Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 107
Thread: Im new here. Jack, don't cut me deep. but please help.
    Show the misfire under load in logs 015 & 016 & while also displaying 115 please.
    Reflash car to stock for consistent diagnostic stack due to FOD.
  2. #12
    On Probation
    Jun 2018
    Woodinville, WA.
    I already made up a wire, because that thought crossed my mind as well. Tested. Done. Still not the answer. I should have elaborated more on my findings for the coils.
    I went all through the wiring for the coil system. I always try to find the cheap solution first.
    If it were as easy as a grounding issue to the coils, I wouldn't have joined and posted here.
    So..... I kinda did do it that fast. CORRECTLY!!!!
  3. Likes Uwe, Jack@European_Parts liked this post
  4. #13
    On Probation
    Jun 2018
    Woodinville, WA.
    I will definately obey the logs.
    015, 016, 115 right after dinner.
    I don't have any way of reflashing my car back to stock.
    my APR tuning has a "stock" program, that I have never used, that I'm sure is an emulator.
    I'm sure it won't do what you want, but I can log in both if you want.
  5. #14
    Show me a picture of your work and how you did it?
    Also during boost issue please log 115 and 020 & 021 please to see CF .......
    Then do so in trims.........
    What is FP and volume tests under load or offset?
    What is MAF GS readings during this too.......I wonder if the MAF is for shit, I wouldn't doubt it at all even with ghost BS good numbers reported!
  6. #15
    On Probation
    Jun 2018
    Woodinville, WA.
    Tuesday	12	June	2018	18:38:53:36218-VCID:28413683C87E61044F-515A	VCDS Version: Release 18.2.1 (x64)	Data version: 20180518 DS287.1
    8D0 907 551 A		2.7l V6/5VT     G   0003
    	Group A:	'015				Group B:	'016				Group C:	'115
    		Misfire Counter	Misfire Counter	Misfire Counter	Misfire		Misfire Counter	Misfire Counter	Misfire Counter	Misfire		Engine Speed	Engine Load	Boost Pressure	Boost Pressure
    	TIME	Cylinder 1	Cylinder 2	Cylinder 3	Recognition	TIME	Cylinder 4	Cylinder 5	Cylinder 6	Recognition	TIME	(G28)		(specified)	(actual)
    Marker	STAMP					STAMP					STAMP	 /min	 %	 mbar	 mbar
    	0.29	0	0	0	Enabled	0.59	0	0	4	Enabled	0.89	760	26.3	1000	1000
    	1.19	0	0	0	Enabled	1.49	0	0	4	Enabled	1.8	800	28.6	1000	1000
    	2.1	0	0	0	Enabled	2.39	0	0	4	Enabled	2.69	760	28.6	1000	1000
    	2.99	0	0	0	Enabled	3.29	0	0	4	Enabled	3.6	800	42.1	1000	1000
    	3.9	0	0	0	Enabled	4.2	0	0	4	Enabled	4.51	920	56.4	1000	1000
    	4.8	0	0	0	Enabled	5.11	0	0	4	Enabled	5.42	1560	51.1	1000	1010
    	5.72	0	0	0	Enabled	6.02	0	0	4	Enabled	6.32	2120	40.6	1000	1010
    	6.62	0	0	0	Enabled	6.92	0	0	4	Enabled	7.23	2520	30.8	1000	1010
