Results 11 to 20 of 23
Thread: 0778 2006 Audi A6 vant Quattro 3.2
    Have you verified that your steering column module supports a heated steering wheel? It wouldn't surprise me if Audi used a different one for that.
    Mar 2014
    Uwe,
    Well, no I haven't. What I bought is complete from the module to the clock spring. I'm changing one piece at a time! I will swap my wiper stalk with the A8 unit and install all the parts. That should do it. I'll let you know. Thanks for all your help with this. I have certainly learned a lot about my VCDS. By the by, I checked the MVB's for HSW and, in green letters, I saw 'not installed'
    Kurt
  3. Likes Uwe liked this post
  4. #13
    Mar 2014
    Uwe,
    I changed the module today and found a new (different) problem. When I tried the SAS alignment/calibration process I get green letters in Basic Settings MVB #001 [ADJ STEERING] [ANGLE SENSOR] [ LOCKED] [N/A]
    MVB 005 has red letters and 'not enabled', 'N/A', etc.
  5. #14
    You changed which module? Got a scan with the new module installed?
  6. Likes jakematic liked this post
  7. #15
    Verified VCDS User gupsterg's Avatar
    Sep 2014
    Hi Porscetech,
    Uwe asked:-
    You replied:-
    Quote Originally Posted by porschetech View Post
    Well, no I haven't
    I'd like to inform you after seeing this info in your autoscan log :-
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549 A
    That you will require a differing steering module to support heated steering wheel.
    If your going to use A8 module one then you need SW: 4E0 910 549 A HW P/N: 4E0 953 549 B
    If your going to use A6 module then you'll need SW: 4F0 910 549 A HW P/N: 4F0 953 549 C
    I was going to look at your coding as VCDS log in post 1 have different coding for module 16 than the one in post 3, then in post 8 & 10 you start stating some other differing codings but no point now until you have correct module 16 installed.
    All the best
    Gup
  8. Likes Dana, Uwe liked this post
  9. #16
    Mar 2014
    Uwe,
    Here is a scan from this morning. What a mess! By the way, after changing the steering column, the heated steering wheel works.
    VCDS Version: Release 12.12.3 (x64)
    Data version: 20140822
    Monday,27,October,2014,10:39:45:52331
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 34 36 37 42 46 47 4F
              52 53 55 56 61 62 65 67 6D 72 76 77
    VIN: WAUKG74F06N018485   Mileage: 182800km/113586miles
    00-Steering Angle Sensor -- Status: Sporadic communication error 1000
    0E-Media Player 1 -- Status: Malfunction 0010
    55-Xenon Range -- Status: Malfunction 0010
    Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
       Part No SW: 4F1 910 559 F    HW: 4F1 907 559 A
       Component: 3.2l V6 FSI         0040
       Revision: --H15---    Serial number:
       Coding: 010D0106190F0520
       Shop #: WSC 98765 666 36911
       VCID: 2E5915CDB9DB2E6E391-807B
                   P1602 - 008 - Voltage too Low - Intermittent
                        Fault Status: 00001000
                        Reset counter: 32
                        Mass Air / Rev.: 0.0 mg/str
                        Temperature: 85.5°C
                            Engine Off
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 008 -
                        Fault Frequency: 13
                        Reset counter: 40
                        Mileage: 182678 km
                        Date: 2014.10.22
                        Time: 15:42:43
                        RPM: 1088 /min
                        Mass Air / Rev.: 92.7 mg/str
                        Temperature: 73.5°C
                            Idle
                        Load: 11.0 %
    009220 - EVAP Leak Detection Pump Sense Circuit
                   P2404 - 006 - Implausible Signal
                        Reset counter: 40
                        Mileage: 182731 km
                        Date: 2014.10.24
                        Time: 16:39:14
                        RPM: 1888 /min
                        Mass Air / Rev.: 223.5 mg/str
                        Temperature: 63.0°C
                            Part Throttle
                        Voltage: 13.97 V
                        Speed: 92.0 km/h
