- Joined
- May 12, 2014
- Messages
- 52
- Reaction score
- 13
- Location
- Palestine Gaza
- VCDS Serial number
- C?ID=11756
Hi all
I have got Audi A6, the problem is sometimes the electricity from the cluter going to be OFF and no more electricity and try to make ignition on but nothing of the light will be on and there is no ignition on in the car ,, when I remove the battery cable and attatch it again everything come back and the car has the ability to ignition on and start the car , PS : without removing the battery cable the car dosnt ignition on and there is no more lights in the cluster ,,
Tank you all
here is the Autoscan :
Tank you all
Sunday,12,October,2014,15:57:22:25282
VCDS Version: 14.8.1.0
Data version: 20140905
Dealer/Shop Name: Ferwana Workshop Bros.
Workshop Code: 123 12345 023456
VIN: WAUZZZ4F55N117161 License Plate: XXXXXXXX
Mileage: 58650km-36443mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
62 72 77
VIN: WAUZZZ4F55N117161 Mileage: 58650km-36443miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 4F0 910 559 E HW: 4F0 907 559
Component: 3.0L V6/5V G 0030
Revision: --H01--- Serial number:
Coding: 0011582
Shop #: WSC 02325 785 00200
VCID: 2C5D60F28F69F55A55-8079
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
16486 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - MIL ON
Readiness: 0010 1101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4F1 910 155 C HW: 01J 927 156 HT
Component: V30 01J 3.0l 5V RdW 0020
Revision: 00000012 Serial number: 00000002071898
Shop #: WSC 04940 001 00001
VCID: 234F8BCEE2B73A22E4-8076
006231 - Load Signal
P1857 - 000 - Error Message from ECU
Mileage: 55972 km
Date: 2005.02.04
Time: 03:32:10
RPM: 896 /min
RPM: 70 /min
(no units): 2.0
Torque: 26.0 Nm
Temperature: 71.0°C
T.B. Angle: 0.0°
Bin. Bits: 1010 0 1
005953 - Clutch Pressure Adaptation
P1741 - 000 - Limit Reached - Intermittent
Mileage: 58642 km
Date: 2005.02.03
Time: 13:22:16
RPM: 1280 /min
RPM: 500 /min
(no units): 6.0
Torque: 106.0 Nm
Temperature: 62.0°C
T.B. Angle: 18.8°
Bin. Bits: 1010 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H03 0090
Coding: 0021338
18265 - Load Signal
Reset counter: 195
Mileage: 58659 km
Date: 2005.02.01
Time: 14:36:13
Hex Value: 0x0000
Hex Value: 0x6282
Hex Value: 0x0028
Hex Value: 0x01A4
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0160
Revision: 27100401 Serial number: 10600300154884
Coding: 0000003
Shop #: WSC 02323 785 00200
VCID: 63CFCBCEA2377A22A4-8036
Subsystem 1 - Part No: 4F0 910 131 A
Component: FBSAUDIC6 EZS H44 0070
Subsystem 2 - Part No: 4F0 910 220
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head Labels: Redir Fail!
Part No SW: 4F0 910 730 K HW: 4F0 035 729 D
Component: MMI Cockpit H35 0130
Revision: C51100DE Serial number: AUZ6Z3E47F13M1
VCID: 295399E6809BE072AE-807C
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000138932
Subsystem 3 - Serial number: 0111.04.050000000100010759ے
Subsystem 4 - Serial number: 010759ے
02259 - Information Display and Control Head (Front) (J685)
Reset counter: 195
Mileage: 58659 km
Date: 2005.02.01
Time: 14:36:32
Bin. Bits: 010
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 F
Component: KLIMABETAETIGUNGH04 0150
Revision: 00000025 Serial number: 00000000132436
Coding: 0008198
Shop #: WSC 02327 785 00200
VCID: 5BBFF32E9A4742E2EC-800E
Reset counter: 195
Mileage: 58659 km
Date: 2005.02.01
Time: 14:35:28
Part No SW: 4F0 910 279 B HW: 4F0 907 279 B
Component: ILM Fahrer H14 0080
Coding: 0000101
Shop #: WSC 02335 785 00200
VCID: 28559CE29B91D97AB1-807D
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: Redir Fail!
