ECM swap
james_flowers
C?ID=318004
Trying to find out how to get coding & perform an ECU swap on a 2013 PASSAT CC. The original ECU is toast. Also wondering if a used ECU is an option. Could really use some assistance.
iichel
Netherlands, eastern part
C?ID=284912
If it's the engine control module, you'll need to marry it with the cluster and the keys. Or defeat immo completely.
Guys like Jetta97 or Jack@EuropeanParts could help out with this.
james_flowers
C?ID=318004
Thanks, and yes I am talking about the engine control module.
Indeed I can help swap identity data, even from dead units with forensic tools I built here....
What part number?
Post a scan of what you can talk to ........
james_flowers
C?ID=318004
What part number?
06J 907 309 B
Monday,04,June,2018,15:00:24:13821
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
Dealer/Shop Name: FMK AUTOMOTIVE
VIN: WVWBN7AN2DE515894   License Plate: LE6642
Mileage: 186050km-115606mi   Repair Order: 00541
Chassis Type: AN-VW46 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55 56
          62 65 72
VIN: WVWBN7AN2DE515894   Mileage: 186050km-115606miles
04-Steering Angle -- Status: Sporadic communication error 1000
Address 01: Engine
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3505
   Revision: 05551213    Serial number: 00001205142762
   Shop #: WSC 05311 000 00000
   VCID: 25022FDCECD4FB6C74-8070
11 Faults Found:
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -
                    Fault Frequency: 176
                    Reset counter: 40
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:45
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU
                    Fault Frequency: 0
                    Reset counter: 40
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:46
01196 - Engine-Transmission Data Bus
                    Fault Frequency: 126
                    Reset counter: 40
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:46
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
                    Reset counter: 40
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:52
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                    Reset counter: 40
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:52
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Reset counter: 40
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
17204 - Message from selector lever; emergency operation
            P0820 - 000 -
                    Reset counter: 8
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:44:13
00511 - Selector Lever (E313)
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 0
                    Reset counter: 40
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:44:13
            014 - Defective
                    Fault Frequency: 0
                    Reset counter: 40
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:44:13
00653 - Selector Lever/Auto Trans Plausibility
                    Fault Frequency: 0
                    Reset counter: 40
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:44:15
28775 - No Communication with Gear Selector Module
            U0103 - 004 -
                    Reset counter: 0
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:44:18
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V484 0024
   Revision: --H07---    Serial number: 00000005807679
   Coding: 0004495
   VCID: 71AA0B8C689CE7CCD8-8024
6 Faults Found:
                    Fault Frequency: 165
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:47
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.00 V
                    Bin. Bits: 00011111
                    Count: 220
                    Hex Value: 0x0000
00532 - Supply Voltage B+
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:16
                    Hex Value: 0x0000
                    Voltage: 6.75 V
                    Bin. Bits: 00011111
                    Count: 115
                    Hex Value: 0x0000
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 218
                    Hex Value: 0x0000
01542 - Yaw Rate Sensor (G202)
                    Fault Frequency: 90
                    Reset counter: 132
                    Speed: 252.0 km/h
                    Hex Value: 0x0000
                    Voltage: 13.00 V
                    Bin. Bits: 00011111
                    Count: 236
                    Hex Value: 0x0000
            014 - Defective
                    Fault Frequency: 7
                    Reset counter: 132
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:43:57
                    Hex Value: 0x0000
                    Voltage: 9.50 V
                    Bin. Bits: 00011101
                    Count: 246
                    Hex Value: 0x0000
            014 - Defective
                    Reset counter: 132
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 01:43:57
                    Hex Value: 0x0000
                    Voltage: 9.50 V
                    Bin. Bits: 00011101
                    Count: 250
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
   Component: Climatronic   H03 0202
   Revision: 00001K01
   Coding: 0010001008
   Shop #: WSC 00015 115 00000
   VCID: 7CB42AB8F7DE9AA47B-8028
          U1111 00 [009] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 42
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 10:32:44
