement after plug change.
Old plugs have whitish coating on the ground strap from the tip to the base, carbon buildup around the shoulder where the threads end. No wetness.
The problem is getting progressively worse and more noticeable at driving speeds. Boost and acceleration are no longer smooth.
I’ve owned quite a few VWs but none with a turbo and I’m a new VCDS user, so I’m trying to get up to speed with both.
Boost pressure specified and boost pressure actual were significantly different from each other and never goes below 950 mbar (even when taking readings with the engine off).
So my question is, with the above information, is there a glaringly obvious point to start at and try to narrow down the issue.
I also have fuel trim readings and a log of a test drive if that helps.
Thanks.
Wednesday,20,June,2018,14:36:26:13750
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: WVGCV75NX9W538304 License Plate:
Mileage: 156870km-97474mi Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVGCV75NX9W538304 Mileage: 156870km-97474miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 997 026 K HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 0607
Revision: AAH03--- Serial number: VWX7Z0I23NI8LL
Coding: 0423010A18070160
Shop #: WSC 64375 001 1048576
VCID: 3C21C88EBA68FC876DF-8068
P0300 - 000 - - Intermittent - MIL ON
Fault Status: 10100000
Mileage: 156853 km
Time: 08:47:23
RPM: 1194 /min
Load: 36.5 %
Temperature: 27.0°C
Temperature: 27.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.970 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent - MIL ON
Mileage: 156853 km
Time: 08:47:30
RPM: 1172 /min
Load: 36.8 %
Temperature: 29.0°C
Temperature: 27.0°C
Absolute Pres.: 950.0 mbar
Voltage: 13.970 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - Intermittent - MIL ON
Mileage: 156869 km
Time: 08:47:49
RPM: 1314 /min
Load: 20.8 %
Speed: 9.0 km/h
Temperature: 33.0°C
Temperature: 18.0°C
Voltage: 14.351 V
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 N HW: 5N0 614 517 N
Component: J104 C2 450 V2 0008
Revision: --H13--- Serial number: 00000001822178
Coding: 0010518
VCID: 392FD19AB55AC9AF769-806C
Part No SW: 1K0 820 047 JD HW: 1K0 820 047 JD
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 6FBB2FC2BB9E571F98D-803A
Revision: 00H54000 Serial number: 00000009481892
Coding: 118C0FA340041C0047190000140000000028F7475C400104420000000000
VCID: 3333E3B2973633FFBC5-8066
Subsystem 1 - Part No: 5N1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 170309 012 0203
Coding: 00038805
Shop #: WSC 01357
Part No SW: 5N0 959 655 K HW: 5N0 959 655 K
Component: J234__200 VW10 HI 1916
Revision: 20013000 Serial number: 003E3P25J1B/
Coding: 0012336
VCID: 45D7AD6AC9A2BD4F021-8010
Subsystem 1 - Part No: 5N0 959 339 A
Component: BF-Gewichtsens. 001 0004
Subsystem 2 - Serial number: 00000000002ES2
