Results 1 to 10 of 20
Thread: ECM swap
    Sep 2017
    ECM swap
    Trying to find out how to get coding & perform an ECU swap on a 2013 PASSAT CC. The original ECU is toast. Also wondering if a used ECU is an option. Could really use some assistance.
    Aug 2016
    Eindhoven, NB, NL
    If it's the engine control module, you'll need to marry it with the cluster and the keys. Or defeat immo completely.
    Guys like Jetta97 or Jack@EuropeanParts could help out with this.
    Sep 2017
    Thanks, and yes I am talking about the engine control module.
    Indeed I can help swap identity data, even from dead units with forensic tools I built here....
    What part number?
    Post a scan of what you can talk to ........
    Sep 2017
    What part number?
    06J 907 309 B
    Monday,04,June,2018,15:00:24:13821
    VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
    Dealer/Shop Name: FMK AUTOMOTIVE
    VIN: WVWBN7AN2DE515894   License Plate: LE6642
    Mileage: 186050km-115606mi   Repair Order: 00541
    Chassis Type: AN-VW46 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55 56
              62 65 72
    VIN: WVWBN7AN2DE515894   Mileage: 186050km-115606miles
    01-Engine -- Status: Cannot be reached 1100
    04-Steering Angle -- Status: Sporadic communication error 1000
    16-Steering wheel -- Status: Malfunction 1010
    2E-Media Player 3 -- Status: Malfunction 0010
    Address 01: Engine
       Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3505
       Revision: 05551213    Serial number: 00001205142762
       Shop #: WSC 05311 000 00000
       VCID: 25022FDCECD4FB6C74-8070
    11 Faults Found:
    28907 - No Communications with Cruise Control (Front) Distance Sensor
                U0235 - 000 -
                        Fault Frequency: 176
                        Reset counter: 40
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:32:45
    18258 - Powertrain Data Bus
                P1850 - 000 - Missing Message from ECU
                        Fault Frequency: 0
                        Reset counter: 40
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:32:46
    01196 - Engine-Transmission Data Bus
                        Fault Frequency: 126
                        Reset counter: 40
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:32:46
    18036 - Powertrain Data Bus
                P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
                        Reset counter: 40
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 00:12:52
    18275 - Powertrain Data Bus
                P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                        Reset counter: 40
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 00:12:52
    18270 - Powertrain Data Bus
                P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                        Reset counter: 40
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 01:56:29
    17204 - Message from selector lever; emergency operation
                P0820 - 000 -
                        Reset counter: 8
                        Mileage: 186053 km
                        Date: 2012.10.25
                        Time: 01:44:13
    00511 - Selector Lever (E313)
                014 - Defective
                        Fault Status: 01101110
                        Fault Frequency: 0
                        Reset counter: 40
                        Mileage: 186053 km
                        Date: 2012.10.25
                        Time: 01:44:13
                014 - Defective
                        Fault Frequency: 0
                        Reset counter: 40
                        Mileage: 186053 km
                        Date: 2012.10.25
                        Time: 01:44:13
    00653 - Selector Lever/Auto Trans Plausibility
                        Fault Frequency: 0
                        Reset counter: 40
                        Mileage: 186053 km
                        Date: 2012.10.25
                        Time: 01:44:15
    28775 - No Communication with Gear Selector Module
                U0103 - 004 -
                        Reset counter: 0
                        Mileage: 186053 km
                        Date: 2012.10.25
                        Time: 01:44:18
       Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
       Component: J104   C2 450M V484 0024
       Revision: --H07---    Serial number: 00000005807679
       Coding: 0004495
       VCID: 71AA0B8C689CE7CCD8-8024
                        Fault Frequency: 165
                        Reset counter: 132
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:32:47
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 11.00 V
                        Bin. Bits: 00011111
                        Count: 220
                        Hex Value: 0x0000
    00532 - Supply Voltage B+
                        Fault Frequency: 6
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:10:16
                        Hex Value: 0x0000
                        Voltage: 6.75 V
                        Bin. Bits: 00011111
                        Count: 115
                        Hex Value: 0x0000
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 01:56:29
                        Hex Value: 0x0000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 218
                        Hex Value: 0x0000
                008 - Implausible Signal
                        Fault Status: 01101000
                        Fault Frequency: 90
                        Reset counter: 132
                        Speed: 252.0 km/h
                        Hex Value: 0x0000
                        Voltage: 13.00 V
                        Bin. Bits: 00011111
                        Count: 236
                        Hex Value: 0x0000
                014 - Defective
                        Fault Frequency: 7
                        Reset counter: 132
