VCDS Version: 18.2.0.3 (x64)
VIN: WAUZZZ8R19A038569 License Plate: EEN999W
Mileage: 127210km-79044mi Repair Order:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 20 42 46 52 53 55 56
57 5F 62 6C 6D 72
VIN: WAUZZZ8R19A038569 Mileage: 127210km-79044miles
Address 01: Engine (J623-CCWA) Labels:| 059-907-401-V1.clb
Part No SW: 8R0 907 401 J HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H01 0008
Revision: 15H01---
Coding: 0121002C240F0220
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 397D7DCBB8506B8C1F-806C
4807 - EGR System
P0401 00 [232] - Insufficient Flow
Fault Frequency: 110
Mileage: 126487 km
Date: 2018.05.23
Time: 09:50:01
Engine speed: 1216.50 /min
Normed load value: 42.7 %
Vehicle speed: 76 km/h
Coolant temperature: 94 °C
Intake air temperature: 26 °C
Voltage terminal 30: 13.980 V
Crankshaft speed (RPM): 1346.0 /min
Vehicle speed: 52.38 km/h
Air Ctl m Gov Dvt: -258.4 mg/stroke
AFS dm: 132.1 kg/h
Inj Ctl q Curr: 14.73 mg/stroke
Charge air pressure: actual value: 1265 hPa
Intake air temperature: 21.1 °C
4875 - Coolant Pump 2
P261A 00 [101] - Open circuit
Mileage: 126827 km
Date: 2018.06.01
Time: 21:27:05
Engine speed: 1312.50 /min
Normed load value: 53.7 %
Vehicle speed: 63 km/h
Coolant temperature: 93 °C
Voltage terminal 30: 13.820 V
Crankshaft speed (RPM): 1312.5 /min
Vehicle speed: 63.44 km/h
Field regeneration status-Bits 0-7: 00000000
Field regeneration status-Bits 0-7: 00000001
Mean injection quantity: 8.78 mg/stroke
Fuel temperature: 34.3 °C
Intake air temperature: 26.1 °C
Air Ctl st Air Ctl Bits-Bits 0-7: 00000000
Readiness: 1 1 0 0 0
Part No SW: 8R0 927 156 D HW: 0B5 927 156 D
Component: 0B5 30 TDIRdW H02 0009
Revision: --H02--- Serial number: 0000001358
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 3C7364DFB7625EA404-8068
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 C HW: 8R0 907 379 C
Component: ESP8 quattro H06 0230
Coding: 0F5D00
VCID: 408B102FD38A3A4458-8014
Part No SW: 8K0 907 064 AQ HW: 8K0 907 064 AQ
Component: BCM2 1.1 H80 0145
Coding: 051500
VCID: 7F0953D3EEF485BC61-802A
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Serial number: 0209000011453014
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 T HW: 8T2 820 043 T
Component: KLIMA 3 ZONEN H06 0150
Revision: D1000000 Serial number: 01050320090855
Coding: 36150000
VCID: 43811F23C29C215C45-8016
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H24 0253
Revision: 05024001 Serial number: 00000000334646
Coding: 260050914074AF010001000300001D0D0F1D470800010141000000
VCID: 306B40EF632AAAC4A8-8064
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 090129 H10 0041
Serial number: 90243015081212195829
Coding: 01DD13
Component: RLS H04 0003
Serial number: 10403466
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - LDS H07 0090
Serial number: 00000000000503090123
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H47 0050
Revision: 00000012
VCID: 214DB5AB38C0134C37-8074
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 G HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0040
Revision: 11001001 Serial number: 40040906409857
Coding: 300108
VCID: 3D7569DBA47857AC33-8068
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 HW: 8R0 907 561
Component: ACC2 H01 0020
Coding: 0079B6
VCID: 76E7B6F7C1CEC4F432-8022
Address 15: Airbags (J234) Labels:| 8R0-959-655.clb
Part No SW: 8R0 959 655 B HW: 8R0 959 655 B
Component: AirbagVW-AU10 H03 0310
Serial number: 003E8D03ALTF
Coding: 30323131313030303030554A305238523053
ASAM Dataset: EV_AirbaAU10SMEAU416 001001
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 43811F23CA9C215C45-8016