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 01:56:28
13635840 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:10:04
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 0008000000000000008802819400094C2055000840200D20E484402400C0
   Shop #: WSC 05311 000 08193
   VCID: 41CA9B4CD8BC374C68-8014
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 070512  010 0604
   Serial number: 070512
   Coding: 00B795
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0024
   Serial number: Y12M05D22h18m45s36S4
   Coding: 0280DD
9 Faults Found:
                    Fault Frequency: 98
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:09:07
                    Voltage: 8.00 V
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:53
                    Voltage: 12.85 V
                    Fault Frequency: 89
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:35:19
                    Voltage: 11.10 V
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:05
                    Voltage: 7.15 V
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:53
                    Voltage: 12.90 V
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:45
                    Voltage: 11.25 V
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
                    Voltage: 12.20 V
03266 - Control Circuit for Signal Horn
                    Fault Status: 00101001
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:49:57
                        Term 15 Off
                    Voltage: 11.70 V
03678 - Coordinator for Start-Stop Operation
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:47
                    Voltage: 11.30 V
   Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
   Component: J234__713 VW10 HI   2118
   Revision: 24017000    Serial number: 003LDPAE5KF/
   Coding: 0012595
   VCID: 4ED0B070D9E2D834E5-801A
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 000000000084R8
   Subsystem 3 - Serial number: 0025.04.120000300000630065ÿ†63
   Subsystem 4 - Serial number: 630065ÿ†6332MTS612791352 ÿ†63
   Subsystem 5 - Serial number: 91352 ÿ†6342MTS640881362 ÿ†63
   Subsystem 6 - Serial number: 81362 ÿ†6351HTS6H97S3BKJ ÿ†63
   Subsystem 7 - Serial number: S3BKJ ÿ†6361HTS6PNAQ3BKJ ÿ†63
   Subsystem 8 - Serial number: Q3BKJ ÿ†63727TS6HUH12BKJ ÿ†63
   Subsystem 9 - Serial number: 12BKJ ÿ†63827TS6D4T12BKJ ÿ
   Subsystem 10 - Serial number: 12BKJ ÿ
03551 - Functional Restriction of Seat Occupied Recognition
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 41
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:09:20
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
                    Fault Frequency: 12
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:09:19
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20120602300254
   Coding: 098A270000
   VCID: 6B9619E482B00D1CE2-803E
   Coding: E20000
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Fault Frequency: 10
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:05
114433 - Function Restricted due to Exessive Voltage
          U1401 00 [008] - -
                    Reset counter: 172
136194 - Supply voltage
                    Fault Frequency: 7
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:04
617736 - Selector Lever Park Position Lock Switch
          B1162 29 [008] - Signal Implausible
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.25
                    Time: 13:44:26
617742 - Selector Lever Park Position Lock Switch
          B1162 07 [008] - Mechanical Failure
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.06.04
                    Time: 22:19:38
   Part No SW: 3C8 920 971 B    HW: 3C8 920 971 B
   Coding: 240F00
   Shop #: WSC 05314 115 00000
   VCID: 2C14DAF8473ECA24AB-8078
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 10:32:44
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 00:12:51
          [Supply voltage too low]
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:04
   Part No SW: 7N0 907 530 AA    HW: 7N0 907 530 G
   Component: J533  Gateway H41 1632
   Revision:   H41       Serial number: 240512F1000974
   Coding: 469006
   Shop #: WSC 05314 000 00000
   VCID: 6FAE0DF4BEA8F13CCE-803A
6 Faults Found:
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:46
                    Fault Status: 00110100
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:53
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:53
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:15:41
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:06
   Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
   Component:    IMMO         042 0400
   Revision: 00042000    Serial number: VWZCZ000000000
   VCID: 373EF594467879FCD6-8062
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:33
   Revision: A1001003    Serial number: 7662551749
   Coding: 020000
   VCID: 291A23EC40CCDF0C50-807C
                    Fault Frequency: 10
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:09:04
                    Reset counter: 172
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H53 0319
   Serial number: VWZAZ2M4238493
   Coding: 0400040104000F000001100A
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 25022FDC24D4FB6C74-8070
1048578 - Supply voltage
          [supply voltage lower limit exceeded]