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 C HW: 4F0 959 655 B
Component: 32 AIRBAG AUDI8RH29 0230
Revision: 06H29000 Serial number: 0037LD06FRX$
Coding: 0013106
VCID: 27579FDE968FD602B8-8072
Subsystem 1 - Serial number: 6332CSME096C5E04B
Subsystem 2 - Serial number: 6342CSME094A44474
Subsystem 3 - Serial number: 6351HSME07075E5DI
Subsystem 4 - Serial number: 6361HSME07160414Y
Subsystem 5 - Serial number: 6371VSME067A5C43U
Subsystem 6 - Serial number: 6381VSME067A173AS
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksنulenmodul H07 0230
Revision: 00H07000 Serial number: 90026050920114
Coding: 0002021
VCID: 66C9D2DA51050F0A43-8033
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 900 M
Component: KOMBIINSTR. M73 H10 0630
Revision: 00900000 Serial number: 4R412UD45
Coding: 0258143
VCID: 1E39BA3AC9D517CACB-804B
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 12008054048132
Coding: 6CFE53C41B1104
Reset counter: 195
Mileage: 58659 km
Date: 2005.02.01
Time: 14:36:12
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 C HW: 4F0 959 793 C
Component: TSG FA H11 0040
Coding: 0000005
VCID: 2A5166EA859DEB6AA7-807F
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H15 0100
Revision: 01000015 Serial number: 01003398900000
Coding: 0263301
Shop #: WSC 00999 444 64523
10 Faults Found:
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 195
Mileage: 57504 km
Date: 2005.02.15
Time: 00:44:22
02739 - Bulb for Tail/Brake Light; Right
Fault Frequency: 209
Reset counter: 195
Mileage: 58654 km
Date: 2005.02.01
Time: 12:50:45
Reset counter: 195
Mileage: 15159 km
Date: 2005.02.01
Time: 12:17:51
02736 - Bulb for Tail/Fog Light; Left
Reset counter: 195
Mileage: 55349 km
Date: 2005.02.02
Time: 15:27:33
01501 - Bulb for Blinkers; Rear Left (M6)
Reset counter: 195
Mileage: 55458 km
Date: 2005.02.11
Time: 16:27:06
02738 - Bulb for Tail/Brake Light; Left
Reset counter: 195
Mileage: 55548 km
Date: 2005.02.04
Time: 06:43:54
Reset counter: 195
Mileage: 55549 km
Date: 2005.02.04
Time: 06:44:21
02740 - Bulb for Tail Light 2; Left
Reset counter: 195
Mileage: 55549 km
Date: 2005.02.04
Time: 06:50:15
01699 - Motor for Central Locking; Hatch/Trunk (V53)
014 - Defective
Fault Status: 01101110
Reset counter: 195
Mileage: 52562 km
Date: 2005.02.07
Time: 13:43:25
Reset counter: 194
Mileage: 52951 km
Date: 2005.02.17
Time: 12:07:57
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 B HW: 4F0 035 223
Component: Amp.-ASK H09 0270
Revision: 19S00001 Serial number: 00704050081200
Coding: 0000004
VCID: 1D3BBD36C4D30CD2D2-8048
Reset counter: 195
Mileage: 58659 km
Date: 2005.02.01
Time: 14:35:22
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000083326
Coding: 0001014
VCID: 5EB9FA3A895557CA8B-800B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
Component: TSG BF H11 0040
Coding: 0000522
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0004031
Shop #: WSC 02334 785 00200
VCID: 5DBBFD3684534CD292-8008
Address 56: Radio Labels: Redir Fail!
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000017866
Shop #: WSC 00000 384 00290
Subsystem 1 - Part No: 4F0 915 105 B
Component: von MLA 0504120881
Coding: 34463039313531303542204D4C4130353034313230383831
02254 - Interface to Generator
Reset counter: 195
Mileage: 58659 km
Date: 2005.02.01
Time: 14:36:05
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H11 0030
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H11 0030
Part No SW: 4E0 910 336 D HW: 4E0 862 335
Component: Handyvorb2 H11 0320
Revision: 00000000 Serial number: 00000007502822
Coding: 0020990
End-------------------------(Elapsed Time: 02:15)--------------------------
