I have a problem with steering assist after a collision. Power steering works, but the check light is on. Does anyone know how to fix it?
Thank you in advance and best regards
Wednesday,06,June,2018,10:25:47:08916
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
VIN: TMBEA6NHXH4525611 License Plate:
Mileage: 57608km-35795mi Repair Order:
Chassis Type: NH-SK25 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: TMBEA6NHXH4525611 Mileage: 57608km-35795miles
Address 01: Engine (J623-CJZC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 LH HW: 04E 907 309 AF
Component: R4 1.2l TFS H23 3855
Revision: R4H23---
Coding: 01110032230411080000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM12TFS01104E906027LH 001001
ROD: EV_ECM12TFS01104E906027BB.rod
VCID: 75B71CCFE5431BEF521-8020
CAN Converter 01:
U0428 00 [039] - -
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:39
Coolant temperature: 13 °C
Intake air temperature: 15 °C
Voltage terminal 30: 11.685 V
selected gear-Bits 0-7: 0
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 614 517 CA HW: 6R0 614 517 CD
Component: EBC 460 ESP H52 0002
Serial number: A01COWZ
Coding: 43F82876998000D8C229142B99230079160400C1
ASAM Dataset: EV_Brake1ESCEBC460PQ26L 003014
ROD: EV_Brake1ESCEBC460PQ26L_003.rod
VCID: 74B121CBEE3902E765F-8020
0360 - Steering angle sensor
0675 - Databus
U1122 00 [137] - Implausible Message
[MSG_LWI_LENKRADWINKEL_OOR]
Reset counter: 186
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:37
DTC: 00 02 A3
Address 08: Auto HVAC (J301) Labels:* Redir Fail!
Part No SW: 5JA 820 045 D HW: 5JA 820 045 D
Component: Man AC 015 0203
Revision: 21025015 Serial number: 00000000267571
Coding: 100000001100100000
ASAM Dataset: EV_AirCondiPrehSK251 005007
ROD: EV_AirCondiPrehSK251.rod
VCID: 372BD6C7BFCFA9FF80D-8062
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H10 0094
Serial number: 006308248575
Coding: 0C0008404215097B438040004007030800005800510A3500000000000000
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_VW26.rod
VCID: 313FE8DF51AB77CFCE9-8064
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6V1 959 801 B HW: 6V1 959 801 B
Component: FHSG DRV 007 0001
Serial number: 00000000000005072022
Coding: 011200
8202 - Bulb for Left DRL
B121D 15 [009] - Open or Short to Plus
Reset counter: 186
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:46
8458 - Bulb for Right DRL
B121E 15 [009] - Open or Short to Plus
Reset counter: 186
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:46
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 3K H10 0054
Revision: -------- Serial number: 39231631602391
Coding: 0001050001
ASAM Dataset: EV_EPHVA14AU3700000 002024
ROD: EV_EPHVA14AU3700000_SK25.rod
VCID: 3C21C9EB86E98AA76DF-8068
13637426 - Databus
Reset counter: 186
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:37
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 K HW: 6C0 959 655 K
Component: VW20Airbag821 002 0380
Revision: -------- Serial number: 003TJ008WG2N
Coding: 88CCC00000000000540000C8002800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3B23CAF783E78D9F645-806E
Subsystem 1 - Part No SW: ----------- HW: 442 152 910 16
Component: SideSensor_Df 1CA 0148
Serial number: 3497A009F21D62112256
Subsystem 2 - Part No SW: ----------- HW: 442 152 910 16
Component: SideSensor_Pf 1CA 0148
Serial number: 3507A00A3218242330FZ
Subsystem 3 - Part No SW: ----------- HW: 442 150 711 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00A5219E8B5242D
Subsystem 4 - Part No SW: ----------- HW: 442 150 711 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00BF21590A200EA
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:39
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:39
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI3
Part No SW: 5JA 920 740 A HW: 5JA 920 740 A
Component: KOMBI 202 2310
Coding: 07240C002180000801082A001000000000000000
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0094
Revision: -------- Serial number: 006308248575
Coding: 030100046F0A640000000000000000010001050000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_SK25.rod
VCID: 26150B83686520772BB-8072
Subsystem 1 - Part No SW: 6C0 915 181 B HW: 6C0 915 181 B
Component: J367-BDM H08 0270
Serial number: 63320K44495881883886
197169 - Controls in Steering Wheel
U108E 00 [009] - No Communications
[MFL (LIN#2) Timeout]
Reset counter: 186
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:38
Supply voltage: Terminal 30: 11.7 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AJ HW: 6C1 909 144 D
Component: EPS_TRW_ALow 313 3242
Serial number: CGBQ0886
Coding: 000300
Shop #: WSC 73430 790 54321
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 70B92DDB9A213EC7817-8024
1094656 - Steering angle sensor
Reset counter: 186
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:37
1073664 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
[DEM_LEFT_ENDSTOP_NOT_KNOWN]
Reset counter: 186
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:37
1073920 - Steering End Stops Not Learned
[DEM_RIGHT_ENDSTOP_NOT_KNOWN]
Reset counter: 186
Mileage: 57608 km
Date: 2018.06.04
Time: 21:01:37
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-ENT2.clb
Part No SW: 5JA 035 871 A HW: 5JA 035 871 A
Component: MU-E--ER 050 7080
Serial number: 02111600013522
Coding: 03533000BE0000005111000400000A002F0000C40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
VCID: 392FD0FF89DBBF8F769-806C
End----(Elapsed Time: 00:46, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
