Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 0778 2006 Audi A6 vant Quattro 3.2
    Mar 2014
    I have retrofitted an heated steering wheel to my A6. I also changed the clock spring or steering angle sensor (G85) and combination switch with attached module. The module was already coded for the HSW and values for it register in MB's. I cannot, however, calibrate my steering angle sensor. My ABS control module appears to be coded and was not disturbed during the changeover. I have followed the instructions in the WIKI, to no avail. When I get to the place I am supposed to click on "on off start", segments are all reed and 3 & 4 say not available. I am attaching a scan for you. Any help will be appreciated.
    Thanks,
    Kurt
    Friday,10,October,2014,17:10:10:52331
    VCDS Version: 12.12.3.0 (x64)
    Data version: 20140822
    VIN: WAUKG74F06N018485   License Plate: BNT-1949
    Mileage: 182100km-113151mi   Repair Order: 10/10/14A6
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 34 36 37 42 46 47 4F
              52 53 55 56 61 62 65 67 6D 72 76 77
    VIN: WAUKG74F06N018485   Mileage: 182100km/113151miles
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    55-Xenon Range -- Status: Malfunction 0010
    Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
       Part No SW: 4F1 910 559 F    HW: 4F1 907 559 A
       Component: 3.2l V6 FSI         0040
       Revision: --H15---    Serial number:
       Coding: 010D0106190F0520
       Shop #: WSC 98765 666 36911
       VCID: 2E5915CDB9DB2E6E391-807B
    009220 - EVAP Leak Detection Pump Sense Circuit
                   P2404 - 006 - Implausible Signal - Intermittent
                        Reset counter: 32
                        Mileage: 181999 km
                        Date: 2014.10.01
                        Time: 16:06:42
                        RPM: 1056 /min
                        Mass Air / Rev.: 98.1 mg/str
                        Temperature: 66.0°C
                            Idle
                        Voltage: 14.08 V
                        Speed: 33.0 km/h
    005672 - Powertrain Data Bus
                   P1628 - 009 - Missing Message from Steering Angle Sensor
                        Reset counter: 40
                        Mileage: 182105 km
                        Date: 2014.10.10
                        Time: 15:27:41
                        Mass Air / Rev.: 0.0 mg/str
                        Temperature: 87.0°C
                            Engine Off
                        Voltage: 12.44 V
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 008 -
                        Fault Frequency: 7
                        Reset counter: 40
                        Mileage: 182105 km
                        Date: 2014.10.10
                        Time: 15:27:41
                        RPM: 672 /min
                        Mass Air / Rev.: 114.5 mg/str
                        Temperature: 87.0°C
                            Idle
                        Load: 18.0 %
       Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
       Component: AG6 09L 3,2 FSI USA 0010
       Revision: --H01---    Serial number:        4025867
       Shop #: WSC 02335 785 00200
       VCID: 31630EB1A8E53196243-8064
    049446 - No Communications with Steering Angle Sender (G85)
                   U0126 - 000 -
                        Reset counter: 40
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
                        (no units): 30.0
                        (no units): 24.0
                        Temperature: 55.0°C
                        T.B. Angle: 0.0°
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H03 0090
       Coding: 0016799
       VCID: 2D5B12C1B4DD557600B-8078
                        Reset counter: 234
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x001E
                        Hex Value: 0x4394
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Component: FBSAUDIC6 ELV   H30 0170
       Revision: 17040501    Serial number: 10600300135994
       Coding: 0000143
       Shop #: WSC 07109 444 65458
       VCID: E3CF34F92299530666F-80B6
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 EZS   H44 0070
       Component: FBSAUDIC6 KSG   H26 0080
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F0 910 731 B    HW: 4E0 035 729
       Component: Interfacebox    H43 1190
       Revision: 00000000    Serial number: 360DI057523065
       Coding: 0000003
       VCID: 2143FEF1F8058116B43-8074
       Subsystem 1 - Part No: 4F0 910 609 B
       Component: Bedienteil MMIC6H07 0010
       Subsystem 2 - Serial number: 00000000143989
       Subsystem 3 - Serial number: 0120.04.050000000100010106’
       Subsystem 4 - Serial number: 010106’
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043     HW: 4F1 820 043 J
       Component: KLIMABETAETIGUNGH11 0150
       Revision: 00000026    Serial number: 00000030016936
       Coding: 0524582
       VCID: DBBF0C191AE96BC62EF-808E
       Part No SW: 4F0 910 279     HW: 4F0 907 279
       Component: ILM Fahrer      H14 0080
       Coding: 0013123
       VCID: E6C92DEDD1AB262E811-80B3