Subsystem 3 - Serial number: 0024.02.090000100000630146ÿ†63
Subsystem 4 - Serial number: 630146ÿ†6332MTS605090569 ÿ†63
Subsystem 5 - Serial number: 90569 ÿ†6342MTS625490569 ÿ†63
Subsystem 6 - Serial number: 90569 ÿ†6351HTS6NKK106KJ ÿ†63
Subsystem 7 - Serial number: 106KJ ÿ†6361HTS6OOKDV5KR ÿ†63
Subsystem 8 - Serial number: DV5KR ÿ†63727TS63J5VV5KJ ÿ†63
Subsystem 9 - Serial number: VV5KJ ÿ†63827TS608NLV5KJ ÿ
Subsystem 10 - Serial number: LV5KJ ÿ
Part No SW: 1K0 953 549 CN HW: 1K0 953 549 CN
Component: J0527 053 0111
Coding: 0000032
VCID: 00597C7E96005867717-8054
Part No SW: 5N0 920 850 D HW: 5N0 920 850 D
Component: KOMBIINSTRUMENT VDD 1224
Revision: V0003000 Serial number: VWX7Z0I23NI8LL
Coding: 0007304
Shop #: WSC 01357 067 57207
VCID: 2F3BEFC27B1E171FD8D-807A
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 240209F1001120
Coding: F9807F06000202006002
VCID: 372BD7A2834EDFDF80D-8062
Component: IMMO VDD 1224
Shop #: WSC 93363 999 54424
Part No SW: 5N0 959 701 B HW: 5N0 959 701 B
Component: Tuer-SG 008 2005
Coding: 0001205
VCID: 3431E0AE923834C7A5F-8060
Part No SW: 5N1 909 144 J HW: 5N1 909 148 F
Component: J500__APA-BS KL.095 0502
Revision: 1AH01263 Serial number: 00082130120502
Coding: 0000258
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0205
Revision: 00020000 Serial number: 00000000000000
Coding: 9380078852832C3F1B04058FB0880F0C88FCA0
VCID: 71BF29BAADAA41EF8E9-8024
007 - Short to Ground
Fault Status: 01100111
Fault Frequency: 15
Reset counter: 86
Mileage: 156800 km
Time: 12:22:57
Part No SW: 5N0 959 702 B HW: 5N0 959 702 B
Coding: 0001204
VCID: 3537DDAA99422DCF921-8060
Part No SW: 5N0 907 801 B HW: 5N0 907 801 D
Component: J540 EPB3 VW-09384 0005
Revision: H10 Serial number: 00000000008512
Coding: 0000057
VCID: 2E05F2C67C141E17D3B-807A
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 019 0022
Revision: 00019000 Serial number: VWZ4Z7H6398069
Coding: 0040401
VCID: 20191CFE36C0B867517-8074
Part No SW: 5N0 959 703 C HW: 5N0 959 703 C
Component: Tuer-SG 007 2001
Coding: 0001168
Shop #: WSC 01357 011 1012552
Part No SW: 5N0 959 704 C HW: 5N0 959 704 C
Coding: 0001168
VCID: 3829D49E8E50D0A7897-806C
End----------(Elapsed Time: 01:09, VBatt start/end: 12.3V/12.3V)-----------
Wednesday 20 June 2018 15:14:36:13750-VCID:3C21C88EBA68FC876DF-8068
06J 997 026 K ADVMB MED17.5 TFSI 2.0 0607
G001 F0 G003 F0 G054 F2 G054 F3 G101 F2 G115 F2 G115 F3 G119
TIME Gr1-F0 TIME G3-F1 TIME G54-F2 TIME G54-F3 TIME G101-F2 TIME G115-F2 TIME G115-F3 TIME G119-F1
STAMP (G28) STAMP MAF(G70) STAMP Accel(G79) STAMP TVA STAMP Inj.Tim. STAMP BP(spec.) STAMP BP(act.) STAMP BPCon.Ad.
/min g/s % % ms mbar mbar %
0.01 760 0.14 2.72 0.56 0 0.56 2.4 0.72 0.77 0.84 290 0.84 950 0.99 0
1.14 720 1.28 2.75 1.75 0 1.75 2.4 1.87 0.77 2.04 290 2.04 950 2.19 0
2.34 720 2.48 2.75 2.91 0 2.91 2.4 3.08 1.02 3.23 350 3.23 950 3.37 0
3.53 960 3.68 3.56 4.12 2.4 4.12 3.5 4.28 0.77 4.45 250 4.45 960 4.62 0