                        Mileage: 186053 km
                        Date: 2012.10.25
                        Time: 01:43:57
                        Hex Value: 0x0000
                        Voltage: 9.50 V
                        Bin. Bits: 00011101
                        Count: 246
                        Hex Value: 0x0000
                014 - Defective
                        Fault Frequency: 6
                        Reset counter: 132
                        Mileage: 186053 km
                        Date: 2012.10.25
                        Time: 01:43:57
                        Hex Value: 0x0000
                        Voltage: 9.50 V
                        Bin. Bits: 00011101
                        Count: 250
                        Hex Value: 0x0000
       Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
       Component: Climatronic   H03 0202
       Revision: 00001K01
       Coding: 0010001008
       Shop #: WSC 00015 115 00000
       VCID: 7CB42AB8F7DE9AA47B-8028
    13701376 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Motorsteuergerät - kein Signal/Kommunikation]
                        Fault Frequency: 42
                        Reset counter: 132
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 10:32:44
    13701456 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.05.29
                        Time: 01:56:28
    13635840 - Supply voltage
              [Versorgungsspannung - unterer Grenzwert unterschritten]
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 11:10:04
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
       Component: BCM PQ47 H++  421 0465
       Revision: BD421001
       Coding: 0008000000000000008802819400094C2055000840200D20E484402400C0
       Shop #: WSC 05311 000 08193
       VCID: 41CA9B4CD8BC374C68-8014
       Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
       Component: WWS464 070512  010 0604
       Serial number: 070512
       Coding: 00B795
       Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
       Component: RLFS  021 0024
       Serial number: Y12M05D22h18m45s36S4
       Coding: 0280DD
    9 Faults Found:
                        Fault Frequency: 98
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:09:07
                            Term 15 On
                        Voltage: 8.00 V
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 00:12:53
                            Term 15 On
                        Voltage: 12.85 V
                        Fault Frequency: 89
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:35:19
                            Term 15 On
                        Voltage: 11.10 V
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:10:05
                            Term 15 On
                        Voltage: 7.15 V
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 00:12:53
                            Term 15 On
                        Voltage: 12.90 V
                        Reset counter: 132
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:32:45
                            Term 15 On
                        Voltage: 11.25 V
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 01:56:29
                            Term 15 On
                        Voltage: 12.20 V
    03266 - Control Circuit for Signal Horn
                        Fault Status: 00101001
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:49:57
                            Term 15 Off
                        Voltage: 11.70 V
    03678 - Coordinator for Start-Stop Operation
                        Reset counter: 132
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:32:47
                            Term 15 On
                        Voltage: 11.30 V
       Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
       Component: J234__713 VW10 HI   2118
       Revision: 24017000    Serial number: 003LDPAE5KF/
       Coding: 0012595
       VCID: 4ED0B070D9E2D834E5-801A
       Subsystem 1 - Part No: 3C8 959 339 A
       Component: BF-Gewichtsens. 003 0001
       Subsystem 2 - Serial number: 000000000084R8
       Subsystem 3 - Serial number: 0025.04.120000300000630065˙†63
       Subsystem 4 - Serial number: 630065˙†6332MTS612791352 ˙†63
       Subsystem 5 - Serial number: 91352 ˙†6342MTS640881362 ˙†63
       Subsystem 6 - Serial number: 81362 ˙†6351HTS6H97S3BKJ ˙†63
       Subsystem 7 - Serial number: S3BKJ ˙†6361HTS6PNAQ3BKJ ˙†63
       Subsystem 8 - Serial number: Q3BKJ ˙†63727TS6HUH12BKJ ˙†63
       Subsystem 9 - Serial number: 12BKJ ˙†63827TS6D4T12BKJ ˙
       Subsystem 10 - Serial number: 12BKJ ˙
    03551 - Functional Restriction of Seat Occupied Recognition
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Fault Frequency: 41
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:09:20
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 01:56:29
                        Fault Frequency: 12
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:09:19
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
       Revision: FF010041    Serial number: 20120602300254
       Coding: 098A270000
       VCID: 6B9619E482B00D1CE2-803E
       Component: E221__MFL-TK6  H07 0022
       Coding: E20000
    114178 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Fault Frequency: 10
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 11:09:05
    114433 - Function Restricted due to Exessive Voltage
              U1401 00 [008] - -
                        Reset counter: 172
    136194 - Supply voltage
                        Fault Frequency: 7
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 11:09:04
    617736 - Selector Lever Park Position Lock Switch
              B1162 29 [008] - Signal Implausible
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.25
                        Time: 13:44:26
    617742 - Selector Lever Park Position Lock Switch
              B1162 07 [008] - Mechanical Failure
