Results 1 to 7 of 7
Thread: Changing the map update count on the navigation
    Nov 2017
    All new Audis are sold with 5 free map updates from the version installed at the factory. Where is this update count stored? Is it possible to reset it?
    Dec 2016
    Amsterdam
    Probably stored on a server, not local.
    Current:
    Nov 2017
    But how will the car access this server with no data connection? You are able to perform a completely Offline Update using a USB or SD card with the update on it. Online Update is an option but not the only one.
    Tartu, Estonia
    Isn't it 5 map updates from date of purchase. Meaning even if You don't update, the number still counts.
    The world is my oyster...
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    When you update via the vehicle data connection the server side counter records this. If you choose to download and create a USB / SD card via myAudi then said creation communicates with the server side in order to update the counter, even if you don't apply the update.
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
  6. Likes t-800 liked this post
    Nov 2017
    Correct. So somewhere there must be a data field that stores what the original version loaded was? Otherwise how can the car determine if the update is within 5 versions or not
    Nov 2017
    But there are people who claim that they share a USB drive between cars and the updates work as long as they are within 5 versions. So an account that has not downloaded any map update and that car has only used 'other' USB, and yet is able to determine that its had its quota of 5 updates. How is that done?