    005672 - Powertrain Data Bus
                   P1628 - 009 - Missing Message from Steering Angle Sensor
                        Fault Frequency: 13
                        Reset counter: 40
                        Mileage: 182781 km
                        Date: 2014.10.26
                        Time: 13:09:20
                        Temperature: 6.0°C
                            Engine Off
                        Voltage: 11.93 V
       Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
       Component: AG6 09L 3,2 FSI USA 0010
       Revision: --H01---    Serial number:        4025867
       Shop #: WSC 02335 785 00200
       VCID: 31630EB1A8E53196243-8064
    049446 - No Communications with Steering Angle Sender (G85)
                   U0126 - 000 -
                        Reset counter: 40
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
                        (no units): 30.0
                        (no units): 24.0
                        Temperature: 55.0°C
                        T.B. Angle: 0.0°
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H03 0090
       Coding: 0016799
       VCID: 2D5B12C1B4DD557600B-8078
                        Reset counter: 13
                        Mileage: 182807 km
                        Date: 2014.10.27
                        Time: 10:18:22
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x001E
                        Hex Value: 0x4392
                        Hex Value: 0x00FF
                        Reset counter: 13
                        Mileage: 182781 km
                        Date: 2014.10.26
                        Time: 13:29:52
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x0021
                        Hex Value: 0x419D
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Component: FBSAUDIC6 ELV   H30 0170
       Revision: 17040501    Serial number: 10600300135994
       Coding: 0000143
       Shop #: WSC 07109 444 65458
       VCID: E3CF34F92299530666F-80B6
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 EZS   H44 0070
       Component: FBSAUDIC6 KSG   H26 0080
    00956 - Key 2
                        Fault Status: 00110010
                        Reset counter: 38
                        Mileage: 182545 km
                        Date: 2014.10.20
                        Time: 12:18:17
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F0 910 731 B    HW: 4E0 035 729
       Component: Interfacebox    H43 1190
       Revision: 00000000    Serial number: 360DI057523065
       Coding: 0000003
       VCID: 2143FEF1F8058116B43-8074
       Subsystem 1 - Part No: 4F0 910 609 B
       Component: Bedienteil MMIC6H07 0010
       Subsystem 2 - Serial number: 00000000143989
       Subsystem 3 - Serial number: 0120.04.050000000100010106ÿ
       Subsystem 4 - Serial number: 010106ÿ
    00384 - Optical Databus
                        Fault Status: 00101011
                        Fault Frequency: 193
                        Reset counter: 39
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:25:01
                        Reset counter: 29
                        Mileage: 182197 km
                        Date: 2014.10.12
                        Time: 16:53:00
                        Bin. Bits: 00000000
                        Bin. Bits:  0000000
                        Bin. Bits:      001
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043     HW: 4F1 820 043 J
       Component: KLIMABETAETIGUNGH11 0150
       Revision: 00000026    Serial number: 00000030016936
       Coding: 0524582
       VCID: DBBF0C191AE96BC62EF-808E
    00797 - Sunlight Photo Sensor (G107)
                        Fault Status: 00101001
                        Fault Frequency: 56
                        Reset counter: 53
                        Mileage: 182120 km
                        Date: 2014.10.10
                        Time: 18:40:22
       Part No SW: 4F0 910 279     HW: 4F0 907 279
       Component: ILM Fahrer      H14 0080
       Coding: 0013123
       VCID: E6C92DEDD1AB262E811-80B3
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0430
       Revision: 00000000    Serial number: AUZ5ZBE7158818
       VCID: 1B3FCC19DA69ABC66EF-804E