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:10:34
1048580 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [restriction due to undervoltage]
                    Fault Frequency: 17
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:22
1048634 - Antenna 2 for radio
          B111A 13 [008] - Open Circuit
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.06.04
                    Time: 06:55:39
1048663 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [CAN TO instrument cluster]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 01:56:28
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0551
   Revision: 12110009    Serial number: 0005069979
   Coding: 0004B7
   Shop #: WSC 05311 115 00000
   VCID: 6D9217FCBCA4032CFC-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002946209
   Coding: 010490
6 Faults Found:
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 10:32:44
68102 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Front CAN Kombi]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 01:56:28
65793 - Supply voltage
          [Front DCU undervoltage]
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:04
131329 - Rear Door Control Module
          B11ED F0 [008] - Supply Voltage too Low
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:05
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 132
                    Mileage: 186053 km
                    Date: 2018.06.04
                    Time: 00:01:05
132866 - Switch for Rear Central Locking
          B122E 29 [008] - Signal Implausible
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.25
                    Time: 13:48:16
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.302 1101
   Revision: 1AH03735    Serial number: 00121460462801
   Coding: 0000258
   VCID: 3D32E7BC644453AC0C-8068
9 Faults Found:
                    Fault Status: 11100100
                    Fault Frequency: 106
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:32:45
                    RPM: 1500 /min
                    (no units): 7.0
                    Voltage: 11.20 V
                    Fault Frequency: 43
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:08:37
                    Voltage: 0.80 V
                    Voltage: 10.30 V
                    Voltage: 4.40 V
                        Not Occup.
                        Not Occup.
            000 -  -  - Intermittent
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.17
                    Time: 12:17:28
                    Voltage: 4.60 V
                    Voltage: 9.30 V
                    Voltage: 9.30 V
                        Not Occup.
                        Not Occup.
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.17
                    Time: 12:17:60
                    Voltage: 2.30 V
                    Voltage: 8.00 V
                    Voltage: 8.00 V
                        Not Occup.
                        Not Occup.
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.17
                    Time: 12:17:60
                    Voltage: 4.00 V
                    Voltage: 7.90 V
                    Voltage: 8.00 V
                        Not Occup.
                        Not Occup.
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 00:12:52
                    RPM: 1500 /min
                    (no units): 7.0
                    Voltage: 12.80 V
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.19
                    Time: 01:56:29
                    RPM: 1500 /min
                    (no units): 7.0
                    Voltage: 12.10 V
01288 - Terminal 30; Steering Assist
                    Fault Status: 00101011
                    Fault Priority: 9
                    Reset counter: 172
                    (no units): 2.0
                    Voltage: 12.10 V
00003 - Control Module
                    Fault Status: 00101100
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 00:06:53
                        Term 15 Off
                    (no units): 11.0
                    Voltage: 12.70 V
   Component:    KSG PQ47 ELV 042 0634
   Coding: 1B910F8001862E521204141FF08A0F0E105801
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:05
                    Fault Status: 00100001
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2012.10.25
                    Time: 00:02:07
   Part No SW: 7N0 907 532     HW: 7N0 907 530 G
   Component: EZE_2         H41 1632
   Coding: 00000008
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0551
   Revision: 14110009    Serial number: 0005063854
   Coding: 0004B6
   VCID: 6E9010F0B1A2F834C5-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002943374
   Coding: 010490
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 172
          U1111 00 [008] - -
          [Front CAN Kombi]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 01:56:28
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:04
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 11:09:05
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2018.05.25
                    Time: 13:48:16
   Revision:   H19       Serial number: 00000000241767
   Coding: 0022156
   VCID: 3620F890417280F4CD-8062
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:10:05
                    Voltage: 7.00 V
                    Count: 48
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 00110010
