- May 23, 2016
- 68
- 11
- Paris of Appalachia, USA
- C?ID=278787
hey guys,
it's been a minute since i've been on, but i'm getting HO2 DTC's again and now accompanied by misfire DTC.
i've replaced the upstream sensors a few times now and have also tested continuity, to the best of my knowledge, of the harness from the sensors to the ICU. all seems to be good. although, a couple years ago i had to put new wires(i believe the heating wires) between the sensor plug and the icu.
basically, i'm just looking for a good place to start for now.
here are the DTC's:
and here are the readiness results:
although, i do believe that when i ran readiness test, the egr part didn't pass. those are what i got from last time and didn't complete test past the initial ABORT in the exhaust diagnostic.
thank you for your time.
here are the DTC's:
18014 - Rough Road/Engine Torque Signal from ABS
P1606 - 35-00 - Electrical Malfunction
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-00 - Open Circuit
17528 - Oxygen (Lambda) Sensor Heating; B2 S1
P1120 - 35-00 - Open Circuit
P0300 - 35-00 -
16685 - Cylinder 1
P0301 - 35-00 - Misfire Detected
16686 - Cylinder 2
P0302 - 35-00 - Misfire Detected
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-00 - No Activity
16538 - Oxygen (Lambda) Sensor B2 S1
P0154 - 35-00 - No Activity
Readiness Status: 0110 0101
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Failed or Incomplete
Oxygen Sensor(s): Failed or Incomplete
Air Conditioning: Passed
Secondary Air Injection: Passed
Evaporative Emissions: Failed or Incomplete
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
