Page 1 of 9 123 ... LastLast
Results 1 to 10 of 89
Thread: 2.7t O2 and misfire DTC
    May 2016
    Paris of Appalachia, USA
    hey guys,
    it's been a minute since i've been on, but i'm getting HO2 DTC's again and now accompanied by misfire DTC.
    i've replaced the upstream sensors a few times now and have also tested continuity, to the best of my knowledge, of the harness from the sensors to the ICU. all seems to be good. although, a couple years ago i had to put new wires(i believe the heating wires) between the sensor plug and the icu.
    basically, i'm just looking for a good place to start for now.
    here are the DTC's:
    18014 - Rough Road/Engine Torque Signal from ABS
                P1606 - 35-00 - Electrical Malfunction
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1
                P1116 - 35-00 - Open Circuit
    17528 - Oxygen (Lambda) Sensor Heating; B2 S1
                P1120 - 35-00 - Open Circuit
                P0300 - 35-00 -
    16685 - Cylinder 1
                P0301 - 35-00 - Misfire Detected
    16686 - Cylinder 2
                P0302 - 35-00 - Misfire Detected
    16518 - Oxygen (Lambda) Sensor B1 S1
                P0134 - 35-00 - No Activity
    16538 - Oxygen (Lambda) Sensor B2 S1
                P0154 - 35-00 - No Activity
    and here are the readiness results:
    Readiness Status: 0110 0101
    Exhaust Gas Recirculation: Passed
    Oxygen Sensor Heating: Failed or Incomplete
    Oxygen Sensor(s): Failed or Incomplete
    Air Conditioning: Passed
    Secondary Air Injection: Passed
    Evaporative Emissions: Failed or Incomplete
    Catalyst Heating: Passed
    Catalytic Converter(s): Failed or Incomplete
    although, i do believe that when i ran readiness test, the egr part didn't pass. those are what i got from last time and didn't complete test past the initial ABORT in the exhaust diagnostic.
    thank you for your time.
    Please post a complete auto-scan with OBD2 and Mode 9 too.
    Thank you
    May 2016
    ok. i'm not sure of the completeness of the mode 9 but i'll give you what i got.
    Sunday,10,June,2018,13:45:43:61315
    VCDS Version: 18.2.1.2 (x64)
    Mileage:    Repair Order: 6-10-18-fulldtc
    Chassis Type: 4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005)
              75 76 77
    Address 01: Engine        Labels: 078-907-551-AZA.lbl
       Part No: 4B0 907 551 K
       Component: 2.7l V6/5VT     G   0005
       Coding: 06612
       Shop #: WSC 02325
       VCID: 2C577EDFDCE4B424AB-5140
    9 Faults Found:
                P1116 - 35-10 - Open Circuit - Intermittent
                P1120 - 35-10 - Open Circuit - Intermittent
                P0300 - 35-10 -  - Intermittent
    16685 - Cylinder 1
                P0301 - 35-10 - Misfire Detected - Intermittent
    16686 - Cylinder 2
                P0302 - 35-10 - Misfire Detected - Intermittent
                P0134 - 35-10 - No Activity - Intermittent
                P0154 - 35-10 - No Activity - Intermittent
    18010 - Power Supply Terminal 30
                P1602 - 35-10 - Voltage too Low - Intermittent
    Readiness: 0110 0101
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY1.lbl
       Part No: 4B0 820 043 R
       Component: A6-Klimavollautomat D63
       Coding: 00160
       Shop #: WSC 02335
       VCID: 295987CBD316A10C50-2580
    Address 15: Airbags        Labels: 4B0-959-655-AI8.lbl
       Part No: 4B0 959 655 F
       Component: Airbag Front+Kopf  0002
       Coding: 00406
       Shop #: WSC 02335
       VCID: 336565A301DAEBDCEA-5198
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487
       Component: E Lenkrad Elektronik D03
       VCID: 69D9C7CB1396610C90-4BCA
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 980 MX
       Component: C5-KOMBIINSTR. VDO D11
       Coding: 02264
       VCID: 071DE17325C2B77C66-515E
    No Faults Found
    Address 35: Centr. Locks        Labels:. 4B0-962-258.lbl