    	7.53	0	0	0	Enabled	7.83	0	0	4	Enabled	8.13	1920	12.8	1000	1010
    	8.42	0	0	0	Disabled	8.72	0	0	4	Disabled	9.04	1480	27.8	1000	1000
    	9.34	0	0	0	Disabled	9.64	0	0	4	Disabled	9.94	1560	43.6	1000	1000
    	10.24	0	0	0	Disabled	10.54	0	0	4	Disabled	10.85	1760	42.1	1000	1010
    	11.15	0	0	0	Enabled	11.45	0	0	4	Enabled	11.75	1920	32.3	1000	1010
    	12.05	0	0	0	Enabled	12.36	0	0	4	Enabled	12.66	2000	28.6	1000	1000
    	12.96	0	0	0	Enabled	13.26	0	0	4	Enabled	13.56	2080	26.3	1000	1000
    	13.86	0	0	0	Enabled	14.17	0	0	4	Enabled	14.47	1920	12.8	1000	1000
    	14.77	0	0	0	Disabled	15.07	0	0	4	Disabled	15.37	1080	22.6	1000	1000
    	15.67	0	0	0	Disabled	15.97	0	0	4	Disabled	16.28	880	22.6	1000	1000
    	16.57	0	0	0	Disabled	16.87	0	0	4	Disabled	17.17	760	22.6	1000	1000
    	17.47	0	0	0	Disabled	17.78	0	0	4	Disabled	18.08	760	24.1	1000	1000
    	18.38	0	0	0	Disabled	18.68	0	0	4	Disabled	18.98	800	24.1	1000	1000
    	19.28	0	0	0	Enabled	19.6	0	0	4	Enabled	19.9	1240	39.1	1000	1000
    	20.2	0	0	0	Enabled	20.5	0	0	4	Enabled	20.8	1880	45.9	1000	1010
    	21.1	0	0	0	Disabled	21.41	0	0	4	Disabled	21.71	2480	43.6	1000	1020
    	22.01	0	0	0	Enabled	22.31	0	0	4	Enabled	22.61	2960	32.3	1000	1040
    	22.92	0	0	0	Disabled	23.22	0	0	4	Disabled	23.52	1680	12.8	1000	1020
    	23.81	0	0	0	Disabled	24.12	0	0	4	Disabled	24.41	1000	22.6	1000	1010
    	24.72	0	0	0	Disabled	25.02	0	0	4	Disabled	25.33	840	21.8	1000	1000
    	25.63	0	0	0	Disabled	25.93	0	0	4	Disabled	26.23	760	21.8	1000	1000
    	26.53	0	0	0	Disabled	26.83	0	0	4	Disabled	27.13	760	22.6	1000	1000
    	27.43	0	0	0	Disabled	27.74	0	0	4	Disabled	28.03	760	24.1	1000	1000
    	28.35	0	0	0	Enabled	28.65	0	0	0	Enabled	28.95	760	26.3	1000	1000
    	29.25	0	0	0	Enabled	29.54	0	0	0	Enabled	29.85	800	27.8	1000	1000
    	30.15	0	0	0	Enabled	30.45	0	0	0	Enabled	30.75	800	27.8	1000	1000
    	31.05	0	0	0	Enabled	31.36	0	0	0	Enabled	31.66	760	27.8	1000	1000
    	31.96	0	0	0	Enabled	32.26	0	0	0	Enabled	32.56	800	27.8	1000	1000
    	32.86	0	0	0	Enabled	33.16	0	0	0	Enabled	33.47	800	27.8	1000	1000
    	33.77	0	0	0	Enabled	34.07	0	0	0	Enabled	34.37	760	27.8	1000	1000
    	34.68	0	0	0	Enabled	34.97	0	0	0	Enabled	35.29	800	27.8	1000	1000
    	35.59	0	0	0	Enabled	35.89	0	0	0	Enabled	36.19	800	27.8	1000	1000
    	36.49	0	0	0	Enabled	36.78	0	0	0	Enabled	37.1	760	27.8	1000	1000
    	37.4	0	0	0	Enabled	37.7	0	0	0	Enabled	37.99	800	27.8	1000	1000
    	38.29	0	0	0	Enabled	38.59	0	0	0	Enabled	38.9	800	27.8	1000	1000
    	39.2	0	0	0	Enabled	39.5	0	0	0	Enabled	39.8	800	27.8	1000	1000
    	40.1	0	0	0	Enabled	40.41	0	0	0	Enabled	40.72	1080	71.4	1000	1000
    	41.01	0	0	0	Enabled	41.32	0	0	0	Enabled	41.62	1560	58.6	1000	1040