4.75 1200 4.9 3.61 5.32 1.6 5.32 3.5 5.46 0.77 5.6 250 5.6 960 5.74 0
5.88 1200 6.02 3.64 6.46 1.6 6.46 3.5 6.6 0.77 6.74 250 6.74 960 6.88 0
7.02 1200 7.16 3.64 7.62 1.6 7.62 3.5 7.77 0.77 7.91 240 7.91 960 8.05 0
8.19 1240 8.33 3.81 8.79 1.6 8.79 3.5 8.94 0.77 9.08 240 9.08 960 9.22 0
9.36 1280 9.5 3.92 9.92 1.6 9.92 3.9 10.09 0.77 10.22 240 10.22 960 10.36 0
10.5 1320 10.64 4 11.06 5.1 11.06 4.3 11.2 0.77 11.34 260 11.34 960 11.48 0
11.65 1440 11.78 4.5 12.2 4.7 12.2 4.3 12.34 0.77 12.48 250 12.48 960 12.62 0
12.76 1520 12.9 4.67 13.34 5.1 13.34 4.7 13.48 0.77 13.62 260 13.62 960 13.76 0
13.9 1600 14.04 5.08 14.48 7.1 14.48 5.1 14.64 0.77 14.79 270 14.79 960 14.93 0
15.07 1720 15.21 5.53 15.64 13.3 15.64 6.3 15.81 0.77 15.96 290 15.96 960 16.1 0
16.23 1920 16.39 6.72 16.85 12.9 16.85 6.7 17.01 0.77 17.16 280 17.16 960 17.3 0
17.44 2120 17.61 7.06 18.03 12.5 18.03 6.7 18.18 0.77 18.32 280 18.32 960 18.46 0
18.6 2200 18.75 7.53 19.21 24.7 19.21 10.2 19.35 1.28 19.49 450 19.49 970 19.63 0
19.77 2680 19.92 12.14 20.37 18.4 20.37 9.4 20.52 1.02 20.66 300 20.66 990 20.8 0
20.95 2920 21.1 10.44 21.55 16.9 21.55 9 21.69 0.77 21.83 310 21.83 990 21.97 0
22.11 3000 22.25 18.14 22.71 23.5 22.71 11.4 22.86 0.77 23.01 310 23.01 1030 23.15 0
23.29 3520 23.45 12.28 23.89 0 23.89 9.8 24.03 0 24.17 300 24.17 1010 24.32 0
24.46 2720 24.64 9.28 25.05 0 25.05 6.7 25.2 0 25.34 270 25.34 1000 25.48 0
25.62 1560 25.76 4.47 26.21 0 26.21 3.5 26.36 1.02 26.51 250 26.51 980 26.65 0
26.79 1000 26.93 3.22 27.39 0 27.39 2.7 27.54 1.02 27.69 270 27.69 960 27.84 0
28.02 800 28.17 2.83 28.62 0 28.62 2.4 28.8 1.02 28.95 270 28.95 960 29.1 0
29.24 760 29.38 2.64 29.84 0 29.84 2 29.99 0.77 30.13 280 30.13 960 30.27 0
30.42 720 30.59 2.58 31.04 0 31.04 2.4 31.19 0.77 31.34 290 31.34 960 31.49 0
31.65 720 31.77 2.64 32.22 0 32.22 2.4 32.37 0.77 32.52 340 32.52 960 32.68 0
32.8 800 32.96 3.81 33.39 9.4 33.39 3.9 33.53 0.77 33.68 290 33.68 960 33.83 0
33.99 1280 34.11 4.75 34.56 14.5 34.56 5.1 34.71 1.02 34.86 310 34.86 960 35.02 0
35.14 1640 35.3 6.64 35.73 20.8 35.73 7.8 35.87 1.02 36.01 440 36.01 960 36.16 0
36.33 2160 36.45 13.11 36.9 26.3 36.9 11.8 37.04 1.28 37.18 510 37.18 980 37.32 0
37.48 3160 37.64 19.86 38.07 28.6 38.07 13.7 38.21 1.28 38.35 410 38.35 1040 38.49 0
38.64 3800 38.79 14.22 39.24 36.5 39.24 10.6 39.39 0.51 39.54 370 39.54 1020 39.7 0
39.82 3800 39.98 14.19 40.43 38.4 40.43 11 40.57 0.51 40.75 310 40.75 1020 40.88 0
41.03 3560 41.18 12.33 41.65 0 41.65 8.2 41.81 0 41.96 290 41.96 1010 42.12 0
42.29 2160 42.41 6.89 42.84 0 42.84 5.1 42.99 0 43.15 250 43.15 990 43.3 0
43.44 1200 43.61 3.56 44.03 0 44.03 3.1 44.17 0.77 44.31 260 44.31 970 44.45 0
44.6 880 44.75 3.03 45.19 0 45.19 2.4 45.34 0.77 45.5 270 45.5 960 45.64 0
45.78 760 45.94 2.69 46.37 0 46.37 2.4 46.52 1.02 46.67 270 46.67 960 46.81 0
Thanks.