       Part No: 4B0 962 258 J
       Component: Central Lock/Alarm  D32
       Coding: 15885
       Shop #: WSC 02335
       VCID: 306F6AAFF0CCD0C497-4EEA
    01560 - Passenger Door
                59-00 - Can't Unlock
    01562 - Rear right door
       Part No: 4B0 959 760 A
       Component: Sitzmemory          D05
       VCID: 2B557DC3D9EAB31CA2-4B1A
    Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
       Part No: 4B0 951 178 A
       Component: Innenraumueberw.    D02
       Coding: 00101
       Shop #: WSC 02335
       VCID: 26438CF7C2088E747D-5210
    01377 - Ultra Sonic Sensor for Alarm System; Left (G170)
                27-00 - Implausible Signal
    01462 - Anti-theft alarm ultra sonic Sensor (G209)
                53-10 - Supply Voltage Too Low - Intermittent
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D004
       Coding: 00006
       Shop #: WSC 02325
       VCID: 65C1CBFBFF8E456CB4-51B6
    00774 - Level Control System Sensor; Rear Left (G76)
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 4B0 035 195 A
       Component:  Radio              D00
       Coding: 00117
       Shop #: WSC 02335
       VCID: 1E33A4179A5856B435-4B32
    End-------------------------(Elapsed Time: 07:01)--------------------------
    Sunday,10,June,2018,13:31:48:61315
    Mileage:    Repair Order: 6-10-18-calID
    Mode 9 : Calibration Identification
    Type 04 - Calibration ID : 0001 (Address 10)
    Type 06 - Calibration Verification Number : 0000002D (Address 10)
    my car is a 2000 allroad unmodified.
  4. Likes Uwe, Jack@European_Parts liked this post
    Change the rear OXS sensors, because the heater circuits are shared in a loop with front and rear & the ECU may be already damaged.
    Be sure that all 4 OXS sensors are genuine units and not even AFT Bosch.
    Check grounds and all lead current tracks to coils.
    Check for false air leak & that is causing the forward OXS sensors to go dead.
    Check for adequate FPR function, Fuel PSI & volume.
    Verify the MAF isn't dead or wrong part number or FOD type because I suspect it is and causing the ABS to wig out and possible cause for forward OXS inactivity too.
    I also have reason to believe your ECU is indeed inconsistent and possibly FOD modified!
    May 2016
    those all sound like very good tests for a baseline, hopefully. do you have any suggestions on checking for false air leaks? as in pressurize the intake and see if anything leaks??? i have also thought that the ECU might be inconsistent as you're mentioning. additionally, the reason that i had changed the leads to the upper OXS is because they were burnt and giving a bit of resistance. might i assume that there are also related traces in the ECU which are also burnt?
    Could be .......
    No no no over here!
    http://forums.ross-tech.com/showthre...you!-Air-leaks!
    May 2016
    haha. i like the pic. thank you for that link. i have to go to dinner, but i'll look through it and gather anything necessary. the only reason that i had asked about the leak test is that i build a pressure tester with a fernco et. al. for the intake, but there is obviously more. i may also have a bad cam seal.
    furthermore, while searching the DTCs online i came across one for the misfire that said that a cylinder might be leaking and to do a compression test. would that be a concern given these DTCs, or is the combination of the codes relative more so to what you are considering?? but that won't stop me from performing one anyways, because i would think that it's a good idea regardless
  9. #8
    May 2016
    do you mean the ultra-expensive, like 200 beans for one, OXS?? instead of the bosch click in or universal?
  10. #9
    Yup........ because it indeed can and most time does matter!
  11. #10
    May 2016
    oh ok. i wasn't sure if that was an urban legend, but i'm definitely taking your word.