    	41.92	0	0	0	Enabled	42.22	0	0	0	Disabled	42.53	2240	56.4	1000	1060
    	42.83	0	0	0	Disabled	43.13	0	0	0	Disabled	43.43	3040	61.7	1000	1150
    	43.74	0	0	0	Enabled	44.04	0	0	0	Enabled	44.34	3800	39.8	1000	1230
    	44.64	0	0	0	Disabled	44.94	0	0	0	Disabled	45.24	2360	12.8	1000	1040
    	45.54	0	0	0	Disabled	45.85	0	0	0	Disabled	46.15	2400	85.7	1310	1130
    	46.45	0	0	0	Disabled	46.75	0	0	0	Disabled	47.05	3000	113.5	1390	1400
    	47.35	0	0	0	Disabled	47.66	0	0	0	Enabled	47.96	3640	106	1320	1390
    	48.26	0	0	0	Enabled	48.56	0	0	0	Enabled	48.86	3680	9.8	1000	1210
    	49.16	0	0	0	Disabled	49.47	0	0	0	Disabled	49.77	2640	69.9	1000	1020
    	50.07	0	0	0	Disabled	50.37	0	0	0	Disabled	50.67	2840	112	1350	1410
    	50.98	0	0	0	Enabled	51.28	0	0	0	Disabled	51.58	3120	100.8	1250	1410
    	51.88	0	0	0	Enabled	52.18	0	0	0	Disabled	52.48	2440	10.5	1000	1090
    	52.79	0	0	0	Disabled	53.09	0	0	0	Disabled	53.39	2400	12.8	1000	1020
    	53.69	0	0	0	Disabled	53.99	0	0	0	Disabled	54.29	2360	16.5	1000	1010
    	54.6	0	0	0	Enabled	54.9	0	0	0	Enabled	55.2	2320	15.8	1000	1010
    	55.5	0	0	0	Enabled	55.8	0	0	0	Enabled	56.1	2280	15.8	1000	1010
    	56.41	0	0	0	Enabled	56.71	0	0	0	Enabled	57.01	2240	34.6	1000	1010
    	57.31	0	0	0	Enabled	57.61	0	0	0	Enabled	57.91	2240	27.1	1000	1010
    	58.22	0	0	0	Enabled	58.52	0	0	0	Enabled	58.82	2200	18.8	1000	1010
    	59.12	0	0	0	Disabled	59.42	0	0	0	Disabled	59.72	2160	19.5	1000	1000
    	60.03	0	0	0	Enabled	60.33	0	0	0	Enabled	60.63	2120	20.3	1000	1010
    	60.93	0	0	0	Enabled	61.23	0	0	0	Enabled	61.53	2080	20.3	1000	1000
    	61.84	0	0	0	Enabled	62.14	0	0	0	Enabled	62.44	2040	21.1	1000	1010
    	62.74	0	0	0	Enabled	63.04	0	0	0	Enabled	63.35	2000	21.1	1000	1000
    	63.65	0	0	0	Enabled	63.95	0	0	0	Enabled	64.25	1960	21.8	1000	1000
    	64.55	0	0	0	Enabled	64.85	0	0	0	Enabled	65.16	1920	18	1000	1000
    	65.46	0	0	0	Enabled	65.76	0	0	0	Enabled	66.06	1880	18.8	1000	1000
    	66.36	0	0	0	Enabled	66.66	0	0	0	Enabled	66.97	1840	18.8	1000	1000
    	67.27	0	0	0	Enabled	67.57	0	0	0	Enabled	67.87	1800	28.6	1000	1000
    	68.17	0	0	0	Enabled	68.47	0	0	0	Enabled	68.78	1800	34.6	1000	1000
    	69.08	0	0	0	Enabled	69.38	0	0	0	Enabled	69.68	1800	33.8	1000	1010
    	69.98	0	0	0	Enabled	70.28	0	0	0	Enabled	70.59	1760	38.3	1000	1010
    	70.89	0	0	0	Enabled	71.19	0	0	0	Enabled	71.49	1800	41.4	1000	1010
    	71.79	0	0	0	Enabled	72.1	0	0	0	Enabled	72.4	1800	41.4	1000	1010
    	72.7	0	0	0	Enabled	73	0	0	0	Enabled	73.3	1800	39.8	1000	1010
    	73.6	0	0	0	Enabled	73.91	0	0	0	Enabled	74.21	1800	32.3	1000	1010
    	74.51	0	0	0	Enabled	74.81	0	0	0	Enabled	75.11	1800	33.1	990	1010
    	75.41	0	0	0	Enabled	75.72	0	0	0	Enabled	76.02	1800	32.3	990	1010
    	76.32	0	0	0	Enabled	76.62	0	0	0	Enabled	76.92	1760	39.8	990	1010