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.06.04
                        Time: 22:19:38
       Part No SW: 3C8 920 971 B    HW: 3C8 920 971 B
       Component: KOMBI         H05 0705
       Coding: 240F00
       Shop #: WSC 05314 115 00000
       VCID: 2C14DAF8473ECA24AB-8078
    12648448 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Motor: keine Kommunikation]
                        Reset counter: 132
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 10:32:44
    12718592 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.05.29
                        Time: 00:12:51
              [Supply voltage too low]
                        Fault Frequency: 6
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 11:09:04
       Part No SW: 7N0 907 530 AA    HW: 7N0 907 530 G
       Component: J533  Gateway H41 1632
       Revision:   H41       Serial number: 240512F1000974
       Coding: 469006
       Shop #: WSC 05314 000 00000
       VCID: 6FAE0DF4BEA8F13CCE-803A
                        Reset counter: 132
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:32:46
                        Fault Status: 00110100
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 00:12:53
    00381 - Databus Instrument Cluster
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 01:56:29
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 00:12:53
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 00:15:41
                        Fault Frequency: 6
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:10:06
       Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
       Component:    IMMO         042 0400
       VCID: 373EF594467879FCD6-8062
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:10:33
       Revision: A1001003    Serial number: 7662551749
       Coding: 020000
       VCID: 291A23EC40CCDF0C50-807C
                        Fault Frequency: 10
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:09:04
                        Reset counter: 172
       Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
       Component: RNS315-NAR    H53 0319
       Serial number: VWZAZ2M4238493
       Coding: 0400040104000F000001100A
       ASAM Dataset: EV_RNS315NARV2UDS 001705
       ROD: EV_RNS315NARV2UDS.rod
       VCID: 25022FDC24D4FB6C74-8070
       Subsystem 1 - Part No: 3AA 919 866 B
       Component: NAR_V3_(0037)  0037
    1048578 - Supply voltage
              [supply voltage lower limit exceeded]
                        Fault Frequency: 6
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 11:10:34
    1048580 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [restriction due to undervoltage]
                        Fault Frequency: 17
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 11:09:22
    1048634 - Antenna 2 for radio
              B111A 13 [008] - Open Circuit
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.06.04
                        Time: 06:55:39
    1048663 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [CAN TO instrument cluster]
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.05.29
                        Time: 01:56:28
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0551
       Revision: 12110009    Serial number: 0005069979
       Coding: 0004B7
       Shop #: WSC 05311 115 00000
       VCID: 6D9217FCBCA4032CFC-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0501
       Serial number: 00000002946209
       Coding: 010490
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 132
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 10:32:44
    68102 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN Kombi]
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.05.29
                        Time: 01:56:28
    65793 - Supply voltage
              [Front DCU undervoltage]
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 11:09:04
    131329 - Rear Door Control Module
              B11ED F0 [008] - Supply Voltage too Low
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 11:09:05
              B11EE 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 132
                        Mileage: 186053 km
                        Date: 2018.06.04
                        Time: 00:01:05
    132866 - Switch for Rear Central Locking
              B122E 29 [008] - Signal Implausible
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.25
                        Time: 13:48:16
       Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.302 1101
       Revision: 1AH03735    Serial number: 00121460462801
       Coding: 0000258
       VCID: 3D32E7BC644453AC0C-8068
    9 Faults Found:
                        Fault Status: 11100100
                        Fault Frequency: 106
                        Reset counter: 132
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:32:45
                            Term 15 On
                        RPM: 1500 /min
                        (no units): 7.0
                        Voltage: 11.20 V
                        Fault Frequency: 43
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:08:37
                        Voltage: 0.80 V
                        Voltage: 10.30 V
                        Voltage: 4.40 V
                            Not Occup.
                            Not Occup.
                000 -  -  - Intermittent
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.17
                        Time: 12:17:28
                        Voltage: 4.60 V
                        Voltage: 9.30 V
                        Voltage: 9.30 V
                            Not Occup.
                            Not Occup.
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.17
                        Time: 12:17:60
                        Voltage: 2.30 V
                        Voltage: 8.00 V
                        Voltage: 8.00 V
                            Not Occup.