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0430
       Revision: 00000000    Serial number: AUZ5ZBE7158818
       VCID: 1B3FCC19DA69ABC66EF-804E
    Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
       Part No: 4E0 910 593 E
       VCID: 2953E6D180354956EC3-FFFF
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
       Component: 56 AIRBAG AUDI8RH29 0310
       Revision: 10H29000    Serial number: 00359D08CE4P
       Coding: 0013622
       Shop #: WSC 40233 444 83861
       VCID: 2649EDED912B662EC11-8073
       Subsystem 1 - Part No: 4F0 910 339
       Component: BF-Gewichtsens. 002 0040
       Subsystem 2 - Serial number: 6332CSME084866531
       Subsystem 3 - Serial number: 6342CSME095138491
       Subsystem 4 - Serial number: 6351HSME07085324$
       Subsystem 5 - Serial number: 6361HSME07001029U
       Subsystem 6 - Serial number: 6371VSME071B5D21N
       Subsystem 7 - Serial number: 6381VSME066F0A6B
    Address 16: Steering wheel        Labels: 4E0-910-549.lbl
       Part No SW: 4E0 910 549     HW: 4E0 953 549 A
       Component: Lenksäulenmodul H12 0040
       Coding: 0012241
       Shop #: WSC 02311 785 00200
       VCID: E5CB2AE12CAD2D3688B-80B0
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
       Component: KOMBIINSTR. M73 H15 0630
       Revision: 01000000    Serial number: 4PY52RW45
       Coding: 2161263
       Shop #: WSC 07109 444 999999
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Component: Gateway         H10 0060
       Revision: 10          Serial number: 1200805428809A
       Coding: ECFE7BCD1B7906
       Shop #: WSC 07109 444 52498
       VCID: 2757E0E996217F26FA7-8072
                        Reset counter: 234
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
    Address 34: Level Control        Labels: None
       Part No SW: 4F0 910 553     HW: 4F0 907 553
       Component: J197 LUFTFEDER  H15 0040
       Serial number: 006280004517
       Coding: 0000210
       VCID: E1C33EF138854116743-80B4
                        Reset counter: 234
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
                        Fault Status: 11101101
                        Reset counter: 234
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
       Coding: 0082954
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
       Component: MNS US          H44 1100
       Revision: 00000000    Serial number: 378DR057521094
       VCID: 387533954B9FE0DE63D-806D
       Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
       Component: TSG FA          H11 0040
       Revision: 00-00000
       Coding: 0052971
       VCID: 2953E6D180354956EC3-807C
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
       Component: Komfortgeraet   H18 0130
       Revision: 01300018    Serial number: 01004042370000
       Coding: 7764669
       Part No SW: 4F0 910 223 A    HW: 4F0 035 223 A
       Component: DSP-High C6     H09 0140
       Revision: PROD_01     Serial number: 00000000782185
       Coding: 0000126
       VCID: 1C3DCF05DF67ACFE675-8049
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000000614
       Coding: 0002114
       VCID: DEB9050D09FB7EEE491-808B
       Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
       Component: TSG BF          H11 0040
       Revision: 00-00000
       Coding: 0052971
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0005022
       Shop #: WSC 02334 785 00200
       VCID: DDBB020104FD65F650B-8088
    Address 55: Xenon Range        Labels: 4F0-910-357.lbl
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Component: AFS 1           H01 0030
       Coding: 0000017
       Shop #: WSC 02331 785 00200
       Subsystem 1 - Part No: 4F0 941 329 D
       Component: AFS-Modul links H02 0010
       Subsystem 2 - Part No: 4F0 941 329 D
       Component: AFS-Modul rechtsH01 0010
                        Fault Status: 11100100
                        Reset counter: 234
                        Mileage: 182104 km
                        Date: 2014.10.10
                        Time: 17:05:45
       Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
       Component: TUNER EU/US/RDW H42 0480
       Revision: 00000000    Serial number: 394EX057543394
       VCID: 234FF4F9E2199306A6F-8076
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000028101
       Shop #: WSC 00477 384 00291
       Subsystem 1 - Part No: 4F0 915 105 E
       Component: von VA0  1504220025
       Coding: 344630393135313035452056413031353034323230303235
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H11 0030
       Coding: 0052778
       VCID: E9D326D1C0B50956AC3-80BC
       Part No SW: 4F0 910 273     HW: 4F0 907 273
       Component: Reifendruck 3   H04 0080
       Revision: 00040080    Serial number: 00000900004252
       Coding: 0062221
       Shop #: WSC 07109 444 54528
       VCID: E0C53BF5338F481E7BD-80B5
       Part No SW: 4E0 910 754 J    HW: 4E0 035 753 A
       Component: SDS 3501 US     H45 0600
       Revision: 00000000    Serial number: 00000503290361
       Shop #: WSC 12336 024 394758
    Address 6D: Trunk Elect.        Labels: Redir Fail!