    	77.22	0	0	0	Enabled	77.53	0	0	0	Enabled	77.83	1800	59.4	990	1020
    	78.13	0	0	0	Enabled	78.43	0	0	0	Enabled	78.73	1880	61.7	990	1040
    	79.03	0	0	0	Enabled	79.34	0	0	0	Enabled	79.64	1920	60.2	990	1050
    	79.94	0	0	0	Enabled	80.24	0	0	0	Enabled	80.54	1960	60.2	990	1050
    	80.85	0	0	0	Enabled	81.15	0	0	0	Enabled	81.45	2000	53.4	990	1090
    	81.75	0	0	0	Enabled	82.05	0	0	0	Enabled	82.35	2000	38.3	990	1030
    	82.65	0	0	0	Enabled	82.96	0	0	0	Enabled	83.26	2000	28.6	990	1020
    	83.56	0	0	0	Enabled	83.86	0	0	0	Enabled	84.16	1920	19.5	990	1010
    	84.46	0	0	0	Enabled	84.77	0	0	0	Enabled	85.07	1880	17.3	990	1010
    	85.37	0	0	0	Enabled	85.67	0	0	0	Enabled	85.97	1840	18.8	990	1000
    	86.28	0	0	0	Enabled	86.58	0	0	0	Enabled	86.88	1400	13.5	990	1000
    	87.18	0	0	0	Disabled	87.48	0	0	0	Disabled	87.77	960	22.6	990	1000
    	88.08	0	0	0	Disabled	88.39	0	0	0	Disabled	88.68	800	20.3	990	1000
    	88.98	0	0	0	Disabled	89.28	0	0	0	Disabled	89.58	760	20.3	990	1000
    	89.89	0	0	0	Disabled	90.19	0	0	0	Disabled	90.49	760	21.1	990	1000
    	90.79	0	0	0	Disabled	91.09	0	0	0	Disabled	91.39	760	21.1	990	1000
    	91.7	0	0	0	Enabled	92.01	0	0	0	Enabled	92.31	760	21.8	990	1000
    	92.61	0	0	0	Enabled	92.91	0	0	0	Enabled	93.2	800	21.8	990	1000
    	93.51	0	0	0	Enabled	93.82	0	0	0	Enabled	94.11	1480	20.3	990	1000
    	94.42	0	0	0	Enabled	94.72	0	0	0	Enabled	95.03	1440	55.6	990	1000
    	95.32	0	0	0	Enabled	95.62	0	0	0	Disabled	95.93	1480	62.4	990	1020
    	96.23	0	0	0	Disabled	96.53	0	0	0	Disabled	96.84	1520	54.9	990	1030
    	97.14	0	0	0	Enabled	97.44	0	0	0	Enabled	97.73	1560	42.9	990	1020
    	98.04	0	0	0	Enabled	98.34	0	0	0	Enabled	98.65	1560	36.1	990	1010
    	98.95	0	0	0	Enabled	99.25	0	0	0	Enabled	99.54	1560	35.3	990	1010
    	99.85	0	0	0	Enabled	100.15	0	0	0	Enabled	100.46	1560	35.3	990	1010
    	100.76	0	0	0	Enabled	101.06	0	0	0	Enabled	101.36	1560	34.6	990	1010
    	101.66	0	0	0	Enabled	101.96	0	0	0	Enabled	102.27	1560	38.3	990	1010
    	102.57	0	0	0	Enabled	102.87	0	0	0	Enabled	103.16	1560	40.6	990	1010
    	103.46	0	0	0	Enabled	103.78	0	0	0	Enabled	104.08	1600	60.2	990	1010
    	104.38	0	0	0	Enabled	104.68	0	0	0	Enabled	104.98	1680	79.7	1110	1080
    	105.27	0	0	0	Enabled	105.59	0	0	0	Enabled	105.89	1800	96.2	1170	1190
    	106.19	0	0	0	Enabled	106.49	0	0	0	Enabled	106.79	1920	91	1170	1270
    	107.09	0	0	0	Disabled	107.4	0	0	0	Enabled	107.7	2080	88.7	1160	1290
    	108	0	0	0	Enabled	108.3	0	0	0	Enabled	108.6	2200	88.7	1160	1320
    	108.9	0	0	0	Enabled	109.21	0	0	0	Enabled	109.51	2280	33.1	990	1210
    	109.81	0	0	0	Disabled	110.1	0	0	0	Disabled	110.4	1200	15	990	1030
    	110.71	0	0	0	Disabled	111.02	0	0	0	Disabled	111.32	1840	12.8	990	1010