                            Not Occup.
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.17
                        Time: 12:17:60
                        Voltage: 4.00 V
                        Voltage: 7.90 V
                        Voltage: 8.00 V
                            Not Occup.
                            Not Occup.
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 00:12:52
                            Term 15 On
                        RPM: 1500 /min
                        (no units): 7.0
                        Voltage: 12.80 V
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.19
                        Time: 01:56:29
                            Term 15 On
                        RPM: 1500 /min
                        (no units): 7.0
                        Voltage: 12.10 V
    01288 - Terminal 30; Steering Assist
                        Fault Status: 00101011
                        Fault Priority: 9
                        Reset counter: 172
                            Term 15 On
                        (no units): 2.0
                        Voltage: 12.10 V
    00003 - Control Module
                        Fault Status: 00101100
                        Fault Frequency: 6
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.25
                        Time: 00:06:53
                            Term 15 Off
                        (no units): 11.0
                        Voltage: 12.70 V
       Component:    KSG PQ47 ELV 042 0634
       Coding: 1B910F8001862E521204141FF08A0F0E105801
                        Fault Frequency: 6
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:10:05
                        Fault Status: 00100001
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2012.10.25
                        Time: 00:02:07
       Part No SW: 7N0 907 532     HW: 7N0 907 530 G
       Component: EZE_2         H41 1632
       Coding: 00000008
       Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
       Component: Analoguhr  005 0003
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0551
       Revision: 14110009    Serial number: 0005063854
       Coding: 0004B6
       VCID: 6E9010F0B1A2F834C5-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0501
       Serial number: 00000002943374
       Coding: 010490
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 172
              U1111 00 [008] - -
              [Front CAN Kombi]
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.05.29
                        Time: 01:56:28
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 11:09:04
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 11:09:05
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2018.05.25
                        Time: 13:48:16
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000000241767
       Coding: 0022156
       VCID: 3620F890417280F4CD-8062
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:10:05
                        Voltage: 7.00 V
                        Count: 48
                        Hex Value: 0x1270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Fault Status: 00110010
                        Reset counter: 172
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 11:11:42
                        Voltage: 6.70 V
                        Count: 50
                        Hex Value: 0x1270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Fault Frequency: 164
                        Reset counter: 132
                        Mileage: 186052 km
                        Date: 2012.10.14
                        Time: 10:18:45
                        Voltage: 9.60 V
                        Count: 71
                        Hex Value: 0x1270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Coding: 071200010B000400
       VCID: 373EF5948E7879FCD6-8062
       Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H06 0007
       Coding: 350000
       Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H06 0007
       Coding: 350000
    13893888 - Function Restricted due to Exessive Voltage
              U1401 00 [008] - -
              [Funktionseinschraenkung durch Ueberspannung]
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.06.04
                        Time: 01:44:11
              U1400 00 [008] - -
              [Funktionseinschraenkung durch Unterspannung]
                        Reset counter: 172
                        Time: 00:00:00
    13705474 - Databus
              [Timeout mLW_1]
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.05.29
                        Time: 00:12:50
    13705475 - Databus
              U1121 00 [137] - Missing Message
              [Timeout mMotor_1]
                        Reset counter: 132
                        Mileage: 186052 km
                        Date: 2018.05.24
                        Time: 10:32:44
    13705477 - Databus
              [Timoout mKombi_3]
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.05.29
                        Time: 01:56:28
    13705483 - Databus
              [Timeout mLSM]
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.05.29
                        Time: 00:12:51
       Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
       Component: RDKBERU30     H09 0010
       Serial number: 10000000128623
       ASAM Dataset: EV_RDKBERU30 003012
       ROD: EV_RDKBERU30_003.rod
       VCID: 3522FF9C94748BECC4-8060
    12652544 - Supply voltage
              [Versorgungsspannung unterer Grenzwert unterschritten]
                        Reset counter: 172
                        Mileage: 186053 km
                        Date: 2018.06.04
                        Time: 22:07:49
    12656662 - Databus
              [CAN Signal Kl15 fehlende Botschaft]
    12656664 - No Communication with Instrument Cluster
              U0155 00 [008] - -
              [Kombiinstrument keine CAN Kommunikation]
    End----------(Elapsed Time: 01:46, VBatt start/end: 13.8V/14.0V)-----------
    Yup got it.......