                    Reset counter: 172
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 11:11:42
                    Voltage: 6.70 V
                    Count: 50
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Frequency: 164
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2012.10.14
                    Time: 10:18:45
                    Voltage: 9.60 V
                    Count: 71
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Component: AFS-ECU       H04 0111
   Coding: 071200010B000400
   VCID: 373EF5948E7879FCD6-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
6 Faults Found:
13893888 - Function Restricted due to Exessive Voltage
          U1401 00 [008] - -
          [Funktionseinschraenkung durch Ueberspannung]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.06.04
                    Time: 01:44:11
          U1400 00 [008] - -
          [Funktionseinschraenkung durch Unterspannung]
                    Reset counter: 172
                    Time: 00:00:00
13705474 - Databus
          [Timeout mLW_1]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 00:12:50
13705475 - Databus
          U1121 00 [137] - Missing Message
          [Timeout mMotor_1]
                    Reset counter: 132
                    Mileage: 186052 km
                    Date: 2018.05.24
                    Time: 10:32:44
13705477 - Databus
          [Timoout mKombi_3]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 01:56:28
13705483 - Databus
          [Timeout mLSM]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.05.29
                    Time: 00:12:51
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000128623
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 3522FF9C94748BECC4-8060
12652544 - Supply voltage
          [Versorgungsspannung unterer Grenzwert unterschritten]
                    Reset counter: 172
                    Mileage: 186053 km
                    Date: 2018.06.04
                    Time: 22:07:49
12656662 - Databus
          [CAN Signal Kl15 fehlende Botschaft]
12656664 - No Communication with Instrument Cluster
          U0155 00 [008] - -
          [Kombiinstrument keine CAN Kommunikation]
End----------(Elapsed Time: 01:46, VBatt start/end: 13.8V/14.0V)-----------
Yup got it.......
x
Vehicle Identification No.WVWBN7AN2DE515894
ModelPassat CC
CC
Date of production14.06.2012
Year2013
Sales type3584L6
Engine CodeCCTA
Transmission CodePBG
x
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0DJVehicle class differentiation -350-
drive-off assistanceUG1Hill hold control
Emission standard7GBEmission standard ULEV 2
Trailer hitch1D0without trailer towing
airbag4UBAirbag for NAR
Aktivkohlebehälter / Ottopartikelfilter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Tray areas packageQE0Without tray areas package/box
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XCExterior mirrors: power-adjustable
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8FSports equipment
Brake type in rear1KWDisc brakes in rear
batteriesJ0LBattery 340 A (70 Ah)
Brake type, front1ZGDisc brakes in front (Geomet D)
Beverage holders4M9Beverage holders
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0DAssembly kit, USA corresponding vehicle version (not California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H0Without "drive select"
Chrome packageQJ1Chrome package
General operating permit, alterationsC11Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAroof without cut out
Suspension system in rearUA4Rear shock absorption, base version
Suspension system in frontG60Shock absorption in front
Differential lock1Y0without differential lock
Load-through hatch/ski bag3X2Load-through hatch
Insert for the filling up of unleaded fuel/fuel type2G1Insert for the filling up of unleaded fuel
Installation differentiation for components0ESInstallation differentiation for transmission DQ250 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MNDecorative inserts
Scuff plates7M1Scuff plates in door apertures with metal inserts
Park distance control7X0Without park distance control
Electric interface for external useUF8Electric interface for external use
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Headlight activation8K9Daytime headlights with automatic headlight control and coming home function
Parking brakeUH1Parking brake
Vehicle tracing system7G0Without preparation for VTS (Vehicle Tracing System)
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Transmission types/gearshift mechanisms0G7tiptronic
Weight category rear axle0YBWeight range 2 installation control only, no requirement forecast
Weight category front axleL10Suspension range 10 installation control only, no requirement forecast
Base engineTQ24-cyl. petrol engine 2.0 l assembly 06J.B
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Transmission specificationsG1A6-speed automatic transmission
Cruise control system and speed limiter6Y2Speed limiter
Brackets3P0Without bracket for first aid kit and warning triangle
Molded headliner6NCMolded headliner
Rear seats3NJRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8IMGas discharge headlights with dynamic bending light
Customized installationFC1Customized installation
Interior light in footwell6T0Without interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