    	111.62	0	0	0	Disabled	111.92	0	0	0	Disabled	112.22	1800	34.6	990	1000
    	112.53	0	0	0	Disabled	112.83	0	0	0	Disabled	113.13	1800	37.6	990	1010
    	113.43	0	0	0	Enabled	113.73	0	0	0	Enabled	114.03	1800	36.1	990	1010
    	114.33	0	0	0	Enabled	114.64	0	0	0	Enabled	114.94	1800	26.3	990	1010
    	115.24	0	0	0	Enabled	115.54	0	0	0	Enabled	115.84	1800	18	990	1010
    	116.14	0	0	0	Enabled	116.45	0	0	0	Enabled	116.75	1800	16.5	990	1000
    	117.05	0	0	0	Enabled	117.35	0	0	0	Enabled	117.65	1800	16.5	990	1000
    	117.96	0	0	0	Enabled	118.26	0	0	0	Enabled	118.55	1320	12.8	990	1000
    	118.86	0	0	0	Disabled	119.16	0	0	0	Disabled	119.45	920	22.6	990	1000
    	119.77	0	0	0	Disabled	120.07	0	0	0	Disabled	120.37	800	19.5	990	1000
    	120.66	0	0	0	Disabled	120.97	0	0	0	Disabled	121.27	760	19.5	990	1000
    	121.57	0	0	0	Disabled	121.88	0	0	0	Disabled	122.18	760	20.3	990	1000
    	122.47	0	0	0	Disabled	122.77	0	0	0	Disabled	123.07	800	20.3	990	1000
    	123.38	0	0	0	Enabled	123.68	0	0	0	Enabled	123.98	800	21.1	990	1000
    	124.28	0	0	0	Enabled	124.59	0	0	0	Enabled	124.89	760	21.1	990	1000
    	125.19	0	0	0	Enabled	125.49	0	0	0	Enabled	125.8	760	21.8	990	1000
    	126.1	0	0	0	Enabled	126.39	0	0	0	Enabled	126.7	760	21.8	990	1000
    	127.01	0	0	0	Enabled	127.3	0	0	0	Enabled	127.61	800	21.8	990	1000
    	127.9	0	0	0	Enabled	128.2	0	0	0	Enabled	128.5	800	21.1	990	1000
    	128.81	0	0	0	Enabled	129.11	0	0	0	Enabled	129.41	760	21.1	990	1000
    	129.71	0	0	0	Enabled	130.01	0	0	0	Enabled	130.32	760	21.1	990	1000
    	130.62	0	0	0	Enabled	130.92	0	0	0	Enabled	131.22	760	21.1	990	1000
    	131.52	0	0	0	Enabled	131.82	0	0	0	Enabled	132.13	760	21.8	990	1000
    	132.44	0	0	0	Enabled	132.74	0	0	0	Enabled	133.04	760	21.1	990	1000
    	133.33	0	0	0	Enabled	133.63	0	0	0	Enabled	133.94	800	21.8	990	1000
    	378.65	0	0	0	Enabled	378.94	0	0	5	Enabled	379.24	2520	47.4	1010	1060
    	379.54	0	0	0	Enabled	379.84	0	0	5	Enabled	380.15	2960	127.1	1660	1470
    	380.45	0	0	0	Enabled	380.75	0	0	5	Disabled	381.05	3840	139.8	1570	1670
    	381.35	0	0	0	Enabled	381.65	0	0	5	Disabled	381.96	3280	9.8	1010	1120
    	382.26	0	0	0	Disabled	382.56	0	0	5	Disabled	382.86	2440	10.5	1010	1040
    	383.16	0	0	0	Disabled	383.47	0	0	5	Disabled	383.77	2120	10.5	1010	1030
    	384.07	0	0	0	Disabled	384.37	0	0	5	Disabled	384.67	1960	10.5	1010	1030
    	384.97	0	0	0	Disabled	385.26	0	0	5	Disabled	385.58	2040	83.5	1580	1100
    	385.88	0	0	0	Disabled	386.18	0	0	5	Disabled	386.48	2240	131.6	1930	1480
    	386.78	0	0	0	Disabled	387.08	0	0	5	Enabled	387.39	2640	169.2	1980	1940
    	387.69	0	0	0	Enabled	387.99	0	0	13	Enabled	388.29	2800	182	2060	2000
    	388.58	0	0	1	Enabled	388.89	0	0	19	Enabled	389.2	2840	9	1010	1220