    x
    Vehicle Identification No. WVWBN7AN2DE515894
    Model Passat CC
    CC
    Date of production 14.06.2012
    Year 2013
    Sales type 3584L6
    Engine Code CCTA
    Transmission Code PBG
    x
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PE Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0DJ Vehicle class differentiation -350-
    drive-off assistance UG1 Hill hold control
    Emission standard 7GB Emission standard ULEV 2
    Trailer hitch 1D0 without trailer towing
    airbag 4UB Airbag for NAR
    Aktivkohlebehälter / Ottopartikelfilter 1E4 Activated carbon canister (ORVR) and siphoning device for fueling
    Tray areas package QE0 Without tray areas package/box
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XC Exterior mirrors: power-adjustable
    Follow-on warranty EA0 Without subsequent warranty
    Left exterior mirror 5SH Left exterior mirror, flat (US)
    Right exterior mirror 5RR Right exterior mirror, convex (US)
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Equipment levels A8F Sports equipment
    Brake type in rear 1KW Disc brakes in rear
    batteries J0L Battery 340 A (70 Ah)
    Brake type, front 1ZG Disc brakes in front (Geomet D)
    Beverage holders 4M9 Beverage holders
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0D Assembly kit, USA corresponding vehicle version (not California), various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VM Information kit in American English
    Operating voltage 9Z0 Operating voltage 12 V
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H0 Without "drive select"
    Chrome package QJ1 Chrome package
    General operating permit, alterations C11 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FA roof without cut out
    Suspension system in rear UA4 Rear shock absorption, base version
    Suspension system in front G60 Shock absorption in front
    Differential lock 1Y0 without differential lock
    Load-through hatch/ski bag 3X2 Load-through hatch
    Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
    Installation differentiation for components 0ES Installation differentiation for transmission DQ250 -- vehicle components --
    Theft protection system 7AG Electronic immobilizer with anti-theft alarm system (for USA)
    Inserts 5MN Decorative inserts
    Scuff plates 7M1 Scuff plates in door apertures with metal inserts
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF8 Electric interface for external use
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Standard pedestrian protection measures
    Headlight activation 8K9 Daytime headlights with automatic headlight control and coming home function
    Parking brake UH1 Parking brake
    Vehicle tracing system 7G0 Without preparation for VTS (Vehicle Tracing System)
    Alternators 8GU Alternator 140 A
    Transmission types/gearshift mechanisms 0G7 tiptronic
    Weight category rear axle 0YB Weight range 2 installation control only, no requirement forecast
    Weight category front axle L10 Suspension range 10 installation control only, no requirement forecast
    Base engine TQ2 4-cyl. petrol engine 2.0 l assembly 06J.B
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Transmission specifications G1A 6-speed automatic transmission
    Cruise control system and speed limiter 6Y2 Speed limiter
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    Molded headliner 6NC Molded headliner
    Rear seats 3NJ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8IM Gas discharge headlights with dynamic bending light
    Customized installation FC1 Customized installation
    Interior light in footwell 6T0 Without interior light in footwell
    Instrument clusters U5C Instrument cluster, mph speedometer - USA -
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    headphone connection, rear 8MA no headphone connection in rear
    Body style K8C Coupe
    Camera/distance sensor QK0 Without camera without distance sensor (driver assistance system)
    Luggage compartment floor covering 6SE Flat needle-punched trunk floor covering
    Cassette and CD storage unit 4W0 without cassette / CD tray
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Climatic zones 0Y4 Cold and tropical climatic zones (US)
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    Seat ventilation/massage seat 4D0 Without seat ventilation/massage seat
    headrest for seat, rear 3Q9 Three rear head restraints
    Head restraints 5ZG Head restraints for front seats (NAR) (x-adjustment)
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 1A2 Fuel system for SI engine with direct injection (FSI)
    Body measures 5C1 Body measures for increased safety requirements
    Camera systems/accident sensors KA0 without camera systems/environment sensors
    Radiator grille 6KJ Radiator grille with chrome-plated strip
    Rear license plate bracket 6P0 Without rear license plate carrier
    Front license plate bracket 6W3 License plate bracket front (small, NAR)
    Paint preservative/transit coating 5K4 Full body cover (shape-adapted system) with additional transport protection measures
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Country codes FE0 Without country code (no DVD player in vehicle)
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S7 2 reading lights in front
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Light control systems 8G0 Without Light Assist