       Part No SW: 4F9 910 591     HW: 4F9 827 851 B
       Component: ValeoHeckdeckel H14 0280
       Revision: --H14001    Serial number: E5030000B
       Shop #: WSC 23250 431 715754
       VCID: ECDD5FC5CF471C7ED75-80B9
       Subsystem 1 - Part No: 4F9 910 592
       Subsystem 3 - Serial number: KK09.05.05--H14001001A0047’
       Subsystem 4 - Serial number: 1A0047’
       Part No SW: 4F0 910 795     HW: 4F0 959 794
       Component: TSG HR          H11 0030
       Coding: 0052778
       Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
       Component: Parkhilfe 4-Kan H09 0020
       Revision: 00H09000    Serial number: 00000000000000
       Coding: 0201216
       Part No SW: 4F0 910 336 B    HW: 4E0 862 335
       Component: Handyvorb2      H10 0440
       Revision: 00000000    Serial number: 00000007521090
       Coding: 0010900
       VCID: 2241F1FDFD039A0EAD9-8077
    Last edited by Uwe; 10-13-2014 at 10:43 AM. Reason: Wrapped CODE tags around Auto-Scan
    Whenever a steering angle sensor calibration doesn't work as expected, the first thing to check is the actual readings from the steering angle sensor. In that ABS module, look at MVB 005.1 and tell us what you see there with the steering wheel centered and the front wheels pointed straight ahead. Also verify that the readings change in a plausible manner when you turn the steering wheel both to the left of center and the right of center.
    Mar 2014
    Uwe,
    MVB 005 shows 1) 0.0
    2) fluctuates between -0.14 and 0.10 rapidly
    3) .65 BAR to .98BAR fluctuating rapidly
    4)0.00 to 0.19 fluctuating rapidly
    There is no change with any of the MVB #'s while turning the steering wheel.
    In basic settings: 1 2 3 4
    MVB's 001, all red, showing: ERROR (GROUP #) NOT AVAILABLE
    mvb 003 RED SHOWING: ERROR ( GROUP #) SYSTEM TEST ENABLED NOT AVAILABLE
    I have attached a scan from this afternoon.
    I hope this is helpful.
    Kurt
    VCDS Version: Release 12.12.3 (x64)
    Tuesday,14,October,2014,14:46:33:52331
    VIN: WAUKG74F06N018485   Mileage: 182300km/113275miles
                        Reset counter: 40
                        Mileage: 181999 km
                        Date: 2014.10.01
                        Time: 16:06:42
                        RPM: 1856 /min
                        Mass Air / Rev.: 250.7 mg/str
                        Temperature: 79.5°C
                            Part Throttle
                        Voltage: 14.08 V
                        Speed: 91.0 km/h
                        Fault Frequency: 34
                        Reset counter: 40
                        Mileage: 182105 km
                        Date: 2014.10.10
                        Time: 15:27:41
                        RPM: 1216 /min
                        Mass Air / Rev.: 92.7 mg/str
                        Temperature: 84.0°C
                            Idle
                        Voltage: 11.63 V
                   P1653 - 008 -
                        Fault Frequency: 35
                        Reset counter: 40
                        Mileage: 182105 km
                        Date: 2014.10.10
                        Time: 15:27:41
                        RPM: 1024 /min
                        Temperature: 84.0°C
                            Idle
                        Load: 11.4 %
    012410 - Air Intake System
                   P307A - 009 - Flow too Low - Intermittent
                        Reset counter: 33
                        Mileage: 182156 km
                        Date: 2014.10.11
                        Time: 16:37:39
                        RPM: 672 /min
                        Mass Air / Rev.: 119.9 mg/str
                        Temperature: 85.5°C
                            Idle
                        Voltage: 13.97 V
    000104 - MAP/MAF <-> Throttle Position Correlation
                   P0068 - 007 -  - Intermittent
                        Fault Status: 00000010
                        Reset counter: 32
                        Mileage: 182156 km
                        Date: 2014.10.11
                        Time: 16:37:39
                        RPM: 672 /min
                        Temperature: 85.5°C
                            Idle
                        Voltage: 13.87 V
                        Bin. Bits: 00000010
                   U0126 - 000 -
                        Reset counter: 40
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
                        (no units): 30.0
                        (no units): 24.0
                        Temperature: 55.0°C
                        T.B. Angle: 0.0°
       Coding: 0016799
                        Reset counter: 245
                        Mileage: 182309 km
                        Date: 2014.10.14