                        Reset counter: 32
                        Mileage: 182382 km
                        Date: 2014.10.15
                        Time: 15:10:54
    Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
       Part No: 4E0 910 593 E
       Component: SDAR
       VCID: 2953E6D180354956EC3-FFFF
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
       Component: 56 AIRBAG AUDI8RH29 0310
       Revision: 10H29000    Serial number: 00359D08CE4P
       Coding: 0013622
       Shop #: WSC 40233 444 83861
       VCID: 2649EDED912B662EC11-8073
       Subsystem 1 - Part No: 4F0 910 339
       Component: BF-Gewichtsens. 002 0040
       Subsystem 2 - Serial number: 6332CSME084866531
       Subsystem 3 - Serial number: 6342CSME095138491
       Subsystem 4 - Serial number: 6351HSME07085324$
       Subsystem 5 - Serial number: 6361HSME07001029U
       Subsystem 6 - Serial number: 6371VSME071B5D21N
       Subsystem 7 - Serial number: 6381VSME066F0A6B
       Component: Lenksäulenmodul H12 0040
       Coding: 0002242
       Shop #: WSC 02311 785 00200
       VCID: E5CB2AE12CAD2D3688B-80B0
                        Reset counter: 52
                        Mileage: 182536 km
                        Date: 2014.10.19
                        Time: 14:27:43
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
       Component: KOMBIINSTR. M73 H15 0630
       Revision: 01000000    Serial number: 4PY52RW45
       Coding: 2161263
       Shop #: WSC 07109 444 999999
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Component: Gateway         H10 0060
       Revision: 10          Serial number: 1200805428809A
       Coding: ECFE7BCD1B7906
       Shop #: WSC 07109 444 52498
       VCID: 2757E0E996217F26FA7-8072
                        Reset counter: 18
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
                        Fault Frequency: 42
                        Reset counter: 53
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 18:27:40
                        Reset counter: 25
                        Mileage: 182249 km
                        Date: 2014.10.13
                        Time: 14:11:49
                        Reset counter: 36
                        Mileage: 182536 km
                        Date: 2014.10.19
                        Time: 14:43:01
    Address 34: Level Control        Labels: None
       Part No SW: 4F0 910 553     HW: 4F0 907 553
       Component: J197 LUFTFEDER  H15 0040
       Serial number: 006280004517
       Coding: 0000210
       VCID: E1C33EF138854116743-80B4
                        Fault Frequency: 61
                        Reset counter: 13
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
                        Fault Status: 11101101
                        Fault Frequency: 80
                        Reset counter: 13
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
       Coding: 0082954
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
       Component: MNS US          H44 1100
       Revision: 00000000    Serial number: 378DR057521094
       VCID: 387533954B9FE0DE63D-806D
    02927 - DVD Read Error
                        Reset counter: 44
                        Mileage: 182486 km
                        Date: 2014.10.17
                        Time: 11:12:00
                        Hex Value: 0x5447
                        Hex Value: 0x9E98
                        Hex Value: 0x0401
                        Hex Value: 0x0000
       Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
       Component: TSG FA          H11 0040
       Revision: 00-00000
       Coding: 0052971
       VCID: 2953E6D180354956EC3-807C
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
       Component: Komfortgeraet   H18 0130
       Revision: 01300018    Serial number: 01004042370000
       Coding: 7764669
                        Reset counter: 36
                        Mileage: 182536 km
                        Date: 2014.10.19
                        Time: 14:43:04
       Part No SW: 4F0 910 223 A    HW: 4F0 035 223 A
       Component: DSP-High C6     H09 0140
       Revision: PROD_01     Serial number: 00000000782185
       Coding: 0000126
       VCID: 1C3DCF05DF67ACFE675-8049