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P1 Power adjustable lumbar support in front seats
    steering wheels 2PP Leather-wrapped multi-function steering wheel
    Driving on the left/on the right AV2 Driving on the right (NAR)
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q5 Dynamic headlight range control, with cornering light (AFS 1)
    Center armrest 6E3 Front center armrest
    Multi-function display/trip computer 9Q5 Multi-function display with control
    center console 3I6 center console
    Driver alert system EM0 Without driver alert system
    Engine cooling 8Z6 Hot country
    Engine specifications D2L 4-cylinder SI engine 2.0 l/147 kW (16V) turbo FSI, homogeneous base engine: T59/T61/TQ2/TU2/TD6/TN6/TL5
    Left vanity mirror 4SH Left vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
    Right vanity mirror 4TH Vanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
    Navigation device 7T8 Navigation system "RNS315" NAR
    rear fog lamp 8TA witout rear fog lamp
    Front fog lamp/additional headlamp 8WH Front fog lamp and cornering lamp
    Upgrading measures GP1 Vehicles with special upgrade measures
    Hubcaps 1NL Trims for alloy wheels
    Wheels CL4 Alloy wheels 8J x 18
    Radios 8AY Radio navigation system
    Smoker's/non-smoker's package 9JF Non-smoking package (NAR)
    Tire pressure monitoring system 7K3 Tire pressure monitoring system 433 MHz High
    tire H04 All-weather tires 235/40 R 18 95H (NAR) (polymer coating)
    Spare wheel/breakdown kit 1G1 Space-saving spare wheel
    Restraint systems, front 4QQ 3-point seat belts in front with pretensioner and height adjustment, US label
    W75 CC 2.0T SPORT PLUS USA
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SL Taillight assemblies with diodes (LED) (for NAR)
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Service indicator QI7 Service indicator ( 10000 miles )
    Front seat, left 3TF Front left comfort seat
    Front seat, right 3SF Comfort seat, front right
    Seat belt check 9P7 Visual and acoustic seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZD 3-point seat belts, outer rear with US label
    seat covers N2Q Seat trim covers in leatherette
    Seat adjustment 3L5 Both front seats power-adjustable
    seat heater 4A3 seat heating for front seats separat controlable
    Side lights 8F1 Side-marker lamps
    Start-stop system/regenerative braking 7L3 Without start/stop system without regenerative braking
    Horns 8Y1 Two-tone horn
    Control number (no PR family) SX8 Model update, week 22
    Audio-response system/voice control QH0 without voice control
    Lane change assist/lane keeping system 7Y0 no lane change assistant
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B4 Protective side molding
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    power outlet 7B3 12-volt socket(s)
    Bumper 2JC Comfort bumpers
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Special approval measures 3M0 Without special measures
    Nameplate set 0PW Nameplate set "CC"
    Special alarm systems 9A0 Without taxi alarm system
    Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
    Door and lid locking system 4K0 Central locking w/ radio remote control and interior controls
    Type approval countries/countries with special requirements BU1 Legal requirements for USA 1 States without CARB requirement
    Carrier frequency for remote control 5D2 Carrier frequency 315 MHz
    Partition 3CA without partition
    Transit coating NT0 Transit coating (type 1)
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    TV reception/digital radio reception QU4 Satellite radio reception NAR integrated in device
    Assembly parts for engine (drive bearing) 1VG Assembly part for 4-cyl. engine
    Front underbody guard 1SA Without additional front underbody guard
    Identification plates 1EB without identification plate
    Delivery equipment 2A8 Delivery equipment, water border
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9ZS Preparation for UHV-internal telephone with voice control
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG0 without service interval extension
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Second battery/battery installation 8FA without 2nd battery
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZN Bright decorative trims
    Additional child seat anchors 3B3 Child seat anchors
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
    Clocks UP0 Analog clock
    Dallas (McKinney) ,TX ,USA
    Best will be if you put used ECU in car and see if is going to connect to VCDS , maybe you have different problem .
    And on your question for used ECU,
    Yes it can be program but not with VCDS.
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
  9. Likes Uwe liked this post
  10. #8
    Sep 2017
    Used ECU Responds fine. Just need to correctly code and program unit and immobilizer.
  11. #9
    James.......
    I can do it ....just need your credentials to ID you and car ownership or if doing Immo defeat, data transfer, just cost is insured freight and a donation of your choosing for being a VCDS forum member to welcome you.
    I don't need to see the old ecu talk either........
    Send me old ecu and used one.
    No dual identities permitted.
    Best,
    Jack
  12. #10
    Sep 2017
    Thanks Jack. I need to know what you will charge as for this for a customer of mine, not for me personally.
