Results 1 to 10 of 11
Thread: Car thinks it's unlocked when locked. Your thoughts on Fuel cap vs Door fault faults?
    Sep 2016
    US
    I have an 2009 Audi A4 with a door lock issue. The door lock chirp vanished and then I noticed the rear right door wasn't locking. I replaced the lock module and that fixed the door lock. But the car does not chirp when I lock it. Furthermore, I can hear the auto-lock going on every time I slow down to under 10mph or whatever that speed threshold is. I noticed the fuel door is not locked when the car is locked and I replaced that locking mechanism but it did not fix that issue.
    It seems the car thinks it's still not locked, perhaps due to the fuel door, and this is why the car does not chirp when the doors are locked and why the auto-locking is always triggered continually at under 10mph?? But I'm not sure where to go from here... Any thoughts?
    Wednesday,20,June,2018,13:56:29:02305
    VIN: XXXXXXXXXXXXXXXXX   License Plate:
    Mileage: 178850km-111132mi   Repair Order:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 65 72 77
    VIN: XXXXXXXXXXXXXXXXX   Mileage: 178850km-111132miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H14 0001
       Revision: E1H14---
       Coding: 010C010A190F0160
       Shop #: WSC 40832 444 999999
       ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: 79AF101F6959C2DF356-802C
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0050
       Revision: --H04---
       Coding: 001002
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 3635DB2318C7EDA7984-8062
       Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
       Component: ESP8 quattro  H04 0060
       Coding: 150500
       VCID: 79AF101F69D9C2DF356-802C
       Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
       Component: BCM2 1.1      H80 0143
       Coding: 090200
       VCID: 75B71C2F45C1A6BF51E-8020
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Serial number: 0508000057866019
       Component: ELVAUDIB8  H36 0041
       Serial number: 0208000071974008
       Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
       Component: KLIMA 1 ZONE  H06 0140
       Revision: A1000000    Serial number: 0106.10.080892
       Coding: 64002000
       VCID: 70B92D3B3AA38397828-8024
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H22 0253
       Revision: 05022001    Serial number: 00000000242883
       Coding: 690000B1063C00010000080300007F5F0F14460800000001000000
       VCID: 3039ED3BFA23C397C28-8064
       Component: WWS 011008  H06 0070
       Serial number: SWF08100016732
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 F    HW: 8K0 941 531 F
       Component: E1 - LDS  H07 0070
       Serial number: 00000000002909081354
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Component: AirbagVW-AU10 H27 0410
       Serial number: 0039KD149H9%
       Coding: 303836354230303030304A55304C384B3053
       VCID: 40D9BDFB4A035317328-8014
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R0800001AX2
       Serial number: 6334MSME40350507/
       Serial number: 6344MSME432108743
       Serial number: 6352QSME7B0E523AT
       Serial number: 6362QSME4D10401AB
       Serial number: 63732SME5B10483C0
       Serial number: 63832SME4B115320R
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90319HJ3000CU
       Coding: 000017
       Shop #: WSC 06335 123 12345
       VCID: 3D27C40F3D713EFF59E-8068
       Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
       Component: KOMBIINSTR.   H17 0224
       Revision: 00000000    Serial number: 9DR3526A8
       Coding: 8B1E11000300D705020000
       VCID: 2D07F44FED11AE7FE9E-8078
       Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0094
       Revision: 4GB20042    Serial number: 4200G089258155
       Coding: 000303
       VCID: 46D5ABE368A77D27084-8012
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
       Serial number: 18048AFC200908
       Part No SW: 8K0 959 793 B    HW: 8K0 959 793
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007770700
       Coding: 011C03204000410001
       VCID: 3FDBBE07377D2CEF4B2-806A
       Revision: 00002001    Serial number: 0114949719
       Coding: 0126023A207A001400B002
       Subsystem 2 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS127  H06 0037
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J394 PS222  H06 0037
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 250
                        Mileage: 177884 km
                        Date: 2018.05.06
                        Time: 19:34:28
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 250
                        Mileage: 177884 km