Serial number: 6334MSME4474772DL
Serial number: 6344MSME452349135
Serial number: 6352QSME611B10164
Serial number: 6362QSME2B1E4902L
Serial number: 63732SME6B1C1600-
Serial number: 63832SME2D1B501A0
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H15 0013
Revision: -------- Serial number: 90319IC50008K
Coding: 00003F
VCID: 3E776ED7A97E4CB42A-806A
00886 - Turn Signal Switch (E2)
Fault Status: 00101110
Reset counter: 11
Mileage: 127166 km
Date: 2018.06.06
Time: 16:42:15
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 980 G HW: 8R0 920 980 G
Component: KOMBIINSTR. H07 0224
Revision: 00100000 Serial number: 9EX5513C8
Coding: 2F0622000F002600010000
Part No SW: 8T0 907 468 Q HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0095
Revision: FB600048 Serial number: 4800F092188394
Coding: 000303
VCID: 4FA923131ED4D53CD1-801A
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0107
Serial number: 00000000004140449592
Fault Frequency: 77
Reset counter: 13
Mileage: 118561 km
Date: 2017.10.21
Time: 07:35:00
Part No SW: 8K0 857 511 C HW: 8K0 857 511 A
Component: FLA H04 0003
Revision: AA001002
Coding: 02022064747464545425363E
VCID: 316D45EB6820A3CCA7-8064
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008603189
Coding: 011D12205001440004
VCID: 418D152BD880334C57-8014
Revision: 00002001 Serial number: 0117129804
Coding: 013B0E2220393481042005
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008535932
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 10000000193916
VCID: 33614FE3923C91DCD5-8066
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0020
Coding: 0000021
Shop #: WSC 06334 000 00000
VCID: 306B40EFA32AAAC4A8-8064
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Part No SW: 4F0 035 061 B HW: 4F0 035 061
Component: Radio U DAB H45 0020
Revision: AB001007 Serial number: 343CN097518050
Coding: 010103020100000001
VCID: 1B3187431AAC399CED-804E
Address 57: TV Tuner (R78i) Labels: None
Part No SW: 4F0 919 129 B HW: 4F0 919 129
Component: HybridTV-DVB H06 0230
Revision: R0060000 Serial number: 76300802126201
Coding: 03020000
VCID: 2B5157834A0CC91C9D-807E
Part No SW: 8T2 035 670 D HW: 8T2 035 670
Component: H-BNT-EU H64 0047
Revision: -------- Serial number: 329CV097514283
Coding: 010101060105A9EF21000B1E000000030000
VCID: 37797BF386447DFCE9-8062
Subsystem 1 - Part No: 8R0 060 884 C
Component: EUROPE 2008 5608
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356CM091071516
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000247060
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000008523501
Coding: 010C12204001240004
Fault Frequency: 48
Reset counter: 14
Mileage: 120315 km
Date: 2017.12.06
Time: 10:58:51
Part No SW: 8R0 907 441 HW: 4L0 907 441 A
Component: J772__Rearview 0070
Revision: --H12--- Serial number: 525PA8-J91A0L4
Coding: 1022010
VCID: 73E18FE312BCD1DC15-8026
Part No SW: 8R0 827 851 A HW: 8R0 827 851
Component: J605 Master H27 0290
Revision: -------- Serial number: 8R0827851
VCID: 3A7F62C7B556609416-806E
Subsystem 1 - Part No SW: 8R0 827 852 A HW: 8R0 827 852
Component: J756 Slave H27 0290
Serial number: 8R0827852
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000008521798
Fault Frequency: 43
Reset counter: 230
Mileage: 121379 km
Date: 2017.12.19
Time: 10:34:33
End-------------------------(Elapsed Time: 04:09)--------------------------
The egr valve has been replaced and as much pipe work as we could has been cleaned. After clearing the system the fault can take several weeks to return and normaly on a long journey. Also does anyone know where to locate coolant pump 2. Thanks any info would be great.
