Results 1 to 7 of 7
Thread: My VW Golf MK4 won't shift out of first or reverse
    Jun 2018
    Australia
    I bought a 2003 VW Golf mk4 auto with a blown gearbox. The car drove but if taken above 40kmh, or driven with any kind of force on the throttle, it would slip into neutral. We did a fuzzy logic reset, which enable it to drive, and reach 120 kmh fairly comfortably. The problem was that when taking off in first gear, putting any pressure on the throttle would cause the car to rev briefly as if in neutral, and then bunny hop. Once the car shifted into second, you could plant your foot and it would take off. The shift from second to third was a bit glitchy, and the car seemed to hesitate more than normal. Third to fourth was also smooth, and all the downshifts worked fine. We thought the glitch in first and third could be attributed to a worn torque converter, troubled solenoids, or a worn clutch. After removing the gearbox and sending it to a gearbox specialist, we established that the torque converter would need a full rebuild, and all the clutch plates were worn. We bought a second hand gearbox and refitted it, but the car now has the same problem in first, only worse, and won't shift out of first. We now have a whole bunch of error codes from the VCDS that we don't know what they mean. Would someone be able to enlighten us as to what the problem might be and how to fix it?
    Wednesday,09,May,2018,15:34:22:11187
    VIN: WVWZZZ1JZ3W4XXXXX
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: WVWZZZ1JZ3W4XXXXX   Mileage: 167410km-104023miles
    Address 01: Engine        Labels: 06A-906-033-AVU.lbl
       Part No: 06A 906 033 BL
       Component: SIMOS33 1.6l 2V 00AT4578
       Coding: 00033
       Shop #: WSC 44300
       VCID: 6A8ECA0FE56D5267CCC-5184
       WVWZZZ1JZ3W4XXXXX     VWZ7Z0B6581640
    16555 - Fuel Trim; Bank 1
                P0171 - 35-00 - System Too Lean
    Readiness: 1010 1101
    Address 02: Auto Trans        Labels: 01M-927-733.lbl
       Part No: 01M 927 733 LK
       Component: AG4 Getriebe 01M    4985
       Coding: 00000
       VCID: 045284B7E709A417560-0962
    6 Faults Found:
    00281 - Vehicle Speed Sensor (G68)
                03-10 - No Signal - Intermittent
    00529 - Engine Speed Signal Missing
                35-10 -  -  - Intermittent
    00652 - Gear Monitoring
    00545 - Engine-Transmission Electrical Connection
                31-10 - Open or Short to Ground - Intermittent
    00297 - Gearbox Speed Sensor (G38)
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
       Part No: 1C0 907 379 L
       Component: ABS FRONT MK60      0101
       Coding: 0001025
       Shop #: WSC 01271 785 00200
       VCID: 3330176BF727D3AFBFA-5184
       Part No: 1C0 909 601
       Component: 1N AIRBAG VW51      0006
       Coding: 12622
       Shop #: WSC 01271
       VCID: 5DE491D3242335DF39E-513C
       Part No: 1J0 920 806 C
       Component: KOMBI+WEGFAHRSP VDO V11
       Coding: 03722
       VCID: 2708F33B36FFAF0F132-513C
    01039 - Coolant Temperature Sensor (G2)
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 01271
       VCID: 70BAD867C3B1A8B7828-513C
       Part No: 1C0 959 799
       Component: 1Z Komfortgerát HLO 0002
       Coding: 00259
       Shop #: WSC 01271
       VCID: 74B2D477B7A99497660-4B1E
       Subsystem 1 - Part No: 1C2959802A
       Component: 1Z Tőrsteuer.FS KLO 0009
       Subsystem 2 - Part No: 1C2959801A
       Component: 1Z Tőrsteuer.BF KLO 0009
       Component: 1Z Tőrsteuer.HL KLO 0009
       Component: 27 Tőrsteuer.HR KLO 0009
    End----------(Elapsed Time: 05:07, VBatt start/end: 12.3V/12.3V)-----------
    Dec 2016
    Amsterdam
    Did you change the whole assembly, or just the box and swapped the mechatronic? Did you perform any basic settings after the swap? Did you clear DTC's before the test drive, or did these pop up just during the test drive?
    Current:
    There is no "mechatronic" on those old 4-speed transmissions. It's a separate TCU. There aren't any basic settings either aside from learning the kick-down point.
    Quote Originally Posted by Parzival View Post
    These links may be useful:
    http://wiki.ross-tech.com/wiki/index.php/00281
    http://wiki.ross-tech.com/wiki/index.php/00529
    http://wiki.ross-tech.com/wiki/index.php/00652
    http://wiki.ross-tech.com/wiki/index.php/00545
    http://wiki.ross-tech.com/wiki/index.php/00297
    http://wiki.ross-tech.com/wiki/index.php/01314
    Jun 2018
    Australia
    Thankyou for the quick reply Uwe. Would you say that these faults are all issues with the wiring as opposed to the gearbox?
    Aug 2016
    The Hague, NL
    I had a quick look at the wiring diagram, and cannot find any obvious common denominators. Do you have any corrosion or water ingress in the connector?
    Is it still operating with the same TCU or is this one replaced?
  7. Likes Uwe liked this post
    Faulty multi-function switch F125 or contaminated harness with battery acid from over charge condition.