                        Date: 2018.05.07
                        Time: 08:58:23
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
       Component: DSP STD       H07 0220
       Revision: S2100000
       Coding: 0203010102
       VCID: 6E85334320979567904-803A
    00417 - Left Front DSP Mid-Bass Speaker (R101)
                        Fault Status: 00101011
                        Reset counter: 50
                        Mileage: 178680 km
                        Date: 2018.05.13
                        Time: 15:44:20
                        Voltage: 11.90 V
                        Temperature: 23.0°C
                        Bin. Bits: 00000000
       Part No SW: 8K0 959 792 B    HW: 8K0 959 792
       Component: TSG BF        H10 0170
       Revision:             Serial number: 0000007879759
       Coding: 011C03204C00410001
       VCID: 3E25C303307725E7404-806A
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 00000000238339
       VCID: 313FE83FF129CA9FCD6-8064
       Part No SW: 8T1 035 195 L    HW: 8T1 035 195 L
       Component: Symph3 Sirius H02 0211
       Revision: 00000004    Serial number: AUZ5Z4H1051362
       Coding: 05020002010285004159070000
       VCID: 40D9BDFB4A835317328-8014
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
                000 -  -  - Intermittent
                        Reset counter: 49
                        Mileage: 178404 km
                        Date: 2018.05.13
                        Time: 11:21:46
       Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000007815169
       Coding: 010C03204000210001
    Address 65: Tire Pressure (J502)       Labels:. 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140781839473
       Coding: 0CD154
       Shop #: WSC 06334 000 00000
       Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000007912630
                        Reset counter: 249
                        Mileage: 177731 km
                        Date: 2018.05.06
                        Time: 17:15:40
       Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
       Component: FSE_256x BT     H33 0550
       Revision: 00000000    Serial number: 00000005021039
       Coding: 0010370
       VCID: 3B23CA172F6530CF67A-806E
    End----(Elapsed Time: 01:35, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
    Aug 2016
    The Hague, NL
    it looks like it's not very happy with the unlocking mechanism of the fuel tank cap.
    and the rear right door is reporting an implausible signal for the locking unit. did you replace it with the correct part number? is the connecter properly seated?
  3. Likes Uwe liked this post
    Sep 2016
    US
    I’ve made sure both the fuel lock and door lock connectors are seated properly and are using the right part #’s. I’m not sure which to look at and for what. It seems like the fuel door is the issue that is keeping the car from fully locking. But i’ve no idea if the rear dock lock has anything to do with the issue at this point.
    Aug 2016
    The Hague, NL
    My experiences from my own car (it's a VW Polo, not sure that counts as a car in the states ) won't lock and arm the alarm unless it's 100% sure all of the doors are properly closed. Your car doesn't receive the correct signal from the RR door:
    Reset counter: 249
    Mileage: 177731 km
    Date: 2018.05.06
    Time: 17:15:40
  6. Likes Uwe liked this post
    Check harness at swivel chafe points for damage where mechanical interference is obvious.
  8. Likes Uwe liked this post
  9. #6
    Sep 2016
    US
    No obvious signs of chaffing or harness damage. Can I isolate the issue to the door lock versus the fuel door lock?
  10. #7
    You could but is most likely in harness in door which moves being condition sporadic.
    Did you verify with test overlay that problem still existed?
    All correct part numbers?
  11. #8
    Verified VCDS User a4bill's Avatar
    Jun 2018
    Canada
    Has the locking mechanism been replaced with an OE replacement or is it a Chinese knockoff?
    I've had issues in the past where knockoff parts like door latch and lock mechanisms dont play nice with audi.
  12. Likes Jack@European_Parts liked this post
  13. #9
    My favorite FOD is China FOD! /\
    I love Chinese food!
  14. Likes Fredrick Awuor liked this post
  15. #10
    Sep 2016
    US
    The correct part number was used for the door lock module, but it was not OEM. Seems the first thing I need to do is replace with OEM and then triage the issue from there.
    I did not verify with test overlay. I would love to do an additional test, but I'm sorry, I don't know what that means/refers to.