    	389.5	0	0	1	Disabled	389.8	0	0	19	Disabled	390.1	2400	10.5	1010	1050
    	390.39	0	0	1	Disabled	390.71	0	0	19	Disabled	391.01	2360	12.8	1010	1030
    	391.31	0	0	1	Disabled	391.6	0	0	19	Disabled	391.91	2360	54.9	1010	1020
    	392.21	0	0	1	Enabled	392.52	0	0	19	Disabled	392.82	2400	53.4	1010	1090
    	393.12	0	0	1	Disabled	393.42	0	0	0	Enabled	393.72	2400	22.6	1010	1070
    	394.02	0	0	0	Enabled	394.33	0	0	0	Enabled	394.63	2400	30.8	1010	1030
    	394.93	0	0	0	Enabled	395.23	0	0	0	Enabled	395.53	2360	32.3	1000	1030
    	395.83	0	0	0	Disabled	396.14	0	0	0	Enabled	396.44	2280	12	1000	1040
    	396.74	0	0	0	Disabled	397.03	0	0	0	Disabled	397.34	1160	12.8	1000	1020
    	397.64	0	0	0	Disabled	397.94	0	0	0	Disabled	398.24	960	21.8	1000	1020
    	398.54	0	0	0	Disabled	398.84	0	0	0	Disabled	399.15	800	18	1000	1010
    	612.9	0	0	0	Enabled	612.3	0	3	0	Enabled	612.6	1560	46.6	1000	1020
    	613.8	0	0	0	Enabled	613.2	0	3	0	Enabled	613.5	2240	66.9	1000	1030
    	614.71	0	0	0	Enabled	614.1	0	3	0	Enabled	614.41	3520	82	1040	1370
    	615.61	0	0	0	Disabled	615.01	0	3	0	Enabled	615.31	3480	9.8	1000	1140
    	616.52	0	0	0	Enabled	615.92	0	3	0	Disabled	616.22	2360	66.9	1000	1030
    	617.42	0	0	0	Disabled	616.82	0	3	0	Enabled	617.12	2880	122.6	1610	1430
    	618.34	0	0	0	Enabled	617.73	0	3	0	Disabled	618.03	3760	145.1	1560	1680
    	619.24	0	0	0	Disabled	618.63	0	3	0	Enabled	618.93	3680	9	1000	1160
    	620.14	0	0	0	Disabled	619.54	0	3	0	Disabled	619.84	2640	10.5	1000	1050
    	621.05	0	0	0	Disabled	620.44	0	3	0	Disabled	620.74	2600	20.3	1000	1030
    	621.95	0	0	0	Enabled	621.35	0	3	0	Enabled	621.65	2600	33.8	1000	1030
    	622.86	0	0	0	Enabled	622.25	0	3	0	Enabled	622.55	2600	23.3	1000	1030
    	623.76	0	0	0	Enabled	623.16	0	3	0	Enabled	623.46	2600	20.3	1000	1020
    	624.66	0	0	0	Disabled	624.06	0	3	0	Disabled	624.35	1880	11.3	1000	1020
    	625.57	0	0	0	Disabled	624.96	0	3	0	Disabled	625.27	1160	21.1	1000	1020
    	626.48	0	0	0	Disabled	625.87	0	3	0	Disabled	626.17	960	22.6	1000	1010
    	627.37	0	0	0	Disabled	626.77	0	3	0	Disabled	627.07	800	18.8	1000	1010
    	628.28	0	0	0	Disabled	627.67	0	3	0	Disabled	627.97	800	19.5	1000	1010
    	629.18	0	0	0	Enabled	628.58	0	3	0	Disabled	628.88	760	19.5	1000	1010
    	630.1	0	0	0	Enabled	629.48	0	3	0	Enabled	629.79	760	20.3	1000	1010
    	630.99	0	0	0	Enabled	630.39	0	3	0	Enabled	630.69	800	19.5	1000	1010
    	631.9	0	0	0	Enabled	631.29	0	3	0	Enabled	631.6	760	20.3	1000	1010
    	632.8	0	0	0	Enabled	632.2	0	3	0	Enabled	632.5	800	20.3	1000	1010
    	633.71	0	0	0	Enabled	633.1	0	3	0	Enabled	633.41	760	20.3	1000	1010
    	634.61	0	0	0	Enabled	634.01	0	3	0	Enabled	634.31	760	20.3	1000	1010
    	635.52	0	0	0	Enabled	634.91	0	3	0	Enabled	635.22	760	20.3	1000	1010
    953.84 ;2120
