Results 1 to 10 of 10
Thread: Seat Ibiza 6F Crash Mode deactivation
    Jun 2017
    Question Seat Ibiza 6F Crash Mode deactivation
    im trying to deactivate the crashmode of the steering assist (module 44) on a brand new Seat Ibiza 6F. Car was crashed and repaired, i only need to fix the steering assist so i can do calibration.
    I tried the same procedure as EPS_TRW_Alow (but with different security access: 19249).
    I tried it with Odis, VCP and VCDS but all the systems say "pre conditions not met". What are those conditions?
    Wednesday,13,June,2018,16:25:27:55204
    VCDS Version: 18.2.1.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: VSSZZZKJZJRxxxxx  License Plate: SEAT6F
    Mileage: 1372km-852mi   Repair Order:
    Chassis Type: KJ-SE27 (3Q0)
    Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 44 47 55 5F CA
    VIN: VSSZZZKJZJRxxxxx   Mileage: 1372km-852miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CHZJ)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 026 BQ    HW: 04C 907 309 AT
       Component: R3 1.0l TFS   H21 5155
       Revision: WXH21---
       Coding: 01190032234405081000
       Shop #: WSC 00049 770 00137
       ASAM Dataset: EV_ECM10TFS01104C906026BQ 002001
       ROD: EV_ECM10TFS01104C906026BF.rod
       VCID: 71BE24EB912460CF8E9-8024
       CAN Converter 01:
    21472 - Databus
              U1122 00 [039] - Implausible Message
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:49
                        Coolant temperature: 59 C
                        Intake air temperature: 27 C
                        Voltage terminal 30: 11.897 V
                        Acceleration: 0.000 m/s
                        Cruise Control System (CCS): status-Bits 0-7: 7
                        Cruise_control_shutoff_conditions_irreversible-Bits 0-7: 0
                        Cruise_control_shutoff_conditions_irreversible-Bits 0-7: 1
                        Cruise control system: temporary deactivation-Bits 0-7: 255
                        Cruise control switch actuation-Bits 0-7: 49
                        Cruise control switch actuation-Bits 0-7: 129
    17165 - Databus
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:49
              U0428 00 [039] - -
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:49
                        Outside air temperature: 21 C
                        Absolute intake pressure: 101 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel: tank fill level: 5.0 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.0000
    Readiness: 1110 0001
       Part No SW: 2Q0 614 517 AA    HW: 2Q0 614 517 N
       Component: ESC_base_vFGS H23 0222
       Serial number: 08506823180106
       Coding: 510D4C5735428AB532FDAC1E24DF42A649124D26224A242444541254452442659248B26444522424222A482AA249D6427D926B42BE
       Shop #: WSC 00049 770 00140
       ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
       ROD: EV_Brake1BOSCHESPMQBA0.rod
       VCID: 6D86389B8D1C842FAA1-8038
    1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
              U0428 00 [137] - -
              [Scl_LWI_Lenkradwinkel_Error]
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:56
       Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
       Component: VWKESSYMQB    037 0907
       Revision: 00037000    Serial number: 0466522578
       Coding: 112E0E0603
       Shop #: WSC 00049 770 00020
       VCID: 3E24CFD790FACFB743B-806A
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 6F0 907 044 A    HW: 6F0 907 044 A
       Component: Climatronic   H03 0401
       Coding: 0100000108000100110008000240010D0000000000000000000000000000
       ASAM Dataset: EV_ACClimaBHBMQBA0 004017
       ROD: EV_ACClimaBHBMQBA0.rod
       VCID: 251600BB156C7C6F221-8070
       Part No SW: 2Q0 937 090     HW: 2Q0 937 090
       Component: BCM A0 Std+   H97 0915
       Serial number: 07001801500442
       ASAM Dataset: EV_BCMA0 204001
       ROD: EV_BCMA0_104_VW27.rod
       VCID: 6FBA22938710763F98D-803A
       Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  047 0105
       Serial number: S7Y18M01D17H15M04S18
       Coding: 00194D
       Drivers Door Control Module:
       Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
       Component: FHSG_DRV  001 0001
       Serial number: 00000000000018215488
       Coding: 13000F
       Subsystem 3 - Part No SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
       Component: FHSG_PSG  001 0002
       Serial number: 00000000000018299897
       Coding: 09000F
       Subsystem 4 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY173381ZKD
       Serial number: 00000000000039711994
       Subsystem 6 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000018665854
       Subsystem 7 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000018331723
       Coding: 190000
       Part No SW: 5QA 919 294 B    HW: 5QA 919 294
       Serial number: 000308418618016
       Coding: 0471151001
       ROD: EV_EPHVA18AU3700000_009_VW27.rod
       VCID: 4BC29603D3486A1FD45-801E
    13679372 - Databus