headphone connection, rear8MAno headphone connection in rear
Body styleK8CCoupe
Camera/distance sensorQK0Without camera without distance sensor (driver assistance system)
Luggage compartment floor covering6SEFlat needle-punched trunk floor covering
Cassette and CD storage unit4W0without cassette / CD tray
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y4Cold and tropical climatic zones (US)
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
Seat ventilation/massage seat4D0Without seat ventilation/massage seat
headrest for seat, rear3Q9Three rear head restraints
Head restraints5ZGHead restraints for front seats (NAR) (x-adjustment)
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems1A2Fuel system for SI engine with direct injection (FSI)
Body measures5C1Body measures for increased safety requirements
Camera systems/accident sensorsKA0without camera systems/environment sensors
Radiator grille6KJRadiator grille with chrome-plated strip
Rear license plate bracket6P0Without rear license plate carrier
Front license plate bracket6W3License plate bracket front (small, NAR)
Paint preservative/transit coating5K4Full body cover (shape-adapted system) with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Country codesFE0Without country code (no DVD player in vehicle)
Steering system arrangementL0LLeft-hand drive
Reading lamp8S72 reading lights in front
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Light control systems8G0Without Light Assist
Load edge protection2P1Plastic loading edge protection
Lumbar support7P1Power adjustable lumbar support in front seats
steering wheels2PPLeather-wrapped multi-function steering wheel
Driving on the left/on the rightAV2Driving on the right (NAR)
Speaker installation8RM8 speakers (passive)
Headlight range control8Q5Dynamic headlight range control, with cornering light (AFS 1)
Center armrest6E3Front center armrest
Multi-function display/trip computer9Q5Multi-function display with control
center console3I6center console
Driver alert systemEM0Without driver alert system
Engine cooling8Z6Hot country
Engine specificationsD2L4-cylinder SI engine 2.0 l/147 kW (16V) turbo FSI, homogeneous base engine: T59/T61/TQ2/TU2/TD6/TN6/TL5
Left vanity mirror4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Right vanity mirror4THVanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
Navigation device7T8Navigation system "RNS315" NAR
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WHFront fog lamp and cornering lamp
Upgrading measuresGP1Vehicles with special upgrade measures
Hubcaps1NLTrims for alloy wheels
WheelsCL4Alloy wheels 8J x 18
Radios8AYRadio navigation system
Smoker's/non-smoker's package9JFNon-smoking package (NAR)
Tire pressure monitoring system7K3Tire pressure monitoring system 433 MHz High
tireH04All-weather tires 235/40 R 18 95H (NAR) (polymer coating)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G1Space-saving spare wheel
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
W75CC 2.0T SPORT PLUS USA
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SSLabels in English and French
Tail lamp assemblies8SLTaillight assemblies with diodes (LED) (for NAR)
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Service indicatorQI7Service indicator ( 10000 miles )
Front seat, left3TFFront left comfort seat
Front seat, right3SFComfort seat, front right
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
seat coversN2QSeat trim covers in leatherette
Seat adjustment3L5Both front seats power-adjustable
seat heater4A3seat heating for front seats separat controlable
Side lights8F1Side-marker lamps
Start-stop system/regenerative braking7L3Without start/stop system without regenerative braking
Horns8Y1Two-tone horn
Control number (no PR family)SX8Model update, week 22
Audio-response system/voice controlQH0without voice control
Lane change assist/lane keeping system7Y0no lane change assistant
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B4Protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
power outlet7B312-volt socket(s)
Bumper2JCComfort bumpers
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Special approval measures3M0Without special measures
Nameplate set0PWNameplate set "CC"
Special alarm systems9A0Without taxi alarm system
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5Hz
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsBU1Legal requirements for USA 1 States without CARB requirement
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Transit coatingNT0Transit coating (type 1)
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
TV reception/digital radio receptionQU4Satellite radio reception NAR integrated in device
Assembly parts for engine (drive bearing)1VGAssembly part for 4-cyl. engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9ZSPreparation for UHV-internal telephone with voice control
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Second battery/battery installation8FAwithout 2nd battery
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZNBright decorative trims
Additional child seat anchors3B3Child seat anchors
Auxiliary heating system9M0Without auxiliary heater/parking heater
ClocksUP0Analog clock
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Best will be if you put used ECU in car and see if is going to connect to VCDS , maybe you have different problem .
