Vehicle came in with parking brake stuck and bad module.
Replaced and coded module, did basic settings for various required sensors.
Will not allow basic settings for parking brake- not sure if this is due to "functional restriction" fault in module or fault in steering assist? Could not perform basic settings for steering limit stop either.
Thursday,09,October,2014,08:42:57:20325
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
VIN: WVWJK73C79P026032 License Plate:
Mileage: 96220km-59788mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
72
VIN: WVWJK73C79P026032 Mileage: 96220km/59788miles
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 906 026 AG HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 3319
Revision: AAH03--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 00028 028 00001
VCID: 6FED2F447ED26966727-803A
049508 - No Communications with HVAC Control Module (J301)
U0164 - 000 - - Intermittent
Mileage: 96226 km
Date: 2014.10.08
Time: 16:51:32
Temperature: 53.0°C
Temperature: 29.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.319 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 GP HW: 09G 927 750 GP
Component: AQ 250 6F 1391
Revision: 00H76000 Serial number:
Coding: 0000840
VCID: 8501EDECCC6EC33628B-80D0
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000785963394
Coding: 0000376
Shop #: WSC 08079 002 1048576
VCID: 2B55FB548A4A55461EF-807E
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78FF14180B9C2EDEA3D-802D
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 00000004931092
Coding: 15848F0340041A00470000000F00000000285D435C000100000000000000
VCID: 3365E334527A0D8656F-8066
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 280508 003 0205
Coding: 00046997
Shop #: WSC 00028
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0376327
Coding: 0000100
00003 - Control Module
Fault Status: 00101110
Reset counter: 60
Mileage: 14257 km
Date: 2009.09.08
Time: 14:09:49
Reset counter: 49
Mileage: 96226 km
Date: 2014.10.09
Time: 08:30:22
01304 - Radio
Reset counter: 49
Mileage: 96226 km
Date: 2014.10.09
Time: 08:30:17
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__01F VW10 HI 1815
Revision: 19013000 Serial number: 0039BPFSC9D$
Coding: 0012614
VCID: FAFB8E10B590BCCE559-80AF
Subsystem 1 - Part No: 3C0 959 339 D
Component: BF-Gewichtsens. 001 0002
Subsystem 2 - Serial number: 000000000013W1
Subsystem 3 - Serial number: 0031.05.080000100000640075ÿ†63
Subsystem 4 - Serial number: 640075ÿ†6333FTS622581508 ÿ†63
Subsystem 5 - Serial number: 81508 ÿ†6343FTS611291728 ÿ†63
Subsystem 6 - Serial number: 91728 ÿ†6353ETS6UHJFUVNH ÿ†63
Subsystem 7 - Serial number: FUVNH ÿ†6363ETS66GIMUVNP ÿ†63
Subsystem 8 - Serial number: MUVNP ÿ†6374CTS6MI4CUVNP ÿ†63
Subsystem 9 - Serial number: CUVNP ÿ†6384CTS6GGPAUVNH ÿ
Subsystem 10 - Serial number: AUVNH ÿ
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Fault Status: 11101001
Reset counter: 49
Mileage: 96226 km
Date: 2014.10.09
Time: 08:30:13
Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AR
Coding: 0001111
VCID: 6DD1354C74DE9B7640B-8038
Component: E0221 002 0010
Part No SW: 3C0 920 972 A HW: 3C0 920 972 A
Component: KOMBIINSTRUMENT VD1 2416
Revision: V0002000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 00028 000 00001
VCID: 24471068E7949A3EDF5-8071
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 H HW: 3C0 907 951
Component: J533__Gateway H13 0142
Revision: H13 Serial number: 2600P0871411B2
Coding: FD807F070013021002
VCID: 26430A6091A8682EC11-8073
01304 - Radio
Reset counter: 49
Mileage: 96226 km
Date: 2014.10.09
Time: 08:30:17
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1166279TSHG906
VCID: EDD1B54CF4DE1B76C0B-80B8
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 08203 444 97442
VCID: 73E5233412FA4D8696F-8026
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1517
Revision: 72009005 Serial number: 00000299788722
Coding: 0001205
Fault Status: 01100101
Reset counter: 49
Mileage: 96226 km
Date: 2014.10.09
Time: 08:30:11
Part No SW: 5N1 909 144 G HW: 5N1 909 148 F
Component: J500__APA-BS KL.082 0401
Revision: 1AH02234 Serial number: 00081440126502
Coding: 0000258
VCID: 3663DA20410818AE711-8063
02546 - Steering Limit Stop
Fault Status: 11100101
Reset counter: 49
Mileage: 96226 km
Date: 2014.10.09
Time: 08:30:11
(no units): 4.0
Voltage: 13.00 V
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001862E521004141FF08A0F0E085801
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1517
Revision: 72009005 Serial number: 00000016388724
Coding: 0001204
VCID: 70EF2C3863EC769E6BD-8025
Reset counter: 49
Mileage: 96226 km
Date: 2014.10.09
Time: 08:30:11
Part No SW: 3AA 907 801 D HW: 3AA 907 801 D
Component: J540 EPB4 VW-53083 0006
Revision: H18 Serial number: 00000000064401
Coding: 0021057
VCID: 326BE630AD60048E5D9-8067
Fault Status: 01110000
Reset counter: 49
Voltage: 13.90 V
Count: 43
Hex Value: 0x0140
Hex Value: 0x0082
Hex Value: 0x4040
03263 - Functional Restriction
Fault Status: 01111000
Reset counter: 49
Mileage: 96225 km
Date: 2014.10.08
Time: 15:01:07
Voltage: 12.70 V
Count: 140
Hex Value: 0x1250
Hex Value: 0x0001
Hex Value: 0x0404
Part No SW: 1K0 959 703 AD HW: 1K0 959 795 P
Component: J388 TUER-SG HL 0308
Revision: 42004101 Serial number: 00000000517238
Coding: 0001168
VCID: 72EB26306DE0448E9D9-8027
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 AD HW: 1K0 959 794 P
Component: J389 TUER-SG HR 0308
Revision: 42004101 Serial number: 00000000543207
Coding: 0001168
End ---------------------------------------------------------------------