              [Steuergert fr Lenkhilfe-J500 - LWI_01.LWI_Lenkradwinkel - Fehlerspeicher auslesen]
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:17:01
    13637426 - Databus
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:17:01
       Coding: 2A00608140FF8728749C8145604085
    7 Faults Found:
    2101 - Databus
              [FAULT_ESP_STATUS_SYSTEM]
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:58
                        Voltage terminal 15: 11.7 V
                        Control Module temperature: 43 C
                        Longitudinal_acceleration_vehicle_reference: -0.03 m/s
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:18:15
                        Control Module temperature: 45 C
    2062 - Databus
              [FAULT_MAINSWITCH_FAIL]
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:58
    1116 - Databus
              [FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:58
                        Voltage terminal 15: 11.8 V
                        Longitudinal_acceleration_vehicle_reference: -0.06 m/s
    2052 - Databus
              [FAULT_ALP_STEERINGWHEEL_FAIL]
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:58
    2049 - Databus
              [FAULT_ALP_DT_STEERING_WHEEL_FAIL]
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:58
    2127 - Databus
              [FAULT_OP_FAIL]
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:58
    Address 14: Susp. Elect. (J250)       Labels:. 6C0-907-359.clb
       Part No SW: 6C0 907 359     HW: 6C0 907 359
       Component: DAEMPFUNGS-SG H04 0007
       Serial number: 27111702000249
       Coding: 81
       ASAM Dataset: EV_SwitcDampeContiTemic 001004
       ROD: EV_SwitcDampeContiTemic.rod
       VCID: 6A8C3387BCF29317CF3-803E
       Part No SW: 5QF 959 655 L    HW: 5QF 959 655 L
       Component: Airbag VW22   006 0520
       Revision: --------    Serial number: 003XNPEY3ES5
       Coding: 88CCC0C000000000585400CF000C00000065
       ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
       ROD: EV_AirbaVW22TS6VW48X.rod
       VCID: 5F9A525377B0E6BF28D-800A
       Subsystem 1 - Part No SW: -----------    HW: 454 001 001 18
       Serial number: 357000000000FBD0CB2-
       Subsystem 2 - Part No SW: -----------    HW: 454 001 001 18
       Serial number: 35800000000520FCCB2W
       Subsystem 3 - Part No SW: -----------    HW: 454 801 101 18
       Serial number: 351000FA803130000006
       Subsystem 4 - Part No SW: -----------    HW: 454 800 501 18
       Serial number: 352005C29D512000000G
       Subsystem 5 - Part No SW: -----------    HW: 454 801 412 17
       Component: FrontSensor_D  307 0189
       Serial number: 3550018AFA812000000P
    1050117 - Databus
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:57
       Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
       Revision: --------    Serial number: 20180301500093
       Coding: 6E10
       Shop #: WSC 01286 386 08256
       ASAM Dataset: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3C20C5DF86E6DDA76DF-8068
    226843 - Turn Signal Switch
              B1144 13 [009] - Open Circuit
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:17:00
                        Ubat 30 Voltage: 12.00 V
                        Ignition State: On
                        Terminal 15: 11.20 V
                        A/D #1: 97.65 %
                        A/D #2: 35.69 %
                        A/D #3: 0.00 %
    227355 - Windshield Wiper/Washer Switch
              B1149 13 [009] - Open Circuit
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:17:00
                        Ignition State: On
                        A/D #1: 97.65 %
                        A/D #2: 50.59 %
                        A/D #3: 0.00 %
    229235 - Switch for ADR Distance Selection
              B1155 07 [009] - Mechanical Failure
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:17:00
                        Ignition State: On
                        A/D #1: 65.49 %
                        A/D #2: 0.00 %
                        A/D #3: 0.00 %
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 6F0 920 740     HW: 6F0 920 740
       Component: KOMBI         206 0450
       Coding: 04A401103D800008018862011000000080000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001020
       ROD: EV_DashBoardVDDMQBA0_SE27.rod
       VCID: 629C5BA744C2CB57073-8036
       Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
       Component: GW MQB High   436 4326
       Revision: --------    Serial number: 0007323347
       Coding: 030100046F085700E9000258880F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF_SE27.rod
       VCID: 3828D9CFB2DEF187897-806C
       Subsystem 2 - Part No SW: 5F0 959 537 E    HW: 5F0 959 537 E
       Component: E221__MFL-PR6  H04 0130
       Serial number: 000000000G0212121217
       Coding: 002000
       Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
       Component: J367-BDMBOSCH  H02 2011
       Serial number: 1003BA2F
    8526363 - Unknown Error Code
              B189C F0 [009] - Unknown Error Elaboration