                        Time: 14:38:43
                        Hex Value: 0x00C0
                        Hex Value: 0x4282
                        Hex Value: 0x001E
                        Hex Value: 0x4397
                        Hex Value: 0x00FF
                        Fault Frequency: 29
                        Reset counter: 245
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:24:06
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x0021
                        Hex Value: 0x4199
                        Hex Value: 0x00FF
       Coding: 0000143
       Coding: 0000003
    00384 - Optical Databus
                        Fault Status: 00101011
                        Fault Frequency: 49
                        Reset counter: 39
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:25:01
                        Reset counter: 24
                        Mileage: 182197 km
                        Date: 2014.10.12
                        Time: 16:53:00
                        Bin. Bits: 00000000
                        Bin. Bits:  0000000
                        Bin. Bits:      001
       Coding: 0524582
    00797 - Sunlight Photo Sensor (G107)
                        Fault Status: 00101001
                        Fault Frequency: 19
                        Reset counter: 30
                        Mileage: 182120 km
                        Date: 2014.10.10
                        Time: 18:40:22
       Coding: 0013123
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 593 E    HW: 4E0 035 593 A
       Component: SDAR
       Serial number: AUZ4Z7D20
                        Reset counter: 234
                        Mileage: 182107 km
                        Raw, Form. N/A: 000 000 075
                        Raw, Form. N/A: 000 000 000
       Coding: 0013622
       Coding: 0012242
       Coding: 2161263
                        Reset counter: 234
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
                        Fault Frequency: 14
                        Reset counter: 28
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 18:27:40
                        Reset counter: 25
                        Mileage: 182249 km
                        Date: 2014.10.13
                        Time: 14:11:49
       Coding: 0000210
                        Fault Frequency: 30
                        Reset counter: 245
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
                        Fault Frequency: 33
                        Reset counter: 245
                        Mileage: 182107 km
                        Date: 2014.10.10
                        Time: 17:05:43
       Coding: 0082954
       Revision: 00-00000
       Coding: 0052971
       Coding: 7764669
       Coding: 0000126
       Coding: 0002114
       Revision: 00-00000
       Coding: 0052971
       Revision: C63C0030
       Coding: 0005022
       Coding: 0000017
                        Fault Frequency: 28
                        Reset counter: 245
                        Mileage: 182104 km
                        Date: 2014.10.10
                        Time: 17:05:45
       Coding: 0052778
       Coding: 0062221
       Coding: 0052778
       Coding: 0201216
       Coding: 0010900
    Tartu, Estonia
    Just a reminder.
    [ CODE] autoscan info [/ CODE]
    Without spaces.
    The world is my oyster...
    Does this change when you move the steering wheel? 'Cause if it doesn't, then that would explain why you can't calibrate the sensor.
    Mar 2014
    Uwe,
    The numbers do not change.
  7. #7
    OK, and you also have this in the ABS.
    Given that
    Quote Originally Posted by porschetech View Post
    I think you need to back-track your steps and perhaps revert some parts to figure out what's wrong here.
    Mar 2014
    Uwe,
    I have succeeded in gaining steering angle sensor recalabration. Everything works better when I followed the directions properly! This whole deal started as I am trying to add a heated steering wheel to the car. All the hardware has been changed (wheel and associated clock spring). I am trying to change the coding from factory default 0002042 to 0002242 but VCDS shows code not accepted. I'm wondering if I need a security code (as with ABS) in order to recode? Where may I find this code, if that is what I need?
    Thanks,
    Kurt
  9. #9
    What's the exact error you get when the module rejects it?
    I don't think a security access code is needed to code the steering column module.
    Mar 2014
    Uwe,
    Just in case my efforts are getting in trouble; here is what I have done.
    Start VCDS select 16-steering wheel 07 coding changed 0004042 to 0004242.
    Do it Code rejected. Error 31 Request out of range. exit, exit, etc.
    Kurt