And on your question for used ECU,
Yes it can be program but not with VCDS.
james_flowers
C?ID=318004
Used ECU Responds fine. Just need to correctly code and program unit and immobilizer.
James.......
I can do it ....just need your credentials to ID you and car ownership or if doing Immo defeat, data transfer, just cost is insured freight and a donation of your choosing for being a VCDS forum member to welcome you.
I don't need to see the old ecu talk either........
Send me old ecu and used one.
No dual identities permitted.
Best,
Jack
james_flowers
C?ID=318004
Thanks Jack. I need to know what you will charge as for this for a customer of mine, not for me personally.
Normally I get $350 + 50 USD standard freight to observe each controller I touch, plus apply that observation fee toward a service.
In this case my offer is 50 USD to cover freight + a donation you see fit.
This is my good deed offer for the day extended.
Do as you wish.......
https://europeanpartsemporium.com/contact/
Jetta 97
C?ID=81680
James.......
Best,
Jack
Jack, IF is MCU dead , no way to get info form it , like water damage or etc. I run few times in this problem.
This is 2013 model, should be UDS protocol , so Immo defeat is out of the question.
OP just an FYI:
The controller you submitted supplied by your customer or prior customers repair shop & to be used as replacement, is tampered & for a CBFA not a CCTA with different SMOG tier.
Marin
ECU is not UDS.
UDS and TP 2.0 or MED17 ECU's can indeed have the Immo removed.
Just because an ECU doesn't communicate with VCDS & via normal diagnostic methods, doesn't mean an MCU is dead.
I look forward to proving that & other ubiquitous inaccurate statements you have made in the past, indeed are wrong.
Very good!
[h=2]VINCheck® Results[/h]VIN: WVWBN7AN2DE515894
[h=3]VINCheck® Theft Record[/h]VIN: WVWBN7AN2DE515894 has not been identified as a vehicle listed in the VINCheck® Theft Records.
VINCheck® is updated regularly as additional information is reported.
[h=3]VINCheck® Total Loss Record[/h]VIN: WVWBN7AN2DE515894 has not been identified as a vehicle listed in the VINCheck® Salvage Records.
And than there is reality! :rolleyes:
Address 01: Engine
Control Module Part Number: 06J 906 027 FE
Component and/or Version: MED17.5.2 TFSI 2 06 5369
Software Coding: 0404010A1C070160
Work Shop Code: WSC 03738
Advanced Identification
Identification: BPG-810
Revision: P3H07---
Date: 27.08.12
Manufacturer number: 1586
Test stand number: 1324
Flash Status
Programming Attempts: 2
Successful Attempts: 2
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 452326 152 78387
Flash Date: 00.00.00
Software
A0101
M13E00
Misc.
Hardware number: 06J 907 309 A
Car Info
Chassis Number: WVWBN7AN2DE515894
Engine code: CCT
VCDS Info:
Labels: None
Readiness: No script available
Adaptation Channel 091:
Stored value 1
N/A
N/A
N/A
N/A
Jetta 97
C?ID=81680
Jack, read my post again ,
I said "IF MCU IS DEAD ",
I never said it is not possible to read data form ECU if can not communicate with VCDS.
Marin,
MCU is almost never dead, that is what a programmer & external after being de-soldered is for.
Plus you said Immo defeat can't be done again and indeed it can.
I spoke with James today & to verify that this is indeed solved and when he has time he will tell the story.
Immobilizer defeat Successful Marin!
NostraJackASS Has Spoken!
rhinopower
C?ID=58979
Well done Jack, love reading success stories like this, very talented
james_flowers
C?ID=318004
Ok, finally taking time out to finish this post. Jack is awesome! He was able to supply me with a functional control unit that had the immobilizer disabled. Best part is that it was all done legitimately, and by the book. Three months later, and everything is all well.
Thanks again Jack!