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:57
                        Supply voltage: Terminal 30: 11.7 V
                        Terminal 15: On
       Part No SW: 2Q0 905 861     HW: 2Q0 905 861
       Component: ELV-MQBB      H06 0020
       Serial number: 17000252591005
       Coding: 0000000000000000
       ROD: EV_ELVMarqMQBA0.rod
       VCID: 70B821EF9A2E69C7817-8024
    Address 44: Steering Assist (J792)       Labels:* None
       Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
       Component: TRW_G4L_MQBA0 610 6030
       Serial number: 0317585CB4J0202
       Coding: 00000000000000010101020101000101000001
       ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
       ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
       VCID: 392EDCCB89D4E88F769-806C
    15788544 - Crash Shut-Down Activated
              P1609 00 [137] - -
              [DEM_FRONT_CRASH_FAULT]
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:21:48
                        Engine speed: 959 /min
                        Terminal 15 status: On
                        Voltage terminal 30: 13.68 V
                        Power steering current consumption: 0.5 A
                        max.value: 0.5 A
                        End stage temperature: 215 C
                        Steering assistance: engine output: 100 %
                        Engine angle: 65535
                        Electric motor speed: 45535 /min
                        Steering assistance: target engine torque: 0.0 Nm
                        Steering torque: 0.0 Nm
       Part No SW: 5Q6 035 456     HW: 5Q6 035 456
       Component: KonzernAmp 8K H01 2426
       Revision: --------    Serial number: A1117A00040379
       Coding: 0202000000AAAA00000000000000
       ASAM Dataset: EV_AMPCAN8C1PASE 001015
       ROD: EV_AMPCAN8C1PASE_VW27.rod
       VCID: 73B22EE3EB3852DF7C5-8026
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0070
       Coding: 078A000001200003
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
       VCID: 41DEB42BE104B04F3E9-8014
    13705992 - Databus
              [Fehlerwert im Signal LWI_Lenkradwinkel]
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:21:24
    Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
       Part No SW: 5QA 035 858 B    HW: 5QA 035 858 B
       Component: MU-S-ND-ER    H41 0468
       Serial number: SEZAZ2U0227551
       Coding: 047200010000000011110103008808232F0101D401200500C6
       ASAM Dataset: EV_MUStd4CTSAT 001001
       ROD: EV_MUStd4CTSAT_VW27.rod
       VCID: 46D4A737C82A97770BB-8012
       Subsystem 1 - Part No SW: 6F0 919 605 A    HW: 6F0 919 605 A
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: SEZ6ZHV0164009
       Subsystem 2 - Part No SW: 6P0 919 866 AB    HW: -----------
       Component: ECE1 2018  --- 0915
    0008 - Connection between Antenna Amp 2 for Radio and Antenna
              B1273 13 [009] - Open Circuit
                        Reset counter: 111
                        Mileage: 1372 km
                        Date: 2018.06.13
                        Time: 15:16:56
                        Voltage terminal 30: 11.8 V
                        Status of antenna 2 for radio-Antenna current: 0 mA
                        Status of antenna 2 for radio-Connection between radio and antenna amplifier: Electrical OK
                        Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Open circuit
                        Status of antenna 2 for radio-Reception level antenna 2: 0 dBV
       Part No SW: 4M0 907 594 H    HW: 4M0 907 594
       Coding: 408040527001
       ROD: EV_SunRoofCONTIAU736.rod
       VCID: 3B22C6C383E8DA9F645-806E
    End----------(Elapsed Time: 01:30, VBatt start/end: 14.4V/14.4V)-----------
    Oct 2017
    Northwest UK
    Hi
    It appears that you may have a damaged steering angle sensor. Have you tried re-calibrating it? If not it may require replacement.
    Feb 2018
    Czech Republic
    For this purpose(/reset) it should be SA:10608
    Jun 2017
    I replaced steering angle sensor with brand new one.
    SA:10608 is incorrect
    Oct 2017
    Northwest UK
    Have you replaced the steering wheel?? Have you checked the clock spring? The errors are showing that there is a comms errors from the stalks/ steering depending on where your selection buttons are.
  6. #6
    Jun 2017
    Quote Originally Posted by myounus View Post
    No original steeringwheel, but new airbag.
    Errors of stalks are fixed because of wrong coding. Module16 is error free now.
  7. #7
    Oct 2017
    Northwest UK
    Can you delete all DTC's, turn steering wheel all the way left and then right. Then please post a new autoscan.
  8. #8
    Jun 2017
    Already did that. DTC's comes back from crash shut-down
  9. Likes Dana liked this post
  10. #9
    Oct 2017
    Northwest UK
    Did you replace the airbag with the correct one with MFSW wires?
    I'd advise you to double check the part numbers and connections from the airbag and slip ring.
  11. #10
    Jun 2019
    Birmingham, UK
    Did you find a solution to deactivate crash shut down?