    954.74 ;2320
    955.65 ;2400
    956.55 ;2880
    957.46 ;2800
    958.37 ;2760
    I see some misfires right off the bat, but it is all clear up until I get into boost, and get pressure differentials.
    That is a bit embarrassing, Egg on my face and stuff.
    I wonder if my AC being on during startup caused it?
    and why does it switch from Enabled to Disabled?
    Ill get the 020 and 021 shortly.
    What did I do?? Its all jumbled up....
    Last edited by Catahula; 06-12-2018 at 09:15 PM. Reason: I guess i suck at posting logs .... sorry
  7. #16
    Than log one or two blocks at a time and post the data to see the event & notate with markers!
    You know I'm only kidding around right, seriously trying to help but that stack is been dumb down with tests omitted?
    Are your injectors stock or modified in size?
  8. Likes Catahula liked this post
  9. #17
    On Probation
    Jun 2018
    Woodinville, WA.
    Jack,
    don't go soft on me. I knew damn well what I was getting into.
    we're all good.
    I'll try and select the blocks off of Excel differently and see if they will post better.
    Marker	STAMP					STAMP
    Group C:	'115
    still all jumbled. ok. learning by mistakes is slow.
  10. Likes Uwe liked this post
  11. #18
    On Probation
    Jun 2018
    Woodinville, WA.
    Injectors are stock, stock FPR,
    I'm going to reinvestigate the coils and grab the knock sensor scans (020 and 021) tomorrow. I'll redo the 015 and 016 logging them together to see if it will post better after looking over the wiring AGAIN.
    My boost deviation has me confused. I can't tell yet if the missfires are caused by the deviation, the deviation by the missfires.
  12. #19
    Sorry sandman showed....
    Still a boost leak, WG issue, exhaust restricted or a turbo bank is smoked.
    Compare EGT's........?
    Inspect turbo chargers and inlets for FOD.
    What was DV situation and did you verify that DV solinoid isn't leaking vacuum to them by a quick isolation test to see if they are being dumped outside OBD detection?
    Also have you crimped off boost signal lines from n75 to WG air motors and did you check hold springs, plus physical integrated WG valve for burn off or crack?
    These tests should net full on boost and are only to verify from isolation.
    No throttle snaps in either direction!
  13. #20
    On Probation
    Jun 2018
    Woodinville, WA.
    I'm going to let you down today Jack.
    Its raining like a mother here, and I work outside, so I'm going to be a pussy and call it for the day.
    I'll do some extensive testing tomorrow, and get back to you.
    Thank you again for all of your help, if I haven't thanked you yet.
  14. Likes Uwe liked this post