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000000614
       Coding: 0002114
       VCID: DEB9050D09FB7EEE491-808B
       Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
       Component: TSG BF          H11 0040
       Revision: 00-00000
       Coding: 0052971
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0005022
       Shop #: WSC 02334 785 00200
       VCID: DDBB020104FD65F650B-8088
    Address 55: Xenon Range        Labels: 4F0-910-357.lbl
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Component: AFS 1           H01 0030
       Coding: 0000017
       Shop #: WSC 02331 785 00200
       Subsystem 1 - Part No: 4F0 941 329 D
       Component: AFS-Modul links H02 0010
       Subsystem 2 - Part No: 4F0 941 329 D
       Component: AFS-Modul rechtsH01 0010
                        Fault Status: 11100100
                        Fault Frequency: 58
                        Reset counter: 13
                        Mileage: 182104 km
                        Date: 2014.10.10
                        Time: 17:05:45
       Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
       Component: TUNER EU/US/RDW H42 0480
       Revision: 00000000    Serial number: 394EX057543394
       VCID: 234FF4F9E2199306A6F-8076
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000028101
       Shop #: WSC 00477 384 00291
       Subsystem 1 - Part No: 4F0 915 105 E
       Component: von VA0  1504220025
       Coding: 344630393135313035452056413031353034323230303235
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H11 0030
       Coding: 0052778
       VCID: E9D326D1C0B50956AC3-80BC
       Part No SW: 4F0 910 273     HW: 4F0 907 273
       Component: Reifendruck 3   H04 0080
       Revision: 00040080    Serial number: 00000900004252
       Coding: 0062221
       Shop #: WSC 07109 444 54528
       VCID: E0C53BF5338F481E7BD-80B5
       Part No SW: 4E0 910 754 J    HW: 4E0 035 753 A
       Component: SDS 3501 US     H45 0600
       Revision: 00000000    Serial number: 00000503290361
       Shop #: WSC 12336 024 394758
    Address 6D: Trunk Elect.        Labels: Redir Fail!
       Part No SW: 4F9 910 591     HW: 4F9 827 851 B
       Component: ValeoHeckdeckel H14 0280
       Revision: --H14001    Serial number: E5030000B
       Shop #: WSC 23250 431 715754
       VCID: ECDD5FC5CF471C7ED75-80B9
       Subsystem 1 - Part No: 4F9 910 592
       Subsystem 3 - Serial number: KK09.05.05--H14001001A0047ÿ
       Subsystem 4 - Serial number: 1A0047ÿ
       Part No SW: 4F0 910 795     HW: 4F0 959 794
       Component: TSG HR          H11 0030
       Coding: 0052778
       Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
       Component: Parkhilfe 4-Kan H09 0020
       Revision: 00H09000    Serial number: 00000000000000
       Coding: 0201216
       Part No SW: 4F0 910 336 B    HW: 4E0 862 335
       Component: Handyvorb2      H10 0440
       Revision: 00000000    Serial number: 00000007521090
       Coding: 0010900
       VCID: 2241F1FDFD039A0EAD9-8077
    Kurt
  10. Likes gupsterg liked this post
  11. #17
    Sep 2014
    Coding: 0002242
    EPC data showed that module doesn't support heated steering wheel
    But good news! and a round of applause for your perseverance!
  12. #18
    Mar 2014
    Quote Originally Posted by gupsterg View Post
    The scan you are referring to is from before I changed the module and clock spring out of my A6 using a good used clock spring and module and heated steering wheel from an A8.
    Please look at the scan from this morning an verify that all the A8 parts on the car now will work OK together. I have heat, but I can't calibrate the steering wheel sensor.
    Kurt
  13. #19
    Sep 2014
    The data I've posted in post 17 is from your new scan in post 16.
  14. #20
    Mar 2014
    Gup,
    I don't know what is going on with the scan data. I now have the "B" clock spring and the "B" module (4E0) from an '05 A8 along with the SW with heat/switch, etc. The heat works fine after installing the "B" module but the SAS is "locked" and I cannot adjust it. I was able to do steering centering before I installed the HSW "B" module?
    At this point, I really need to know how to unlock the SAS for calibration? Any ideas?
    Kurt
